Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. NICE PAIR USED ORIGINAL PORSCHE 911 914-6 BRAKE SHIELDS (0 replies)
  2. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  3. USED ORIGINAL PORSCHE 911 912 914-6 REAR BRAKE SHIELD (0 replies)
  4. Porsche 911 914 924 944 ROH wheels (0 replies)
  5. PAIR ORIGINAL PORSCHE 911 912 914-6 REAR BRAKE SHIELDS (0 replies)
  6. ORIGINAL PORSCHE 911 912 914-6 REAR BRAKE SHIELD BRIDGE (0 replies)
  7. PORSCHE Front Bearing/Seal Set 911 914 924 944 (64-89) (0 replies)
  8. O.E.M. door latch set w/ special attaching hardware Porsche 914 vw (0 replies)
  9. Porsche : 914 TARGA / 1.8L 1975 Porsche 914 1.8L w/Just re-built "IceCold" A/C / Fac.Fuel Inj,records,books (0 replies)
  10. Porsche 914 1.7 EA engine for core or rebuild located in Southern California (0 replies)
  11. 91-95 Legend 4DR Clear Signal Corner/Bumper Lights Lamp (0 replies)
  12. 91-95 Legend 4DR Euro Clear Bumper Lights Signal Lamps (0 replies)
  13. ROTAX 912/914 Oil Cooler (0 replies)
  14. Eagle Dodge Plymouth Colt Mitsubishi Mirage Ignitor Ignition Module 1989 - 1994 (0 replies)
  15. Porsche 911 912 914 930 Oil Strainer Sump Screen 65-83 (0 replies)
  16. USA Air Force - 914th Aero Medical Evac Squadron NEW (0 replies)
  17. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  18. USA Air Force - 914th Aero Medical Evac Squadron decal (0 replies)
  19. VW Porsche 914 Bug Beetle Bus NOS Bosch Vacuum Advance (0 replies)
  20. VW Bus Vanagon Porsche 914 2.0 Connecting Rods NR USED (0 replies)
  21. Porsche Muffler Early 911 & 914-6 (0 replies)
  22. Porsche : 914 GT 1973 Porsche 914-6 GT Reproduction - Ultimate Streetable Monster - Must See!! (0 replies)
  23. Wagner QuickStop Brake Pads ZX914 (0 replies)
  24. Porsche : 914 2.0 73' 914 2.0 Fuel Injected (0 replies)
  25. OIL SWITCH for ALFA AUDI PORSCHE 911 912 914 924 BMW VW (0 replies)
  26. PORSCHE 911 912 914 SHIFT ROD BRACKET (0 replies)
  27. PORSCHE 914 HEAT CONTROL LEVER (0 replies)
  28. VW BUS PORSCHE 914 912e type 4 cylinder heads CNC PORTED BIG VALVES 48x38mm (0 replies)
  29. PORSCHE 914 VW 412 VW Type 2 BUS Alternator (0 replies)
  30. Porsche 914 six 914-6 factory engine number 645356 found at last! (0 replies)
  31. Porsche 914/6 GT Mid Engine Racing Montage CarPoster: ) (0 replies)
  32. Porsche 911 912 914 GT door pull set brand new neat item (0 replies)
  33. PORSCHE 914 70-76 REAR SWAY BAR 16 MM (0 replies)
  34. Porsche 914 VDO Tachometer 1973 (0 replies)
  35. Porsche 914 Accelerator Pedal (70-75) (0 replies)
  36. AC DELCO FUEL PUMP (0 replies)
  37. Porsche Keys Black & Red Genuine Set 911 912 914 964 (0 replies)
  38. Porsche 911 / 912 / 914 Heat Control Knob (0 replies)
  39. Porsche 914 Starter Ignition (0 replies)
  40. Porsche 914 Air Cleaner Box (0 replies)
  41. Porsche 914 Air Cleaner Box (0 replies)
  42. USA Air Force - 914th Aero Medical Evac Squadron decal (0 replies)
  43. Porsche 914 interior rear view mirror BMW conversion (0 replies)
  44. Porsche Wiper Blade Set Bosch 911 911SC Carrera 930 914 (0 replies)
  45. Porsche 914 Rear Caliper Repair Kit (70-76) (0 replies)
  46. Pair Porsche 914 Rear Brake Dust Shields (0 replies)
  47. Porsche 914 Factory Bilstein Jack (0 replies)
  48. Porsche Targa Top Trunk Mount Kit 914/4 914/6 70-76 (0 replies)
  49. Porsche Genuine Black Master Key 911 912 914 930 964 (0 replies)
  50. PORSCHE Front Bearing/Seal Set 911 914 924 944 (64-89) (0 replies)
  51. Porsche 914 defrost vent (0 replies)
