Thanks guys! I'm glad we caught them too, and all that stuff is over with.
As for the car, I literally have a month before Rennsport, so it's full speed ahead whenever I'm not at work, which is basically from 3pm until 9pm, and even then I'm still 'available'
I've been working on the hard oil line for the engine. Originally, I was simply going to get a converter for the oil inlet on the bottom of the engine and run the stock /6 oil line, however, I'm concerned about oil volume, as my engine is a 2.9 where-as the stock /6 was 2.0.
After trying to find a few alternatives, and effectively getting 'blown off' by the guys at Patrick Motorsports, even after I bluntly told them, "Look, what do you recommend? Tell me, and I'll buy it....' I decided to-hell-with-it and I'm making my own.
So here we go....
My main issues regarding the hard oil lines are:
-Volume
-Adaptors
-Space limitations (due to me using stock HE's)
-Alignment (clutch cables, shift rods, etc).
At first, I thought I would simply use braided lines with a 90 or 45 degree connector, as I've seen this done, but that runs me right into the HE's and is really loose. At that point, I realized that many of the photos where I have seen this done, the author of the conversion was running headers, which give you significant more space.
The next approach was using an oil line off a 3.2 engine, as it is the correct fitting to go into the bottom of the engine, and follows a very similar routing to the stock /6. However, this again had issues, as I would have to 'ding in' the HE sheet metal about 1/2' on the left side (acceptable and still maintaining stock look) but more importantly, the tube ran right in front of the shift rod outlet, which killed that plan all-togther.
Just before I was about to say 'screw it' and go with headers, I resolved to try a hybrid idea by cutting the bigger oil line shorter just below the chain tensioners, welding a fitting onto the end (an adaptor for braided lines) and running the braided line to a thermostat mounted on the body on the passenger side, in preparation for when I eventually put in an oil cooler. For the time being, the thermostat ( which will be located where the Fuel Pump is currently, see pictures) will have one line going into it from the oil tank, then a 'U-turn' on the other side, to redirect to the exit, where it will go into the engine.
I'm not completely finished, as I have to weld on the fitting today, however, I've cut the tube, rolled in the HE sheet metal, and mocked everything up. OFr good measure, I sandblasted and rinsed out the oil line and had it sitting overnight in the part cleaner to get rid of any metal scraps, gunk, or sand.
