Re-reading my thread from the start I made it to about page-17 when I came to a realization. I suppose I came to a point that everyman arrives to at some-time... "Wow.... I
really didn't know what the hell I was doing..."
Anyway, moving on from that I've been plugging along as the car was getting prepped and focused on bleeding the brakes, setting the e-brake cables and setting the proper venting-clearance on the rotors.
For venting the rotors, check out this thread that I started >
Thread HereAs for bleeding the brakes, something that was left unclear to me from various threads - bleeding the Master Cyl. (MC). If you have a new MC, or a substantially new or refurbished brake-system make sure to bleed your MC. This was unclear to me before, and when I changed from 21mm to 19mm it gave me a few problems when bleeding my brakes.
@iankarr has a great video on this, and it's pretty straight-forward >
Video Link HereAs for bleeding the brakes, I also referenced another video from
@iankarr (
Video link here ) because I purchased the same power-bleeder. I won't go into a whole explanation, because the video is pretty clear, though I will leave some notes that I found useful. I'm sure that I made ALL the mistakes and had the worst-luck while doing this, so check out my list below...
- If you're unfamiliar with this watch Ians video a few times. Good? Now watch it again.
- Before you start, have extra towels and water ready. Have MORE than enough, and stage them around your car. This will be handy if you spill.
Most important: Make sure your brake-fluid reservoir is solid with no leaks or cracks and same for your lines and such. I had just started bleeding the system the first-time, only to find a 'crack' in the reservoir just above the plated retaining strap. Very annoying to stop what you're doing, get a turkey-baster/syringe, drain the system, install a new reservoir, and start all over.
Further, it becomes very messy and stressful, especially with all that brake-fluid around.
- Check. Your. Reservoir. Lines!. This relates to the above point. I found that, in addition to the crack I had lines that were completely deteriorated. Suggest that everyone buy new rubber brake hose to connect the reservoir to the lines and new hose-clamps. (
Link to brake-lines here)
- My system had already been bled before with blue brake-fluid. As it still had fluid in the system I found this helpful because when the new, clear, fluid came through I could visually tell that the system had been 'flushed'.
- If you're bleeding your brakes after a restoration or major swap (new calipers / MC), make sure to first bleed the MC, then add more fluid before bleeding your brakes. I made a similar mistake, and when bleeding the brakes let the reservoir run dry and had to start over.
- Some call it an urban myth, but I found it helpful to tap the brakes and brake-lines while bleeding. I think the vibrations help get out any 'stuck' air-pockets.
- I brought the pressure on the power-bleeder up to 7.5 PSI, and had no problem.
- My car has early 'S' brakes. If you have the same or similar 'big brakes' you need to bleed both-sides of the caliper. Order is still the same as bleeding 'stock' brakes, though with a minor adjustment; Right-rear caliper, Left-rear caliper, Right-front inner caliper, Right-front outer caliper, Left-front inner caliper, Left-front outer caliper.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
