Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. 1972 porsche 914 ski rack (0 replies)
  2. porsche 914 parts lot (0 replies)
  3. Porsche Genuine Black Master Key 911 912 914 930 964 993 (0 replies)
  4. Type 4 Porsche 914 Vokswagen 411,VW Bus Web Cam Hydraulic Lifters and Pushrods (0 replies)
  5. Porsche 914 rear shock cover (0 replies)
  6. Fuchs wheels Porsche 911, 912, 914/6 rims 5 1/2"x14" (0 replies)
  7. Porsche 914 front turn/ marker light housing (0 replies)
  8. Porsche 914 emergency brake lever (0 replies)
  9. Porsche 914-4 1.7L Qty(2) Dish Top Pistons (0 replies)
  10. Porsche 914-4 1.7L 90MM Cylinder housing (0 replies)
  11. Porsche 914-4 1.7L 90MM Cylinder housing (0 replies)
  12. Porsche 914-4 1.7L Set of 4 Cylinder Housings (0 replies)
  13. VW Bus type 4 Porsche 914 1.7L rocker arms rocker arm assemblies PAIR (0 replies)
  14. Volkswagen bus type 4 Porsche 914 camshaft & lifters from rebuilt engine (0 replies)
  15. Porsche 914 Trunk Hinge Cup Pair of Two (2) 91450103010 (0 replies)
  16. Porsche 914 VW Bus Crankshaft rotating assembly 1.7 & 1.8 from rebuilt engine (0 replies)
  17. porsche 914 speedometer (0 replies)
  18. 3 SNAP ON LONG BALL EXTENSIONS STANDARD PFSX912 3/8 PFSX914 7/16 PFS916 9/16 (0 replies)
  19. IGNITION WIRE SET FOR PORSCHE 911 65-73,914 70-72 (0 replies)
  20. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 1.8 2.0 73-76 (0 replies)
  21. 4 incomplete Porsche 914 distributors for parts 011 001 007 & 007 (0 replies)
  22. Porsche : 914 porsche 914 (0 replies)
  23. Porsche 914 Jack Hole Plugs, Pair of Two - 91455926710 (0 replies)
  24. 97 ACURA TL HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  25. Porsche 914 86 Stunden NüRburgring 1970 Factory Poster RARE (0 replies)
  26. Porsche 911 914 914-6 Front Brake Calipers Pair USED (0 replies)
  27. Porsche 914 Fuse Box Block, 12 Pole Ceramic Fuse Style ,NOS, 914 '70-'76, New (0 replies)
  28. Porsche 914 Electric Fuel Pump, New, Never Installed, Porsche 914 1970-1974 (0 replies)
  29. Porsche 911 & 914 Engine Cooling Fan, Impeller, Genuine, New, Porsche 911 & 914 (0 replies)
  30. Porsche 914 Seat Belt, 3 Point Complete With Hardware,Pair, Porsche 914 3 Point (0 replies)
  31. 94 TOYOTA CAMRY HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  32. Porsche 914 front hood. (0 replies)
  33. 96 SEBRING HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  34. Porsche 356 Hubcap/Center Cap Remover Tool 911/912/944/914/930/VW UNIVERSAL TOOL (0 replies)
  35. Infiniti G20 & Nissan 200SX NX Sentra New Exedy Clutch Pressure Plate NSC914 * (0 replies)
  36. PMU BESTOP Front Brake Pad Impreza GDA GEE GHE GGA Legacy BE5 BH5 Outback SG9 (0 replies)
  37. porsche 914 heater control lever (0 replies)
  38. OBX Stainless Steel DYI Exhaust Header Manifold 69-76 PORSCHE 2.0L 914 H4 (0 replies)
  39. porsche 914 oil temp " taco plate" with cover. (0 replies)
  40. porsche 914 engine lid grill and emblems (0 replies)
  41. 1972 porsche 914 two outlet blower motor (0 replies)
  42. 1972 porsche 914 wiper motor (0 replies)
  43. One porsche 914 or vw 4 lug riviera rim (0 replies)
  44. 1972 porsche 914 drivers side door handle (0 replies)
  45. 01 ISUZU RODEO HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  46. porsche 914 rear trunk release (0 replies)
  47. Porsche 914 Fuel Gauge - Used 91464110240 (0 replies)
  48. porsche 914 engine lid latch (0 replies)
  49. porsche 914 front hood latches (0 replies)
  50. Porsche 914 Chassis Stiffening &Tr-Arm Boxing Kit Plans (0 replies)
  51. porsche 914 left and right chrome door handles (0 replies)
  52. Porsche 914 Metal Trunk Roller, Rollers - Made in USA (0 replies)
  53. Porsche 914 Tachometer Black Button - Used 91464130212 (0 replies)
