Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 engine deck lid bumper NEW NLA part (0 replies)
  2. Porsche 914 outer window fuzzy set of 2 metal (0 replies)
  3. New Door Handle Rear Outer Driver Side Smooth black LH Left Hand Car 826072Y914 (0 replies)
  4. Porsche 914 rear trunk rubber roof holder and upper clip set (0 replies)
  5. Porsche 914 TPS Position sensor board 2.0L only (0 replies)
  6. Porsche 914 windshield to dash seal only one you can install w windshield in (0 replies)
  7. Porsche 914 Delrin clutch cable pulley + ss busing NLA (0 replies)
  8. Porsche 914 defrost vent seals set of 2 rubber (0 replies)
  9. Porsche 914 fender to cowl seal 914-559-155-10 set of 2 (0 replies)
  10. Porsche 914 Smoke front turn signal lenes set of 2 with seals (0 replies)
  11. Porsche 914 amber front side marker lenes set of 2 left and right NEW (0 replies)
  12. Porsche 914 clear front side marker lenes set Left and right (0 replies)
  13. Porsche 914 fog light seals with new rubber wire grommet to seal the housing (0 replies)
  14. Porsche 911 912 944 914 clear tail light trunk clear lens (0 replies)
  15. Porsche 911,912, 914 Bosch Super Coil 12volt, New (0 replies)
  16. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  17. New Porsche VDO Speedometer Cable Angle Drive 1970-1976 (0 replies)
  18. 914 Vw Bus Oem Oil Cooler Type 4 (0 replies)
  19. Porsche 914 911 Heater control lever knob NEW (0 replies)
  20. Porsche 914 late 1975-76 door end caps New rubber seal (0 replies)
  21. Porsche 914 rubber targa roof to window seal set of 2 (0 replies)
  22. Porsche 914 early door end caps new Rubber unlike OEM hard plastic ones (0 replies)
  23. Porsche 914 Fuse Box Cover, OEM Qlty., New, 12 Pole, Porsche 914 Fuse Box (0 replies)
  24. Porsche 914 door stay aluminum strap Sale this week only (0 replies)
  25. Porsche 914 inner door seal set left and right with aluminum clip WILL NOT RUST (0 replies)
  26. Porsche 356,911,912,914 Stainless Steel Wheel Ring Set (0 replies)
  27. Porsche 914,Turn Signal Switch/High Beam,914 '74-'75 (0 replies)
  28. Porsche 911 901 914 Transmission Shifting Guide Sleeve 90130240202 1965-71 (0 replies)
  29. 1 - Porsche 911 901 914 Transmission Synchro & Hardware Kit (2nd-5th) 1965-76 (0 replies)
  30. Porsche 911 901 914 Transmission 1st / Reverse Slider / Shift Sleeve 91130222600 (0 replies)
  31. Porsche 911 901 914 Transmission Pinion Shaft Front Bearing 99911000700 1965-76 (0 replies)
  32. 5 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  33. Porsche 911 901 914 Transmission Pinion Shaft Thrust washer 90130229401 1965-76 (0 replies)
  34. Porsche 911,912,914, Nardi 'Annie 60' Steering Wheel, On Sale~!! (0 replies)
  35. Porsche 914 & 911/911S / Carrera '74-'77 Oil Cooler, OEM Qlty, New, OEM Qlty (0 replies)
  36. Porsche 914 Speedometer Gauge (74-76 Late Model) (Refurbished) W/Glass Lens (0 replies)
  37. ABGAG903 Porsche 356 911T 911S 912 914 Original German License Plate,VW AUDI BMW (0 replies)
  38. Apex Stainless Brake Lines Hoses Hose Racing Race PORSCHE 911 912 914 Carerra (0 replies)
  39. Porsche 914 Fuch Wheel 8 Spoke Black W/Polished Lip (0 replies)
  40. PORSCHE 914 2 LITER CENTER CAPS MAHLE FUCHS (0 replies)
  41. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  42. NEW NOS Right Lower Engine Timing Chain Guide Rail Porsche 911 914 930 ON SALE (0 replies)
  43. NEW Clewett Engineering Spark Plug Wire Set Red Porsche 911 914-6 930 Turbo (0 replies)
  44. NEW Clewett Engineering Performance Spark Plug Wire Set Porsche 914 2.0L 1973-76 (0 replies)
  45. NEW NOS Front Sway Bar Hardware Adapter Kit Porsche 911 914-4 914-6 ON SALE (0 replies)
  46. New Porsche 911 914-6 356B 356C MOMO Steering Wheel Hub Race (0 replies)
  47. MOMO 8002 Porsche 914 914-4 Steering Wheel Hub NEW Race (0 replies)
