Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Eaton Detroit Truetrac Differential 914A575 GM 8.875" Car 12-Bolt 33 Spline (0 replies)
  2. COMP Cams Valve Spring 914-16 (0 replies)
  3. PORSCHE 914 1969-1976 CAR COVER *POLYESTER* (0 replies)
  4. Porsche 914 (70-72) Brake Caliper Repair Kit Front FTE OEM NEW + 1 year Warranty (0 replies)
  5. Porsche 911 914 (70-76) Transmission Clutch Cable End Boot OEM NEW + Warranty (0 replies)
  6. porsche 914 Door Handle Trim Surrounds -- Black Style (0 replies)
  7. Porsche 914/6 GT Mid Engine Racing Montage CarPoster: ) (0 replies)
  8. SportsCarGraphic PORSCHE 914 ROVER 3500S DODGE CHALLENGER 440 MAGNUM BRM FORMLA1 (0 replies)
  9. PORSCHE 914/6 70 71 72 BRAKE ROTORS + PADS F (0 replies)
  10. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS + PADS F/R (0 replies)
  11. Porsche 914 (70-76) Clutch Cable + COMPLETE mount KIT (0 replies)
  12. Porsche 914 /6 (70-71) ignition KIT cap rotor plugs OEM (0 replies)
  13. 70 76 Porsche 914 instrument cluster with gauges Speedometer Tach OEM (0 replies)
  14. Porsche The Engineering Story - 911 914 924 928 Cayenne (0 replies)
  15. PORSCHE 914, VW BUS,TYPE 3,TYPE 4,SOLEX CARBURETOR ELECTRIC CHOKE ELEMENT, NOS (0 replies)
  16. Porsche 914 Factory Ashtray -- Good Condition (0 replies)
  17. Porsche 914 4cyl rear Axle Joint Bolt set (x16 bolts) BILSTEIN (0 replies)
  18. Aftermarket Fiberglass Rear Valance, w/o Exhaust Cut Out 73, 74 Porsche 914 (0 replies)
  19. PORSCHE Front Wheel Bearing & Seal kit 911 912 930 914 924 944 Carrera Turbo (0 replies)
  20. Porsche 914 4-cylinder 1969-76 Haynes Automotive Repair Manual (0 replies)
  21. The 914 & 914/6 Porsche - A Restorer's Guide to Authenticity (1970-76) (0 replies)
  22. Dual Electric Trumpet Hi/Lo Horns Set Porsche 911 912 914 LOUDEST We Can Find!!! (0 replies)
  23. PORSCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  24. 1970-1976 Porsche 914 Cluster Instrument Cluster White Face Gauges 70-76 (0 replies)
  25. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER (0 replies)
  26. Porsche 914 Center Console Gauge Wiring Harness (NEW! Reproduction) (0 replies)
  27. SACHS (NOS) KM914 Side Springs Set 6pcs Wankel 303 Arctic Cat Panther Skiroule (0 replies)
  28. THE TYPE IV UPRIGHT CONVERSION MANUAL-VW BUG PORSCHE 914 411 412 T-4 GHIA BUS (0 replies)
  29. 914 Vw Bus Type 4 Engine Case (0 replies)
  30. Ac Delco 213-914 Throttle Position Sensor New (0 replies)
  31. SCGraphic PORSCHE 914 AMC & HUDSON HORNET DE TOMASO MANGUSTA ASTON MARTIN (0 replies)
  32. SportsCarGraphic 1970 PORSCHE 914 FORD CAPRI1600 & 3000GT GREMLIN ROOTES AVENGER (0 replies)
  33. SportCarGraphic FIAT 850 RACER PORSCHE 914 TRIUMPH STAG LOTUS 72 FERRARI 365GT (0 replies)
  34. Porsche 914 rear chrome bumper & more (0 replies)
  35. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  36. PORSCHE STEERING WHEEL RESTORATION 911 914 944 928 964 993 996 997 BOXSTER (0 replies)
  37. PORSCHE 914 WHEEL EMBLEMS - 1 3/4" diameter (44mm) (0 replies)
  38. 16 LUG BOLTS NUTS for PORSCHE 914 MAHLE PEDRINI 2.0 FUCHS RIVIERA ALLOY WHEELS (0 replies)
  39. 3 1/4" BLACK "GEAR" STYLE WHEEL CENTER CAPS - PORSCHE 914 (82-83mm) (0 replies)
  40. Porsche 914 Steering Wheel with Hub & Horn Button (0 replies)
  41. 1970-1976 Porsche 914 Rear Reflector (0 replies)
  42. Porsche : 914 1970 Porsche 914 Runs and Drives Great NO RESERVE Minimal Rust Fuchs (0 replies)
  43. LOUD Fiamm Dual Blaster Trumpet Hi/Lo Horn Set fits Classic Porsche 911 912 914 (0 replies)
  44. Porsche 914 Manifold Pressure Sensor Core 1973-1976 2.0 Liter (0 replies)
  45. Porsche 914 Manifold Pressure Sensor Core 1973-1976 2.0 Liter (0 replies)
  46. Porsche 914 Manifold Pressure Sensor Core (0 replies)
