Socalandy
Jan 9 2014, 10:34 AM
QUOTE(Luke M @ Jan 9 2014, 07:24 AM)
QUOTE(Socalandy @ Jan 7 2014, 09:11 PM)
Anyone use a Mocal unit with their front cooler, looking for mounting ideas in the engine compartment. Show me our pics
Thanks
Andy,
Are you planning on installing the t-stat in the engine bay or front trunk?
I like the lower firewall/engine bay mounting area.
Here's a few links that I've looked at for my car :
Thanks Guys!!!
The front trunk was my first choice but my concern going with that location is the distance. there is a lot of cooling with the brass oil lines alone and I want it to open and close properly. Mocal calls for an engine compartment location and distance may be the reason. I was thinking the lower firewall would be the spot but I don't want a spaghetti mess of hoses. I might have to figure it out once the engine is in.
Luke M
Jan 9 2014, 10:43 AM
QUOTE(Socalandy @ Jan 9 2014, 09:34 AM)
Thanks
Andy,
Thanks Guys!!!
I like you want a simple install w/o all the hose mess. I'm going to mount mine in the lower right side firewall. I'm going to run my lines down the right side to the front trunk. I see you have the GT lines/routing so you may want to mount yours on the left side if you have the room. I have a few pics someplace just need to find them. IIRC I have pics of both mounting locations.
I'll post the pics after I find them.
jfort
Jan 9 2014, 12:38 PM
I don't know how I had not seen this thread before. I just spent two hours salivating my way through it. Truly remarkable and an inspiration to us all.
Andy, my six ran too hot IMO during hot days. I had a front cooler added about this time last year by Auto Assets in Powell, OH. I think it is the best improvement I have done. It ran cool all last summer.
I sold a '73 Corvette in 1976 when I came across a six in an interstate highway, quasi-race. I was impressed. It was yellow, too. Sold it for a family car -- a 911. But the six always haunted me and I am happy to have one now.
Keep going. Can't wait to see it done.
Socalandy
Jan 9 2014, 02:06 PM
And keep going I will. The early bird gets to put trim on before heading to work
Socalandy
Jan 9 2014, 02:09 PM
This aluminum trim is so soft
MoveQik
Jan 9 2014, 03:22 PM
Route 66 is in March. Would love to see this car in person Andy!
yellgokart
Jan 9 2014, 03:55 PM
Looking good my man!!! This project has come alooooong way, few more steps to go.
This will be one awesome ride to pull into "Cars & Coffee" on fine morning!!!
-Other 914 owner
Socalandy
Jan 9 2014, 06:22 PM
QUOTE(MoveQik @ Jan 9 2014, 01:22 PM)
It's doable in that time frame and work has eased
I'm looking forward to seeing your car too with your flares and fresh paint
I did what I think is the final hanging of the oil lines. the last pic is from a late 914 fuse panel, was the bailing string used on the early cars like in the photo? it sure cleans things up.
saigon71
Jan 9 2014, 06:53 PM
Awe inspiring work Andy - your car looks awesome!
Your first drive in that thing is gonna be sweet!
9146FAN
Jan 12 2014, 07:50 PM
Amazing detail, can't wait to see your 6 at C&C. This will be a show-stopper!
My 70 didn't have the string on the wires at the fuse panel.
Socalandy
Jan 18 2014, 10:53 PM
Should have the front cooler in tomorrow after getting some AN fittings and line from my buddy Kent, It only cost me a fiberglass rear valance Shea said I cant use
Socalandy
Jan 18 2014, 10:57 PM
I also got a puke tank from a F1 car as a nice gift
but is it too much carbon for the Six?
0396
Jan 19 2014, 11:23 AM
Nice work,.... A labor of love.
scotty b
Jan 19 2014, 11:28 AM
gorgeous
Socalandy
Jan 19 2014, 10:54 PM
More progress, just need to bolt down the cooler to the car after I paint the shroud.
Socalandy
Jan 19 2014, 10:56 PM
first time assembling AN fittings so I took my time, hope they dont leak
Socalandy
Jan 19 2014, 11:08 PM
finally got a good/tested proportioning valve that was the last piece to the brake system. I'm done in here, Just need to put the engine in. PMB brake lines are spot on!!! Thanks again Eric
zambezi
Jan 20 2014, 09:06 AM
Nice work. Even your vise is fast
sixnotfour
Jan 28 2014, 04:28 AM
I found a part you may need rattling around under the seat in my truck, I will send it to you...
r_towle
Jan 28 2014, 07:36 AM
QUOTE(sixnotfour @ Jan 28 2014, 05:28 AM)
I hope it's another roll of blue tape....cause if he tapes all his tools up he will run out.
Socalandy
Jan 28 2014, 11:28 AM
Thanks Jeff
Am I crazy for using blue tape to keep from scratching the AN fittings?
I have gone thru a few rolls on this project.
SLITS
Jan 28 2014, 11:44 AM
QUOTE(Socalandy @ Jan 28 2014, 09:28 AM)
Thanks Jeff
Other than purchasing the specialty wrenches for AN fittings I think you did good. I just scratched the AN fittings but then I am a barbarian.
You were always nutz, crazy, couple bricks short of a full load
Ferg
Jan 28 2014, 12:50 PM
QUOTE(Socalandy @ Jan 28 2014, 10:28 AM)
Thanks Jeff
Socalandy
Jan 30 2014, 11:20 PM
Got a set of E-Brake pins from PMB and the Sway bar is ready to go in
Thanks Eric!!!
Socalandy
Jan 30 2014, 11:28 PM
fuel pump and hoses will get run this weekend and set the tank in for the last time. I will have a recirc. loop so with the PMO pressure regulator I can have the remaining PSI feed the return. I also got my ignition ECU programmed today.