  52. Porsche (2) Window Crank Handles 914 924 70-82 (0 replies)
  53. Porsche Cyl. Head Temperature Sensor 914/4 914/6 70-76 (0 replies)
  54. Porsche 4 Rear CV boots 911 912 914/4 914/6 65-76 (0 replies)
  55. Canton Racing Windage Tray 20-914 (0 replies)
  56. PORSCHE 914 1970 1971 1972 1973 1974 1975 1976 Stereo Radio HIRSCHMANN ANTENNA (0 replies)
  57. Porsche Brake Caliper Kits Front & Rear 914/4 70-72 (0 replies)
  58. Porsche (2) Window Crank Handles 914 924 70-82 (0 replies)
  59. Porsche 914 Window Scraper Seal weatherstrip LT Outer (0 replies)
  60. Porsche 914 914 6 OEM Headlight Motor with Relay (0 replies)
  61. Porsche 914 Back-Up Light Switch (70-76) (0 replies)
  62. Porsche : 914 Porshe 914 Slant Nose (0 replies)
  63. Porsche 914 Oil Pump Melling HD Type 4 vw Never used No Reserve (0 replies)
  64. PORSCHE 912/914 Racing Piston set w/coating (0 replies)
  65. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER (0 replies)
  66. Porsche 914 Fuse Box Cover, OEM Qlty., New, 12 Pole, Porsche 914 Fuse Box (0 replies)
  67. Porsche 914 Wiper/Washer Switch/Column 914 '74-'75,New (0 replies)
  68. PORSCHE 356 911 912 914 924 CLUTCH ALIGNMENT TOOL NEW (0 replies)
  69. Porsche 914 Fuel Pump Relay (0 replies)
  70. PORSCHE 914 HEADLIGHT PARTS FREE SHIPPING (0 replies)
  71. Porsche 911 914 Alternator W/REGULATOR 55AMP 65-66 67 68 69 70 71 72 73 74 1975 (0 replies)
  72. 02 DODGE 1500 PICKUP Alternator 136K 7604 (0 replies)
  73. Porsche 356,911,912,914 Stainless Steel Wheel Ring Set (0 replies)
  74. Porsche 914 Chrome Window Crank Handle, all 914 (0 replies)
  75. Porsche 914 Fusch Wheel 8 Spoke Black W/Polished Lip (0 replies)
  76. Porsche 914 & 911/911S / Carrera '74-'77 Oil Cooler, OEM Qlty, New, OEM Qlty (0 replies)
  77. Porsche 914 Dual Weber 44IDF Carb.Kit W/Air Cleaner,New (0 replies)
  78. Porsche 911,912, 914 Bosch Super Coil 12volt, New (0 replies)
  79. Porsche 914 Seat Belt, 3 Point Complete W/Hardware,Pair (0 replies)
  80. Porsche 914-6 & 911 Fuel Pump, Electrical, 911 '70-'71 (0 replies)
  81. Porsche 914,Turn Signal Switch/High Beam,914 '74-'75 (0 replies)
  82. Porsche 911,912,914, Nardi 'Annie 60' Steering Wheel, On Sale~!! (0 replies)
  83. Porsche 914 Fuse Box, 12 Pole, OEM Quality, 914 '70-'76, New (0 replies)
  84. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  85. VW Bus Van Porsche 914 Front Brake Hose 1971-79 (PAIR) (0 replies)
  86. Dual Electric Trumpet Hi/Lo Horns Set Porsche 911 912 914 LOUDEST We Can Find!!! (0 replies)
  87. 1973 VW / Volkswagen Type 3 / Porsche 914 - Bosch D-Jetronic ECU (#2) (0 replies)
  88. 1973 VW / Volkswagen Type 3 / Porsche 914 - Bosch D-Jetronic ECU (0 replies)
  89. BOSCH 09171 Porsche 912 - 914 Ignition Wires Wire Set 1970 71 72 73 74 75 76 (0 replies)
  90. Porsche 914 Rear CV Joint Gasket NEW (0 replies)
  91. Porsche 914/6 GT # 58 Brumos Sebring 1972 Poster (0 replies)
  92. Porsche 914 Front Turn Signal Housing (0 replies)
  93. Porsche 914 Front Turn Signal Housing (0 replies)
  94. Porsche 914 Windshield Washer Bottle (0 replies)
  95. PORSCHE 914 WEBER CARBURETORS (0 replies)
  96. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  97. 1971 PORSCHE 914 MATCHBOX TOY CAR NIB! IN HUNTER GREEN! (0 replies)
  98. Porsche 914 & 914/6 BOOK (0 replies)
  99. Porsche 911 914 boxster 944 front factory license plate (0 replies)
  100. Porsche Fuel Pump Relay 911 912 914 930 911 Carrera (0 replies)
