Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Bosch Electric Fuel Pump (0 replies)
  2. Porsche 914 Windshield Wiper Motor *Tested & Working* (0 replies)
  3. Porsche 911,912,914, Nardi 'Guilloche' Steering Wheel, Made In Italy, On Sale~!! (0 replies)
  4. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  5. Porsche 914 windshield to door seal holder clamping strip weatherstrip (0 replies)
  6. Porsche 914 windshield to door seal holder clamping strip weatherstrip (0 replies)
  7. 1 - Porsche 911 901 914 Transmission Synchronizer Snap Ring 91130231101 1965-86 (0 replies)
  8. PORSCHE 914 HEADLIGHT PARTS (0 replies)
  9. 70 71 72 73 74 75 76 Porsche 914 SACHS New Clutch Kit (0 replies)
  10. porsche 914 aluminum pedal board (0 replies)
  11. Vintage PORSCHE 914 1.7/2.0 Instruction Owners Manual 1973 (0 replies)
  12. Porsche 914 & 914-6 rear alignment shims (0 replies)
  13. Porsche 914 factory spare tire hold down LOOK (0 replies)
  14. Porsche 914 fog light switch great condition (0 replies)
  15. Porsche 914 ecu supporting angle (0 replies)
  16. Porsche 914 headlight switch tested LOOK (0 replies)
  17. Pace Setter Spark Plug Wire Set Various 1970 - 1983 Volkswagen Porsche 914 411 (0 replies)
  18. VW Radio Beetle Käfer Bug 411 Karmann Ghia porsche 914 (0 replies)
  19. MUSTANG 3/4" REAR SWAY BAR KIT BY ADDCO MFG. 65-66 (0 replies)
  20. PORSCHE 911/912/914 OEM ORIGINAL GAUGE & DASH LAMPS (HOLDER & BULB) (0 replies)
  21. PORSCHE 914 OEM ORGINAL 2.0 LITER AIR BOX / AIR CLEANER (0 replies)
  22. Multi Function 5 Pin Relay for Porsche 914 (1970-1976) (0 replies)
  23. VW Bus Vanagon Porsche 914 2.0 Hydraulic lifters Qty 2 Never Used Volkswagen (0 replies)
  24. VW 94mm 2.0 Type 4 Pistons & Cylinders,Bus Porsche 914 (0 replies)
  25. PORSCHE 911-912-914 OEM ORIGINAL WOODEN SHIFTER KNOB (0 replies)
  26. PORSCHE HOOD EMBLEM 914 911 (0 replies)
  27. Porsche Bump Steer Rack Spacer Kit 911 912 914 930 (0 replies)
  28. OBX Exhaust Manifold Headers 69-76 Porsche 914 2.0L H4 (0 replies)
  29. Hirschmann Telescopic AM FM Radio Antenna/Aerial BLACK MAST Porsche 356 914 911 (0 replies)
  30. porsche 914 mahle wheels (0 replies)
  31. PORSCHE 914 RUBBER BUMPER MOUNTS (0 replies)
  32. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  33. Porsche Oil Pressure Sender 911 914 E L S T 6 65-73 65 (0 replies)
  34. Porsche 914/914-6 Original Odeometer Reset Cable and Dial (0 replies)
  35. High Torque Starter for Porsche 914 (1970-1976) (0 replies)
  36. PORSCHE 914 INTERIOR DOOR HANDLE (LEFT) (0 replies)
  37. Porsche 911 912 914 901 Transmission Clutch Fork (0 replies)
  38. Alternator V Belt, Porsche 911/914-6/930 (65-89) (0 replies)
  39. Porsche 914 2.0 stainless heat exch and heater pipes (0 replies)
  40. Gemo Parking Brake Cable (0 replies)
  41. 12 Porsche 914 gauges speedometer tachometer gas fuel temperature 1970-76 (0 replies)
  42. PORSCHE 914 TRUNK HINGE CUP REPLACEMENT KIT (0 replies)
  43. Porsche 911 912 914 930 Turbo fuel tank sender level sending unit 1965-89 (0 replies)
  44. OE Genuine Porsche USA NEW 914 2.0 Throttle Switch (0 replies)
  45. Used Porsche 914 2.0 1973-1974 Cylinder Head Complete With Valves & Springs (0 replies)
  46. PORSCHE ASHTRAY 911 912 356 917 904 914 922 924 928 944 968 VW KÄFER BEETLE BENZ (0 replies)
  47. PORSCHE 914 FRONT BUMPER RUBBER (0 replies)
  48. porsche 914 original fog light bumper grilles (0 replies)
  49. porsche 914 AIR BOX WET OIL BATH (0 replies)
  50. porsche 914 GLOVE BOX LID (0 replies)
  51. PORSCHE 914 SEAT BELT RECEPTICLES (0 replies)