  48. NEW Clewett Engineering Spark Plug Wire Set Black Porsche 911 914-6 930 Turbo (0 replies)
  49. Porsche ATE Disc Brake Caliper Repair Kits NEW QTY2 914-6 911 356 912 356SC 356C (0 replies)
  50. Genuine Porsche Engine Temperature Sender NEW 914-6 911 356C 356SC 912 (0 replies)
  51. Beru Ignition Coil Porsche Volvo VW Volkswagen BMW NEW 1602 2002 914 356 912 142 (0 replies)
  52. Porsche 914 aluminum Trunk Roller, Rollers - Made in USA (0 replies)
  53. Porsche 914 Rivierra Wheel Black With Polished Lip & Spokes or All Chrome 914 (0 replies)
  54. Porsche 914 Fuse Box Block, 12 Pole Ceramic Fuse Style, OEM , 914 '70-'76, New (0 replies)
  55. porsche 914 squeegee gusset (0 replies)
  56. porsche 914 light switch (0 replies)
  57. porsche 914 channel glass guide 1973/1976 (0 replies)
  58. Porsche 914 1.8 & 1.7 Engine Gasket Set (0 replies)
  59. Porsche 914/911 Carrera Hi Energy Blue Bosch Coil (0 replies)
  60. SACHS (NOS) KM914 Bosch 75W Ignition Coil Plate Wankel 303 Arctic Cat Panther (0 replies)
  61. Porsche 914 Transmission Gasket Set (0 replies)
  62. Porsche 914 rear trunk shoulder bolt (0 replies)
  63. Blaupunkt Becker Grundig Radio Knobs Porsche 911 912 914 356 VW BMW Mercedes (0 replies)
  64. VW Logo Radio Knobs Blaupunkt Becker 914 VW Bus Bug Beetle Thing (0 replies)
  65. Porsche 914 Steering Wheel (0 replies)
  66. Porsche 914 high and low tone horns TESTED (0 replies)
  67. VW Rabbit GOLF JETTA SCIROCCO Passat Porsche 914 Radio 80-84 (0 replies)
  68. Porsche Manuals & Brochures - 1975 914 1.8/2.0 (0 replies)
  69. Porsche Hood Crest Emblem kit 911 914 944 928 964 968 Carrera Turbo 65-94 (0 replies)
  70. Porsche 12 Engine Valve Adjuster Nuts 911 914/6 911SC Carrera 964 930 Turbo (0 replies)
  71. Porsche 1 Valve Cover Gasket Set Graphite 911 914/6 911SC Carrera 930 Turbo (0 replies)
  72. Genuine Front Door Window Weatherstrip (0 replies)
  73. PORSCHE KEYCHAIN KEYFOB 356 911 912 914 CARRERA SPEEDSTER TARGA VE BEETLE RARE  (0 replies)
  74. RALLYE SIGN PORSCHE 356 RACE MEETING NEDERLAND 550 911 912 914 917 VW BEETLE BUG (0 replies)
  75. Porsche Parts - 914 Wiper Motor And Assembly (0 replies)
  76. Used Porsche 914 2.0 1973-1974 Cylinder Head Complete With Valves & Springs (0 replies)
  77. OE Porsche USA NEW 914 2.0 Throttle Switch #0-280-120-032 (0 replies)
  78. Brand New Complete OE German Porsche 914 Axle With CV Joints (0 replies)
  79. Brand New OE German Porsche 914-4 CV Joint With Boot, Grease, and roll pins. (0 replies)
  80. Porsche 914 Turn Signal Lens set and seals (0 replies)
  81. STEERING RACK PORSCHE 911 S SC CARRERA 912 914 (0 replies)
  82. STEERING RACK PORSCHE 911 S SC CARRERA 912 914 (0 replies)
  83. Porsche 914 fuel injection repair kit (0 replies)
  84. Brake Light Switch PORSCHE 911 S CARRERA 914 (0 replies)
  85. Porsche 911 5 speed transmission trans 911/01 1970-71 Race 914 (0 replies)
  86. True Trac limited slip for GM 9.5" rear (0 replies)
  87. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  88. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 912 65-68 (0 replies)
  89. Jaguar XJ6 XJS Porsche 912 914 Volkswagen Genuine Bosch Fuel Regulator 028016020 (0 replies)
  90. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  91. Porsche 911 and 914-6 Weber Carburetors 40 ida3c (0 replies)
  92. Porsche 2 Grommets Master Cylinder Brake Reservoir Lines 356 911 914 912 930 (0 replies)
  93. New SVDA 034 Vacuum/Centrifugal Distributor: Porsche 4-cyl 356 912E 914 924, 12V (0 replies)
  94. Porsche 914 Bracket For Gauges (0 replies)
  95. Porsche 914 Oil Filter NEW (0 replies)
  96. Volkswagen Engine Full Gasket Set 1.7 Bus, 411, porsche 914 1.7 (0 replies)
  97. porsche 911/912/914 air flow control unit (0 replies)
  98. Porsche 914 Window Regulator Passenger Side (0 replies)
  99. PORSCHE 914 CUSTOM REAR DECK LID FOR WATER COOLED 914's (0 replies)