  101. Porsche Fuel Pump Relay 911 912 914 930 911 Carrera (0 replies)
  102. porsche rebuilt alternator 914 porsche charging vw (0 replies)
  103. Tilton slave cylinder for Porsche 911 914 912 with 901 transmission (0 replies)
  104. Hidden Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  105. 1971 Porsche 914! 1969 1970 1972 1973 1974 1975 1976 vw (0 replies)
  106. Apex Stainless Brake Lines PORSCHE 911 912 914 (0 replies)
  107. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 996 (0 replies)
  108. PORSCHE Battery Cut Off Racing Switch 911 914 944 964 986 996 (0 replies)
  109. PORSCHE 914 TARGA TOP SHELL (0 replies)
  110. PORSCHE 914 WINDSHIELD WASHER RESERVIOIR TANK (0 replies)
  111. PORSCHE 914 SEAT RAILS *** PAIR *** (0 replies)
  112. Porsche 914 oil cooler VW BUS Type 4 No Reserve. (0 replies)
  113. PORSCHE 914 INTERIOR DOOR HANDLE (RIGHT) PASSENGER WITH CHROME LATCH CUP (0 replies)
  114. TACHOMETER - Westach - for Rotax 618, 912, 914 (0 replies)
  115. PORSCHE 914 EMERGENCY BRAKE GEAR PARKING BRAKE GEAR (0 replies)
  116. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  117. Porsche 914 1969 - 76 four cylinder Haynes Auto Repair Manual book (0 replies)
  118. PORSCHE 914 SEAT ADJUSTMENT CATCH (0 replies)
  119. Porsche 914 Fuel Tank Level Gauge Sender / Sending Unit (0 replies)
  120. PORSCHE 914 OEM ENGINE COMPARTMENT LID LATCH (0 replies)
  121. PORSCHE 914 FRONT SHIFT COUPLER '73-'76 SHIFTER SOCKET (0 replies)
  122. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  123. PORSCHE 914 OIL COOLER VW TYPE 4 (0 replies)
  124. Porsche (2) Window Crank Handles 914 924 70-82 (0 replies)
  125. Porsche 914 seats (0 replies)
  126. PORSCHE 914 ASHTRAY MOUNT (0 replies)
  127. PORSCHE 914 HEADLIGHT COVERS PAIR (0 replies)
  128. Porsche 911 912 914 928 930 Windshield Washer Pump (0 replies)
  129. Porsche 356, 911 Carrera/Turbo 912, 914, 924, 928 factory part interchange info. (0 replies)
  130. Porsche 911 912 914 Shift Knob Early (0 replies)
  131. BOSAL 251-914 Exhaust Hanger/Parts (0 replies)
  132. Porsche 914 4-cylinder Haynes Repair Manual 69 thru 76 (0 replies)
  133. Porsche 911 930 914 License plate Light (set 2) OEM NEW (0 replies)
  134. Porsche 914 944 931 Ignition start Switch NEW OEM (0 replies)
  135. PORSCHE 914/6 70 71 72 ROTORS PADS FRONT (0 replies)
  136. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS PADS F&R (0 replies)
  137. Porsche 914 Windshield Seal Front (Small Upper Section) OEM (0 replies)
  138. PORSCHE 914 Rear Trunk Gas Shock Kit (0 replies)
  139. PORSCHE 914 Rear Trunk Seals set of 2 (0 replies)
  140. Porsche 914 Parking Brake Cable LEFT OEM NEW (0 replies)
  141. Vintage Porsche 911 912 914 Misc Hardware Lot 1lb (0 replies)
  142. Vintage VW Capri Porsche 911 912 914 Ceramic Fuse Lot NOS (0 replies)
  143. Porsche 914 2 1/2" Chromed Hex Style Wheel Center Caps (0 replies)
  144. Distributor Cap DR914 75-89 Buick Chevy Pontiac *NEW* (0 replies)
  145. 1 Porsche 911 901 914 Transmission Synchroniser & Hardware Kit (2nd-5th) 1965-76 (0 replies)
  146. NICE PAIR REBUILT ORIGINAL GENUINE PORSCHE 914 FRONT BRAKE CALIPERS SINGLE BLEED (0 replies)
  147. REBUILT ORIGINAL GENUINE PORSCHE 911 T E S 914-6 STEEL RIGHT FRONT BRAKE CALIPER (0 replies)
  148. PAIR REBUILT ORIGINAL GENUINE PORSCHE 911 T E S 914-6 STEEL FRONT BRAKE CALIPERS (0 replies)
  149. 1969-1976 KYB Shock Strut Porsche 914 (0 replies)
  150. 914 engine inside chrome door handle/latch SET, west coast nice Porsche vw (0 replies)