  54. PORSCHE NOS WINDSHIELD WASHER PRESSURE CONNECTOR FOR 70-76 914 (0 replies)
  55. porsche 914 headlight motor covers set (0 replies)
  56. PORSCHE 924 CALENDAR COIN 1977 ORIGINAL MÜNZE 356 911 914 VW BEETLE KDF TARGA  (0 replies)
  57. Porsche 914 soft foam steering wheel with horn butterfly LOOK (0 replies)
  58. 03 MALIBU HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  59. 91 TOYOTA CAMRY HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  60. 09 HYUNDAI ACCENT HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  61. ORIGINAL PORSCHE 914 DRIVER SIDE HEATER HOSE for 1973-76 (0 replies)
  62. Custom Windshield SunShade for 1970-1976 Porsche 914 (0 replies)
  63. PORSCHE NOS SINGLE POLE BRAKE WARNING SWITCH FOR 914 AND 911 (0 replies)
  64. Porsche 23mm Master Cylinder High Performance URO 911 911SC 914/4 68-77 (0 replies)
  65. Porsche Brake & Clutch Pedal Pads 356 911 930 912 914 Carrera Turbo (50-98) (0 replies)
  66. 94 GALANT HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  67. Porsche 914 center console custom from Bumblebee interior (0 replies)
  68. 00 LEGANZA HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  69. TrackData RACING Checklists: PORSCHE 356, 911, 912, 914, 930, 935, 944, Boxster (0 replies)
  70. Hidden Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  71. Porsche Dr. 914 Tech Tips 700 the ultimate troubleshooting guide for Porsche 914 (0 replies)
  72. Power Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  73. 92 TOYOTA CELICA HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  74. 75 PORCSHE 914 (0 replies)
  75. 97 VILLAGER HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  76. 87 PATHFINDER HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  77. Porsche 911 914 930 Gen Engine Timing Idler Sprocket (0 replies)
  78. PORSCHE 911 914 CAMSHAFT TIMING GEAR 92-95 (0 replies)
  79. 89 NISSAN PICKUP HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  80. 95 SAAB 9000 HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  81. 89 MAZDA 626 HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  82. Porsche 914 Tachometer Gauge...Refurbished! (0 replies)
  83. Porsche 914 Tachometer Gauge 1974-76 Refurbished! Glass Lens Upgrade! (0 replies)
  84. Porsche 914 Speedometer Gauge (Refurbished) Satisfaction Guarantee! (0 replies)
  85. MONROE DX914 Brake Pad or Shoe, Front (0 replies)
  86. 92 TOYOTA COROLLA HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  87. 92 LOYALE HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  88. 92 LOYALE HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  89. 93 PATHFINDER HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  90. FUEL PUMP MG OPEL PORSCHE 911 914/6 PEUGEOT 504 RENAULT TR6 AIRTEX E8016S (0 replies)
  91. Porsche (2) Front Turn Signal Lenes 914/4 914/6 70-76 (0 replies)
  92. Porsche 914 VW Bus 1972-79 ALL VW Type 4 Alternator Fan Belt 3 lot 021 903 137A (0 replies)
  93. Porsche : 914 1970 Porsche 914 Fuchs Wheels Wide Body Custom Alluminum V8 Slant Nose 911 5 lug (0 replies)
  94. Porsche 914 924 Wheel Bearing Front Outer SKF OEM Brand New (0 replies)
  95. Porsche 914 70-76 Axle Joint Bolt 8 X 48 mm Set of 8 FEBI - POR Brand New (0 replies)
  96. Porsche 914 70-76 Axle Joint Bolt 8 X 48 mm Set of 16 FEBI - POR Brand New (0 replies)
  97. PORSCHE Front Wheel Bearing & Seal Set 911 914 924 944 (64-89) (0 replies)
  98. 96 NISSAN PICKUP HAZARD LIGHT CONTROL LAMP SWITCH INTERIOR DASH UNIT OEM (0 replies)
  99. PORSCHE 914 ENGINE LID HINGE BRACKETS ***PAIR*** (0 replies)
  100. Volkswagen Porsche Vanagon 914 - Full Gasket Set 74-83 (0 replies)
  101. Porsche 911 E L S T 1975 912 914 4 6 Accelerator Pedal (0 replies)
