QUOTE(Maltese Falcon @ Jan 11 2026, 11:14 PM)
Few pics of prep for the installation of the poly carbonate door windows ...
Aluminum window frame was milled for side roll bar clearance , and another aluminum piece was tig welded on its backside for strength. Fuzzy channels still used but only grabs the new slider window "Depth". Blue lines show mill cutting area.
Click to view attachmentQUOTE(Maltese Falcon @ Jan 11 2026, 11:33 PM)
A bit of soapy water and guide + tap the vent window into position. New 914Rubber is being installed wherever we can utilize it on our build.
Click to view attachmentYou shame us all!
For those who have never painted a car's interior, inner door shells, or a roll cage, this paint work is the hardest, most time/material consuming painting of all.
Tubes are an absolute BITCH, especially if already installed!
His stuff looks color sanded, polished, and waxed!
INSIDE the freaking door shell!
I've done it once, nowhere near this level, and will AVOID doing it again if possible.
Marty, how did you do that?
Only way I could is MASSIVE prep, a tiny airbrush, or a big dip tank.
This is some of the best paint work I've seen on the forum!
Whole car is just "Ultimate 914"!
