Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 Owner's Manual (0 replies)
  2. Porsche 914 Drivers Manual (0 replies)
  3. Porsche 914 1.7 2.0 owners manual (0 replies)
  4. Porsche 911, 912 & 914 Clock REPAIR SERVICE (0 replies)
  5. 1973 PORSCHE 914 HEAD LIGHT MOTOR (0 replies)
  6. Porsche 914 gear set with intermadiate plate included (0 replies)
  7. PORSCHE 914 CONTROL ARM INTERMEDIATE PLATE (RIGHT) (0 replies)
  8. PORSCHE 914 COWL VENT ELBOWS ***PAIR *** (0 replies)
  9. PORSCHE 914 AIR GUIDES VENTS *** PAIR *** (0 replies)
  10. OEM Early 1970 1971 1972 1973 1974 1975 1976 Porsche 914 Center Seat Section Pad (0 replies)
  11. OEM 1970 1971 1972 1973 1974 1975 1976 Porsche 914 Engine Compartment Drip Tray (0 replies)
  12. OEM Early 1970 1971 1972 1973 1974 1975 1976 Porsche 914 Center Seat Section Pad (0 replies)
  13. Coverlay - Dash Board Cover Black 20-914-BLK For Porsche 914 Front Upper (0 replies)
  14. PORSCHE 914 TIRE IRON LUG WRENCH BAR (0 replies)
  15. porsche 914 fender archs 914 parts (0 replies)
  16. 1974 Porsche 914 Owner's Manual & Maintenance Records, Emission Control System (0 replies)
  17. Porsche 914 2.0 Original Air Cleaner Mount (0 replies)
  18. Porsche 914 Ash Tray (0 replies)
  19. Porsche 914 Engine Cooling Tin Shroud- Air Duct, Rear, Drivers Side 022119362A (0 replies)
  20. Porsche 914 hazard warning light switch (0 replies)
  21. Porsche 914 Ash tray (0 replies)
  22. Porsche 914 rear view mirror (0 replies)
  23. Hella Driving Lights / Porsche 914 / Others / New Pair / 914.631.131.10 (0 replies)
  24. 1971 Porsche 914 ECU with Wiring Harness- (0 replies)
  25. Porsche 914 914-6 Appearance Package Heater genuine factory part (0 replies)
  26. Porsche 914 Rear Brake Rotors / New Pair / Genuine Porsche / 914.352.401.10 (0 replies)
  27. Porsche Used OEM 914 Styled Steel Sun Bug Wheel 4.5J x 15 (0 replies)
  28. Blaupunkt Frankfurt AM FM Autoradio radio Porsche 911 912 914 Mercedes VW BMW (0 replies)
  29. Porsche 914 interior rear view mirror BMW conversion (0 replies)
  30. USED ORIGINAL GENUINE PORSCHE 914 914-6 DASHBOARD DASH BOARD (0 replies)
  31. OEM BOSCH ECU Porsche 914 1.7L /2.0L ECU Bosch 0 280 000 037 Tested GUC 1972 -73 (0 replies)
  32. Porsche 914 2.0L 1974 Fuel Injection Wiring Harness (0 replies)
  33. 74 Porsche 914 2.0L Air Intake Manifolds W Airbox Bracket, Injectors & Fuel Rail (0 replies)
  34. Porsche 914 2.0L Air Cleaner Intake Boot Clamp (0 replies)
  35. Porsche 914 2.0L Deceleration Valve Oem Decel 1974 (0 replies)
  36. Porsche 914 2.0L 1974 Throttle Body Intake Plenum GUC (0 replies)
  37. Porsche 914 2.0L 1974 OEM Air Cleaner Assembly (0 replies)
  38. PORSCHE 914 2.0 Ignition Distributor 039902205A complete w/ Injection points (0 replies)
  39. RetroSound RC900C-AM/FM RetroClassic Radio - 1970-1976 Porsche 914 (0 replies)
  40. Porsche 914 Expansion tank gasket. (0 replies)
  41. BMW E10 1600 2002 Porsche 911 912 914 Volvo 122 Voltage Regulator 90160320602 (0 replies)
  42. Porsche 914 Transmission side shifter (0 replies)
  43. 1970-1974 Porsche 914 1.7 1.8 & 2.0 Technical Specification Book 1971 1972 1973 (0 replies)
  44. Vintage Porsche 914 VDO Fuel/Combo Gauge 914 641 102 20 late 1971-1972 (0 replies)
