Finalized the finishing work to the motor side of things. I plumbed and setup the intercooler cooling. As I had mentioned I had been running on essentially no intercooler, which was pretty impressive that I didnt have any detonating up top at 10psi. If anything it put a good about of strain on the motor which is good, Thats how I like to break in rings
I modified the stainless joiner pipes I had made so that they take account for most of the "U" turn on the radiator coolant hoses. Im happy with this decision as it makes for a cleaner engine bay as well as shorter hoses. That being said it appears as if I have one leak as well as the pump itself appears to leak a little. Im going to leave it for now and re-address it after 4 months when I pull the motor to clean things up and finish the metal work on the body firewall (I will address the oil leak at the front as well at that time and probably pull the pan and check the internals for premature wear).
I wired the water pump on the Audi's factory fuel pump wire (I have a dedicated 12ga wire for the fuel pumps), so it runs when the engine runs. However I have the small 4" fan wired up to my fan controller I bought for $12. I have the temp sensor taped to the intercooler and it works pretty well this way.
https://www.youtube.com/watch?v=tXcIDlWkGk0
If I needed to just have this work for say my radiator fans I would hook it up to a relay, but the amp draw on the 4" fan shouldnt necessitate that. Something for you homebrew guys to think about. This would work great for a dual fan setup running twin controllers at different temps. I currently have the fan setup for about 115degF turn on and it'll turn off at ~ 110. Its a small radiator and thus I imagine it could get hot, but on a quick test drive with a 1-2 pull I didnt even see the intercooler go up 5 degrees. It also pulled much stronger with the colder dense air.
I tried all weekend and late last week for my tuner to get to work on my tune but he is responding once and then ignoring me.. I might have to go to my back ups soon.
I also spent some time on the dash. I first worked on the "Mike Bellis Special" cardboard template but wanted a more solid foundation.. So I hacked up the stock dash base to fit.
The stock Audi dash cluster didnt have any provisions for bolting/mounting (apart from the front 2 flimsy ones) so I opened it up, clipped the noisy alarm charm, and put some bolts in the backside.
I'll grab some foam, tape, plastic, tin foil, and blades and start getting back to my "creative" side shortly. I hope to have the dash and center console completed by the time the competition is over. It would also be nice to have the rear firewall done but thats dreaming really tall....
