Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367
  1. 914 Porsche Side Shifter Transmission, very good cond. (0 replies)
  2. T15 Wedge Super Red 5 LED Back/Stop Light Bulbs 915 (0 replies)
  3. How To Rebuild Your Volkswagen / Porsche Air Cooled Engine & Porsche 914 Engine (0 replies)
  4. Porsche 914-6 Winner 24 Hrs of LeMans Factory Racing Poster (0 replies)
  5. 1971, 1972 Porsche 914 Doors (0 replies)
  6. Porsche Cylinder Head Temperature Sensor 914/4 914/6 70-76 (0 replies)
  7. Porsche 914 Drivers side sun visor in excelant condition (0 replies)
  8. Porsche 914 Drivers side sun visor in perfect condition (0 replies)
  9. VW BUS PORSCHE 914 215MM CLUTCH DISC (0 replies)
  10. PORSCHE 914 DOOR LOCK CATCH BRACKET LH OEM (0 replies)
  11. 1969-1976 KYB Shock Strut Porsche 914 (0 replies)
  12. Porsche Brake Caliper Repair Kits Rear 914/4 (70-76) (0 replies)
  13. 901 Transaxle gears 4th or 5th gear V (27:25). Porsche 914 911 912 Transmission (0 replies)
  14. Porsche 914 VDO Fuel gauge (0 replies)
  15. Porsche 914-4 clutch cable (0 replies)
  16. Hawk F&R HP Plus Brake Pads, 1970-1972 Porsche 914 6 (0 replies)
  17. OEM Porsche 914 Emblem Insignia Logo Black 1970-1976 (0 replies)
  18. Hawk F&R HPS Brake Pads, 1970-1972 Porsche 914 6 (0 replies)
  19. Volkswagen : Bus/Vanagon Volkswagon Bus, REBULT PORSCHE 914 ENGINE 24,817K MILES (0 replies)
  20. PORSCHE 914 TARGA TOP LATCH LEVERS LOCK HANDLES OEM PAIR (0 replies)
  21. PORSCHE 914 MANUAL CRANK WINDOW REGULATOR OEM LH (0 replies)
  22. PORSCHE 914 WINDSHIELD WASHER BOTTLE RESERVOIR TANK OEM (0 replies)
  23. PORSCHE 914 BRAKE FLUID RESERVOIR CONTAINER WITH CAP OEM (0 replies)
  24. Porsche 914-6 GT Oil Console Spacer New Rare Vintage (0 replies)
  25. Porsche 914-6 GT Bumpers and Valance New Rare Vintage (0 replies)
  26. Porsche 911 / 912 / 914 Rubber Brake Hose Rear NEW (0 replies)
  27. Porsche 914 used clutch disc and pressure plate (0 replies)
  28. Pilot Red Anodized License Plate Frame Bolts WL-914R (0 replies)
  29. Xenon White 5 LED T15 Wedge Light Bulb x2 12256 904 909 (0 replies)
  30. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 Boxster Carrera 996 (0 replies)
  31. Vintage Classic Old Porsche Friend Window Sticker Decal 911 912 914 356 & VW (0 replies)
  32. Porsche 914 Engine Gasket Set 1.7L 021198009B (0 replies)
  33. 5 LED T15 912 921 White Backup Reverse Light Bulbs 2pcs (0 replies)
  34. Porsche 912E 1976 1977 & 914 1970-1974 New Intake Manifold Gaskets 70-23083,28E (0 replies)
  35. Porsche 912 E 914 914 4 FRONT CRANKSHAFT SEAL (0 replies)
  36. Porsche (2) Window Crank Handles 914/4 914/6 924 70-82 (0 replies)
  37. Porsche 911 SC Carrera 930 914 steering universal joint (0 replies)
  38. Boge Front Strut Insert (0 replies)
  39. Porsche Gauge Clock 914 2.0L 1973-1976 WORKING Horloge Uhr Orologio VDO Kienzle (0 replies)
  40. Porsche 914 blower motor (0 replies)
  41. Porsche 914 seat (0 replies)
  42. 1973 PORSCHE 914 SERIES SERVICE AND REPAIR HANDBOOK BY CLYMER (0 replies)
  43. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  44. NEW!-Stainless Steel Heat Exchangers Porsche 914-4 from SSI - NEW! (0 replies)
  45. COMP Cams Valve Springs Dual 1.489" OD 367 lbs./in. Rate 1.110" Coil Bind (0 replies)
  46. Porsche 911,912, 914 Bosch Super Coil 12volt, New (0 replies)
  47. 401914 Chrome Fuel Tank Door Cover (Black Accents) 914 (0 replies)
  48. 400914 Chrome Fuel Tank Door Cover (Black Accents) 914 (0 replies)
  49. Porsche 914 Wiper/Washer Switch/Column 914 '74-'75,New (0 replies)
  50. Porsche 914 clear front turn signal lens 1 (0 replies)
  51. Porsche VDO Windshield Washer Pump 911 914 Carrera 928 930 65-89 (0 replies)
  52. Porsche 914-4 Fuel Pump, Electrical,Porsche 914 '74-'76 (0 replies)
