Yesterday, I attempted to install my flex plate onto my crank with the 6 special bolts I bought only to find out that one of the bolts was the wrong size.
On a Sun, I was SOL. So, I decided to try to install my alternator. This required me to get a socket head bolt as there is no room for a socket on the inboard bolt. Of course, Zach doesnt have any standard hex keys that I could use so I gave up and went to Joe's for some food.
Today I tried to rectify the bolt situation and to get a few odds and ends at the corvair junk yard (Corvair ranch). No problem, I got the right bolt, some intake gaskets that I will need, measured a stock dip stick to mark my aftermarket one correctly, and got a few small free pieces. Feeling triumphant, I head over to Zach's to finally assemble my tranz, torque converter and engine together......or so I thought. I get the flex plate on and go to pick up my TC only to see that one of the three special captive nuts was missing
(damnit!). Defeated again. So, I will be going out to the yard again tomorrow.....1 hour there, 1 hour to Zach's, 1 hour to home. Good thing I am unemployed.
So, since I had some newly free time I decided to remove Zach's tranz, clutch and flywheel to install the o-ring on the flywheel Zach forgot. Then I installed the flywheel and clutch, then I installed the squirrel cage, fan belt, tensioned it, installed the front tin, transmission, and then installed the whole works in the car. At least his engine and tranz is out of my way now
More room for me to attempt working on mine.
With any luck, we will be attempting to install the engine into the bus this Sat. The next hard part I see is the creation of the special engine tin from the corvair engine to the bus.
