Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Power ANTENNA Mast - 1970 thru 1976 Porsche 914 (0 replies)
  2. Porsche 914 VDO combination gauge -fuel /oil /brake (0 replies)
  3. Fuel Injectors Porsche 914 1.7L 2.0L 1970 1971 1972 1973 4 NEW FJ114 (0 replies)
  4. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  5. Blaupunkt Frankfurt Radio Escutcheon Porsche 356 911 912 914 VW BMW Mercedes (0 replies)
  6. Porsche 914 fiberglass door panels left and right w standard vinyl and clps (0 replies)
  7. Porsche 914 70-76 Jack Hole Plugs - NEW OEM (0 replies)
  8. Porsche 914 fiberglass door panels left and right w basket weave vinyl and clps (0 replies)
  9. USED ORIGINAL PORSCHE 911 914-6 ALTERNATOR HUB AIR DEFLECTOR COVER (0 replies)
  10. USED ORIGINAL PORSCHE 911 930 914-6 OIL COOLER AIR DEFLECTOR COVER (0 replies)
  11. Porsche 914 drain bushing for front turn signal wirring in wheel well New rubber (0 replies)
  12. USED PAIR GENUINE ATE PORSCHE 911 911S 914-6 FRONT BRAKE CALIPERS (0 replies)
  13. Porsche 914 fog light lens period correct for TN4 Reproduction 1 lens NEW (0 replies)
  14. 1973 Porsche 914 914S Sales Brochure Catalog. MINT! See my other Porsche lots!!! (0 replies)
  15. Porsche : 914 Porsche 914 (0 replies)
  16. Porsche Cylinder Head Temperature Sensor 914/4 914/6 70-76 (0 replies)
  17. EATON TRUETRAC GM 914A538 9.5 REAR DIFFERENTIAL 33 SPLINES (0 replies)
  18. Porsche : 914 914 73 Porsche 914 (0 replies)
  19. VW bus Westfalia 72-79 Nos Type 4 Main bearings std case .20 crank Porsche 914 (0 replies)
  20. 1970s Porsche 914 Rear Trunk Lid Latch Used (0 replies)
  21. PORSCHE 914 WHEEL ROTOR DISC (0 replies)
  22. PORSCHE 914 ULTIMATE PORTFOLIO 914/6, 914SC, 914S & 2.0 (0 replies)
  23. Porsche 914 1.7 1.8 2.0 side shifter 901 transmission pickup only S/ Calif. (0 replies)
  24. Porsche 914 & 914/6 Restorer's Guide to Authenticity (0 replies)
  25. Road & Track On Porsche 1968-1971 911 914 912 917 908 (0 replies)
  26. How to Restore & Modify Your Porsche 914 and 914-6 NEW (0 replies)
  27. Porsche Differential Carrier Bearing & seal set 911 912 914 924 928 69-86 (0 replies)
  28. Porsche 914 Center Deposit / Cushion / Tray / Seat (0 replies)
  29. Road & Track Porsche 1972 73 74 75 911 914 916 917 910 (0 replies)
  30. PORSCHE LOGO/356/911/912E/914/924/928 TOOL ROLL !!! (0 replies)
  31. Road & Track On Porsche 1979-1982 911 912 914 917 924 (0 replies)
  32. Power Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  33. * Vintage P O R S C H E White Stripes 356 912 914 911 (one side)* (0 replies)
  34. Orginal Porsche 914 Fuel Pump !!!!! (0 replies)
  35. Genuine Vent Window Weatherstrip (0 replies)
  36. Porsche 914 911 912 factory used jack nice!!! (0 replies)
  37. Bosch 0237022025 Distributor for VW - porsche 914, 924, 928? (0 replies)
  38. 1970-1976 Porsche 914 Cluster Instrument Cluster White Face Gauges 70-76 (0 replies)
  39. PORSCHE 914 DISTRIBUTOR (0 replies)
  40. Porsche VDO Windshield Washer Pump 911 914 Carrera 928 930 65-89 (0 replies)
  41. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  42. 91-95 Legend 4DR Euro Clear Corner Signal Lights Lamps (0 replies)
  43. Blaupunkt Radio Speaker Cable Porsche 911 356 VW 914 Mercedes BMW 2002 (0 replies)
  44. porsche 914 parts lot (0 replies)
  45. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  46. PORSCHE 914 TOOLS FOR TOOL KIT (0 replies)
  47. Porsche Bump Steer Rack Spacer Kit 911 914 930 Carrera Turbo (73-89) (0 replies)
  48. PORSCHE 914 REAR TURN LIGHTS LENS HELLA (0 replies)
  49. NEW BRAILLE LITHIUM ML20C BATTERY 6.1 lbs 914 cranking amp Free Shipping (0 replies)
  50. Porsche 914 conversion bmw front calipers, (0 replies)
