Aaron Cox
Apr 12 2012, 08:33 AM
looking good!
what did you grind the fender welding down with? flapper wheel? what grit?
(i'll be embarking on this task shortly...)
effutuo101
Apr 12 2012, 08:34 AM
Beautiful work. Looking forward to paint!
Socalandy
Apr 12 2012, 09:11 AM
QUOTE(Aaron Cox @ Apr 12 2012, 07:33 AM)
looking good!
Thanks Guy's
Disk to flapper wheel 36 grit. No matter how smooth it is you'll still need a thin coat of filler to blend it perfect
jmill
Apr 12 2012, 03:34 PM
Amazing work!!!
Socalandy
Apr 18 2012, 09:31 PM
the body work on the flares is done and it's time to build the rotiss. and get the pans replaced.
Engine stands are sweet so its time for some metal and bottle jacks. Also I had to see one side of the car with it's shoes. Pinch me
Socalandy
Apr 18 2012, 09:38 PM
I Cant wait for paint. I'm thinking 2 stage like I did on my 72, Anyone have a picture of canary yellow GT side profile? I'd like to photoshop my wheels on it to get a rendering
Socalandy
Apr 19 2012, 04:50 PM
hello Group,
I purchase some 944 3/4" spacers for the front and it kicks the wheel out perfect for the flares. Thats alot hanging out there with the stock spacer already, Am I safe to buy longer studs and go with it or is there another stronger/safer way to go
Thanks in advance!!!
Apr 19 2012, 05:07 PM
QUOTE(Socalandy @ Apr 19 2012, 06:50 PM)
hello Group,
I'm using 944 spacers as well. My friend races a ford cobra with 3" of spacers on each wheel so I'm thinking we're ok.
Socalandy
Apr 25 2012, 10:34 PM
the passenger sill is done and primered rear quarter.
I remember reading about the cost of materials for building a quality Rotiss. from Mr. O'Brien and how correct he was. Scratch the build as I bought one ready for use. picture's tomorrow
Socalandy
Apr 25 2012, 10:36 PM
hope to have it on the rotiss this Sat.
Madswede
Apr 26 2012, 12:03 AM
This is really looking good, Andy!
Socalandy
Apr 30 2012, 11:19 PM
so its finally on the rotiss. and ready for floor pan removal
it took a bit of work to get it mounted
Socalandy
Apr 30 2012, 11:21 PM
Socalandy
May 2 2012, 09:56 PM
up and away
Socalandy
May 2 2012, 10:00 PM
just a few spot welds to drill out
MoveQik
May 2 2012, 11:00 PM
QUOTE(Socalandy @ May 2 2012, 09:00 PM)
What's with all the missing metal??? Looks like red stuff that eats old cars.
Socalandy
May 15 2012, 06:30 PM
Thanks for all the hard work Andy!!!!
Getting close to the end of all the metal work and should be cutting a path for GT cooler lines
Time for some progress pictures
Socalandy
May 15 2012, 06:32 PM
Socalandy
May 15 2012, 06:34 PM
Pans half way done
Socalandy
May 15 2012, 07:10 PM
Aha, Found the other pics of the long repair to show more detail
infraredcalvin
May 15 2012, 11:52 PM
Wow, car looking great, love the previous shots with the Fuchs, are those 15's or 16's ( I know you showed them before but too lazy to find). The factory 930 has about a 1" spacer on the rear hub with longer studs, you'll be fine with 3/4" spacers and longer studs.
That's a great looking rotisserie, wish I could stop the spending on the new dd and focus on the p-cars... I really miss my 914, these threads are so inspiring. You're pretty close, im on south oc, if you really need a hand let me know and I'll make some time to lend a hand.
Socalandy
May 16 2012, 12:05 AM
Thanks,
they are 16x7 and 8's
We are getting close and I've been having dreams of it painted and driving the car
sbsix
May 16 2012, 09:34 AM
Andy,
This is a great thread, thanks for posting everything. Can I ask you where you got your rotisserie? And are you planning to sell it after you finish your 6? I'm up for buying it from you if you are.
Gary
Socalandy
May 16 2012, 02:11 PM
Thanks for the nice comments guys!!! I'm living my dream with this car and have many here to thank for helping make it possible and getting it done.
