Note for anyone following along, and conducting a similar swap:
Not sure of the specifics between years, but there are some differences between a late harness and an early harness. Also, some notes to keep in mind if you're replacing / refurbishing your harness.
- Running the harness: The locations of the 'tabs' or clips located behind the pedals are about 2-3 inches higher on later cars than early cars. This makes the length of the harness slightly different, but most affects how the harness is loomed. You have to get creative, and be patient, around the point where the grounds are, next to the fuse board. As the harness flows differently, this area gets very tight (Trunk release, speaker pods, etc).
If refurbishing, tape your harness, but do not use so much tape as to make it inflexible. I made this mistake, and it took a bit of 'massaging' to get everything to sit right.Click to view attachmentClick to view attachment- Grommet sizes: Some small diameter differences between early and late. Picture below, a late grommet (large) vs an early. Not necessarily a big problem, however the hole to pass the grommet through is closer to the fuse-board on the early cars, whereas on the later cars, it's closer to the gas tank. I suppose you could use an early grommet on a later car, but this just won't work with a later grommet on an early car.
Click to view attachmentClick to view attachment- Running the harness through the firewall: Big item...
Tape your leads! Tape your leads! Tape your leads! It is very easy to get 'caught up' and snagged. Even though I taped my harness to maintain all the lengths, this happened to me, and I should have used more. I got frustrated, and starting pulling and pushing harder, and almost ruined a lot of the work I had done when organizing the harness before extracting it from the previous car. Furthermore, using lube makes it even easier for the leads and branches to 'slip out'. This oversight nearly ruined the whole conversion, and ended up costing me 1-2 hours after everything was in getting the lengths right.
Additionally, take plenty of pictures, from multiple angles, before starting anything tricky. In this example, I had to do that with the pinned connector that goes in the engine bay. It needed to be removed, disassembled, and reassembled.
Click to view attachmentClick to view attachment- Repairs: Once in, use this opportunity to fix any questionable or broken wires and connections.
Click to view attachment- Patience: You're going to experience some compromising and uncomfortable situations during this little exercise. Give yourself plenty of checkpoints to take a break. In some cases, walk away if you are getting frustrated, and start on another section.
All-in-all, installing this harness took me about 9-12 hours, not including prep, cleaning, research and planning.