  51. Porsche 914 front brake calipers from a 1973. (0 replies)
  52. Ferrari 328 308 GTS rear sheetmetal clip repair section kit car 1987 914 metal (0 replies)
  53. porsche 914 targa top latches front and rear (0 replies)
  54. porsche 914 vdo oil temp sensor, and " taco plate" or temp plate with cover. (0 replies)
  55. Porsche 914 stainless steel heat exchangers, No Reserve! (0 replies)
  56. Porsche 914 Air Cleaner Box (0 replies)
  57. Porsche 914 and 914/6 Workshop Service Repair Manual Set - Rare Original !!! (0 replies)
  58. VW type 4 Porsche 914 1.7L rocker arms, shafts, spacers and blocks 8mm threads (0 replies)
  59. Weber 48 IDA empi VW Velocity stack Filters VW 914 RX-7 Cobra GT-40 (0 replies)
  60. Porsche 914 interior rear view mirror BMW conversion (0 replies)
  61. Porsche 914 Refurbished Glove Box Door 1973 Basketweave (0 replies)
  62. PORSCHE 912e/914 DIP STICK WITH TEMP. GAGE (0 replies)
  63. VW DIP STICK WITH TEMP. GAGE (0 replies)
  64. SportsCarGraphic PORSCHE 914 ROVER 3500S DODGE CHALLENGER 440 MAGNUM BRM FORMLA1 (0 replies)
  65. Porsche 914 Chrome Window Crank Handle, all 914 (0 replies)
  66. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  67. PORSCHE Genuine Key Set Leather Fob 911 912 914 924 930 964 Carrera Turbo 70-97 (0 replies)
  68. Porsche Ignition Switch Meyle 914/4 73-76 (0 replies)
  69. PORSCHE 914/6 70 71 72 ROTORS PADS FRONT (0 replies)
  70. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS PADS F&R (0 replies)
  71. SIA 1940 LINCOLN ZEPHYR 1958 BONNEVILLE 1976 PORCHE 914 (0 replies)
  72. SportsCarGraphic 1970 PORSCHE 914 FORD CAPRI1600 & 3000GT GREMLIN ROOTES AVENGER (0 replies)
  73. Porsche 914 Rear Trailing Arms Bushing Set NEW + 1 Year WARRANTY (0 replies)
  74. Porsche 356 911 914 Horn Return Spring (Rubber Cup) NEW + 1 year Warranty (0 replies)
  75. Porsche 914 exterior Rear View chrome Mirror ___OEM_new (0 replies)
  76. Porsche 914 Parking Brake Cable (Left) ____OEM Gemo NEW (0 replies)
  77. Porsche 914 Parking Brake Cable (Right) ___OEM Gemo NEW (0 replies)
  78. Porsche 911 914 930 VDO Fuel Tank Level Sensor seal OEM gas sending unit (0 replies)
  79. Porsche 911 930 914 Rear Sway Bar Retaining Brackets (2 (0 replies)
  80. Porsche 911 930 914 Rear Sway Bar Retaining Brackets (2) back stabilizer mount (0 replies)
  81. Porsche 914-4 912e Alternator Belt (10 x 965) ContiTECH (0 replies)
  82. Porsche 914 4/6 Jack hole covers ( 2 ) plugs GENUINE cover plug set (0 replies)
  83. Porsche 914 VW Type 4 Engine Heater / Cooling Tin / Heater (0 replies)
  84. Porsche 911 914 944 Oil Temperature Gauge w/ Temp Sensor NEW (0 replies)
  85. 1974 PORSCHE 914 ORIGINAL DEALERSHIP SALES BROCHURE (0 replies)
  86. 1974 PORSCHE 914 ORIGINAL DEALERSHIP SALES BROCHURE (0 replies)
  87. PORSCHE 911 912 914 930 FRONT SHIFT COUPLER (0 replies)
  88. Dark Green 1971 Porsche 914 Keychain Key Chain Ring 71 (0 replies)
  89. HAWK Brake Pads Combo Fits 1970-1972 Porsche 914 (0 replies)
  90. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  91. Porsche 914 & 914/6 Interior Lights & Lenses Hella OEM Replacement (0 replies)
  92. Porsche Buyer's Guide 4th Ed. 356 901 911 Carrera 912 914 924 928 944 Boxster (0 replies)
  93. 1972 PORSCHE --DR. FERRY PORSCHE-- 911 - 914 - RACING IS THE..***ORIGINAL AD*** (0 replies)
  94. Porsche VW Bus Vanagon Beetle Bug 356 911 912 914 Weber Tuning & Tip Book (0 replies)
  95. BMW 2002 318 320 Bavaria Weber Tuning Tips Book MG MGB Porsche 356 912 914 (0 replies)
  96. Porsche VW Bus Vanagon Beetle Bug 356 911 912 914 Weber Tuning & Tip Book (0 replies)
  97. BMW 2002 318 320 Bavaria Weber Tuning Tips Book MG MGB Porsche 356 912 914 (0 replies)
