Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. NOS Porsche 914 94mm Kolbenschmidt Pistons In Original Box (0 replies)
  2. porsche 914 heater ducting (0 replies)
  3. Porsche 911 Gear shifter for 915 Trans 911c 914 (0 replies)
  4. Porsche 914 headlight (0 replies)
  5. Blaupunkt Frankfurt Radio Porsche 911 912 914 VW Bus BMW Mercedes Volvo Ferrari (0 replies)
  6. Blaupunkt Frankfurt Radio Porsche 911 912 914 VW Bus BMW Mercedes Volvo Ferrari (0 replies)
  7. Blaupunkt Frankfurt "X" Series Radio Porsche 911 912 914 VW BMW Mercedes Ferrari (0 replies)
  8. Blaupunkt Radio Porsche 911 356 914 VW BMW Mercedes Volvo Ferrari Alfa Jaguar (0 replies)
  9. Porsche 911 912 914 928 944 930 964 993 Ignition Starter Switch (0 replies)
  10. Porsche 914 rear transmission cover use for linkage conversion (0 replies)
  11. 70-76 Porsche 914 Clutch Cable Bracket And Pulley (0 replies)
  12. Porsche 914 OEM Clutch Release Fork 914 Ā #901.116.712.00 and Bearing (0 replies)
  13. PORSCHE 924 924S 944 TURBO 951 S2 968 Screw Hole Trim Plug Used Brown (0 replies)
  14. PORSCHE 924 924S 944 TURBO 951 S2 968 Screw Hole Trim Plug Used Black (0 replies)
  15. Vintage Porsche Automobiles Grille Mounting Part (0 replies)
  16. Gearshift Knob - 5 Speed - Porsche 911 1965-1971 and 914 1970-1976 (0 replies)
  17. Porsche 914 wiper wish part (0 replies)
  18. Porsche 914 Solid Transmission Mount (0 replies)
  19. Porsche 914 Exhaust Manifolds Pipe (0 replies)
  20. VW BUS TYPE 4 PORSCHE 914 WEBER IDF DELLORTO DRLA INTAKE MANIFOLDS (0 replies)
  21. Porsche 914 Heat Exchanger (0 replies)
  22. Front Bumper for a 916 GT fiberglass will fit any 1971 to 1976 Porsche 914 (0 replies)
  23. Porsche 914 70-76 Clutch Cable COFLE Like New 914 423 401 05 (0 replies)
  24. Porsche set of four 911 914-6 factory velocity stack for weber carbs Nice Parts! (0 replies)
  25. Dual Dellorto carburetor kit for 72 and later Volkswagen van and Porsche 914 (0 replies)
  26. Porsche 914 4/6 Speedometer Angle Drive on Transmission (0 replies)
  27. Porsche 914 Tachometer 1974-76 (Restored) (0 replies)
  28. Porsche 914 & VW Bus 1.7 - 2.0,Alternator Bracket. (0 replies)
  29. Porsche 914 & VW Bus 1.7 - 2.0,Alternator Tin. (0 replies)
  30. ANCO WIPER BLADES # 833 ANTI WIND LIFT FOR 66-77 PORSCHE 911-912-914 (0 replies)
  31. Porsche : 914 1911 Type 4 Engine (0 replies)
  32. Porsche 917k 1970 Siffert Redman Poster Vinyl Banner 911 914 944 928 140x60cm (0 replies)
  33. Porsche 914 1.7/2.0 Owner's Manual Model '73 (0 replies)
  34. Porsche 914 speedometer (0 replies)
  35. New SVDA 034 Vacuum/Centrifugal Distributor for Porsche 4-cyl 356 914 12V (0 replies)
  36. Vintage Porsche Automobiles Wooden Shift Knob (0 replies)
  37. For VW BMW Jaguar Porsche Intank Electric Fuel Pump One Year Warranty (0 replies)
  38. Front wheel bearing seals Qty 2 pair Porsche 914 924 1970-1982 311405641b 1195 (0 replies)
  39. SVDA Replacement Electronic Distributor for VW Type IV 4 Bus, Porsche 912, 914 (0 replies)
  40. High Performance Electric Fuel Pump Install For 75-93 BMW Porsche Range Rover (0 replies)
  41. Porsche 914 Ashtray - Very Good Condition (0 replies)
  42. Porsche 914/6 Relay Board with Cover -Excellent. (0 replies)
  43. Early Porsche 911 / 912 / 914 Horn Button 9016138050 OEM (0 replies)
  44. Porsche : 914 Race (0 replies)
  45. Porsche 914, 912E, VW Cam Kit (0 replies)
  46. Porsche 914 air intake pipe 022.133.211A + 15 intake gasket + 1 intake shim (0 replies)
  47. Connecting rod porsche 914 1.8L (set of 3) (0 replies)
  48. Porsche 914 Tech Tips 700 George A Hussey handbook manual (0 replies)
