Full Version: Porsche 914 - 8 GTT
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20
Maltese Falcon
Dusted off the roof and started in on the livery layout
Maltese Falcon
The 8gtt is spicing up the workshop ! More livery on the way from a cool shop in UK, referred to us by forum member Keith @KSCarrera; isaydingdong.co.uk
They have some really cool (ready made) period correct decals.
Maltese Falcon
Today while putting the oil tank into a proper alignment for the oil line paths, I needed to remove the v-band clamp which holds the top + bottom together. Found a small bit of unfinished aluminum slag hanging from the fill-tube strainer mad.gif
Cairo94507
NorCalScott
QUOTE(Maltese Falcon @ May 20 2024, 09:13 PM) *
wow, you might expect that from some cheap overseas product, but not from an upscale company based in SoCal. That's not cool. You shouldn't have to disassemble everything, but good thing you took this apart. Did you plan to have a filter between the tank and the pump, or did your pump just get very lucky?
Maltese Falcon
@NorCalScott I'll be revising my oil flow schematic this week; comparing the LBP (engine builders) to the Aviad (tank mfg.) drawings...but I do have a cnc aluminum oil filter stand for this purpose smile.gif
Maltese Falcon
@NorCalScott For the oil filter placement, I'm going with the LBP engine builder's tech handbook !
Just need to be careful during tank filling + topping up; keep small bits of debris from getting in.
NorCalScott
I have seen some people place a small billet inline filter between the tank's outlet and the pump to protect the pump's pressure stage. Seems like cheap insurance.
Maltese Falcon
Meanwhile> while inspection of the lower ½ of the oil tank...more alum slag, rough drilling and deburring required at the baffle plate / all 8) ½" dia holes. I used a short section of band-saw blade for lancing off the slag; and then hand sanded with emery cloth.
Maltese Falcon
'Catch of the day 3) nice size pieces of alum slag
Maltese Falcon
Baffle plate>>all 8) holes needed deburring Click to view attachment
Maltese Falcon
Baffle plate a BIG 3 minutes to clean up with a #220 fine sanding belt; you think Aviaid Oil Tank Co. could come up with QC checklist for their Made in USA product ¿¿ blink.gif
930cabman
Either made on a Monday or a Friday. Deburr is a straightforward operation, somebody dropped the ball. Maybe bead blast?
QUOTE(Maltese Falcon @ May 24 2024, 03:02 PM) *
Maltese Falcon
17) pieces of trim headed off for satin-black coatings. Not powder painting, but using a durable 2-step 3M automotive product.
Maltese Falcon
I've added the transaxle oil temp sender here, using the same 10mm x 1.5 port* which normally has a thermo switch that operates the valving for engine coolant to flow through a small heat exchanger on the trans. Our trans cooling system uses a seperate tank & radiator and not shared with engine coolant...and a manual on-off switch for the pump.
www.fittings.space in Sparks, NV, makes all sorts of 'Metric to SAE, AN, NPT adapters, which we used their *stainless steel part here/ in conjuction with a VDO ⅛" NPT sending unit.Click to view attachment
Maltese Falcon
GT2 trans thermo switch sending unit (on left) and 10mm Metric to ⅛" NPT SS adapter/ VDO oil temp sending unit on right.
Maltese Falcon
Roof livery is done; thank you George @dr914 @autoatlanta.com for the quick delivery !
Maltese Falcon
These were originally made for the rocker panels, cut down on length to replicate the Sonauto roof livery...this v8 just a bit spicy
Maltese Falcon
Topside done, now for some hardware on the flip side
Maltese Falcon
Last time this targa top had hardware installed on it, it was in a freind's backyard under a persimmon tree !
Maltese Falcon
Next up will be setting the Porsche script on the Sheridan rocker panels
Maltese Falcon
Getting back to engine accessories; setting up the coolant temp sender, coolant bleeder line (to fill tank); set up on a #4AN flexible line/ bracket (fab'ing up now).
NorCalScott
QUOTE(Maltese Falcon @ Jun 1 2024, 02:47 AM) *
Saving this resource. Little things like this can be so frustrating when you can't find the right adapter.
Maltese Falcon
Throwback to the iconic Porsche showroom Sonauto in Paris: It's all Stock trust me !
Maltese Falcon
Bracketed and ready to install on to the Cayenne engine coolant-crossover manifold
Maltese Falcon
Oil Tank supports / upper & lower brackets. Top bracket mounts to spec frame rail>>drill and tap
Maltese Falcon
Using .125" c/r steel for the fabricated brackets (gold color)
Maltese Falcon
These black-anodized (Aviaid Co.) tank brackets are supplied from mfg. for use on this 7½" dia. oil tank
Maltese Falcon
I think that with the adding of 2) Garretts, wastegates, intercooler and b/o/v are all packed into the 'Trunk area, No more luggage room avail. Maybe just strap these to the cold side of intercooler biggrin.gif
Maltese Falcon
Good day today & tidied up runs of wire that have been pulled through into the trunk area. I use 'Goodridge fire sleeve which I've been sourcing at www.pegasusautoracing.com
Also purchased all sorts of racing hardware, Tilton pedal assembly, brake bias control, etc. from them; excellent product knowledge/ customer service thumb3d.gif
Maltese Falcon
Looks like they are fire-sleeving the turbo oil supply (#4AN) lines, and #12AN (oil drain scavenge) lines which seem to be in a super hot zone !
