And now for the little part I am most pleased with. The throttle connection on the tranz was a 5/8 hole. So, I bought a 5/8 bolt with a good size unthreaded portion. I cut the threads off, flattened one side to make it easy to drill, drilled a hole for a cotter pin and one for the cable, put a washer on it, and installed it. It friggen worked as I imagined! I like fabricating things.....when they work
Click to view attachmentClick to view attachmentI had to make a new arm for the pivot on the tranz. This time I made it longer and with extra holes for adjustment. I did the drawing, caveman-trigonometry, and measurements and found the previous iteration to be 1cm too short. I could not get full throttle until I made the new arm. I will be cutting off the extra limb, and tacking the small fasteners on Sun, most likely.
Click to view attachmentI should be able to start it and maybe drive it tomorrow
I need to jack up the rear so I can spin the wheels to finish installing the bolts in the axles. The to do list includes:
- Finish axle install
- Tack the throttle tube down
- Tack the linkage arm down
- Cut off extra limb of pivot arm
- Check hose at brake booster
- Clean up the cabin and finish any left over wiring
- Attach MAP line to tranny
- Design, build and install mount for the tranz shifter
- Fill fluids
- Sacrifice goat
- Power up and fix what ever goes wrong