  47. Porsche 914 Manifold Pressure Sensor Core 1970-1973 1.7 Liter (0 replies)
  48. Porsche 914 latch (0 replies)
  49. EARLY PORSCHE 911 912 914 HORN BUTTON BUTTER FLY (0 replies)
  50. BING 64 CD Carburetors for Rotax 914 F/UL Engines (0 replies)
  51. PORSCHE 914 911 912 ORIGINAL BOSCH VOLTAGE REGULATOR (0 replies)
  52. PORSCHE 914 ENGINE LID DRIP PAN RAIN TRAY *** EARLY *** (0 replies)
  53. PORSCHE 914 FACTORY STEEL DASH FRAME (0 replies)
  54. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  55. PORSCHE 356 FLYWHEEL END PLAY TOOL 911/912/914/924/VW (0 replies)
  56. Porsche 911 964 993 boxster 914 six 944 968 Miro wheel set bbs knockoff w tires! (0 replies)
  57. Porsche 10 Emblem Speed Nuts 911 912 914 930 944(65-98) (0 replies)
  58. 94 Saab NG900 2.5L V6 Yazaki Instrument Cluster Assembly (0 replies)
  59. Very nice used Porsche 914 hazard light switch rare piece 914-6 2.0 1.7 1.8 (0 replies)
  60. Porsche 914 interior rear view mirror BMW conversion (0 replies)
  61. Porsche 914 side marker lens set NOS Hella with screws rare 1970-1976 (0 replies)
  62. Porsche 914 Chrome Window Crank Handle, all 914 (0 replies)
  63. Porsche Bump Steer Rack Spacer Kit 911 914 930 Carrera Turbo (73-89) (0 replies)
  64. Porsche (69-89) Brake Line hose Kit STEEL BRAIDED +Bar (0 replies)
  65. Porsche 911 914 (70-76) Clutch Cable End Boot @ transmission (0 replies)
  66. Porsche 914 912e clutch Flywheel Bolt set (x5 Bolts) OEM (0 replies)
  67. porsche 914 seats (0 replies)
  68. EXCELLENT USED PORSCHE 914 TIRE LUG WRENCH TOOL (0 replies)
  69. New Porsche 914 Rear Wheel Bearing SKF BA2B633457 999-053-035-00 545495AD (0 replies)
  70. Porsche Brake & Clutch Pedal Pads 356 911 930 912 914 Carrera Turbo (50-98) (0 replies)
  71. 2 - Porsche 911 901 914 Transmission Synchronizer Lock Rings 91130231101 1965-86 (0 replies)
  72. 3 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  73. OBDMate Full Protocol Professional OBD-II Car Code Reader CAN PWM VPW KPW ISO914 (0 replies)
  74. 02 03 DODGE 1500 PICKUP 01 02 03 DURANGO Alternator 7604 (0 replies)
  75. Porsche 914 Exhaust Gasket Repair Kit for 2.0 1975 (0 replies)
  76. Porsche 914 Exhaust Gasket Repair Kit (0 replies)
  77. Porsche 914 Oil Cooler (0 replies)
  78. Porsche 914 Sachs Clutch Kit (0 replies)
  79. Porsche 914 Petronix Electronic Ignition Conversion Kit (0 replies)
  80. Porsche 914 Engine Crankshaft Main Bearing Set (0 replies)
  81. OEM TIMING CHAIN TENSIONER PORSCHE 911 CARRERA S SC 2.4 H6 2.2 H6 2.0 914 930 (0 replies)
  82. porsche 914 911 912,Leather steering wheel complete.Rare (0 replies)
  83. 91-95 Legend 4DR Euro Clear Corner Signal Lights Lamps (0 replies)
  84. Porsche 914 OEM Right side Head lamp Cover (0 replies)
  85. PORSCHE 914 HEADLIGHT BEZEL USED, LEFT SIDE ONLY (0 replies)
  86. OEM FULL CAR COVER PORSCHE 914 1970 1971 1972 1973 1974 1975 1976 4 (0 replies)
  87. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 Boxster Carrera 996 (0 replies)
  88. Crankshaft Main Bearing Set - German Kobleschmidt - Porsche 912 - 914 - VW 411 (0 replies)
  89. 914 NEW NOS OEM DASH 91455202211 NEW INSTRUMENT BRACKET NEW OEM NOS 914 DASH (0 replies)
  90. Hot Air Connecting Hose Set For Porsche 914 (70-76) (0 replies)
  91. Porsche 914 vent window seal (left side only) (0 replies)
  92. Connecting Rod Bearings - German Kobleschmidt - Porsche 914 - VW Type 2 / 3 / 4 (0 replies)
  93. Porsche 914 Heater Control Box Flapper - Pair (0 replies)
  94. Porsche 914 Shift Rod Bushing In Tunnel 1973 New OEM (0 replies)
  95. Porsche Ball Joint fits 911 930 and 914 (0 replies)
  96. Porsche 911, 912, 914 Sachs Throwout Bearing (0 replies)
  97. Porsche 914 Swaybar Bushing rear Ball pin OEM New Qty4 (0 replies)