I ordered the rotiss. from Summit Racing and if my buddy passes on buying it your 2nd in line since its was purchased for this project alone.
sbsix
May 16 2012, 03:53 PM
Thanks Andy. Don't scratch it or anything, just in case!
porbmw
May 16 2012, 03:57 PM
Nice!
Good to see you are saving it!
You'll be done before I get close to completing mine....don't let it stagnate!
Socalandy
May 18 2012, 11:15 PM
We have a complete floor again, next are the seat reinforcement strips
Socalandy
May 18 2012, 11:24 PM
the jack points were hammered and this repaired area under gas tank the was swiss cheese
Socalandy
Jul 7 2012, 05:27 PM
Well its been awhile but back at it after my buddy Kent broke his hand that closed the shop for 6 weeks.
Great to get back at it!! Finish work on the pans and prep for the last of the stiffining kit...
Socalandy
Jul 7 2012, 05:33 PM
cutt the plug holes and need to notch them for the locking tabs, Front hood is close to done
Socalandy
Jul 7 2012, 05:37 PM
It was great to get the car on the rotiss. but cant wait to get it back on the ground. No more rust please
sixnotfour
Jul 7 2012, 05:56 PM
wow, oil lines monday, and some cheezy templates, cut once.
bigkensteele
Jul 7 2012, 06:51 PM
I am impressed that you went to the trouble to do the plugs. It is that kind of attention to detail that will set this car apart - great work!
peteyd
Jul 7 2012, 09:48 PM
QUOTE(bigkensteele @ Jul 7 2012, 04:51 PM)
That rotis is a serious piece too! Great job Andy
Socalandy
Jul 11 2012, 11:43 PM
Socalandy
Jul 11 2012, 11:47 PM
Next will be the GT engine mount modification and backing plates for the sway bars
Socalandy
Jul 12 2012, 10:46 AM
Hello All. I'm looking for a good picture of where the oil line suport hook should be so I can get it back in the correct position
Thanks in advance!!
sbsix
Jul 12 2012, 11:03 AM
QUOTE(Socalandy @ Jul 12 2012, 09:46 AM)
Thanks in advance!!
Andy,
Are those Racer Chris' mounting sleeves installed on your susp console?
I'll crawl under my six when I get home tonight and take a picture of the oil line support hook for you.
Gary
Socalandy
Jul 12 2012, 11:12 AM
Gary
If my memory is correct YES and thanks in advance for the pic.
I think it should be strait down with no bends
sbsix
Jul 12 2012, 11:15 AM
QUOTE(Socalandy @ Jul 12 2012, 10:12 AM)
Gary
If my poor memory serves me I think its not quite 90 degrees straight down, but has a slight angle to it, but the pictures will confirm.
sbsix
Jul 12 2012, 09:11 PM
QUOTE(sbsix @ Jul 12 2012, 10:15 AM)
Gary
Andy this is my first attempt to add a picture to a post, please be patient.
sbsix
Jul 12 2012, 09:15 PM
Click to view attachmentClick to view attachmentI have 9 more pix of the oil line hook. From the pictures you can see a slight curve from top to bottom, I think in order for the oil line coupling to fit properly.
sbsix
Jul 12 2012, 09:21 PM
you can see the slight curve from the top. The clearance at the coupling is minimal and would not fit if the hook was completley straight.
sbsix
Jul 12 2012, 09:23 PM
the curve is exaggerated because of the harsh lighting, but the end of the hook curves back slightly
sbsix
Jul 12 2012, 09:26 PM
this shot shows the slight curve compared with a straight edge. I was upside down taking this shot and suprised this one came out as well as it did
sbsix
Jul 12 2012, 09:28 PM
this shows the slight curve at the end of the hook towards the rear of the car
sbsix
Jul 12 2012, 09:30 PM
the edge is highlighted by the flash, but it does show the curve again
sbsix
Jul 12 2012, 09:32 PM
this shows both curves and the relationship of the hook to the oil line coupling.
sbsix
Jul 12 2012, 09:35 PM
this shot shows the oil line coupling and the clearances again. Of course, there is play in the line when you move it, but the coupling fits nicely within the curves surfaces.
sbsix
Jul 12 2012, 09:37 PM
another shot of the curves