  53. Porsche 914 Fuch Wheel 8 Spoke Black W/Polished Lip (0 replies)
  54. Porsche 911,912,914, Nardi 'Annie 60' Steering Wheel, On Sale~!! (0 replies)
  55. Porsche 356 911 912 914 924 928 944 964 Steering Wheel (0 replies)
  56. Porsche Ignition Switch Meyle 914/4 73-76 (0 replies)
  57. Original Porsche 914 Brown Center Cushion. (0 replies)
  58. Porsche 914/4 Workshop Maintenance & Repair Manual by Drake Publishers (0 replies)
  59. NEW OLD STOCK PORSCHE 914 WARM AIR ELBOW (0 replies)
  60. 2 Bulbs T15 Wedge Super Red 5 LED Light 917 922 939 (0 replies)
  61. PORSCHE Genuine Key Set Leather Fob 911 912 914 924 930 964 Carrera Turbo 70-97 (0 replies)
  62. Nos Bosch 0 190 600 017 Voltage Regulator Volkswagen Beetle & Ghia 914 911 (0 replies)
  63. 2 x Super White Backup Light 5 LED T15 Bulbs 921 912 (0 replies)
  64. Spec Stage 4 Performance Clutch SE914 01-04 Mercedes SLK320 3.2L (0 replies)
  65. Porsche 914 front disc brake shields covers guards (0 replies)
  66. VW Type4 Porsche 914 .STD/.STD Steel Back Main Bearings (0 replies)
  67. Tyre Tire Valve Stem Caps Air Dust Covers+Tool Wrench Modified Porsche Auto 5pcs (0 replies)
  68. PORSCHE Front Wheel Bearings Inner, Outer & Seal Set 911 914 924 944 (0 replies)
  69. 2 x T15 Wedge Super White 5 LED Light Bulb 12256 12961 (0 replies)
  70. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  71. 80's Porsche 911 914 Radio VW Scirocco GOLF (0 replies)
  72. Porsche Tyre Tire Stem Valve Air Cap Anti-Theft Locking (0 replies)
  73. Fuel Tank SENDING Unit GENUINE Porsche VDO (sender for fuel guage) fits 911 930 (0 replies)
  74. NEW MOOG DS914 STEERING DRAG LINK DODGE PLYMOUTH (0 replies)
  75. T15 Wedge Xenon White 5 LED Light Bulb x2 908 909 912 (0 replies)
  76. ART QUARTZ CLOCK PORSCHE 911 CARRERA BOXSTER 928 944 924 914 912 (0 replies)
  77. Porsche 914 Interior Seat Back pad (0 replies)
  78. Porsche 914 radio face plate (0 replies)
  79. Porsche 914 Throttle Switch (0 replies)
  80. Xenon White 5 LED T15 Wedge Light Bulb x2 901 904 906 (0 replies)
  81. 1/4" Drive Standard Metric Impact Socket - 14mm GRE914UMS BRAND NEW! (0 replies)
  82. Porsche (2) Window Crank Handles 914/4 914/6 924 70-82 (0 replies)
  83. Porsche 911 & 914 Engine Cooling Fan, Impeller, Genuine, New, Porsche 911 & 914 (0 replies)
  84. Porsche Genuine Black Master Key 911 912 914 930 964 993 (0 replies)
  85. Genuine Front Door Window Weatherstrip (0 replies)
  86. PORSCHE 901 911 912 914 930 S T E RS Hood Badge Ornament Emblem ORANGE (0 replies)
  87. 22X8.5 CHROME MASSIV 914 CYCLONE WHEEL RIMS 5 LUG FRONT WHEEL DRIVE CARS ET38 (0 replies)
  88. Porsche 914 tailshift transmission (0 replies)
  89. Porsche 914-6 GT Koni Dual Adjustable Racing Rear Shock New NLA Rare (0 replies)
  90. Screwdriver DBGM Original Porsche 914 Tool Bag Box toolkit Targa 911 rare (0 replies)
  91. Porsche 914 & VW Transporter 412 Fuel Injection Cold Start Valve 0.280.170.026 * (0 replies)
  92. HiFlo Oil Filter 2003 HONDA CBR600F 600 HF-204C (0 replies)
  93. HiFlo Oil Filter 2000 HONDA VFR800F INTERCEPTOR 800 HF-303 (0 replies)
  94. HiFlo Oil Filter 2000 HONDA VFR800F INTERCEPTOR 800 HF-303C (0 replies)
  95. Porsche 914 4 cylinder type IV air filter cleaner housing base bottom VW (0 replies)
  96. Porsche Gauge 912 914 1970-76 Fuel Tank Oil VDO Jauge a Essence a Huile Tankuhr (0 replies)
  97. OBX Stainless Steel DYI Exhaust Header Manifold 69-76 PORSCHE 2.0L 914 H4 (0 replies)
  98. Porsche Early 914 Door Window Glass - Tinted - Left (0 replies)
  99. PORSCHE USED MONZA EXHAUST SYSTEM FOR 74-76 914 (0 replies)
  100. Porsche 2 Rear Brake Caliper Repair Kits 914/4 (70-76) (0 replies)
  101. Distributor Cap ALFA ROMEO AUDI BMW 2002 320i OPEL SAAB PORSCHE 914 PORSCHE 924 (0 replies)