  100. PORSCHE 914 FRONT BRAKE CALIPER ***DUAL BLEEDER*** (0 replies)
  101. PORSCHE 914 FRONT BRAKE CALIPER ***SINGLE BLEEDER*** '70-'72 RIGHT (0 replies)
  102. PORSCHE 914 DASH VENTS *** EARLY SIDE VENTS *** PAIR (0 replies)
  103. PORSCHE 914 FRONT BRAKE DUST SHIELD (0 replies)
  104. Porsche 914 Hinge (0 replies)
  105. Porsche 914 Hinge (0 replies)
  106. TENSIONER GEAR PORSCHE 911 S SC TURBO CARRERA 914 930 (0 replies)
  107. 1960 Pontiac Rear Peak Mouldings NOS (0 replies)
  108. Porsche : 914 1975 914 2.0 metallic bronze loaded with options.. (0 replies)
  109. porsche 914 tail light lenses in good condition USA (0 replies)
  110. 1973 PORSCHE 914 OEM REAR BUMPER PAD (0 replies)
  111. OEM COMPLETE* FRONT SWAY BAR SYSTEM FOR PORSCHE 914 ALL YEARS AND MODELS (0 replies)
  112. OEM COMPLETE* FRONT SWAY BAR SYSTEM FOR PORSCHE 914 ALL YEARS AND MODELS (0 replies)
  113. Genuine and Original Porsche 914 FOG LIGHT. (0 replies)
  114. Genuine and Original Porsche 914 Left Rear tail light cover (0 replies)
  115. Porsche 914 916 GT Style Door Panels Black Vinyl (0 replies)
  116. Porsche 914 916 GT Style Door Panels Black Vinyl (0 replies)
  117. Porsche 914 916 GT Style Door Panels Black Vinyl (0 replies)
  118. Porsche Differential Carrier Bearing & seal set 911 912 914 924 928 69-86 (0 replies)
  119. 2 Brand New Porsche 914 Front Turn Signal Lenses (0 replies)
  120. Genuine and Original Porsche 914 Spare Wheel securing hardware (0 replies)
  121. K&N E-2381 PORSCHE 914 Replacement Air Filter (0 replies)
  122. Dodge CHALLENGER CLASSIC Graphics Stripes Decals - Pro Grade 3M Vinyl 2010 914 (0 replies)
  123. Genuine and Original Porsche 914 Fuel Tank Rubber Buffers and Retaining Strap (0 replies)
  124. COMP CAMS 1.489" DIAMETER DUAL VALVE SPRINGS 914-16 (0 replies)
  125. PORSCHE 914/6 70 71 72 ROTORS PADS FRONT (0 replies)
  126. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS PADS F&R (0 replies)
  127. GENUINE AND ORIGINAL REAR SWAY BAR CLAMPS/SUPPORTING BOW FOR 73-74 PORSCHE 914 (0 replies)
  128. Genuine and Original Porsche 914 Fuel Tank Level Sending Unit (0 replies)
  129. Porsche Targa Top Trunk Mount Support Kit 914/4 914/6 70-76 (0 replies)
  130. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  131. EXC German EURO license plate + Porsche frame 911 928 944 356 912 914 Boxster (0 replies)
  132. Porsche 914/4 Accelerator Pedal (70-75) #901.423.010.00 (0 replies)
  133. Porsche Ignition Switch Meyle 914/4 73-76 (0 replies)
  134. Porsche 917 k 24 Hours of Daytona 1970 Vinyl Banner Poster 914 917 944 928 NEW (0 replies)
  135. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  136. Porsche 4 CV Axle boots 911 912 914/4 914/6 65-76 (0 replies)
  137. Porsche Interior Light Lens Switch 914/4 914/6 (0 replies)
  138. Porsche 914-4 Fuel Pump, Electrical,Porsche 914 '74-'76 (0 replies)
  139. 4 - Porsche 911 901 914 Transmission Synchronizer Lock Rings 91130231101 1965-86 (0 replies)
  140. porsche 914 headlight surround (0 replies)
  141. Distributor Cap ALFA ROMEO AUDI BMW 2002 320i OPEL SAAB PORSCHE 914 PORSCHE 924 (0 replies)
  142. Porsche 914 Dealer Option Oil Temp Sender Drain Plate VW BUS COMPATIBLE + Type-4 (0 replies)
  143. Porsche 914 4 or 6 Front Sway Bar mounts (NEW) (0 replies)
  144. WBK914 Timing Belt Package B18C Integra GSR 1994-2001 (0 replies)
  145. SACHS (NOS) Wankel Apex Seals & Springs 2pcs KM914 303 Arctic Cat Panther (0 replies)
  146. PORSCHE LICENSE PLATE FRAME 911 914 944 996 986 BOXSTER CARRERA (0 replies)
  147. SACHS (NOS) Wankel Side Seals Set 3pcs KM914 303 Arctic Cat Panther KM24 Lynx (0 replies)
  148. original correct Porsche 914 tool kit 70 -73 (0 replies)
  149. PORSCHE 914 ORIGINAL OEM EARLY STYLE WINDOW REGULATOR ( Drivers Side ) (0 replies)
  150. PORSCHE 914 OEM ORIGINAL HELLA LICENSE PLATE / TRUNK COMPARTMENT LIGHT (0 replies)
