Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 Rear Engine Inspection Lid, Trunk (0 replies)
  2. Power ANTENNA Mast - 1970 thru 1976 Porsche 914 (0 replies)
  3. MATCHBOX 1971 PORSCHE 914 MINT LOOSE (0 replies)
  4. Porsche Cyl. Head Temperature Sensor 914/4 914/6 70-76 (0 replies)
  5. Porsche 914 Engine and Trans combo (0 replies)
  6. Porsche 914 Rear Caliper Repair Kit (70-76) (0 replies)
  7. NOS Campagnolo Campy VW Volkswagen Wheel Bug Ghia 914 Not EMPI (0 replies)
  8. Wagner QuickStop Brake Pads ZX914 (0 replies)
  9. 1971 PORSCHE 914 MINT 1/64 (0 replies)
  10. Porsche 914 OEM Steering Wheel's Horn Button (0 replies)
  11. Porsche 914 OEM Steering Wheel (0 replies)
  12. PORSCHE 911 912 914 SHIFT ROD BRACKET (0 replies)
  13. PORSCHE 914 HEAT CONTROL LEVER (0 replies)
  14. Porsche 914-6, oil tank, external (0 replies)
  15. Moved: 1973 914-6 Ultimate Streetable Monster! (-- replies)
  16. Porsche 914-6, oil cooler, engine part, Behr (0 replies)
  17. Vintage Classic Old Porsche Friend Window Sticker Decal 911 912 914 356 & VW (0 replies)
  18. Porsche : 914 914 2.0 RESTORED & VERY SPECIAL MUST GO NO RESERVE (0 replies)
  19. PORSCHE 914 TYPE 4 BLOCK (0 replies)
  20. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  21. Porsche 914 Accelerator Pedal (70-75) (0 replies)
  22. Single Porsche 356 911 914 Hub Cap (0 replies)
  23. OBX Stainless Steel DYI Exhaust Header Manifold 69-76 PORSCHE 2.0L 914 H4 (0 replies)
  24. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  25. FRONT WHEEL BEARINGS 64-79 PORSCHE 356 911 924 930 914 (0 replies)
  26. PORSCHE 914 1970 1971 1972 1973 1974 1975 1976 ANTENNA (0 replies)
  27. 901 Transaxle gears 4th or 5th gear V (27:25). Porsche 914 911 912 Transmission (0 replies)
  28. PORSCHE 914 CLUTCH CABLE (0 replies)
  29. PORSCHE/VWVAN 914-4 OIL COOLER DATE 6/77 (0 replies)
  30. PORSCHE 914 3 WAY FUEL PUMP (0 replies)
  31. PORSCHE 914 SAIL FIN GRILLS (0 replies)
  32. PORSCHE 914 HEAT CONTROL BOXES (0 replies)
  33. PORSCHE 914 HEAT VENTS DASH VENTS PAIR (0 replies)
  34. porsche 914-6, 911, rear hubs, stub axles, hub bearing (0 replies)
  35. PORSCHE 911 STARTER BOSCH ORIGINAL, ALSO FITS 914 (0 replies)
  36. OIL SWITCH for ALFA AUDI PORSCHE 911 912 914 924 BMW VW (0 replies)
  37. Porsche Brake Caliper Kits Front & Rear 914/4 70-72 (0 replies)
  38. PORSCHE 914 70-76 REAR SWAY BAR 16 MM (0 replies)
  39. Porsche 914-4 Bosch Complete Tune-up Kit 1.7 1.8 2.0 (0 replies)
  40. Canton Racing Windage Tray 20-914 (0 replies)
  41. Porsche (2) Window Crank Handles 914 924 70-82 (0 replies)
  42. 91-95 Legend 4DR Clear Signal Corner/Bumper Lights Lamp (0 replies)
  43. 91-95 Legend 4DR Clear Signal Corner/Bumper Lights Lamp (0 replies)
  44. 91-95 Legend 4DR Euro Clear Bumper Lights Signal Lamps (0 replies)
  45. 91-95 Legend 4DR Euro Clear Bumper Lights Signal Lamps (0 replies)
  46. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  47. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  48. Motormite 914-016, New (0 replies)
  49. Motormite 914-015, New (0 replies)
  50. Motormite 914-014, New (0 replies)
  51. Motormite 914-013, New (0 replies)
  52. Motormite 914-011, New (0 replies)
  53. Motormite 914-012, New (0 replies)
  54. Motormite 914-010, New (0 replies)
  55. Porsche 914 Racing Style Rear Valance (0 replies)
