Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche Alternator Belt ContiTech 914 70-76 (0 replies)
  2. ACDELCO DURASTOP 18A914 Front Brake Rotor/Disc-Disc Brake Rotor (0 replies)
  3. PORSCHE 914/VW TRUNK TENSION SPRING REMOVAL TOOL (0 replies)
  4. New Porsche 914 Clutch Cable 1970 - 1976 1.7 1.8 2.0 (0 replies)
  5. Porsche 914 4/6 Hood Seal Front GENUINE Brand New (0 replies)
  6. Porsche 914 70-76 Hood Seal GENUINE Brand New 914 511 901 10 (0 replies)
  7. Porsche 914 H4 1.7L; H6 2.0L (1970-1976) Hood Seal GENUINE 91451190110 (0 replies)
  8. Porsche 914 Decklid Seal Rear Genuine Brand New (0 replies)
  9. Porsche 914 Decklid Seal Rear OEM 914 512 317 10 (0 replies)
  10. Porsche Interior Light Lens Switch 914/4 914/6 (0 replies)
  11. Porsche 356 912 914/4 Ignition Contact Set Points BOSCH OEM NEW +Warranty (0 replies)
  12. PORSCHE 914 GEAR SHIFT ROD COUPLER '70-'72 (0 replies)
  13. PORSCHE 914 VW OIL PUMP OEM (0 replies)
  14. PORSCHE 911 912 914 930 FRONT SHIFT COUPLER (0 replies)
  15. PORSCHE 911 914 AM FM MONO RADIO DIAL LENS '72 (0 replies)
  16. PORSCHE 914 VALVE COVERS (0 replies)
  17. PORSCHE 914 SPARE TIRE PLATE & BOLT (0 replies)
  18. PORSCHE 914 DOOR LOCK ASSEMBLY (RIGHT) (0 replies)
  19. PORSCHE 914 HEADLIGHT SURROUND *** DRIVERS SIDE *** (0 replies)
  20. PORSCHE 914 A/C DRIER UNIT & CLAMP (0 replies)
  21. PORSCHE 914 FRONT BRAKE ROTORS ZIMMERMANN '70-'72 ***PAIR*** (0 replies)
  22. Porsche 356 911 912 914 924 928 944 964 Steering Wheel (0 replies)
  23. Porsche 10 Emblem Speed Nuts 911 912 914 930 944(65-98) (0 replies)
  24. PORSCHE 914-6 914 1.7 1.8 2.0 POLO SHIRT-CUSTOM COLOR AND SIZE....LOOK!!! (0 replies)
  25. Porsche 911 930 914 Rear Sway Bar Retaining Brackets (2 (0 replies)
  26. Porsche 914 1969 1970 1971 1972 1973-1976 Car cover (0 replies)
  27. NOS Porsche 914 Haneline Engine Turned Stainless Steel Throttle Plate (0 replies)
  28. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  29. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  30. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  31. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  32. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  33. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  34. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  35. "RARE" Porsche 901 911 914 Transmission "N" 23:29 "Close Ratio" 3rd Gear Set (0 replies)
  36. Porsche 911 914 901 Transmission "0" Third Gear Set 23: 28 1965-1976 (0 replies)
  37. Porsche 911 & 914 Engine Cooling Fan, Impeller, Genuine, New, Porsche 911 & 914 (0 replies)
  38. Porsche 911, 912, & 914 Fuel Sending Unit, VDO, NOS, New, Porsche 911,912,914 (0 replies)
  39. Porsche 914 Fuse Box & Cover Kit,O.E.M.Box & W/Correct Symbol Cover,914 '70-'76 (0 replies)
  40. Porsche 914 Dual Weber 44IDF Carb.Kit W/Air Cleaner,New (0 replies)
  41. Porsche 914-4 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  42. Porsche 911 914 KONI Red Adjustable Strut Inserts 4 BOGE Struts (0 replies)
  43. Porsche 911 914 KONI Sport Front Gas Adjustable Strut Inserts 4 BOGE Struts (0 replies)
  44. Vintage VW, Formula, Porsche 914 Campagnolo Race Wheels (0 replies)
  45. Porsche 914 2.0L Crank (0 replies)
  46. Porsche 914-4 74-76 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  47. Pair of Porsche Books over 400 pages of information 911, 944, 914, Turbo (0 replies)
  48. 1974 PORSCHE 911 914 917 TARGA-AD/PICTURE/PRINT 73 74 75 76 CAN-AM 12 CYL. TURBO (0 replies)
  49. Type4 VW Bus Westy Porsche 914 912 912E Smog Pump Core Emissions Part OEM Cali (0 replies)
  50. PORSCHE 911-912-914 OEM ORIGINAL UNIVERSAL BLK ROUND RELAY ( 911.615.109.01 ) (0 replies)