  102. Porsche 914 front turn signal lens reflector amber NOS in box 1970-1976 rare (0 replies)
  103. ART QUARTZ CLOCK PORSCHE 911 CARRERA BOXSTER 928 944 924 914 912 (0 replies)
  104. PORSCHE 356 911 912 914 924 CLUTCH ALIGNMENT TOOL NEW also fits VW (0 replies)
  105. Porsche 911,912,914, Nardi 'Guilloche' Steering Wheel, Made In Italy, On Sale~!! (0 replies)
  106. Porsche 914/4 8/72 73 74 75 76 Rotors Ceramic Pads (0 replies)
  107. Porsche 914/4 70 71 8/72 Rotors Ceramic Pads (0 replies)
  108. Porsche 356 911 930 914-6 Camshaft Gear 3 Lock Plates + 1 year Warranty (0 replies)
  109. Standard Ignition Door Window Switch DS-914 (0 replies)
  110. Porsche 914 '70-'76 Fuel Tank Cap, German Qlty,New,914 (0 replies)
  111. Porsche 914 4/6 Front Brake Pad Set _ FRESH STOCK pads friction liner liners (0 replies)
  112. Porsche 914 OEM Accelerator gas throttle Cable Gemo NEW (0 replies)
  113. Porsche 914 (70-76) Vent Glass Seal RIGHT ( Genuine ) (0 replies)
  114. Porsche 914 924 Wheel Bearing Front Outer L=R oem SKF (0 replies)
  115. Porsche 914-4 924 4-lug Wheel Bearing Front Outer SKF oem (0 replies)
  116. MUSTANG 3/4" REAR SWAY BAR KIT BY ADDCO MFG. 65-66 (0 replies)
  117. Mevotech Front Steering Drag Link MDS914 (0 replies)
  118. Powder Coated Porsche 914 2.0 L, VW Type 4 Beetle Bus Intake Manifolds (0 replies)
  119. Pierburg 12V fuel pump P/N: 7.21440.28 (Rotax 914) (0 replies)
  120. Hirschmann Telescopic AM FM Radio Antenna/Aerial BLACK MAST Porsche 356 914 911 (0 replies)
  121. Porsche 914-4 Bosch Complete Tune-up Kit 1.7 1.8 2.0 (0 replies)
  122. Porsche 914-4 74-76 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  123. Porsche 914-4 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  124. Porsche 914 front engine motor mount mounting bar beam (0 replies)
  125. Porsche 914 heat exchanger heater left branch piece tin channel connector (0 replies)
  126. Porsche : 914 914-6 Porsche 914-6, Recently Restored, Numbers Matching, with Porsche COA (0 replies)
  127. Porsche 914 heat exchanger heater left J pipe (0 replies)
  128. Porsche 914 heat exchanger heater right J pipe (0 replies)
  129. Porsche : 914 1972 Porsche 914, 2.0 liter update, 5 spd, Arizona car,356 (0 replies)
  130. Porsche Key Blanks Black & Red Genuine Set 911 912 914 964 930 Carrera Turbo (0 replies)
  131. Porsche 914 rear transmission tranny transaxle mount with plates and bolt (0 replies)
  132. Porsche 914 rear transmission tranny transaxle mount with plates and bolt (0 replies)
  133. SACHS (NOS) KM914 Bosch 75W Ignition Coil Plate Wankel 303 Arctic Cat Panther (0 replies)
  134. SACHS (NOS) KM914 Bosch 40W Ignition Coil Plate Wankel 303 Arctic Cat Panther (0 replies)
  135. 1973 73 Porsche 911 914 Dealer Color Chips (0 replies)
  136. PORSCHE 914 J-PIPES ***PAIR*** (0 replies)
  137. Porsche 914 nos brake warning switch NOS (0 replies)
  138. PORSCHE 914 VW EMERGENCY BRAKE HANDLE (0 replies)
  139. Porsche Hood Crest Emblem kit 911 914 944 928 964 968 Carrera Turbo 65-94 (0 replies)
  140. 00-05 BUICK LESABRE Rear Bumper Reinforcement Bar NEW (0 replies)
  141. Porsche 914 and 914-6 front stablizer links LOOK (0 replies)
  142. Porsche 911-912-914 Jack Support LOOK! (0 replies)
  143. Porsche 911,912 and 914 used accelerator pedal with linkage (0 replies)
  144. Porsche 914 front and rear trunk stops. LOOK! (0 replies)
  145. Porsche 914 oil strainer gasket set (0 replies)
  146. PORSCHE 914/6 70 71 72 BRAKE ROTORS + PADS F (0 replies)
  147. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS + PADS F/R (0 replies)
  148. Porsche 914 Fender to Cowl Seal 2 Sets of Two (4) (0 replies)
  149. Porsche 914 Body Plugs LOOK! (0 replies)
  150. Porsche 914 and 914-6 used steel outer rocker panels LOOK (0 replies)
