Got some more work done today. I heard that the weather would be about 50* so I planned my week around today being bus day. No pics, all in prose so consider yourself forewarned
I finished cutting the engine bay shelf, prepped and painted it. Then I did some wiring to get things about where they need to be on the engine. I will finish up the wiring when the engine is in.
I had received the nice HT starter but had yet to test it as I didnt want to go through the paces of bringing my car up, opening the hood, getting the damn cables. However, Zach's battery was just sitting there and his cables were near by so I figured what the heck. This starter cranked the engine over like it was nothing. I think that the stock corvair starters are no match for the abomination that I have created
I did some more work on the front tin with putting holes in it for the vacuum lines to pass. Its not complete, but I wanted to get the engine in the bus before I did anything more.
I had to raise the ass end of the bus up 32" to get the engine to slide right under the rear. It was so high up that I almost had to jump to pull the hatch down. I lowered the bus to its wheels afterward and the engine was not smooshed. I am starting to get a little concerned with clearance, though. It will be tight.
If I could have one more thing done to the bus, I would have the rear floor above the engine bay cut out and a late model large opening hatch welded in so I could get to the engine easily. Oh Scotty!
I am gonna need to find some more matchbox cars.
Lastly, I took some naval jelly and applied it to the engine bar to cure the rust that developed on it. Worked like a champ. I primered it and left the final undercoat coating for another day.
Not wanting to be idle at home, I did some fancy wiring stuff for my bus. I got a bread board and used it to make several connections. The alt light now goes through the bread board and when the alt stops or dies a buzzer and light will go off. This board is also a junction for power to the electronic fuel control.
Next wiring stuff to do:
- Wire shifter cut off so that bus only starts in N.
- Wire reverse lights to trigger from auto shifter.
- Wire back up camera to turn on when shifter is in R.
Next time, I intend to mount the engine in the bus so that I can finish mocking up the engine tin. Once the tin is done, then is the wiring which is pretty much done. Then I will be goofing in the cabin with the wiring, then I try to make the boom in a useful way. I also need to weld in the bung for the O2 sensor which will require a small section of pipe to be added to one of the headers.
Thats about it. Pretty exciting. Hopefully I will have picture worthy stuff next time.
