QUOTE(RiqueMar @ Aug 25 2019, 09:34 PM)
QUOTE(ClayPerrine @ Aug 25 2019, 07:03 PM)
Looks like you are doing a bunch of stuff that I have already tackled on my conversion. I did the steering column and ignition switch years ago, and I am just finishing up a 964 based 4.0L install. I deleted the DME relay, and went with solid state bosch square relays.
Also, I noticed you have the /4 headlight relay installed. You won't need it with the /6 column.
Let me know if I can help.
Clay
Clay, thanks for the post! Please do-tell, and leave your response here should anyone in the future need any insight. We did find a few ‘funky’ things happening now that we are trying to include the 914/6 steering column, and you have me thinking about that relay.
Also, very excited to hear your thoughts on deleting the DME relay, my conversion is 964 based too.
Thanks in advance, eager to hear from you.
EDIT: Briefly looked over your project thread, really like what you did with the coils below the battery. Again, eager to hear your thoughts on the above!The coils are mounted to a factory 914-6 CD box bracket. Makes for a place close to the distributor. I also put the FI grounds on the same post as the negative battery cable, and added a second ground cable to the engine at the right front corner. I wanted to insure a good ground.
I extended the DME harness so I could put the ECU on the front passenger wall. I cut out the foam block (fyi.. it is actually compressed and shellacked sawdust) to fit around it. I had to add a diagnostic plug, so I got a OBD2 plug kit off evilbay, and wired it according to the adapter diagram.
FYI.. 914-6 wiper switch has what looks like a plug for a relay on it. The other end attaches directly to the 914-6 wiper motor. The switch doesn't connect anywhere else, and the only wiring to the 914-6 motor is a single power wire.
If you are going to run anything other than LED bulbs in your headlights, you need to add a headlight relay kit to your wiring. The switch in the column takes the full load of the headlights, so the contacts burn out with any load more than a sealed beam or LED light. I don't want to sound like a shill, but this kit works good:
http://www.allzim.com/store/zim-s-12v-brig...-relay-kit.html You will have to modify it slightly for a 914.
Let me know if you have any questions.
Clay
