What a friggen day. The last part of this post will need to be read while you are not drinking anything as to prevent from spitting.
The day started off pretty good. There was rain forecasted, but none happened so I decided to head down to try and finish the bus. We still need a second vehicle up and the bus is closer than the Suby at this point.
I went to Lebanon, PA to pick up my under dash A/C unit that I got for the bus (future plans). I then went directly to york to work on the beast.
I managed to get all of the rear wiring done and a battery installed. I was pretty happy about this and figured that the end was near (in a good way).
So, I figured it was time to install the passenger side axle and exhaust since I was finished with that side.
The axles.....
I bought my axles off of Eric Shea at a good deal. They were shipped and marked fragile. Whatever. The axles were contained in bags and there was a baggy of grease accompanying each one. One axle was dropped so hard that it burst the bag of grease all over the inside of the box. Excellent. The axle was clean, though. The other axle had one CV that someone had previously greased and as such the zip ties were missing and the whole damn thing was in pieces
I HATE reconstructing greasy CVs. Well, that only too too long and made a huge mess. So, off to the beast I go to install the one I just reconstructed. Or so I though. I get under the bus and put the axle into place only to notice that.....it is too short
How the hell? So, I try to fit it on the other side and wouldnt you know it,.....its too long!
So, it would appear that my drive train, some how as we trial fit the throttle stuff in the bus, IIRC, is too far over to the drivers side by about an inch (2" too close on drivers, 2" to far on passenger).
Now, I need to drop the engine a little and see if I need to modify the front mount over, the rear bar (I hope not), or both. Oh ya, and the tin
I took pics, but what is the point
Looks like I have a project waiting for me when I go down again. Tomorrow is home work day. Depending on how long it takes, I will likely not be going down.