  98. Porsche 914 2 Jack Hole Covers NEW OEM (0 replies)
  99. Porsche 912 914 911 Multi Function Relay 1965-89 (0 replies)
  100. Porsche 914 Engine Shelf Sheet Metal NEW Stamping (0 replies)
  101. Porsche 914 Shift Rod Bushing in Tunnel thru 72 (0 replies)
  102. Porsche 912 914 911 911 Turbo Fuel Pump Relay 1965-89 (0 replies)
  103. Porsche 912 914 VW 411 412 Sachs Clutch Friction Disc (0 replies)
  104. Porsche 914 73-74 2.0L 4 Cyl Dansk Banana Muffler New in stock at my warehouse (0 replies)
  105. LeatherLyke Cruiser Case T914 Universal Motorcycle Trunk - NEW (0 replies)
  106. Porsche 911 912 914 Windshield Washer Sprayer Nozzles 1965-1973 (0 replies)
  107. Porsche 914 Hard Start Solenoid Bosche NEW (0 replies)
  108. Speed Bleeder Pack of 2 M7x1.0 Porsche 911 914 944 928 (0 replies)
  109. Porsche 914 Clutch Cable Clevis Fork and Pin New OEM (0 replies)
  110. Porsche 914 Oil Filter Mahle OEM New (0 replies)
  111. 4 OEM Porsche 911 914 Front Drop Link Bushings New (0 replies)
  112. 3 Porsche 914 Mahle OEM Oil Filters Great Gift (0 replies)
  113. Porsche 914 Rear Bilstein shocks NEW Qty2 (0 replies)
  114. Pair of original OEM Porsche 914 speaker grills and Alpine speakers (0 replies)
  115. PORSCHE 914/4-914/6's 70-76 HEADLIGHT MOTORS (0 replies)
  116. Harley-Davidson Skull with Wings 14" x 17" Auto Car Floor Utility Rubber Mat 914 (0 replies)
  117. Porsche 911 914 Lemforder Turbo Tie Rod Set New (0 replies)
  118. Porsche 912, 914 Engine Crankshaft Seal (0 replies)
  119. Blaupunkt Radio Bracket Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  120. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  121. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  122. Blaupunkt Frankfurt Radio Lever Switch Porsche 356 911 912 914 VW BMW Mercedes (0 replies)
  123. Blaupunkt Frankfurt Radio Lever Switch Porsche 356 911 912 914 VW BMW Mercedes (0 replies)
  124. Porsche 4 CV Axle boots 911 912 914/4 914/6 65-76 (0 replies)
  125. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  126. Porsche 911 front 19mm torsion bars 1965-89 912 914 930 No Reserve (0 replies)
  127. Porsche 914 Clutch Cable NEW (0 replies)
  128. Porsche 914/924/924 S Reactor (0 replies)
  129. Porsche 914 Clutch Cable NEW (0 replies)
  130. PORSCHE 914 OEM STEEL LUG NUTS BOLTS *** SET OF 4 *** (0 replies)
  131. DASH 4 BRAKES CD914 Brake Pad or Shoe, Front (0 replies)
  132. MOTORCRAFT JK6-914-A Serpentine Belt/Fan Belt (0 replies)
  133. PORSCHE 914 CLUTCH SET (0 replies)
  134. BENDIX RD914 Brake Pad or Shoe, Front (0 replies)
  135. Porsche 2 Ball Joints w/Pin Front Lower 911 914 930 (0 replies)
  136. Porsche (2) Window Crank Handles 914/4 914/6 924 70-82 (0 replies)
  137. Mr. Gasket Flywheel Bolt Kit 914 (0 replies)
  138. Boge Front Strut Insert (0 replies)
  139. PORSCHE 914 69-76 LEATHER ARMREST COVER (0 replies)
  140. Hirschmann Automatic Electric Power Antenna Porsche 911 912 914 944 Chrome Mast (0 replies)
  141. Porsche Sway Bar Drop Link Bushing Set 914 911 912 1965-73 Polyurethane (0 replies)
  142. Porsche 914 Wiper/Washer Switch/Column 914 '74-'75,New (0 replies)
  143. Porsche 914 Original Gauges (0 replies)
  144. Martini Porsche 917 Sebring 1971 Poster Vinyl Banner 911 914 936 944 55.1"x23" (0 replies)
  145. Porsche 911 Carrera RSR Sebring 73 Banner 914 917 944 (0 replies)
  146. Porsche 914 door handle rubber isolators L/ R- 4 pcs (0 replies)
  147. Porsche 914 late style gas cap rubber seal NEW (0 replies)
  148. Porsche 914 early style window rollers bearings (0 replies)
  149. Porsche 914 amber front turn signal lens 1 (0 replies)
  150. Porsche 914 Main targa seal rubber with aluminum clips will not rust (0 replies)