  49. How to Rebuild Your Volkswagen Air Cooled Engine Type 3 4 Porsche 914 Bug Ghia (0 replies)
  50. How to Restore And Modify Your Porsche 914 & 914/6 Patrick Paternie porshe (0 replies)
  51. Porsche 914 Sail Roof Targa Trim - 3 Pieces (0 replies)
  52. Porsche 914/4 914/6 Handbook Lash international 914 Manual (0 replies)
  53. Porsche 914 repair manual 1969 - 1976 (0 replies)
  54. Porsche 914 Koni 82-1722 82K-1722 Rear Shocks Strut with Springs (0 replies)
  55. Porsche 914 Black Ash Tray Ashtray Good Condition (0 replies)
  56. Porsche : 914 front spoiler (0 replies)
  57. 1973 PORSCHE 914 OEM WINDSHIELD WIPER ARMS 1973-1976 (0 replies)
  58. 1973 Porsche 914 1.7 Liter Dual Carb setup (0 replies)
  59. Martini Porsche 917 Sebring 1971 #3 Poster Vinyl Banner 911 914 944 928 140x60cm (0 replies)
  60. Porsche 917k 1970 #20 JoSiffert Redman Poster Vinyl Banner 911 914 944 140x60cm (0 replies)
  61. Sunoco Porsche 914 6 GT 1971 Poster 911 914 936 944 Vinyl Banner Workshop 140x60 (0 replies)
  62. porsche 914 mirror (0 replies)
  63. Porsche : 914 Black (0 replies)
  64. Vintage Original Porsche Automobiles Leather Shift Knob (0 replies)
  65. Porsche/Bosch Rear Reflector Kit 911 914 P/N0315201002 Mint Genuine OEM Rare! (0 replies)
  66. FUCHS WHEEL 14 INCH 14" PORSCHE 911 914 5X130 GERMAN (0 replies)
  67. Porsche 911 01-05 Turbocharger Passenger Right Side Borg Warner 996 123 914 (0 replies)
  68. PORSCHE 914 GOLD COLOR REAR TAIL PANEL EMBLEM SCRIPT VINTAGE ORIGINAL (0 replies)
  69. Porsche 914 New Original Drivers Door Panel. (0 replies)
  70. VW Engine Gasket Set Volkswagen Transporter Type 2 4 1800 Porsche 914 1.8 (0 replies)
  71. VW TYPE 4 BUS 411 412 PORSCHE 914 2.0 ALUMINUM VALVE COVERS Fuel Pump Exhaust (0 replies)
  72. PORSCHE 914-4 & VW Bus 1.7-2.0, Original Engine Case Studs 220 mm.L.( 2 ) (0 replies)
  73. Porsche 914 914-6 Solid Nylon Transmission Trans 901 Transaxle Mounts and Bolts (0 replies)
  74. Porsche 914 Upgraded Blade Type Fuse Box (0 replies)
  75. Porsche 914 Rear Trunk Lid Lift Strut Kit NOS (0 replies)
  76. Porsche 911 912 914 Transmission Transaxle Shift Fork Jig Alignment tool 901 (0 replies)
  77. Porsche 914 5Rug Front Drilled Disk Brake Rotors (0 replies)
  78. PORSCHE 914 TAILLIGHT HOUSING/ BUCKET LENS NYLON NUTS Set of 7 ALL YEARS (0 replies)
  79. Porsche : 914 ONLY 37,114 ACTUAL MILES! ORIGINAL MATCHING #'S! (0 replies)
  80. Porsche : 914 2 door convertible (0 replies)
  81. Porsche 914 Big Bore Engine (0 replies)
  82. 16 Original Lug Nuts for a Porsche 914 (0 replies)
  83. Volkswagen Beetle Ghia Porsche 914 Bus Bosch 009 Distributor German (0 replies)
  84. Used VW VOLKSWAGEN BEETLE, BUS, KARMANN GHIA 67-79 / 914 PORSCHE 70-76 (0 replies)
  85. TARGA TOP ROLL BAR DRIVER SIDE NEW TRIM FOR PORSCHE 914 914/6 914-6 (0 replies)
  86. Porsche 914 VW Type 2/4 EMPI finned Valve Cover Set (0 replies)
  87. PORSCHE USED REAR DECK LID LATCH FOR 914 (0 replies)
  88. Porsche 914 912 1974 1976 Intervalves Intake Valve (42 mm) (0 replies)
  89. Porsche 914 sail trim (0 replies)
  90. Porsche : 914 Base (0 replies)
  91. Porsche 914 and 914/6 Genuine Hella European Turn Signal Lenses. (0 replies)
  92. Porsche 914/4 Aluminum Valve Covers, New. (0 replies)
  93. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  94. Porsche 914 pictures - framed set of four (0 replies)
  95. Blaupunkt Speaker Cable Porsche 356 911 912 914 VW BMW Mercedes Alfa Bug Beetle (0 replies)
  96. BRAND NEW NOS Type 4 VW 1.7 & Porsche 914 1.7 BOSCH fuel injector (0 replies)
