Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. 914 Porsche exhaust, 1.7 Heat Exchangers, 1970-1973 (0 replies)
  2. Porsche 914 Fuel Rails OEM Pair (0 replies)
  3. Porsche Graphic Vinyl Decals BLUE One Pair 2 Decals 911 912 914 928 944 (0 replies)
  4. Porsche 914 Air Filter Assembly. Powder Coated (0 replies)
  5. One used complete set of OEM Porsche 914 gold Engine Lid Letters (0 replies)
  6. Porsche 914 Instrument Cluster (0 replies)
  7. Porsche 914 Instrument Cluster (0 replies)
  8. One New OEM Porsche 914 Silver Engine Lid Letter (Pick from P O R S H) (0 replies)
  9. Porsche : 914 Convertible (0 replies)
  10. Porsche 914 glove box compartment with strap and door (0 replies)
  11. Porsche 356 911 912 914 Pedal Pad Set New Porsche OEM (0 replies)
  12. Porsche : 914 2 door targa (0 replies)
  13. NOS Porsche 914 94mm Kolbenschmidt Pistons In Original Box (0 replies)
  14. 1974 PORSCHE 914 SALES BROCHURE ORGINAL (0 replies)
  15. Porsche 914 Technical Data Specification Booklet (0 replies)
  16. PBR Metal Master Brake Pads D569M Porsche Rear 911, 914, 912 (0 replies)
  17. Porsche 914 1.7L / 1.8L Left Engine Cover 022 119 300 (0 replies)
  18. PORSCHE 914 VW TYPE IV ALTERNATOR SHROUD TIN COVER 021 119 281 (0 replies)
  19. HAYNES MANUAL FOR PORSCHE 914 (0 replies)
  20. Blaupunkt Speaker Cable Porsche 356 911 912 914 VW BMW Mercedes Alfa Bug Beetle (0 replies)
  21. Blaupunkt Speaker Cable Porsche 356 911 912 914 VW BMW Mercedes Alfa Bug Beetle (0 replies)
  22. Blaupunkt Koln Radio Porsche 911 912 914 VW Bus BMW Mercedes Ferrari Frankfurt (0 replies)
  23. Blaupunkt Radio Faceplate Porsche 911 356 914 VW Bug Bus BMW Alfa Ghia Mercedes (0 replies)
  24. VW BUS TYPE 4 PORSCHE 914 WEBER IDF DELLORTO DRLA INTAKE MANIFOLDS (0 replies)
  25. VW TYPE 4 BUS 411 412 PORSCHE 914 2.0 ALUMINUM VALVE COVERS Fuel Pump Exhaust (0 replies)
  26. VW Engine Gasket Set Volkswagen Transporter Type 2 4 1800 Porsche 914 1.8 (0 replies)
  27. Porsche 912e 914/4 Engine Push Rod Tube Set of 8 Aftermatket 021 109 335 C (0 replies)
  28. 1973 Porsche 914 rear Axl 1.7 liter (0 replies)
  29. 1973 Porsche 914 OEM Rear Coil Springs 90Lb (0 replies)
  30. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  31. Porsche 901 911 912 914 Transmission 1st Reverse Bearing Set 4pc. (0 replies)
  32. USED Genuine Porsche 911 912 914 924 930 Needle Cage Bearing for Transmission (0 replies)
  33. PORSCHE 914 COUPE SPORTS CAR REMOVEABLE ROOF TARGA TOP PARTS OR RESTORE (0 replies)
  34. Porsche 901 911 914 Transmission 5th Gear Set "ZD" 31:22 Ratio (0 replies)
  35. PORSCHE 901 911 912 914 Gear Set 3rd "N" 23:29 Ratio Transmission (0 replies)
  36. PORSCHE 911 912 914 914-6 3RD 4TH GEAR SHIFT SLEEVE (0 replies)
  37. Porsche 901 911 914 Transmission 1st Gear assembly "A" 11:34 Ratio (0 replies)
  38. PORSCHE 914 SPARK PLUG WIRE SET BREMI BRAND (0 replies)
  39. Porsche key blank like the racing 917 for 911, 914, 964, 993 (0 replies)
  40. Porsche : 914 -6 (0 replies)
  41. Porsche Timing Chain with Master Link 911 914/6 930 New Oem (0 replies)
  42. Factory Porsche 914 Tachometer - Later Style (0 replies)
  43. Porsche 356A 356B 356SC 912 914 56-76 Ignition Distributor JP GROUP DANSK (0 replies)
  44. HEXOMAT - All-Weather Heavy Duty Floor Mats - Front Mats - CUSTOM - Porsche (0 replies)
  45. Porsche 914 914-6 OEM Left Windshield Post Trim (0 replies)
  46. Porsche 914 914-6 OEM Right Passenger Windshield Post Trim (0 replies)
  47. Genuine Original Porsche 914 Seat Back 1970 1971 (0 replies)
  48. Porsche 914 2.0 engine complete (0 replies)
  49. Vintage Porsche Automobiles Wooden Shift Knob (0 replies)
