I was very hesitant about putting on the Large Main Seal, as I understood it is a pain in the ass. I'm happy to say that after a brief search on here, and finding this thread: http://www.914world.com/bbs2/index.php?showtopic=337114 and this video by 914rubber https://www.youtube.com/watch?v=ui-GSfUS7ak its very easy. Seriously, the whole process only took me about 1hr 30 min, including setup, install, and probably a few distractions along the way.
Before I go over the process, a few items...
- The first assumption people make regarding this seal install is that it slides in from the top. I don't know why I thought this at first, it's gotta be close to impossible especially with a new / reproduction seal. Instead of sliding the seal in from the top, you'll place it in with one side (interior), then work in the outer (exterior facing) side.
- Use standard hand soap as a lubricant, as directed in the video. Its both slippery enough, and not so much that you lose control of the part that you're trying to handle.
- For the tool to pry and work in the seal, I used a standard size flat-head screwdriver. For those of us, like me, that have blacked out the chrome on the trim, I didn't want to lose control and knock the trim.
- The hardest part is the beginning, placing the seal to insert the screw and the 'curve' at the top of the windshield structure.
I first placed the seal as it's directed in the video. I did find that, as Matt directed, you will have to clip or trim the bracket that attaches to the windshield. Big shears did it for me, and it was almost 'level' with the body piece.
On this next step, I found it easier to divert a bit from the video instructions; Once you're able to correctly place the piece and the set-screw, I left the set screw off for the time being, and didn't place it until both sides were done. Starting with the Drivers side, I lined up the seal and placed the side that is closest to the interior of the car in the 'slot'. From there, I used the flathead screwdriver and 'worked in' the outer side. Each time I pushed in with the tool, about 1/2 an inch would slowly work itself into the channel. As I said before, the top is the hardest. Once you get a rhythm going, its pretty easy. You do not have to necessarily alternate between front and back, as the back slides in about 4-6 inches at a time.
With the Drivers side complete (it should be a bit long, recommend letting it rest before trimming), I repeated the process on the passenger side. Same thing, place the rubber, omit the set screw for now, and start working it in. Same on this side, it will be a bit long, wait to trim it. With the seal in and secure on both sides, I used my rubber mallet to very lightly tap in the piece that runs along the length of the windshield connecting the two sides. This pieces is very easy to get on, and at some points, I didn't use the hammer and just tapped it in with the palm of my hand. Its at this point, I put in the set screws on either side.
With all that complete, the final trick is to install the 'Lower Targa Mainseal', which is a joke compared to the process of the Main seal. Simply place it int he correct orientation and begin pushing it in. Once it's all the way in, spanning the length of the windshield, you can push or pull it to center it as you like. NOTE: Looking through the site, reference photos and diagrams, it was confusing to me which side was top, bottom, in, and out, so I included a photo. After thats in, start putting in your interior!