Maltese Falcon
Driver side shorty header securly snuggled down.
KELTY360
QUOTE(Maltese Falcon @ Jun 21 2024, 04:20 PM) *
That’ll make some sweet noise.
Maltese Falcon
@KELTY360 Marc, the 8gtt sounds should be an earful...even for a non-flat plane crank Cayenne v8 ! The basic tech in my shorty shorty header design, is how the placement of the tubes enter into the collector; left and right side headers respectively.
Following the Cayenne v8 firing order: 1-3-7-2-6-5-4-8
I place the tubes in a (rotational) position, so during the normal scavenging taking place = the exhaust pulses fire into the collector in a rotational fashion.
This gives an extra performance benefit during evacuation of the exhaust pulses. Can't hurt getting the pulses to scaveng even quicker, right?
Cairo94507
Maltese Falcon
Passenger side exhaust header with EGT, and o2 port ready for install.
Maltese Falcon
I'm having a few sets of these 18ga. SS plates laser cut for use with these cool 914 headlights, which install into the previous front turn signal locations.
Since we are using Sheridan fiberglass body panels, when you slice the (faux) turn signal 'Pods from the top of the fenders you are left with a ¹/16" perimeter edge...which is not real sturdy to attach these light fixtures on.
The thin plates will be epoxied into place, then these new light assemblies* will have a sturdy foundation to sit on. Then I will add another support bracket inside the fender, in order to catch the stud/nut on the assembly.
Mfg. by* www.3DGAUTO.com
Maltese Falcon
Back side of the new headlight assembly, high and low beam are in this set up. Fully adjustable, simple instructions, and looks like the wire cables are plug + play for converting a stock 914 .
NorCalScott
very cool headlights
Shivers
A bit of of my range but these combo blinker/ headlight housing would be great as an auxiliary driving light. smile.gif
https://3dgauto.com/products/custom-classic...for-porsche-914
technicalninja
QUOTE(Maltese Falcon @ Jun 25 2024, 06:35 PM) *
@Shivers
He already has them...
Shivers
QUOTE(technicalninja @ Jun 26 2024, 10:46 AM) *
@Shivers
Yeah thanks I saw that, that's where I got the address. When he mentioned "these cool 914 headlights" I thought that would be neat but what would I do for a blinker? Then I saw the website. I'd love to have these
Maltese Falcon
May or may not use the front blinker, don't need 'em on the track; but very handy for short romps around the block, or short drive to the Petersen Museum for C+C smile.gif
technicalninja
QUOTE(Maltese Falcon @ Jun 26 2024, 03:07 PM) *
A 2/1 P/W ratio car on the street...
A "short romp around the block" will make all the animals in a 1/4-mile radius crazy!
What I WANT to know is how you are creating the 7k lbs. of down force that you're gonna need to hook up!
Maltese Falcon
@technicalninja >> this is the APR Performance rear c/f wing that we chose for the job. Our own water-jet formed t6 .375" aluminum supports will capture the 1600 psi downforce (rated at 160mph) and send it downwards directly through the transaxle mounting frame. Front canards, and a totally sealed undercar tray with diffuser out back. The wing alone will never reach 7k psi of downforce, and I may never experience w/o/t in 6th gear on a long track; might let Patrick Long enjoy some seat time biggrin.gif
Maltese Falcon
Some APR specs...
Maltese Falcon
Few more pics
technicalninja
"No stall at 52 degrees" is HARD to believe!
BAD ASSED if it can do that...
I was joking, playing with you!
I DON"T believe you will EVER be able to apply WOT at ANY speed.
Unless,
You've created artificial gravity!
And, if you've accomplished that you're setting your sights too low...
Corky once built a twin turbo Cobra with a 351 as the base. The yellow car (my dad painted it).
He couldn't ever get it up to full boost.
By the time he had enough traction to hold WOT he was 160 MPH and running out of runway down at Kestral...
He was nearing 800 hp.
You're hunting 1100 in a lighter car!
I haven't had time to run through your whole thread, life has been busy/crappy.
What I've seen so far is the Ultimate 914 with master level workmanship. Everything is just exquisite!
COMPLETELY BAD ASSED!
Maltese Falcon
@technicalninja Yessir Corky Bell ran a tight shop, and you were definitely in good Mentorship working for him. In the late '70s I think that we both had our business contacts printed in the back pages of Hugh MacInnes 'Turbochargers book smile.gif Corky supplied us with various components when we were in the turbo kit era welder.gif