  45. Porsche early 911/912/914 starter (0 replies)
  46. 1975 Porsche 914 Buick V6 grand national motor (0 replies)
  47. PORSCHE 914 STEERING WHEEL AND HORN BAR (0 replies)
  48. Porsche 914 69-76 Haynes manual (0 replies)
  49. Porsche 911-912-914 Factory Key Blank-Black Head Master Key- # 914 531 903 10 (0 replies)
  50. Porsche 914 5 Speed Tail Shift Transmission (0 replies)
  51. 1973 Porsche 914 - 1.7L Ignition Distributor (0 replies)
  52. Porsche 911 / 914-6 Zenith 40TIN Pair of Carburators (0 replies)
  53. Porsche Front Strut Buffer, 911 914 65-89 # 901.343.301.00 (0 replies)
  54. Porsche Marelli Distributor Condenser 911T 68-71 914-6 70-72 # 901.602.931.00 (0 replies)
  55. Porsche 914 Window Crank (0 replies)
  56. Porsche 914 Window Crank 111.837.579B (0 replies)
  57. Porsche 914 speedometer 150 mph 1974 1975 (0 replies)
  58. 914 Porsche Dash Bezel (0 replies)
  59. Cofle Accelerator Cable Porsche 914 (0 replies)
  60. Bursch Muffler, Porsche 914, 2.0, (72-74) (0 replies)
  61. Porsche 914 Ceramic Fuse Set New German (0 replies)
  62. Vintage Porsche 914 1.7 / 2.0 Owners Manual Model '73 1973 (0 replies)
  63. Porsche 914 charcoal canister (0 replies)
  64. Porsche 914 Tire tools accessories (0 replies)
  65. Porsche 914 2.0 "GA" Core Engine with Fuel Injection (0 replies)
  66. Porsche 914- Rare Genuine Pedrini Wheels- 5 Wheels 4 Lug 15 X 5.5 Inch (0 replies)
  67. Porsche 914 heater control flap (0 replies)
  68. Porsche 914 heater box tubes (0 replies)
  69. Porsche 914 gauges (0 replies)
  70. Classic Porsche 914 2door Targa Sport Watch (0 replies)
  71. Porsche 914 1.7 engine sheet metal (0 replies)
  72. Porsche 914 Driver Side Speaker Cover (0 replies)
  73. Porsche 914 Valve Covers Black (0 replies)
  74. 75 914 1.8 parts (0 replies)
  75. Porsche 914 914/6 Targa Roof Trunk Cups (0 replies)
  76. Porsche 914 Left Taillight Assembly (0 replies)
  77. Porsche 914 Transmisson Gearbox (0 replies)
  78. Porsche 914 1.8 new fuel injector Bosch VW 0280150112 (0 replies)
  79. POrsche 914 transmission clutch cable support and roller (0 replies)
  80. porsche 914 heat exchanger (0 replies)
  81. Porsche 914 door latches, pair (0 replies)
  82. Pair of Porsche 914 headlight motors (0 replies)
  83. Porsche 914/6 Hella front turn signal lens--pair (0 replies)
  84. Porsche 914 steering column (0 replies)
  85. Porsche 914 rims Fuchs (0 replies)
  86. VINTAGE 1969 914 914/6 PORSCHE SERVICE WORKSHOP MANUALS 1-7 (0 replies)
  87. Porsche 914 Bursch Primary Muffler 1975-76 (0 replies)
  88. Porsche 914/4 Thermostatic Air Control Flaps (0 replies)
  89. Porsche 914 Auxiliary Air Valve (0 replies)
  90. Porsche 914 Early Front Calipers with Vented Rotor Spacers (0 replies)
  91. PORSCHE 914-6 TRANSMISSION (0 replies)
  92. Porsche 914 driver side mirror (0 replies)
  93. Porsche 914 horn (0 replies)
  94. Porsche 914 Tach Core (0 replies)
  95. 15X5.5 FUCHS 70-76 PORSCHE 914 OEM Factory Original Alloy Wheel Rim 67136 (0 replies)
  96. Porsche Original Factory 914/6 Timing Decal - 1970 (0 replies)
  97. 1970-1973 PORSCHE 914 SERIES CLYMER SERVICE MANUAL REPAIR HANDBOOK (0 replies)
  98. 1970-1973 PORSCHE 914 SERIES CLYMER SERVICE MANUAL REPAIR HANDBOOK (0 replies)
