Full Version: *Project 2.4* • Dion’s endeavor • Six conversion
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23
Dion
Picked up another Banjo trumpet horn for the passenger side.
Now my OCD can relax with it being balanced.
Dion
Made some brackets up and mounted to front panel for the Cibie Oscar+ .
Basically some Home Depot ties and welded some triangles underneath for more support and stability.
Dion
Cibie’s placed.
Dion
Was still a bit shakey at the top. I ordered some proper “Stay bars” and fabbed up simple brackets for them. Placed them in the seal trough of front trunk. Also some tar caulking around the brackets to divert any water away.
Dion
Fin! Wonder if I should paint the bars black. Any thoughts guys?
A hockey puck horn button might give you a bit more visibility around the spokes. If you want to borrow one to try out, let me know.
Dion
Thanks Mark! Great looking wheel, always liked that style.
Dion
Painted the rod portion of stay bar with “plasti-dip black”. I think
it looks better like this.
Nate W
Those lights are bad ass I like the black bars. Awesome build
peteinjp
Yeah- Love the Oscars! Looking great and well deserve results! Another way I have heard of de carbonizing an engine is to simply drip water in the intake while running. Haven't tried it but worth looking into if you never need to do it in the future. did you give another compression test after?
Pete
Dion
@peteinjp , Pete only did a leak down again shortly after the “treatment” and a bit of running about. Same results with other cylinders between 10-15%. #4 still sad. It was around 35%. Will do again at some point this summer , see if anything settled out with the rings or more crud burned off. So rebuild definitely in the future.
Cheers.
If it’s still drivable with that leak down, keep driving it. No reason to tear it down during the driving season.
porschetub
QUOTE(Dion @ Apr 12 2023, 02:23 AM) *
Cheers.
Hi mate,shit thats no good after all your work,have you taken it out for the classic "Italian
tune up "which maybe you have done? ,when you have done a carb tune up have you noticed poor vacuum on that cylinder ?.
Cheers.
Dion
Latest update to conversion.
Did Mark Henry’s Ford solenoid conversion.
Just a bit more peace of mind of having less juice go through the ignition switch.
Car is running well. Aside from too many pops on accelerator tip in.
Was discussing this with Dave. Might be a need for re jetting. Carbs were set up for Mike Fittons beautiful 2.7 six. Prolly a bit too much for my 2.4. Will investigate.
Solenoid pics:
Dion
Chillin at Toppin’s place this morning. “Smokey” looking good sporting new mini-lites. Sorry don’t have a better pic. Trust me the StoneGrau car looks awesome. smilie_pokal.gif Discussed LeMans, carburetors, etc. A great visit. So glad all his surgeries are done and dusted. He’s doing quite well.
BeatNavy
QUOTE(Dion @ Jul 31 2023, 02:52 PM) *
OrangeBones
TRS63
Antoine
DRPHIL914
QUOTE(Dion @ Jul 31 2023, 02:46 PM) *
Solenoid pics:
nicely done, i plan on doing this soon as well, just for that extra piece of mind, i have never had a non start on my current and original starter from the OEM motor, but i did with a new one, and tihnk the new solenoids are not good so i pulled the new one are returned it and put my orignal one back in and no issues, but it couldnt hurt right? supposed to help protect the ignition switch too. looks pretty simple .
oh and hi to dave good to hear he's doing well and hope to see him at Okteenerfest!!!!
tygaboy
Hey Dion - Great to see you out and about with your lovely car doing the most important thing: hanging with good buddies! aktion035.gif
Dion
Decided I’m going to do an engine rebuild this fall/winter. I was able to obtain, thanks to my eagle eyed buddy Toppin, a set of E cams. Well they are actually 2.7 cams.
They were for another fellas project, he went a different direction.
These were ground to E spec by WEB Cam. So let the parts accumulation begin!
Are these cars ever done?!
The 914MOB has volunteered to help….I hope. Should be a nice package when all done. beerchug.gif
OrangeBones
914MOB will be there. Can’t wait to get wrenching as it will give us an activity after Tennessee.
QUOTE(Dion @ Aug 10 2024, 08:12 PM) *
Dion
Ok. Finally have found some time to begin the process of the rebuild for the 2.4
Oil drained, ancillaries removed, engine out, transmission separated.
The 914Mob is stopping by Sunday to help me attach the engine to the stand. Thanks fellas!
porschetub
QUOTE(Dion @ Jan 30 2025, 04:12 AM) *
Hi buddy, looks like you are on the way on your voyage of discovery engine wise ? ,IMO don't think you will find anything serious and it must be great to have a helper too.
Go well my friend, look fwd to your progress as you move on ,cheers.
rgalla9146
Hey Dion
It's been too long buddy !
Looking forward to your latest.
Good luck with the engine.
An E is a sweet thing.
Rory
Dion
With some help from the “914Mob” , made tremendous progress on the tear down phase.
So #4 cylinder was toast. Rust pitting, etc. Obviously these engines are not really happy sitting for 6yrs. or longer. I can’t really complain. It ran strong for 2 yrs. Albeit smokey at times.
So decisions to be made now on moderate performance upgrades.
I do have the E cams which I was amped up on but might go yet on different path.
With the help of a local Porsche engine guru (Comes with Epsteins blessing :-) I’ve been schooled on the different cams, heads, p & c combos. Still milling ideas around.
Still sticking with the lovely sandcast aluminum case though!
Thanks you guys for hanging out and your help with some of the tear down.
Dion
Consultation
Dion
Sad #4
Dion
#4
Dion
Oh did I mention some chattering of teeth.
Dion
Heads to be shipped to machine shop. Case will get piston squirters and oil bypass mod in prep for oil pump upgrade. 4 rib version likely.
Dion
Case ready to ship.
Dion
Procured some Biral cylinders for the project. Will get these reconditioned.
Dion
This was a fun project the other day. Gear prolly on here since ‘67.
Plenty of heat. Stubborn as hell. Still have the other set to remove. mad.gif
Dion
First round cleaning of the cam carriers. Need to hit them with the scotch brite again and then another round in the ultrasound tank.
Spray bar inside had the end plugs tapped and pulled.
Dion
Was able to find some nice replacement gears for the IMS.
Olympic 914
Pretty serious project. Will you be doing the reassembly ?
Will be following this.
tygaboy
Hey Dion! Great progress. Can't wait to see it back together and on the road. aktion035.gif
Dion
Reconditioned barrels have returned.
Dion
Barrel
Dion
& JE pistons have arrived. Still awaiting for machine shop to complete the heads.
Dion
JE 85mm. Hoping to begin reassembly in late April.
campbellcj
tygaboy
Nothing more exciting than lovely, new engine parts... wub.gif Can't wait to hear it running!
Dion
Well it’s been a hot minute. Trying to get the 2.4 rebuilt along with dealing with my Dad who unfortunately suffered a stroke, fell and broke his humerus.
So firstly I want to thank my family and friends in helping keep my sanity through all this.
Hats off to the 914Mob, they know who they are!
A big thanks to @Mepstein who helped me procure parts and services.
The shop that is helping me allows me to make mistakes and teach me the rebuilding process. It’s an absolutely cool learning experience.
So here we are, a catch up on my build.
Lovely rebuilt heads:
Dion
Timing gears on IMS and polished chains.
Dion
Cranky
Dion
Double coated Bearings in place.
Dion
Rebuilt 4 rib pump