  56. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  57. Porsche 914 Back-Up Light Switch (70-76) (0 replies)
  58. Porsche 914 914/6 Transmission 2nd Gear "F" Mainshaft (0 replies)
  59. Porsche 911 901 914 Transmission 5th Gear Set Z 29:23 (0 replies)
  60. Porsche 914 (70-76) Clutch Cable + COMPLETE mount KIT (0 replies)
  61. Porsche 914 Factory Bilstein Jack (0 replies)
  62. OEM Porsche 914 Blower Motor (0 replies)
  63. Porsche 2 Ball Joints w/Pin Front Lower 911 914 930 (0 replies)
  64. OEM Porsche 914 Blower Fan Heater Motor (0 replies)
  65. Porsche 914 later black plastic door thresholds (0 replies)
  66. Porsche 914 used speaker grill with the speakers (0 replies)
  67. Porsche 914 & V W 411 & 412 front brake rotors NEW (0 replies)
  68. Porsche 914 009 distributor & big blue Bosch ignition coil (0 replies)
  69. seat belt relay #133 919 431 Porsche 914 ghia bug (0 replies)
  70. Porsche 914 early aluminium door thresholds (0 replies)
  71. Porsche 914 Fiberglass Hood 11lbs (0 replies)
  72. PORSCHE 911 930 914 WHEEL SPACERS (0 replies)
  73. PORSCHE BB STYLING REAR REFLECTOR 911 914 ? (0 replies)
  74. Porsche 914 Interior Mirror (70-76) (0 replies)
  75. Porsche 911 914 901 Transmission Gear Set "X" 28:24 (0 replies)
  76. Porsche 911 914 Alternator W/REGULATOR 55AMP 65-66 67 68 69 70 71 72 73 74 1975 (0 replies)
  77. PORSCHE 914 1970-1972 INSTRUMENT CLUSTER (0 replies)
  78. Porsche 911/912/356 /914SHIFTER BOOT-BLACK RUBBER (0 replies)
  79. WEBER Carburetor Technical Manual Porsche 911 914/6 (0 replies)
  80. Porsche 914 INTAKE AIR BOX- 2.0 (0 replies)
  81. Posche 914 - HORN GRILLS (0 replies)
  82. NEW PORSCHE 914 1969 1970 1971 1972 1973-1976 CAR COVER PREMIUM INDOOR / OUTDOOR (0 replies)
  83. Early Porsche 911/ 901 / 914 Transmission Clutch Fork 901.116.712.00 (0 replies)
  84. Porsche 911 924 944 968 944 914 Hood Crest Emblem Badge (0 replies)
  85. PORSCHE 914 Coco Floor Mats RARE (0 replies)
  86. PORSCHE 914/4 Lower CONSOLE for Appearance Group Console (0 replies)
  87. PORSCHE 914/4 UPPER CONSOLE for Appearance Group Console (0 replies)
  88. Porsche : 914 1975 Porsche 914 (Numbers-Matching) *Great Resto/Drive* (0 replies)
  89. 02 DODGE 1500 PICKUP Alternator 136K 7604 (0 replies)
  90. BMW 633 CSi 528i 3.0 2500 2800 & Porsche 914/4 Caliper Repair Kit 24-22014 * (0 replies)
  91. Porsche : 914 GT 1973 Porsche 914-6 GT Reproduction - Ultimate Streetable Monster - Must See!! (0 replies)
  92. VW Bus Van Porsche 914 Front Brake Hose 1971-79 (PAIR) (0 replies)
  93. Panasport Minilite Wheels 6JJX14 SET OF 4 fit TVR (0 replies)
  94. Power Stop Performance Brake Upgrade Kit K914 Front (0 replies)
  95. 69-76 PORSCHE 914 H4 2.0L OBX HEADER EXHAUST MANIFOLD (0 replies)
  96. Mevotech MDS914 Drag Link (0 replies)
  97. Porsche 914 vent window seal (left side only) (0 replies)
  98. 22X8.5 CHROME MASSIV 914 CYCLONE WHEEL RIMS 5 LUG FRONT WHEEL DRIVE CARS ET38 (0 replies)
  99. USA Air Force - 914th Aero Medical Evac Squadron decal (0 replies)
  100. Porsche : 914 914 1974 914 Porsche (0 replies)
  101. LOUD Fiamm Dual Blaster Trumpet Hi/Lo Horn Set fits Classic Porsche 911 912 914 (0 replies)
  102. VERY NICE ORIGINAL PORSCHE 914 ENGINE CASE 1.7 1.8 2.0 (0 replies)
  103. EXCELLENT USED PORSCHE 911 912 914-6 TRANSMISSION CASE (0 replies)