  51. Martini Porsche 911 RSR Turbo 1974 Banner 956 914 935 (0 replies)
  52. VINTAGE PORSCHE 911 356 914 (?) USED ORIGINAL (1) HUB CAP TIRE WHEEL COVER (0 replies)
  53. Set (4) of rare Performance industries Porsche 914 or VW Wheels 15x6 (0 replies)
  54. 1972 Porsche 914/6 Steering Wheel part #914 347 805 11 (will also fit 914 /4) (0 replies)
  55. PORSCHE 914 1.7L PISTONS RODS PINS (0 replies)
  56. PORSCHE 914 REAR TRUNK AND ENGINE COMPARTMENT LIGHT (0 replies)
  57. PORSCHE 914 OIL DIP STICK DIPSTICK (0 replies)
  58. Porsche 1971 - Why a mid-engine Porsche? Porsche 914 and 914/6 (0 replies)
  59. Porsche 914 Plush Carpet set 70-76 NEW (0 replies)
  60. Porsche 914 GERMAN MATCH Perlon Carpet set 70-76 (0 replies)
  61. VW Porsche 914 Bug Beetle Bus NOS Bosch Vacuum Advance (0 replies)
  62. German Stuttgart EURO license plate + PORSCHE Frame 911 928 944 356 Cayenne 914 (0 replies)
  63. Porsche crest, enamel, 911, Carrera, 914, 914/6, (0 replies)
  64. 1975 Porsche 914 Side Shift Transmission OEM Used (0 replies)
  65. Porsche Red Valet Key Genuine 911 912 930 914 964 993 Carrera Turbo (70-94) (0 replies)
  66. Rear Door Hinges Dodge MB Freightliner Sprinter: 901 740 08 37 (0 replies)
  67. PORSCHE 914 FRONT TURN SIGNAL (0 replies)
  68. PAIR OF USED ORIGINAL PORSCHE 914 FRONT WHEEL GREASE CUP CAPS (0 replies)
  69. Dellorto carburetor DHLA 40 for 914 Porsche VW Volkswagen bug Ghia Bus etc. (0 replies)
  70. PORSCHE "Do you speak 914?" in german retro t shirt (0 replies)
  71. PORSCHE 914 OEM ENGINE LID RELEASE CABLE & KNOB (0 replies)
  72. PORSCHE 914 FUEL GAS TANK SUPPORT MOUNTS (0 replies)
  73. PORSCHE VW 914 TECHNICAL- SPECIFICATIONS (0 replies)
  74. PORSCHE 914 HEADLIGHT COVERS *** PAIR *** (0 replies)
  75. PORSCHE 914 GT / 916 / Carrera RS 2.7 Hornbutton, clacson, Hupenknopf. VERY RARE (0 replies)
  76. Porsche Red Valet Key 911 912 930 914 964 993 Carrera Turbo (70-94) USED PAIR (0 replies)
  77. Porsche Ignition Switch Meyle 914/4 73-76 (0 replies)
  78. Intake Manifold Sleeve CRP 039133241 vw 914 1.8 2.0 set of 4 (0 replies)
  79. Porsche 914 ENGINE COMPARTMENT HEATING Blower Fan Original German (0 replies)
  80. PORSCHE 914 Heater Control Box (0 replies)
  81. Watershield Air Filter Plates for 911 and 914 Porsche (0 replies)
  82. Porsche 914 911 912 factory used jack nice!!! (0 replies)
  83. PORSCHE 914 GLOVE BOX DOOR LID (0 replies)
  84. PORSCHE 914 PUSH RODS (0 replies)
  85. PORSCHE 914 DOOR STRIKERS PAIR WITH MOUNTING SCREWS (0 replies)
  86. PORSCHE 914 OIL FILTERS ***PAIR*** (0 replies)
  87. PORSCHE 911 914 AM FM STEREO RADIO DIAL LENS '72 (0 replies)
  88. PORSCHE 914 SEAT RAILS *** PAIR *** (0 replies)
  89. PORSCHE 914 HEAT CONTROL LEVER (0 replies)
  90. PORSCHE 914 CONTROL ARM BRACKET (RIGHT) (0 replies)
  91. PORSCHE 914 SEAT BELT LOCKS (0 replies)
  92. PORSCHE 914 FRONT TRUNK LATCH LOWER (0 replies)
  93. PORSCHE 914 PASSENGER ARM REST INTERIOR DOOR HANDLE (0 replies)
  94. PORSCHE 914 ENGINE LID HINGE BRACKET (0 replies)
  95. PORSCHE 914 1.7L/1.8L DECEL VALVE (0 replies)
  96. PORSCHE 914 1.8L PRESSURE REGULATOR (0 replies)
  97. Vintage Bosch rotor 1 234 332 209 VW Vanagon/ Porsche 914 rev limiter 5300 rpm (0 replies)
  98. Porsche 914 Engine Gasket Set NEW REINZ '74-'75 1.8 Liter (0 replies)
  99. Mustang Falcon Comet Front and Rear Sway Bar Kit 536/914 ADDCO solid bars (0 replies)
  100. Porsche 914 Engine Gasket Set NEW REINZ '73-'76 2.0 Liter (0 replies)
  101. Porsche 911 914 Audi TT A3 A4 Volvo BMW E36 E34 46 Turbo Blow Off Valve Type RS (0 replies)
  102. Bosch 0237022025 Distributor for VW - porsche 914, 924, 928? (0 replies)