  98. Porsche 356 912 914 Weber Tuning Tips Book Fiat 124 Spider 1500 1800 2000 (0 replies)
  99. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  100. Porsche Road & Track Book 914 911 917 924 928 1979-82 (0 replies)
  101. Porsche 914-6 911 engine stickers decals reproduction (0 replies)
  102. Porsche 911 914 Audi TT A3 A4 Volvo BMW E36 E34 46 Turbo Blow Off Valve Type RS (0 replies)
  103. DP BRAKES STD BRAKE PADS DP914 ARCTIC CAT 250-500 (0 replies)
  104. PORSCHE 914 RUBBER BUMPER MOUNTS (0 replies)
  105. PORSCHE 914 FOG LIGHTS CROME (0 replies)
  106. PORSCHE 914 HOOD LATCH (0 replies)
  107. NEW OLD STOCK PORSCHE 914 WARM AIR ELBOW (0 replies)
  108. PORSCHE 914 SEAT BELT LIGHT (0 replies)
  109. PORSCHE 914 CIGARETTE LIGHTER (0 replies)
  110. PORSCHE 914 GAS GUAGE (0 replies)
  111. PORSCHE 914 1.7 ENGINE AND TRANSMISSION (0 replies)
  112. PORSCHE 914 ENGINE PULL CABLE KNOB (0 replies)
  113. PORSCHE 914 DOOR STRIKER PLATE (0 replies)
  114. PORSCHE 914 INTERIOR TRIM WINSHIELD (0 replies)
  115. POSCHE 914 REFLECTOR WITH ELECTRIC SOLENOID (NEW) (0 replies)
  116. New Bumper Reinforcement Front Primered MB C Class C230 2000 99 Car 2028800152 (0 replies)
  117. 1974 PORSCHE 911 CARRERA & 914 2.0 in11x17 in RARE AD! GREAT GIFT IDEA FRAMED! (0 replies)
  118. Porsche 356 -911-912-914 JACK PAD RECEIVER STEEL TOOL NEW! A Must Porsche Tool (0 replies)
  119. Porsche 914 86 Stunden NüRburgring 1970 Factory Poster RARE (0 replies)
  120. Porsche 914 Center console gauges (0 replies)
  121. Porsche 914 Center console gauges (0 replies)
  122. Porsche 914 Seats (0 replies)
  123. Porsche 914 Seats (0 replies)
  124. Porsche Flasher Turn Signal Relay 912 914 911 (70-89) (0 replies)
  125. 1974 HUGE PORSCHE 914 Dealer Sales Brochure + bonus (0 replies)
  126. 72 73 74 75 76 77 78-97 JAGUAR VASNDEN PLAS XJ6 XJR 914 + Wix 46025 Air Filter (0 replies)
  127. Borg Warner EGR Valve New in Box EGR914B Fits Chevy V6 4.3L 1988 89 90 91 92 93 (0 replies)
  128. Porsche Bump Steer Rack Spacer Kit 911 912 914 930 (0 replies)
  129. Porsche Interior Light Lens Switch 914/4 914/6 (0 replies)
  130. Porsche 914 Hard Nylon Motor Mounts Race NEW with bolts (0 replies)
  131. PORSCHE 914 HEAT CONTROL LEVERS (0 replies)
  132. Porsche 914 ENGINE COMPARTMENT HEATING FAN (0 replies)
  133. PORSCHE 914 THROTTLE CABLE (0 replies)
  134. PORSCHE 914 ADJUSTABLE FUEL PRESSURE REGULATOR (0 replies)
  135. PORSCHE 914 CLUTCH CABLE (0 replies)
  136. PORSCHE 914 911 912 EMPI IDF 40 Carburetors (0 replies)
  137. SACHS (NOS) KM914 Side Springs Set 6pcs Wankel 303 Arctic Cat Panther Skiroule (0 replies)
  138. Porsche 914 Trunk Hinge Cup Pair of Two (2) 91450103010 (0 replies)
  139. Muffler Installation Set GASKET KIT Leistritz PORSCHE 914/ VW Type 2 Transporter (0 replies)
  140. Muffler Installation Set GASKET KIT Leistritz PORSCHE 914/ VW Type 2 Transporter (0 replies)
  141. [Front Kit] Brake Pads+Rotors Semi-Metallic Premium for 70-71 Porsche 914 K24483 (0 replies)
  142. Porsche Euro-Spec Clear/Amber Front Turn Signal Park Lens set Hella 914/4 914/6 (0 replies)
  143. Porsche : 914 1973 914- 4-cyl 1.7 (0 replies)
  144. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  145. Porsche Front Shocks Bilstein w/rotors 911 912 914 914-6 930 Used (0 replies)
  146. Porsche Steering Rack 911 912 914 914-6 930 Used (0 replies)
  147. PORSCHE & VW FLYWHEEL "O" RING, 1700-2000, 914/4,912E (0 replies)
  148. Porsche 911 Front Control Arms 911 912 914 914-6 930 Used (0 replies)
  149. NEW NOS Front Sway Bar Hardware Adapter Kit Porsche 911 914-4 914-6 ON SALE (0 replies)
  150. Kawaski ZX6 1990-93 Targa Tinted Fluorescent Red Windscreen/ Windshield (0 replies)