  50. PORSCHE 914-4, VW, VDO Original, Oil Pressure Sending Unit, 0 - 5 bar. (0 replies)
  51. PORSCHE 914 & VW Bus 1.7- 2.0, New, Original, 0.34 mm. Fly Wheel Shim. (0 replies)
  52. Porsche 914 Fuel Rails (0 replies)
  53. Porsche : 914 Barn Find (0 replies)
  54. Porsche 356 911 912 914 944 928 embossed owners manual cover nice (0 replies)
  55. 2 NEW GENUINE PORSCHE 911 930 914-6 964 993 CAMSHAFT RETAINER PART # 93010519600 (0 replies)
  56. Porsche : 914 (0 replies)
  57. Porsche 914-6 engine tin quality reproduction (0 replies)
  58. PORSCHE 914 FUEL DISTRIBUTION LINES (0 replies)
  59. OES OE SUPPLIER Manual Transmission Synchro Sleeve 1ST-REVERSE 91130222600 (0 replies)
  60. Porsche 914 headlight (0 replies)
  61. Porsche 914 Defrost Lever -- VG Condition (0 replies)
  62. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  63. Porsche 911 912 914 924 930 944 AntiSkid Dash Panel Mat (0 replies)
  64. For VW BMW Jaguar Porsche Intank Electric Fuel Pump One Year Warranty (0 replies)
  65. Porsche 911/914-6 Plastic airbox air cleaner housing (0 replies)
  66. Porsche 914 Center Console With VDO Gauges (0 replies)
  67. Weber Progressive Carburetor 32/36 DFAV Porsche 914 Parts Rebuild Core (0 replies)
  68. VW Type 4 IV Porsche 914 Stroker Crankshaft DPR 78mm type 1 rod (0 replies)
  69. Porsche 914 914/6 Passenger Door Latch (0 replies)
  70. Porsche Shop Manual 914 1970-1976 (0 replies)
  71. Porsche 914 70-72 heads PN 021-101-371 J (10) & (11) (0 replies)
  72. PORSCHE 914 2.0 AIR FILTER BOX (0 replies)
  73. Dellorto DRLA 40 Made in Italy Carburetor & Velocity Stacks Volkswagen Porsche (0 replies)
  74. Front Bumper for a 916 GT fiberglass will fit any 1971 to 1976 Porsche 914 (0 replies)
  75. PORSCHE 924 924S 944 TURBO 951 S2 968 Screw Hole Trim Plug Used Black (0 replies)
  76. PORSCHE 924 924S 944 TURBO 951 S2 968 Screw Hole Trim Plug Used Brown (0 replies)
  77. Porsche 914 70-76 Clutch Cable COFLE Like New 914 423 401 05 (0 replies)
  78. Gearshift Knob - 5 Speed - Porsche 911 1965-1971 and 914 1970-1976 (0 replies)
  79. Porsche 911 914-6 Internal Engine Oil Thermostat 1965-1971 90110775100 (0 replies)
  80. Porsche 911 930 Chain Guide Bolts 1965-1989 Set (8) USED (0 replies)
  81. Porsche : 914 911 (0 replies)
  82. Porsche 914-6 owner manual nice reproduction of the nla original 1970 (0 replies)
  83. Porsche 914 Sail Roof Targa Trim - Center (0 replies)
  84. Porsche 914 914/6 GT 901 Racing Transmission Transaxle (0 replies)
  85. Martini Porsche 917k Vinyl Banner Poster 1971 911 914 Garage Decoration 140x60cm (0 replies)
  86. Battery Tray, For 914 PorscheĀ® , 1970-1976 (0 replies)
  87. Dual Dellorto carburetor kit for 72 and later Volkswagen van and Porsche 914 (0 replies)
  88. Porsche 914 1.7 Fuel injection parts with computer and extras (0 replies)
  89. Porsche 914 & VW Bus 1.7 - 2.0,Alternator Bracket. (0 replies)
  90. Porsche 914 & VW Bus 1.7 - 2.0,Alternator Tin. (0 replies)
  91. Porsche 914 emblem gold (0 replies)
  92. PORSCHE 914 CONTROL ARM BRACKET (LEFT) (0 replies)
  93. PORSCHE 914 SHIFTER CONNECTING TUBE '70-'72 (0 replies)
  94. PORSCHE 914 REAR TRUNK CARPET MAT (0 replies)
  95. PORSCHE 914 SEAT BELT RECEPTACLE RECEIVER (0 replies)
  96. PORSCHE 914 LOWER DASH PAD KNEE PAD OEM WITH MOUNTING HARDWARE (0 replies)
  97. Porsche Genuine OEM Targa Top Trunk Mount Support Kit 70-76, 914/4 914/6 (0 replies)
  98. Porsche : 914 PORSCHE 914 TARGA (0 replies)
  99. Porsche 914 Shifter Complete With Knob (0 replies)
  100. Porsche 914 box of lenses (0 replies)
  101. Porsche 914 1974 owners manual (0 replies)