  52. porsche 914 DISTRIBUTOR WITH POINTS (0 replies)
  53. porsche 914 AIR BOX DRY (0 replies)
  54. PORSCHE 914 SAIL FIN GRILLS (0 replies)
  55. PORSCHE 914 HEAT CONTROL BOXES (0 replies)
  56. porsche 914 HEAT DUCTS OFF HEAT EXCHANGER (0 replies)
  57. PORSCHE 914 3 WAY FUEL PUMP (0 replies)
  58. porsche 914 FUEL INJECTION WIRE HARNESS AND BRAIN (0 replies)
  59. porsche 914 fuel injection system (0 replies)
  60. PORSCHE 914 CDI ECU BOSCH COMPUTER BRAIN BOX (0 replies)
  61. porsche 914 back bumper (0 replies)
  62. Dorman (OE Solutions) 603-914 Power Steering Reservoir (0 replies)
  63. OBX HEADER EXHAUST MANIFOLD 69-76 PORSCHE 914 H4 2.0L (0 replies)
  64. PORSCHE WHEELs RIMS EMBLEMS DECALS 356 911 928 914 924 944 912 speedster 17 18 (0 replies)
  65. PORSCHE WHEELs RIMS EMBLEMS DECALS 356 911 928 914 924 944 912 speedster 17 18 (0 replies)
  66. Porsche 944 914 911 telephone dial wheel set nice used 15x7 (0 replies)
  67. ATE AT914 Front Disc Pads (0 replies)
  68. 2 Brand New Porsche 914 Front Turn Signal Lenses (0 replies)
  69. Thule Thule 914XT Roadway 4 Bike Receiver Hitch Rack: | Fedex Free Shipping (0 replies)
  70. ATK 406 WP Rear Shock 4861 Super Trax ATK914TLA 14.25" (0 replies)
  71. Iltis VDO Oil Pressure Sensor F/DIESEL ONLY New (0 replies)
  72. PORSCHE 914 1969-1976 CAR COVER *POLYESTER* (0 replies)
  73. Porsche 911 912 914 Brake pressure warning Switch for braking light (0 replies)
  74. Porsche 911 912 914 Brake pressure warning Switch for braking light master (0 replies)
  75. Porsche 911T 914/6 OEM Ignition Distributor Rotor BOSCH (0 replies)
  76. AM Radio iPod MP3 Adapter fits PORSCHE 356 911 912 914 Adapts Blaupunkt & Becker (0 replies)
  77. NOS Porsche 914 Haneline Engine Turned Stainless Steel Throttle Plate (0 replies)
  78. Porsche 911 930 914 6 Momo Sparco New Alloy Aluminum seat mount rails - Black (0 replies)
  79. Momo Sparco New OMP Alloy Aluminum race seat mount rails - Black 911 930 914-6 (0 replies)
  80. PORSCHE 914 WINDOW VENT CAP (0 replies)
  81. PORSCHE 914 REAR TRUNK CARPET ***GOOD CONDITION *** (0 replies)
  82. Porsche 914 1.7 1.8 2.0 Valve Cover Gasket Set - New (0 replies)
  83. PORSCHE 944 911 912 928 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  84. PORSCHE 944 911 912 928 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  85. WEBER Carburetor Technical Manual Porsche 911 914/6 (0 replies)
  86. Porsche 911 901 914 Transmission 1st / Reverse Slider / Shift Sleeve 91130222600 (0 replies)
  87. 2 - Porsche 911 901 914 Transmission Synchronizer Lock Rings 91130231101 1965-86 (0 replies)
  88. 5- Porsche 911 901 914 Transmission Shafts Needle Bearings & Bushings 1965-76 (0 replies)
  89. Porsche 911 901 914 Transmission 1st Gear Synchro & Hardware Kit 1965-76 (0 replies)
  90. 1 Porsche 911 901 914 Transmission Synchroniser & Hardware Kit (2nd-5th) 1965-76 (0 replies)
  91. 2 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  92. Porsche 914 front strut shock absorber spindle (0 replies)
  93. Porsche 914 front strut shock absorber spindle (0 replies)
  94. Porsche 914 front suspension support rack pinion beam (0 replies)
  95. Porsche 914 911 912 front left side control A arm (0 replies)
  96. Porsche 914 911 912 front right side control A arm (0 replies)
  97. PORSCHE 944 951 924 911 928 914 OEM LUG NUTS SET OF 5 (0 replies)
  98. PORSCHE 944 951 924 911 928 914 OEM LUG NUTS SET OF 5 (0 replies)
  99. "RARE" Porsche 901 911 914 Transmission "N" 23:29 "Close Ratio" 3rd Gear Set (0 replies)
