It appears as if I need to do an intro for the "Build Off Challenge" So here are the details
Andrew Dalen
Andyrew
Modesto, Ca
73 914 1.7 (Previously 5.7 SBC swap)
New engine: Audi 1.8 Turbo (Low boost: 275hp, Daily boost: 400hp, Race boost: 500+HP)
Exterior Color: Orange (Hugger Orange)
Interior color: Cinnamon Whisp/ Black Suede, Silver Paint
Wiring: Audi wiring 100%
Engine management: Modified OEM Audi ECU
ABS: Yes
Traction control and Stability control: Yes
Launch control: Yes
Cruise control: Yes
Climate control: Yes
OBD2 full control: Yes
Front and rear trunk: Yes!
Anticipated total budget required: $6500 less sold parts
The 5 large obstacles that I need to overcome are below.
1. Wiring layout/strip and integration into 914 wiring(Lights and wipers) A. Finish ID'ing every plug
B. Finish stripping wiring (Dash harness, body harness, and engine harness)
C. Finish removing 914 wiring as well as existing wire identification
D. Install Audi harnesses
- 1. Locate and test install engine harness in body.
- 2. Locate and install dash harness in body.
- 3. Locate and install body harness in body.
- 4. Install engine harness in body.
E. Run power lines to the battery
F. Install battery and check for any shorts
G. Wire up lights and wipers
(This was just one of three harnesses required)
2. ABS Module integration (replumb all brake lines, abs sensor and pickup integration, revised pedal box) A.
B.
C.
D.
E.
3. Audi engine/trans install A. Remove v8 and cut out all non essential brackets and shelving in the engine bay.
B. Mount the mock up engine/trans together and locate it in the engine bay.
C. Cut out sections of the trunk for clearance
D. Create motor and trans mounts and mount engine/trans
E. Mount turbo and route plumbing for intercooler
F. Mock up and measure cv joints for order
G. Mount new fuel pump and run lines
H. Rebuild engine and install forged rods
I. Locate water pump, water reservor and lines
J. Plum intercooler pump, reservor, lines and radiator
K. Plumb oil cooler lines and run turbo lines
L. Run transmission shifter cables to the cabin, bleed clutch
M. Fabricate exhaust system
N. Oil and water in engine, hood up electrical connections except spark plugs, crank engine for 2 minutes to generate oil pressure and check for leaks.
O. Check ECU for error codes and address as needed.
P. Finalize connections and fire engine.
Q. Figure out what went wrong, fix it, and actually start the engine
R.
4. Audi a/c and heater box mounted and plumbed in the front trunk, factory Audi climate control integration. A.
B.
C.
D.
E.
5. Full custom interior build from scratch (custom dash, doors,center,back,ect. Tablet install for radio/nav/onboard diagnostics) A.
B.
C.
D.
E.
(Note, this is draft one, I already have a new concept in mind for the interior that I have been drawing up)
You can see from the pics earlier in the thread that the bodywork is done and painted. Trunks will be painted in the build as well as probably a repaint of the engine bay. I also will redo the bumpers, but this may not make it into the build.