  104. Brake Reservoir PORSCHE 911 2.4 H6 2.2 H6 2.0 H6 S SC CARRERA 914 6 930 (0 replies)
  105. 901 Transaxle gears 4th 5th gear ZD (31:22). Porsche 914 911 912 Transmission (0 replies)
  106. 901 Transaxle gears 3rd gear O (23:28). rare Porsche 914 911 912 Transmission (0 replies)
  107. Slim XENON HID KIT D2S H1 H3 H4 H7 H11 H13 9006 9007 881 893 899 9003 9145 914A0 (0 replies)
  108. PORSCHE 914 ENGINE LID GRILLE EXTENSIONS ***PAIR*** (0 replies)
  109. Porsche : 914 914/6 993 Engine, 325 hp! Fully built street-legal track car! (0 replies)
  110. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  111. VW Beetle Type II, Porsche 912 914 German Fuel Pump New (0 replies)
  112. Valve Stem Seal PORSCHE 911 914 924 928 930 944 (0 replies)
  113. 1969-1976 KYB Shock Strut Porsche 914 (0 replies)
  114. Porsche 914 Motor Mount (0 replies)
  115. Porsche 911 / 912 / 914 Heat Control Knob (0 replies)
  116. Porsche 911 / 912 / 914 Heat Control Knob (0 replies)
  117. Porsche 911 / 912 / 914 Heat Control Knob (0 replies)
  118. Porsche 914-6 GT Bumpers and Valance New Rare Vintage (0 replies)
  119. Type 4 VW bus or Porsche 914 fuel pump. New German (0 replies)
  120. Porsche 914 seats (0 replies)
  121. HOW TO RESTORE MODIFY PORSCHE 914 914/6 OUT OF PRINT (0 replies)
  122. 1970 DODGE CHALLENGER DASH CAP-WITH SPEAKER INSET/AC (0 replies)
  123. Porsche 914 Original steering wheel (0 replies)
  124. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  125. MONROE DX914 Brake Pad or Shoe, Front (0 replies)
  126. FEDERATED MD914 Brake Pad or Shoe, Front (0 replies)
  127. FEDERATED D914 Brake Pad or Shoe, Front (0 replies)
  128. PORSCHE 914 TURN SIGNAL SWITCH (0 replies)
  129. Porsche 914 audi 60 75 super 90 volkswagen beetle front wheel bearing kits nos (0 replies)
  130. porsche 914 rear trunk lid lock latch (0 replies)
  131. PORSCHE 912 914 VW TRANSPORTER FUEL PUMP BOSCH OEM NEW 72-92 (0 replies)
  132. Porsche 911 930 914 License plate Light (set 2) OEM NEW (0 replies)
  133. Porsche 914 944 931 Ignition start Switch NEW OEM (0 replies)
  134. Porsche 911 914 924 944 ROH wheels (0 replies)
  135. Porsche 914 Tail Lights Light Housing and Lens, No Reserve, 914/6 (0 replies)
  136. Porsche 914 Windshield Seal Front (Small Upper Section) (0 replies)
  137. Porsche : 914 1974 PORSCHE 914 AUTOCROSS (0 replies)
  138. Porsche 914 Parking Brake Cable LEFT OEM NEW (0 replies)
  139. Porsche 914 1972 - 1973 COLOR Wiring Diagram 11x17 (0 replies)
  140. USA Air Force - 914th Aero Medical Evac Squadron decal (0 replies)
  141. Porsche 911 901 914 Transmission 5th Gear Set ZD 31:22 (0 replies)
  142. Porsche 911 914 901Transmission "V" 4th Gear Set 27:25 (0 replies)
  143. Porsche Key Blank 911 Carrera 912 914 Steel A81M PO5 (0 replies)
  144. New Centric Parts 120.37003 Rear Premium Rotor Porsche 914/4 (0 replies)
  145. Porsche 911 914 901 Transmission "0" Gear Set 23: 28 (0 replies)
  146. LOWERING STRAPS CBR 954RR 929RR 900RR 919 CBR1100XX BLACKBIRD 1000RR 954 929 900 (0 replies)
  147. 70-76 PORSCHE 914 914-6 Oem Roof Front Latch (0 replies)
  148. Porsche 911 914 901 Transmission Gear Set "M" 29:22 (0 replies)
  149. USA Air Force - 914th Aero Medical Evac Squadron NEW (0 replies)
  150. PORSCHE 914 HEAT CONTROL AND AIR CONTROL DASH UNIT (0 replies)
