So, the diff is assembled with different R/P set (was 3.55 now 3.27), back lash is w/i tolerance, all bearings preloaded per MFR instructions. I just need to score some gear marking dye to check the interface and I can call that part good.
I still have the engine on the sled and will need help lifting it onto the stand. As such, I figured I could shed 30# by removing at least one head. Plus, I wanted to see what was going on with the passenger side.
very rich running, possible oil burning. The carbon build up is insane. No pics right now...at work until tomorrow AM sometime.
I am debating on whether or not to CC the chambers on the new heads like I did on the old ones. I probably will
I hope I still have all the gear that I made.
Can I reuse the copper head gaskets? They look fine. Do I need to re-anneal them? I may need new ones after doing the CR calc anyway. Maybe I will bump it a few tenths
The major transmission leak seems to have all come from the selector cable. The sheath on it parted from the metal sleeve at the end and allows fluid to piss all over the place. Everywhere I go the back of the bus is covered in ATF. As such, I had to shell out some dough for a repro cable (ouch). It is about the only "expensive" part that I have bought for this drive train (stock).
Next, I will pull the other head, check the diff, get engine on stand.