  97. BRAND NEW NOS Type 4 VW 1.7 & Porsche 914 1.7 BOSCH fuel injector (0 replies)
  98. Porsche 911 914 Synchro Ring large lot as is (0 replies)
  99. Porsche 914 mirror/spiegel Genuine 91473103910 late version 73-76 (0 replies)
  100. PORSCHE 911 / 912 / 914 / 930 BRAKE FLUID RESERVOIR GENUINE (0 replies)
  101. ORIGINAL PORSCHE 914 CENTER CONSOLE COMPARTMENT W/ CUSHION TOP BLACK (0 replies)
  102. PorscheĀ® 911/914/924/944 Harness Bar, Weltmeister, 1969-1998 (0 replies)
  103. Porsche : 914 Targa (0 replies)
  104. Porsche 914 oil cooler (0 replies)
  105. Porsche 914 fuel gauge sending unit (0 replies)
  106. 1975 Porsche 914 NEW Mass Air Flow Meter Bosch # 0280201002 (0 replies)
  107. PORSCHE 914 HEATER CONTROL LEVER (0 replies)
  108. Porsche 914 Windshield Wiper Assembly (0 replies)
  109. Porsche 914 Rear Brake Rotor Backing Plates. (0 replies)
  110. Porsche 914 Upper "J" Tube Seals New (0 replies)
  111. Porsche 914/4 Cylinder Head Temperature Sensor Extension. (0 replies)
  112. NICE USED ORIGINAL GENUINE PORSCHE 914 PASSENGERS CENTER SEAT CUSHION BASE UNIT (0 replies)
  113. PORSCHE 911 / 914 REAR VIEW MIRROR (0 replies)
  114. Porsche 914 & VW 1.7 - 2.0, Distributor Drive Shaft, washer & spring. (0 replies)
  115. Porsche 914 engine compartment seals (0 replies)
  116. Porsche 914 fiberglass GT Valance (0 replies)
  117. 1971 Porsche 914 Engine Bay Sheet Metal (0 replies)
  118. Porsche Automobiles Dash Part Vintage LighterElementRare (0 replies)
  119. My 914-6 on eBay (0 replies)
  120. Porsche 914 Car Cover 1971 1972 1973 1974 1975 1976 New (0 replies)
  121. Porsche 911 914 VDO TIRE PRESSURE GAUGE (0 replies)
  122. PORSCHE 356 911 912 914 924 CLUTCH ALIGNMENT TOOL NEW also fits VW (0 replies)
  123. Porsche 356 Hubcap/Center Cap Remover Tool 911/912/944/914/930/VW UNIVERSAL TOOL (0 replies)
  124. PORSCHE 914 HEADLIGHT MOTOR RUBBER COVERS (0 replies)
  125. PORSCHE 914 BOSCH AIR PRESSURE SENSORE MPC JETRONIC (0 replies)
  126. PORSCHE 914 SKI RACK OPTION PIPER (0 replies)
  127. PORSCHE 914 HEATING AIR SUPPLY TUBE (0 replies)
  128. PORSCHE 914 RED KNOB HEAT LEVER (0 replies)
  129. PORSCHE 914 REAR RUBBER BUMPER (0 replies)
  130. PORSCHE 914 LUG NUTS (0 replies)
  131. Porsche 914 Heater Control Box Connector Elbows Left and Right (0 replies)
  132. Porsche 914 Pillow Trim (0 replies)
  133. Porsche 914 Rear Deck Lid Spoiler (0 replies)
  134. Battery Mat ACID ABSORBER PORSCHE Boxster S 911 944 928 914 356 (0 replies)
  135. Porsche 914 Fresh air Box blower motor unit (0 replies)
  136. Porsche : 914 appearance group (0 replies)
  137. Porsche Factory OEM Spare Parts Catalog 914-6 914 -4 Eng French Italy German 3 (0 replies)
  138. PORSCHE 356 550 908 911 912 914 928 930 944 959 962 LEATHER SEAT BELT COVERS 2x (0 replies)
  139. 1974 PORSCHE 914 ORIGINAL DEALERSHIP SALES BROCHURE (0 replies)
  140. NOS PORSCHE 356 550 908 911 912 914 928 930 944 959 962 YELLOW LEATHER KEYCHAIN (0 replies)
  141. Porsche 914 manual 1976 (0 replies)
  142. Factory Porsche 914 Combination Gauge - Later Style (0 replies)
  143. Porsche 914 Technical Specifications (0 replies)
  144. PORSCHE 914 TAIL LIGHT LENS OEM ORIGINAL HELLA WITH NYLON NUTS (0 replies)
  145. LEFT SIDE PORSCHE 914 TAIL LIGHT LENS OEM ORIGINAL HELLA WITH NYLON NUTS (0 replies)
  146. Porsche 914 tool bag (0 replies)
  147. BRAND NEW NOS Type 4 VW 1.7 & Porsche 914 1.7 BOSCH fuel injector (0 replies)
  148. Porsche 914, 911 Metal Shift Knob (0 replies)
  149. Porsche 914 V8 front engine Mounts, from Rod Simpson (0 replies)
  150. Porsche 914 Upper Steering Column with Switches (0 replies)