  102. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 1.8 2.0 73-76 (0 replies)
  103. 1970-76 - PORSCHE 914 PARTS & ACCESSORIES BOOK BY AUTOATLANTIA-200 PAGES (0 replies)
  104. 1970-1976 Porsche 914 New Green Shade Band Windshields Still Only $205 For 2012 (0 replies)
  105. Porsche 914 Brake Cable Part #91442455201 (0 replies)
  106. DAYCO 71289 Upper Radiator Hose (0 replies)
  107. Arctic Cat Silver Right A-Arm & Spindle Set 2009-2012 F TZ1 Z1 Bearcat, 2703-372 (0 replies)
  108. PORSCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  109. Genuine Water Pump O-Ring (0 replies)
  110. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Mercedes BMW 2002 (0 replies)
  111. Porsche Key Blanks Black & Red Genuine Set 911 912 914 964 930 Carrera Turbo (0 replies)
  112. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  113. Porsche Euro-Spec Clear/Amber Front Turn Signal Park Lens set Hella 914/4 914/6 (0 replies)
  114. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER LOCKS (0 replies)
  115. Porsche 914/4 8/72 73 74 75 76 Rotors Ceramic Pads (0 replies)
  116. Porsche 914/4 70 71 8/72 Rotors Ceramic Pads (0 replies)
  117. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  118. [Front+Rear Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  119. [Front+Rear Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  120. [Front+Rear Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  121. Porsche Bump Steer Rack Spacer Kit 911 914 930 Carrera Turbo (73-89) (0 replies)
  122. WBK914 Timing Belt Package B18C Integra GSR 1994-2001 (0 replies)
  123. [Front+Rear Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  124. [Front+Rear Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  125. [Front+Rear Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  126. [Front+Rear Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  127. [Front+Rear Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  128. [Front+Rear Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  129. 1973 Porsche 914 Rebuilt Cylinder Heads 1.7 Liter Engine (0 replies)
  130. [Front Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  131. [Front Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  132. [Front Kit] Cross Drilled Zinc Plated Performance Brake Rotors Ceramic Pads (0 replies)
  133. [Front Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  134. [Front Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  135. [Front Kit] Cross Drilled Zinc Plated Brake Rotors Imego Ceramic Pads (0 replies)
  136. SACHS (NOS) KM914 Side Springs Set 6pcs Wankel 303 Arctic Cat Panther Skiroule (0 replies)
  137. [Front Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  138. [Front Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  139. [Front Kit] Cross Drilled Gold Zinc Performance Brake Rotors Ceramic Pads (0 replies)
  140. [Front Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  141. [Front Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  142. [Front Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  143. [Front + Rear Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  144. Porsche 914 Dual Weber 44IDF Carb.Kit W/Air Cleaner,New (0 replies)
  145. Porsche 914 Fuse Box & Cover Kit NOS Box & W/Correct Symbol Cover,914 '70-'76 (0 replies)
  146. [Front + Rear Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  147. [Front + Rear Kit] Cross Drilled Gold Zinc Brake Rotors Imego Ceramic Pads (0 replies)
  148. Porsche Key Blanks Black & Red Genuine Set 911 912 914 964 930 Carrera Turbo (0 replies)
  149. SACHS (NOS) KM914 Bosch 40W Ignition Coil Plate Wankel 303 Arctic Cat Panther (0 replies)
  150. SACHS (NOS) KM914 Bosch 75W Ignition Coil Plate Wankel 303 Arctic Cat Panther (0 replies)
Invision Power Board © 2001-2013 Invision Power Services, Inc.
