Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 window crank handle & insert (0 replies)
  2. Set of Original Porsche 914 Heater Control Valves/Boxes (0 replies)
  3. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 996 (0 replies)
  4. Porsche 911, 930, 914, 120mph Speedometer (0 replies)
  5. 1970-1975 Porsche 914, Clutch disk aligment Tool, 1.7, 2.0, 5 speed (0 replies)
  6. 1970-1975 Porsche 914,1.7L Rear Engine Main Block Seal 029-105-245B (0 replies)
  7. Porsche 2 Ball Joints w/Pin Front Lower 911 914 930 (0 replies)
  8. Porsche 914 Clutch Disc & Pressure Plate (0 replies)
  9. Porsche 914 Intake Air Distributor (0 replies)
  10. Porsche 914 Actuator Lever (0 replies)
  11. Porsche 914 Oil Filler& Breather (0 replies)
  12. Porsche 914 Cam (0 replies)
  13. Porsche 914 engine cover (0 replies)
  14. Porsche 914 intake manifolds (0 replies)
  15. Porsche 914. Air Cleaner (0 replies)
  16. Porsche 914 front Hood Latch (0 replies)
  17. 914 front strut, Passenger side (0 replies)
  18. porsche 914 defrost ventilator (0 replies)
  19. Porsche 914 instrument cluster holder (0 replies)
  20. Porsche 356C 911 914 & Jaguar XJ6 Inner Wheel Bearing * (0 replies)
  21. Porsche 914 front Quarter window& Guide (0 replies)
  22. Porsche 914 Front Hood Hinge Set (0 replies)
  23. Porsche 914 Engine Compartment Bonnet (0 replies)
  24. Porsche 914 rear engine cover (0 replies)
  25. Porsche 914 Fuel Injection control Unit. (0 replies)
  26. Porsche 914 Engine Compartment Latch (0 replies)
  27. Porsche 914 center console early style (0 replies)
  28. Long Bolt Lug Set Fuch Mahle Pedrini Wheels Porsche 914 VW 14 mm (0 replies)
  29. Porsche 911 914 916 930 Oil Cooler 27 Row Brass (0 replies)
  30. Porsche 914 throttle switch 1972-73 1.7 nos LOOK (0 replies)
  31. PORSCHE ROAD SPORT RACING CAR 356 911 944 928 914 917 (0 replies)
  32. Porsche Parts - NEW 911 '65-'9/74 & 914-6 '70-'71 Main Bearing Set 0.25 (0 replies)
  33. Western Dan Gurney Aluminium Wheels Rims Porsche 914 VW 15" 4 x 130 mm (0 replies)
  34. Porsche Parts - NEW Camshaft for all 914-4 & '76 912E (0 replies)
  35. PORSCHE 914 ULTIMATE PORTFOLIO 914/6, 914SC, 914S & 2.0 (0 replies)
  36. Porsche Parts - Transmission Shift Housing (Nose Cone) for 914 '70-'71 (0 replies)
  37. How to Restore & Modify Your Porsche 914 and 914-6 NEW (0 replies)
  38. Porsche 914 Center Console Gauge Wiring Harness (NEW! Reproduction) (0 replies)
  39. Porsche 911 1965-1997 914/6 1970-72 & 930 1978-79 Crankshaft Rear Oil Seal S5007 (0 replies)
  40. 914 911 Porsche Fuel GasTank metal OEM (0 replies)
  41. 914 911 Porsche Fuel GasTank expansion metal OEM (0 replies)
  42. Centerline Racing Wheels Rims 15" 4 x 130 mm Porsche 914 VW Bug Bus Ghia (0 replies)
  43. K-D Tools Valve Spring Compressor Tool 914 (0 replies)
  44. Tyre Tire Valve Stem Caps Air Dust Covers+Tool Wrench Modified Porsche Auto 5pcs (0 replies)
  45. Porsche Tyre Tire Stem Valve Air Cap Anti-Theft Locking (0 replies)
  46. Cool Black Porsche Emblem Tyre Tire Stem Valve Air Caps Cover Anti-Theft Locking (0 replies)
  47. Porsche Brake & Clutch Pedal Pads 356 911 930 912 914 Carrera Turbo (50-98) (0 replies)
  48. NOS MANN Oil Filter W920/17 VW Porsche 411 412 914 4cyl VW Transporter (0 replies)
  49. 1970-1976 Porsche 914 Rear Reflector (0 replies)
  50. PORSCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  51. Porsche Bump Steer Rack Spacer Kit 911 912 914 930 (0 replies)