  102. Porsche 914-6 owners manual (0 replies)
  103. Porsche 914-6 & 914 Dash Rubber Base (0 replies)
  104. Porsche 914 Heater Control Box Connector Elbows Left and Right (0 replies)
  105. Porsche 914 Heater Air Flow Branch OEM Heater Part (0 replies)
  106. Porsche 914 914-6 Interior Hella Light Gaskets! Original! No Reserve! (0 replies)
  107. Blaupunkt Radio Porsche 911 356 914 VW BMW Mercedes Volvo Ferrari Alfa Jaguar (0 replies)
  108. Blaupunkt Frankfurt Radio Porsche 911 912 914 VW Bus BMW Mercedes Volvo Ferrari (0 replies)
  109. Porsche 911 912 914 924 928 944 Ceramic Fuse Set 8-16-25 AMP NEW GERMAN (0 replies)
  110. Early Porsche 911 / 912 / 914 Horn Button 9016138050 OEM (0 replies)
  111. Porsche 914 and 914/6 "Mid-Engine Porsche" Original Brochure (0 replies)
  112. PORSCHE 911 912 914 MANUAL TRANS SYNCRO SLEEVE 1973-1976 30543005001 (0 replies)
  113. PORSCHE TRANSMISSION TRANSAXLE SYNCRO 367 901 911 914 DOG RING SYNCRO HUB (0 replies)
  114. Porsche 914 VW BUG 2.0 1.8 American Racing LeMans Wheels RIM Bug Bus (0 replies)
  115. Porsche : 914 2.0 with Appearance Group (0 replies)
  116. PORSCHE 914 FRONT TURN SIGNAL LENS OEM HELLA (0 replies)
  117. Porsche : 914 Cabriolet (0 replies)
  118. PORSCHE 914 ENGINE TIN METAL COVERS (0 replies)
  119. WORKING DRIVER SIDE HEADLIGHT MOTOR FOR PORSCHE 914 914/6 916 914-6 (0 replies)
  120. PORSCHE 914 WINDSHIELD WIPER ARMS (0 replies)
  121. Porsche 907 Targa Florio 1968 #224 Vinyl Banner Poster 911 914 Garage Decoration (0 replies)
  122. PORSCHE 914 SUN VISOR CLIPS (0 replies)
  123. PORSCHE 914-6 EUROPEAN HEADERS (0 replies)
  124. Porsche 914 injector VW (0 replies)
  125. PORSCHE 914 VACUUM LIMITER (0 replies)
  126. PORSCHE USED HORN CONTACT FOR 914,911,356 (0 replies)
  127. Porsche 911 1966 1967 1968 1969 1970 1971 1972-1998 Engine Timing Chain Iwis (0 replies)
  128. Porsche 914 Brain (0 replies)
  129. High Performance Electric Fuel Pump Install For 75-93 BMW Porsche Range Rover (0 replies)
  130. Porsche 914 914-6 Seat Rail Hardware! Bolts/Nuts/Washers! No reserve! (0 replies)
  131. Porsche 914 914-6 Misc. Parts! A Lot! No Reserve! Switch/knob Etc. (0 replies)
  132. porsche 914 sun visor clips (0 replies)
  133. 1973 Porsche 914 1.7 Liter Dual Carb setup (0 replies)
  134. Porsche 914-4 & VW Volkswagen Type 4 OEM Rocker Arm 8mm Hard to Find (0 replies)
  135. Porsche 914 instrument cluster speedometer tachometer fuel gauge (0 replies)
  136. PORSCHE 914-4 & VW Bus 1.7-2.0, Original Engine Case Studs 220 mm.L.( 2 ) (0 replies)
  137. Porsche 917k 1970 #20 JoSiffert Redman Poster Vinyl Banner 911 914 944 140x60cm (0 replies)
  138. Sunoco Porsche 914 6 GT 1971 Poster 911 914 936 944 Vinyl Banner Workshop 140x60 (0 replies)
  139. PORSCHE 914 RADIO DELETE FACE (0 replies)
  140. EMPI Dual EPC 34 Kit VW Porsche 914 Type 4 (0 replies)
  141. NEW GENUINE BOSCH 0280160001 Pressure regulator Porsche,Renault,Saab,VW,Volvo (0 replies)
  142. Porsche 914 4 Accelerator Throttle Cable 1970 - 1976 1.7L Gemo Germany OEM new (0 replies)
  143. Gear Shifter and 2 Knobs 1972 Porsche 914 (0 replies)
  144. Porsche 914 Front Right Axle Nut 131405670 KMM (0 replies)
  145. 2 UNBREAKABLE Clear License Plate SHIELD Covers + 2 Black Frames for PORSCHE (0 replies)
  146. Solex 40 P11-4 Carburetors Porsche 356 912 914 (0 replies)
  147. Porsche 911, 912, 914 Horn Button (0 replies)
  148. Porsche 914 Front Turn Signal Light Housing Buckets (0 replies)
  149. Blaupunkt Frankfurt Radio Porsche 911 912 914 VW Bus BMW Mercedes Volvo Ferrari (0 replies)
  150. Porsche 914 Windshield Wiper Motor Assembly (0 replies)