  99. Porsche 914 removable targa top excellence condition (0 replies)
  100. 1956 Porsche 356A (0 replies)
  101. Porsche 911 914 Weltmeister Aluminum Extending Oil Return Tube 1965 - 1998 (0 replies)
  102. Porsche 914 fuel/oil gauge VDO # 914.641.102.40 (0 replies)
  103. Porsche 914 Interior Door Handle Assemblies RH LH (0 replies)
  104. porsche 914 transmission (0 replies)
  105. Porsche 914-6 Facory Oil Line (0 replies)
  106. porsche 914 distributor (0 replies)
  107. Porsche 914 hub axle flange - short shaft (0 replies)
  108. Porsche 914 heater blower motor and housing (0 replies)
  109. Porsche 914 Seat Belts (0 replies)
  110. Porsche 914 Steering Wheel and batwing horn pad (0 replies)
  111. Porsche 914 Parking Brake assembly (0 replies)
  112. PORSCHE 914 1969-1976 4 CYLINDER HAYNES Repair MANUAL 239 air cooled Germany (0 replies)
  113. PORSCHE 914 TRUNK LIGHT WITH GASKET (0 replies)
  114. 1974 Porsche 914 (0 replies)
  115. Porsche rally stripe decal White 3M Classic 911 914 356 944 968 951 930 964 (0 replies)
  116. Porsche 914 Roll Bar Vinyl Covering. (0 replies)
  117. Porsche 914 Interior Trim for A and B Pillars (0 replies)
  118. Porsche 914 Chassis Repair Panels (0 replies)
  119. 16450N Starter Motor for Porsche 914 Volkswagen Beetle Campmobile (0 replies)
  120. 1974 Original Porsche 914 Large Sales Brochure Technical Specifications 1.8 2.0 (0 replies)
  121. 1975 Porsche 914 (0 replies)
  122. 1972 Porsche 914 (0 replies)
  123. PORSCHE 911 912 914 STRUT TOPS (0 replies)
  124. Porsche 914 Manta Exhaust With 1.8L, 2.0L 1975-1976 (0 replies)
  125. Porsche 914 Front Torsion Bar Pair, good condition (0 replies)
  126. Porsche 914 throttle valve with housing (0 replies)
  127. 914 Porsche computer (0 replies)
  128. 914 Porsche computer (0 replies)
  129. 1973 PORSCHE 914 / 914-6 PARTS CATALOGUE (0 replies)
  130. Porsche 911 912 914 synchro sleeve (0 replies)
  131. VINTAGE PORSCHE SALES BROCHURE LOT 9 PIECES 911T, 912, 914, 924, 928 & MORE! (0 replies)
  132. Used Porsche 911 914 Seat Belt Warning Light - 911 632 012 01- Tested & Working (0 replies)
  133. Porsche Fuse Box Clear Plastic Cover, 12 Fuse, 914.612.316.10, 914 (70-76) (0 replies)
  134. Porsche 914 Center Cushion With Tray Storage Bin Tan Vinyl Console Armrest (0 replies)
  135. OEM PORSCHE 914 Seat Sliders/Rails 1 pair (0 replies)
  136. OEM PORSCHE 914 Seat Sliders/Rails 1 pair (0 replies)
  137. Porsche 914 Original Black Vinyl Seats Fabric inserts (pair) 1974 (0 replies)
  138. 1973 Porsche 914 (0 replies)
  139. Porsche 914 Muffler Bracket # 5 (0 replies)
  140. Porsche 914 Muffler Bracket # 4 (0 replies)
  141. Porsche 914 Muffler Bracket # 3 (0 replies)
  142. Porsche 914 Muffler Bracket # 2 (0 replies)
  143. Porsche 914 Muffler Bracket # 1 (0 replies)
  144. Porsche 911 928 924 Fuch Wheel Center Cap 1970’s 1980's 1990’s 914 RSR Aluminum (0 replies)
  145. 914porsche speedometer cable (0 replies)
  146. 914 Porsche dashboard (0 replies)
  147. Vintage 1974 Porsche 914 Car Sales Dealer Brochure (A3) (0 replies)
  148. Porsche 914 914-6 Rebuilt Pedal Assembly Cluster (0 replies)
  149. Porsche 914 914-6 Front Sway Bar Assembly (Restored) (0 replies)
  150. Porsche 912, 914 VW Type IV Bus Taco Plate Temperature Sender (0 replies)