Socalandy
Feb 2 2014, 10:47 PM
all my outer satin parts get painted Wednesday so time to fiberglass the bumper brackets in place, Painted the intakes and a little polishing.
Socalandy
Feb 2 2014, 10:51 PM
Got the wiper motor in. Anyone know where the red wire off the motor harness goes to? my wiring diagram was no help, this is a -6 wiper motor.
Ready..... The nipples for the washer bottle were busted off. Found a T fitting and chopped it for the fix. I think it worked out pretty good.
Socalandy
Feb 2 2014, 10:59 PM
I also got the engine harness done, pedal cluster in, basket weave on the dash face and more.
I think listening to the game in the garage working on the car was less painful than watching
Socalandy
Feb 4 2014, 10:49 PM
Thanks Jeff!!! You rock
and this part is killer. Also thanks to those who made the blue tape comments as Jeff thought I was almost out and included a few rolls
Got the oil tank lines and painted the headlight bezels. rockers, bumpers and valance are being painted. engine and trans goes in on the 21st
MoveQik
Feb 5 2014, 07:29 AM
Looks amazing as always Andy! Will we see it in ABQ?
rick 918-S
Feb 5 2014, 08:33 AM
awesome!
sbsix
Feb 5 2014, 11:55 AM
Andy it's interesting that you painted your headlight surrounds. Did you try to clean or refinish original white surrounds first?
TJB/914
Feb 5 2014, 01:14 PM
QUOTE(rick 918-S @ Feb 5 2014, 09:33 AM)
awesome!
Beautiful workmanship.
Andy: Wondering how many man-hours of your time into the project so far??
Just a wild ass estimate please??
BTW: My guess-estimate will be 3,000 plus+++ man-hours of your time?
Tom
worn
Feb 5 2014, 01:59 PM
QUOTE(mepstein @ Jan 9 2014, 07:56 AM)
Andy - I applaud your vision!
I also spent a lot of time with the before images trying to get a better feeling for the spaces under the fenders for oiling and also the shape of the frame overall. Thanks!
Socalandy
Feb 5 2014, 02:59 PM
I painted the bezels since the originals had at least 3 coats of paint and primer on them and when I striped them I could tell they would wouldn't clean up enough for my liking.
As for time spent on the car, there's my time and kent's time but I'm sure were above the 3K mark!!!
Got some goodies in the mail and home for lunch. my rough plan for fuel, filter location and washer pump is in. Back to the day job
pete000
Feb 5 2014, 05:38 PM
Who does your yellow cad plating ?
2mAn
Feb 5 2014, 05:39 PM
WOW! just went through another looooooooooong thread, hoping the car would be done at the end and it wasnt. This says a few things about this group. #1 you do things right the first time. #2 you have the patience of a buddhist monk #3 a proper resto on a 914 is ~3-5 years!!!
Andy, Im in Fullerton and would love to come and BS with you someday. I'll try to keep the drool off the car
r_towle
Feb 5 2014, 06:12 PM
Hey, could you back up a bit and show where you are putting the fuel pump?
I can't make out the location.....
Rich
Eric_Shea
Feb 5 2014, 06:40 PM
Mr. Bowlsby may be of assistance but the red wire has a jacket consistent with tying into another harness. If it's what I'm thinking, I thought there were more.
Intermittent relay harness?
Socalandy
Feb 5 2014, 10:55 PM
QUOTE(r_towle @ Feb 5 2014, 04:12 PM)
Rich
Thanks Guy's,
pump is just below the pass. side headlight bucket.
Jeff Hines answered the mystery wire issue. I don't want a visit from Mr. Sparky or his pal Smoke
Sleepin
Feb 6 2014, 12:28 PM
I'll call you this evening Andy.
r_towle
Feb 6 2014, 10:33 PM
QUOTE(Socalandy @ Feb 5 2014, 11:55 PM)
Rich
Thanks Guy's,
Got it.
Based upon experience, I would strongly suggest you either don't put fuel lines and pump in the front trunk, or build a cover for everything.
Once you start using the car, the front trunk is key to be able to stuff full.....and things rolling around and bumping into the fuel system is just not cool.
Just putting that on the table for you to consider.
Rich
Socalandy
Feb 6 2014, 11:52 PM
Thanks Rich, Always good to think this stuff threw and I welcome other options that don't require cutting or having it somewhere hard to service.
Socalandy
Feb 8 2014, 02:25 PM
I had to special order the front mount bolt but had to order 5 so ping me if you need one. My cost was 9.75 ea.
sbsix
Feb 8 2014, 02:45 PM
andy, i'll take one. let me know much you need and how you would like paid.
rick 918-S
Feb 8 2014, 06:23 PM
PM sent
Car looks awesome!
r_towle
Feb 8 2014, 06:27 PM
QUOTE(Socalandy @ Feb 7 2014, 12:52 AM)
Hmm, no cutting....
Underneath the tank, under the car, just above the steering rack.
Cover plate would protect it.
Similar to a 911.
Or
At the rear, mounted to the firewall, passenger side.
bigkensteele
Feb 8 2014, 08:21 PM
QUOTE(r_towle @ Feb 8 2014, 04:27 PM)
Similar to a 911.
This gets my vote. Under the tank is a PITA as hoses get kinked and pinched. Behind the steering rack is the perfect location - short, direct hose runs and easy to get to.
Love this thread - keep up the awesome work, Andy!
Socalandy
Feb 8 2014, 08:29 PM
two more bolts remain.
More progress, taking a dinner break and then back in the front trunk and the flapper boxes and cables.
scott_in_nh
Feb 9 2014, 08:23 AM
QUOTE(bigkensteele @ Feb 8 2014, 09:21 PM)
Similar to a 911.
that's where I put mine - no sheet metal mods other than two mounting holes.
