Okey dokey, I finally took some time to go work on the bus yesterday. I have a download of the factory CIS manual and another one of a troubleshooting guide. From this I made a trouble shooting chart and reacquainted myself with the CIS.
Gripe list:
- Hard to start cold or warm
- Sometimes will not start warm
- Shitty mileage (could be because it is a bus and I drive it kind of fast)
- Poor idle. I had to adjust the idle high to keep the engine running when I switch from idle to D, otherwise it dies right off and it sucks to start (as above mentioned).
Based on this list, I had a suspicion that my fuel pressure was likely too low, and that this was either a restriction problem due to pump, or flow issue due to faulty WUR.
Pre-test exam of parts:
- Found that I had my Cold Start Injector wired backwards. This should not have been an issue, but I corrected it. I had Ground directly to one wire and power going first to the thermoswitch and then to CSI. This may have heated the TS and caused the CSI to prematurely close, but I doubt this was the issue. Fixed it anyway. The location I chose to put the TS in is unfortunately under more pressure than the TS could handle and it is pissing oil all over the place
I will need to remedy this soon.
- Cleaned up oil, checked a bunch of other stuff, proceeded.
The test:
- The manual says to hook the gauge between the control pressure outlet on the fuel distributor and the WUR. Did this. Almost all tests are done here.
Findings:
- All cold, key on, system pressure is around 2.2 bar ( I think this is high).
- Warm running control pressure was 4.7 bar (seems kind of high, actually).
- System leak down pressure was good as it dropped fairly fast to 2.2bar and then maintained for over 10 min. (pass)
I have to admit making a mistake. I did not unplug the WUR power in when doing the cold system pressure check so I just noted the pressure dropping and the WUR making a whining noise due to it shunting the pressure in back to the return line. So, I did not record exact cold system pressure. I could not replicate the cold system pressure as the WUR did not cool down over the hour or two I was messing with it while doing other projects around the garage. I will go back tonight (maybe) and see if I can get cold pressure.
Thoughts:
-If cold pressure is too high, starting will be hard. The WUR did warm up pretty damn fast. The manual mentions 10min, mine was like <2min. The manual is not exact on each WUR and they changed about every friggen year.
-If I can deduce that the whole system pressure is actually too high, I can then change the check valve pressure limit with removal of a shim on the intake of the fuel distributor.
- One issue I am having with this thing is that the WUR I have has a vacuum component to it. So, to accurately measure it I have to have a vacuum source. So, I need to buy one I can measure. OR, I have a WUR without this feature and I can just omit this and try that out. I would rather do it with the one that came with the system (I think it is correct). An improperly functioning vacuum mechanism in the WUR would make cold starts suck as it would not drop the pressure and the pressure would then flood the cylinders on start up. A high pressure state makes sense as the engine floods often; smell of gas, wont start, have to wait 30min for fuel to dissipate from cylinders.
Any thoughts from those that know CIS stuff? Maybe the WUR originally had a special time delay circuit that I am not compensating for. Maybe changing to a simpler WUR would solve/remove some issues. I want simple. The current system does not have the TB pressure regulator that I have on my 74 2.7 in my 914.