  100. PORSCHE 256 911 912 914 VW fuchs 14 x5.5 SET (0 replies)
  101. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  102. 1968 PORSCHE 911L 911 t SOFT WINDOW TARGA REAR STUB ALXE ASSy. 1970 914-6 914 6 (0 replies)
  103. SPARCO Steering Wheel with Porsche 914 Hub (0 replies)
  104. Porsche 911 912 914 Speedometer (0 replies)
  105. Porsche 914 Transmission Gasket Set, 1.7/1.8/2.0 (1970-76), 914-6 (1970-72), (0 replies)
  106. Porsche 911 930 Oil Temp-Pressure Guage 914-6 (0 replies)
  107. Porsche 914 2.0L EURO Pistons and Cylinders (0 replies)
  108. Porsche 914 2.0L Crank and Rods (0 replies)
  109. Porsche 911 914-6 Tachometer (0 replies)
  110. PORSCHE 911 912 912E 914 930 ACCELERATOR PEDAL ROD (0 replies)
  111. PORSCHE 914 SEAT BELT LOCK (0 replies)
  112. PORSCHE 914 SEAT BELT LOCKS (0 replies)
  113. PORSCHE 914 TURN SIGNAL HOUSING (0 replies)
  114. PORSCHE 914 DASH VENTS *** EARLY SIDE VENTS *** PAIR (0 replies)
  115. PORSCHE 911 SC FRONT WHEEL ASSEMBLY 914 5 lug conversion (0 replies)
  116. 1970 PORSCHE 914/917-AD/PICTURE/PRINT 68 69 928 TARGA 926 911 TARGA MID ENGINE (0 replies)
  117. PORSCHE 914 70-76 REAR SWAY BAR 16 MM (0 replies)
  118. Porsche 914 914-6 912 911 rear tow hook (0 replies)
  119. Porsche 914 targa rubber roof seal right and left - 2 (0 replies)
  120. VW Beetle Gia Porche 914 Minlite Racing 14x5.5 Wheels Rims 4x130mm (0 replies)
  121. Porsche 914 engine seal set of all 4 seals (0 replies)
  122. Porsche 914 windshield to dash seal 914.552.263.10 NLA no need to remove glass (0 replies)
  123. Porsche 914 TPS Position sensor board 2.0L only (0 replies)
  124. Porsche 914 fender to cowl seal 914-559-155-10 set of 2 (0 replies)
  125. Porsche 914 911 Heater control lever knob NEW (0 replies)
  126. Porsche 914 Throttle body gaskets NLA stock 1.7 intake (0 replies)
  127. Porsche 914 outer window fuzzy set of 2 metal ON SALE (0 replies)
  128. Porsche 914 engine deck lid release cable knob base NEW (0 replies)
  129. Porsche 914 rear targa seal rubber on roof at back (0 replies)
  130. Porsche 914 911 visor clips set of all 3 stainless pins (0 replies)
  131. Porsche 911 912 914 GT door pull set brand new neat item (0 replies)
  132. Porsche 914 911 912 stearing pan seal set of 2 seals NLA OEM (0 replies)
  133. wheel caps for Porsche 914 fuch mahle PEDRINI (0 replies)
  134. Porsche 914 six 914-6 factory engine number 645356 found at last! (0 replies)
  135. Porsche 914 911 914-6 new reproduction factory driving fog lens set great news! (0 replies)
  136. Porsche 914 targa roof to window seal set of 2 (0 replies)
  137. Porsche 914 engine seal set of all 4 seals (0 replies)
  138. Porsche 914 fog light seal set of 2 (0 replies)
  139. Porsche 914 door handle rubber isolators L/ R- 4 pcs (0 replies)
  140. Porsche 914 rubber accelerator foot pedal new 911 (0 replies)
  141. Porsche 914 rear trunk spring rollers New set of 2 (0 replies)
  142. Blaupunkt Frankfurt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  143. Porsche 914 defrost vent seals set of 2 rubber (0 replies)
  144. Porsche 914 rubber front turn signal seal gaskets NEW (0 replies)
  145. Porsche 914 Rear deck lid seal glass to engine lid (0 replies)
  146. Porsche 914 door lock bushing NLA set (2) improved (0 replies)
  147. Porsche 914 suspension articulated rear strut bushings (0 replies)
  148. Blaupunkt Mannheim AM/FM 12/6 Volt Radio Porsche 911 356 VW 914 Bug Bus Jaguar (0 replies)
  149. Porsche 914 rear trunk spring retainer lock pin (0 replies)
  150. Porsche 914 seat adjuster handle unbreakable (0 replies)