  52. Lot # 67 Porsche 914 beauty ring 15? stainless VW & others also mag steelie rim (0 replies)
  53. Porsche 914-4 Bosch Complete Tune-up Kit 1.7 1.8 2.0 (0 replies)
  54. Porsche 901 transmission 911 912 914 Release Fork (0 replies)
  55. OBX HEADER EXHAUST MANIFOLD 69-76 PORSCHE 914 H4 2.0L (0 replies)
  56. Porsche 914 / VW Type 4 Cylinder Head Studs. Used. (0 replies)
  57. Porsche 914-6 Winner 24 Hrs of LeMans Factory Poster (0 replies)
  58. Denso Iridium Spark Plugs 4 - IW20#4 5306#4 - Porsche 914 (0 replies)
  59. porsche 914 parts lot (0 replies)
  60. 1973 Porsche 914 Parts car, (no engine or transmission) (0 replies)
  61. 914 Porsche Side Shifter Transmission, very good cond. (0 replies)
  62. OE Genuine Porsche USA NEW Taillight Lens Pair (0 replies)
  63. Porsche 914 Passenger Side Rear Taillight Housing Brand New NOS (0 replies)
  64. OE Genuine Porsche Euro Passenger Side Taillight Lens (0 replies)
  65. Porsche 914-4 clutch cable (0 replies)
  66. Headlight motor Porsche 914 (0 replies)
  67. Porsche 914 Trunk Latch (0 replies)
  68. Porsche 914 Front spoiler (0 replies)
  69. 80's Porsche 911 914 Radio VW Scirocco GOLF (0 replies)
  70. Porsche 914 FI Air Intake Short System for 1.7 (0 replies)
  71. Porsche 914 Rocker Panel Covers with Raised Lettering. (0 replies)
  72. Porsche 914/4 & 914/6 Sachs Clutch Disc 1861.540.003 (0 replies)
  73. Porsche 914 Original Bumper (0 replies)
  74. Porsche 914 Chassis Stiffening &Tr-Arm Boxing Kit Plans (0 replies)
  75. Porsche 914 Metal Trunk Roller, Rollers - Made in USA (0 replies)
  76. 70-91 Porsche 912 914 VW 411 412 Transporter Crankshaft Seal Kit Fel Pro BS25034 (0 replies)
  77. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  78. Porsche 914 & VW Type 4 411 NOS Front Brake Discs (0 replies)
  79. Porsche 914 Fuel Pressure Regulator Kit with Gauge (0 replies)
  80. Porsche 356 911 912 914 924 928 944 964 Steering Wheel (0 replies)
  81. BREMBO 2P FRONT SOLID BRAKE DISC ROTOR 08.2436.10 70-72 PORSCHE 914 1.7L NR 1102 (0 replies)
  82. Working Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  83. Premium Quality FRONT BRAKE PAD SET D914 NR (0 replies)
  84. PORSCHE USED 914 PARTS: RIGHT SIDE HEADLIGHT SURROUND FOR 72 AND EARLIER 914 (0 replies)
  85. Intake Manifold Sleeve CRP 039133241 vw 914 1.8 2.0 set of 4 (0 replies)
  86. PORSCHE USED AFTERMARKET CONVERSION ENGINE MOUNTING BRACKET FOR 914 (0 replies)
  87. PORSCHE USED 914 PARTS: BLACK LEFT HEADLIGHT SURROUND FOR 72 AND LATER 914 (0 replies)
  88. VW Porsche 2.0 96mm x 71mm Big Bore Piston & Cylinder Kit 914 Type 4 (0 replies)
  89. CRP Radiator Hose (0 replies)
  90. Porsche 914/ VW Type 4 Stroker Crankshaft Crank (0 replies)
  91. Porsche 914 Motor Mount Brackets (0 replies)
  92. Porsche 914 Transmission Mount (0 replies)
  93. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  94. Porsche 914 engle 110 camshaft 1.7 1.8 2.0 VW Type 4 411 412 Van Cam vanagon (0 replies)
  95. VW bus Westfalia 72-79 Nos Type 4 Main bearings std case .20 crank Porsche 914 (0 replies)
  96. porsche 914 vw vanagon 411 412 type 4 performance fuel injection F.I. camshaft (0 replies)
  97. Porsche Camshaft Towers 1969-77 2.7 911 S , T, E Carrera and 1970-72 914 - 6 (0 replies)
  98. Porsche 914 Clutch Cable NEW (0 replies)
  99. Porsche 914 Clutch Cable NEW (0 replies)
  100. Porsche 914/924/924 S Reactor (0 replies)
  101. Porsche 914 plastic headlight linkage covers. LOOK! (0 replies)
