@NorCalScott Yes it is a tight fit in there, we worked with our friends Aasco in OC, Calif for the mating of Transaxle + engine. They came up with the billet 19mm thick adapter plate, which didn't cause much loss of space (towards rear of trunk). They also engineered the clutch pack and hydraulic T/O/B. There will still be some angle to the cv's, but we have sourced spec built joints + axles to deal with that.
Since we're on the subject. What's your opinion on axle angle? I've read places that these CV joints work perfectly well with angles of 15 degrees and maybe even more. If you look at sand rails, that appears to be true. Some say the angle encourages lubrication. If you could, would you run zero angle? Seems like the natural movement of the suspension would be enough to move the grease around in the CV joint. Also, I've read that it's not a good idea to run plunge CV joints on both the inner and outer locations. That it's better to have either the inner or outer CV a fixed/non-plunging CV to prevent the axle from floating inward and outward as it rotates.
