Full Version: *Project 2.4* • Dion’s endeavor • Six conversion
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23
defianty
Having recently removed my motor mounts I can vouch for what a pig of a job it is. Well done!
Dion
Saturday’s project while listening and occasionally glancing at the 24hr at Daytona:
Addressed the hole in the floor that made me give my 914 the U-boat moniker.
It’s not pretty, no finish sanding or primer yet.
Just wanting to fill that split. It must have occurred due to an improperly
adjusted jack. That whole was filled with pure undercoating when I was removing it from the interior floor.
Dion
Interior/ exterior near jack donut.
Dion
Exterior repair
Dion
Some primer:
Dion
Closed the holes on the console piece that were under the extra steel plates.
Those plates are for strengthening the console.
I do enjoy the welding. Hopeful I will get more proficient the more I do. And there’s plenty to do!
Dion
Primer pic
Looking good Dion!
Dion
Attempted cleaning up the right engine mount area. Had a few holes to weld up
and a rather large one along the edge of the console. Some small holes were from the
spot welds holding the mount. Making progress.
Still need to reattach the brake line/hose bracket. Wanted to get some
primer on the bare metal. I’m getting flash rust showing up. It’s been raining and the
garage is a bit humid.
Dion
Top pic is primered.
Bottom pic just welded holes up.
Dion
Gap/hole on bottom of console edge/kick up.
Dion
Rough finish with primer.
Dion
Out of work early today to take advantage of good warm weather, tackled a small job.
I can finally tic that off the punch list.
Made a panel for the access panel in the firewall. Using a firewall provided by Garold
I cut a piece out oversized so it could lay on top of the contours of the existing firewall
in the car enabling me to use two sets of rubber weatherstripping.
One will surround the cut out and another will wrap around the larger cover.
So noise and any water (unlikely) will be stopped. As well as flames (ha, never know with carbs). I still need to weld the nuts to the engine side. Take care of that this weekend. Cheers all.
Dion
double post, sorry
Dion
Pic
Dion
Front engine access panel
tygaboy
Very nice!
Just a minor suggestion: you may want to round the corners of the opening in the firewall. That'll eliminate the likelihood of a crack developing in that area.
Keep up the great work and progress and you'll be on the road before you know it. driving.gif
Dion
Thanks Chris. Ok will round the edges. Thanks for the suggestion. Never thought of that happening.
Dion
Took Chris advice and rounded the corners slightly of hatch opening.
Welded the nuts on the panel. Primered the cover, wanted to do more but the temps are
dropping quickly so no further primer today. Come on spring!
tygaboy
Nice!
mb911
I need to do this as well.. Need to either find a panel like you did or weld a flange all around..
JmuRiz
Ben, a panel might be a good idea for your /6 conversion parts smile.gif
mb911
QUOTE(JmuRiz @ Feb 26 2018, 05:50 PM) *
Very true..
Dion
So for a change of pace and not having a lot of free time for sanding/painting I did a
a small project for a bit of fun. I modified the horn bracket to accept a banjo horn like
a few of the real GT ran. I was lucky to stumble upon this one for a
reasonable price (to me). The prices on these horns can be ridiculous. Found it on a Sweden based car parts site. Tested and functions as it supposed to. It certainly sounds different from the stock horn.
I need to modify the “flat” area on the chrome bumper where the rubber spacer meets the body. I will make a slot on the bumper bracket for the trumpet end to slide through. Shouldn’t be too bad to do. Wel’ll see :-)
Dion
And here it waits...... Placed the Webers on.
If anyone needs some Zeniths from a 911T ,I’ll be posting them soon on
here as well as Pelican.
Dion
Began digging into the front left fender.
Dion
Cleaning out the bad metal.
Dion
Next weekend I’ll make a patch and weld it up. Made sure I had clean metal to weld to
and no further perforations. Certainly going to be a challenging area to sort out.
bbrock
I'm going to be hitting that same spot on both sides of mine soon. I think I'll sit back and wait while you show me how it's done first. popcorn[1].gif
QUOTE(Dion @ Mar 25 2018, 08:30 PM) *
Pretty
Dion
QUOTE(bbrock @ Mar 25 2018, 05:14 PM) *
av-943.gif You are too kind sir!
bbrock
QUOTE(Dion @ Mar 25 2018, 07:59 PM) *
BTW, I have serious engine envy!
Dion
It will be extremely nice to wrap this project up and drive it out your way Brent.
To cruise about Big Sky country would be awesome. I only had a taste of it
exiting Yellowstone near Roosevelt’s Arch.
Be more than happy to let ya have a go!
bbrock
QUOTE(Dion @ Mar 25 2018, 08:29 PM) *
Deal! Our house is only 1 hour from Roosevelt Arch and you are welcome to stay in our guest room. A cruise over the Beartooth Hwy is a must!
tygaboy
Dion - Your engine wub.gif is BEAUTIFUL!
mb911
Dion,
Those are interesting cam covers what are they from?
Dion
Ben it’s a 1967 aluminum case.
QUOTE(Dion @ Mar 26 2018, 03:34 PM) *
I must have missed that. Those cases are very pricey these days.
Dion
Great, now I can be more nervous. Thanks Mark hehehe.
mb911
QUOTE(Dion @ Mar 26 2018, 11:49 AM) *
If thats the case you just hit the lottery.. I would really consider cashing out on thay engine and buy another..
Dion
Heheheh sweet. piratenanner.gif Didn’t know they’ve escalated. I’m trying to cash out with Mark right now on the Zeniths! Heheh. Fingers crossed Mark! popcorn[1].gif
mb911
Looks like 8-9k for a case..
Dion
Wow. Well I appreciate that news. I spent 7k originally for the engine,carbs & an oil tank! Thanks Ben. Now the paranoia can set in! Heheheh beer.gif
porschetub
QUOTE(Dion @ Mar 26 2018, 01:30 PM) *
Hi mate,love the engine tucked away in the corner crying 'bolt me in' hissyfit.gif I found having a built engine inspired to get on with the job,hope it works that way for you.
Wow that's a nice engine I notice an early cast iron dizzy too drooley.gif drooley.gif ,these work really well with carbs I have read.
Best of luck and keep knocking away @ that bloody rust smash.gif smash.gif sawzall-smiley.gif welder.gif welder.gif
porschetub
QUOTE(mb911 @ Mar 27 2018, 08:59 AM) *
I did see one of these cases listed for 15k a while back .
I think Dion bought this a while back.....just guessing lol-2.gif lol-2.gif .
Dion
Thanks Dean. Yes the clean motor does inspire, as
well as Dave’s completed beauty! I purchased the engine in 2015. I guess before all the 911 speculation took off.
Cheers mate!
Here’s 914Daves:
Dion
Happy Easter from the guy working on this project.
I worked on the front lower left fender today. What a treat this was.
Made some cardboard templates and then cut my shapes.
Bending the one piece was tricky as I don’t have the proper tools for this so
some pipe of different diameters and a vice helped me shape the curve.
Dion
Shapes
Dion
Placement
Dion
Curved outer piece mounted, welds ground & sanded.
