One little O-ring can really mess up a morning
The story:
Since Noel enjoyed driving the bus so much, she was looking forward to driving it to work today (with me as a passenger). Well, if anything will break, she will cause it to. She is cursed and is the best test pilot. Problem #1, I had just hit reserve on the fuel gauge. Plenty of gas to get to work and the gas station. She mentioned that the fuel was low....Problem #2, I did not look at the gauge as I thought I knew what she meant. Problem #3, it was running like shit this morning
We get to the hospital (where she works) and when I get out I smell gas, VERY STRONG. I look in the engine bay and find it sprayed with fuel
The O-ring that seals the tube connecting the primary and secondary bowls of the carb, on the secondary side, has split and was allowing fuel to spew forth. Obviously not good. Soooooo, I commenced to repairing it in the fire lane, out side the hospital. Except, I did not have any sealer, or a new O-ring.
So, as spots behind me opened up (semi OK parking for drop off and pick up) I pushed the bus back into them. Then, luckily, I saw my friend on his way to work and he lent me his car so I could go home and get another O-ring. When I returned, security was writing tickets for those vehicles left in the spots, unattended, for too long. I told the guy that I was just going to park my friends car (required me parking it behind the bus, leaving it, going into the basement to get Noel's ID for the lot, returning, driving to the lot, and walking back) and that I would be fixing and driving the bus away shortly. He was very cool and said no problem.
When I returned I had the bus fixed and running in less than 5min
So, the valuable lessons learned:
1) I need to keep a fire extinguisher in the bus at all times. This could have been bad.
2) I need to assemble a tool kit to carry at all times. All I had was a small pair of vice grips to use as a wrench
I went to sleep at 0330, awoke at 0800 to take Noel to work, and got home at about 1130 after this ordeal
Next<_<