  103. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  104. Porsche 914-6GT Porsche 914-6GT, 914-6 (0 replies)
  105. Porsche Brake Caliper Repair Kits Rear 914/4 (70-76) (0 replies)
  106. Porsche 914 manual transmission with drive shafts (0 replies)
  107. PORSCHE Front Wheel Bearing & Seal Set 911 914 924 944 (64-89) (0 replies)
  108. Porsche 914 How to Restore and M odify (0 replies)
  109. VW Porsche 914 2 liter alloy wheel Empi American Eagle (0 replies)
  110. Porsche : 914 PORSCHE 914 NICE HIGH PERFORMANCE 914 / trade (0 replies)
  111. 69-76 PORSCHE 914 H4 2.0L OBX HEADER EXHAUST MANIFOLD (0 replies)
  112. porsche 914 engine tin (0 replies)
  113. Porsche 914 Strut Left Side (0 replies)
  114. Porsche 914 dash board No cracks beautiful (0 replies)
  115. DASH PAD REPAIR CAP OVERLAY 70-76 PORSCHE 914 (0 replies)
  116. Pierburg 12V fuel pump P/N: 7.21440.28 (Rotax 914) (0 replies)
  117. Porsche 914 Brake Speed Bleeders 1970-1976 (0 replies)
  118. Porsche Pedal Bushing Set Bronze 911 914 912 911SC Carrera 930 Turbo 65-86 (0 replies)
  119. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 996 (0 replies)
  120. 901 Transaxle gears 4th or 5th gear V (27:25). Porsche 914 911 912 Transmission (0 replies)
  121. Porsche Bump Steer Rack Spacer Kit 911 912 914 930 (0 replies)
  122. Porsche Flasher Turn Signal Relay 912 914 911 (70-89) (0 replies)
  123. Porsche 914 cylinder head temp switch for 1973 2.0 NOS (0 replies)
  124. 914 US Made LHD/RHD Carbon Fiber Dash Kit 07-09 Chevrolet Silverado 1500 (0 replies)
  125. Porsche 914-4 Bosch Complete Tune-up Kit 1.7 1.8 2.0 (0 replies)
  126. 91-95 Acura Legend Coupe Chrome Clear Corner Lights LH RH Signal Lamps 4DR (0 replies)
  127. Porsche 914 912E Intake Manifold Sleeve Connecting Hose - Set of 4 - NEW (0 replies)
  128. Porsche Brake Caliper Seal Repair Kits Front & Rear 914/4 70-72 (0 replies)
  129. SIA 1940 LINCOLN ZEPHYR 1958 BONNEVILLE 1976 PORCHE 914 (0 replies)
  130. PORSCHE POLO COOL MESH FABRIC-BOXSTER, GT, PANAMERA, 356 914 911 944 968 LOOK! (0 replies)
  131. PORSCHE POLO SHIRT-COOL MESH FABRIC-912 911 914 993 964 BOXSTER CAYMAN PANAMERA (0 replies)
  132. PORSCHE POLO SHIRT-COOL MESH 911 914 996 997 BOXSTER CAYMAN DESIGNER LABEL (0 replies)
  133. Porsche 10 Emblem Speed Nuts with seals 911 912 914 930 944 (65-98) (0 replies)
  134. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  135. PORSCHE 914 HELLA FOG LIGHT SWITCH (0 replies)
  136. Porsche 914 914-6 passenger side outside door handle with key (0 replies)
  137. PORSCHE 356SC 904 912 911S Carrera 2 HUGE 914 coffee table book No Reserve (0 replies)
  138. Porsche 914 4 cylinder type IV air filter cleaner housing base bottom VW (0 replies)
  139. Dual Electric Trumpet Hi/Lo Horns Set Porsche 911 912 914 LOUDEST We Can Find!!! (0 replies)
  140. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  141. Afco Silver Pavement Late 7" Gas Shock 3-6 Cmp/9-14 Reb (0 replies)
  142. Afco 46 S Aluminum 7" Reb Adjustable Shock, 5:9-14 (0 replies)
  143. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER (0 replies)
  144. 91-95 Legend 4DR Euro Clear Corner Signal Lights Lamps (0 replies)
  145. Porsche Differential Carrier Bearing & seal set 911 912 914 924 928 69-86 (0 replies)
  146. 1970-1976 Porsche 914 Cluster Instrument Cluster White Face Gauges 70-76 (0 replies)
  147. Porsche Parts - NEW Camshaft for all 914-4 & '76 912E (0 replies)
  148. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  149. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 912 65-68 (0 replies)
  150. SOLEX H40/44EIS DUAL CARBS PORSCHE 914 1.7 / 1.8 LT (0 replies)