  102. Porsche 914 Front Trunk Hinges LOOK! (0 replies)
  103. VW Front Crank Seal 1.7 1.8 2.0 Bus T4 Porsche 914 (0 replies)
  104. Porsche 914 Front Backing Plates LOOK! (0 replies)
  105. BING 64 CD Carburetors for Rotax 914 F/UL Engines (0 replies)
  106. Road & Track On Porsche 1979-1982 911 912 914 917 924 (0 replies)
  107. 17" PANTHER 914 FLITE 5X115 IMPALA SS CHARGER ALERO BLACK WHEELS RIMS FREE LUGS! (0 replies)
  108. Road & Track On Porsche 1968-1971 911 914 912 917 908 (0 replies)
  109. Porsche 914 & 914/6 Restorer's Guide to Authenticity (0 replies)
  110. Road & Track Porsche 1972 73 74 75 911 914 916 917 910 (0 replies)
  111. Porsche 914 fiberglass door pockets left right fiberglass unfinished (0 replies)
  112. Porsche 914 interior Carpet kit Loop charcoal New (0 replies)
  113. wheel caps for Porsche 914 fuch mahle PEDRINI Much harder to dent than OEM (0 replies)
  114. Porsche 914 front and rear trunk stops. LOOK! (0 replies)
  115. Porsche 911Turbo 914/6 Engine Crankshaft Seal Rear Flywheel 65 X 85 X 10 OEM New (0 replies)
  116. Porsche 911 914 65-77 Crankshaft Seal Flywheel 65 X 85 X 10 mm Rear OEM New (0 replies)
  117. Pagid Orange Brake Pads Fits BMW320I Porsche 914 320I Brake Conversion 4605353 (0 replies)
  118. Porsche 914 1.8 Distributor LOOK! (0 replies)
  119. Porsche : 914 Porsche 914 Porsche 914 (0 replies)
  120. MOTORCRAFT JK6-914-A Serpentine Belt/Fan Belt (0 replies)
  121. MONROE DX914 Brake Pad or Shoe, Front (0 replies)
  122. MONROE CX914 Brake Pad or Shoe, Front (0 replies)
  123. NICE ORIGINAL PORSCHE 914 914-6 DRIVERS SIDE A PILLAR TRIM BLACK (0 replies)
  124. NICE ORIGINAL PORSCHE 914 PASSENGERS SIDE A PILLAR TRIM BLACK (0 replies)
  125. CAR & DRIVER 4/73,TRIUMPH GT6,SPITFIRE,VW KARMANN GHIA,OPEL GT,PORSCHE 914,FIAT (0 replies)
  126. keyChain, leather, metal, fashion and honorable, key rings, HONEST-914 (0 replies)
  127. keyChain, leather, metal, fashion and honorable, key rings, HONEST-914 (0 replies)
  128. PORSCHE 914 Rear Trunk Gas Shock Kit (0 replies)
  129. PORSCHE 914 Inner door seals (0 replies)
  130. PORSCHE 914 Rear Trunk Seals set of 2 (0 replies)
  131. 1973 Porsche 914 1.7/2.0 Emission Control System Manual (0 replies)
  132. 2 Bucket Seat Covers Universal Fit Blue (0 replies)
  133. Porsche 911,912,914, Nardi 'Guilloche' Steering Wheel, Made In Italy, On Sale~!! (0 replies)
  134. Porsche 914 (70-72) Brake Caliper Repair Kit Front FTE OEM NEW + 1 year Warranty (0 replies)
  135. Porsche 911 914 (70-76) Transmission Clutch Cable End Boot OEM NEW + Warranty (0 replies)
  136. Porsche 914/4 70 71 8/72 Rotors Ceramic Pads (0 replies)
  137. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER LOCKS (0 replies)
  138. porsche 914 left heater box (3) (0 replies)
  139. porsche 914 left & righg heator box (0 replies)
  140. Spec Stage 4 Clutch SP914 65-69 Porsche 911 2.0L 911 T 911E (0 replies)
  141. porsche 914 left & righg heator box (0 replies)
  142. porsche 914 altinator (0 replies)
  143. porsche 914 front headlamp surrounds . used (0 replies)
  144. Porsche 914 Front Control Arm Torsion Bar Adjuster (0 replies)
  145. porsche 914 guage cluster (0 replies)
  146. Porsche 914 Hood Hinge Springs Set (0 replies)
  147. Porsche 914 Door Limiter (0 replies)
  148. 4 Porsche 911 901 914 Transmission Synchroniser & Hardware Kits (2-5th) 1965-76 (0 replies)
  149. Porsche 914 Door Limiter (0 replies)
  150. Porsche : 914 RACE CAR PORSCHE 914 RACE CAR (0 replies)
