Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. 15" X 5.5" AMERICAN EAGLE ALLOYS 073 4X130 VOLKSWAGON 914 WHEELS RIMS POLISHED (0 replies)
  2. PARTS MASTER DS914 Drag Link-Steering Drag Link (0 replies)
  3. Hirschmann Telescopic AM FM Radio Antenna/Aerial BLACK MAST Porsche 356 914 911 (0 replies)
  4. Porsche Targa Top Rosette Set, 911/912/914/930 (69-85) (0 replies)
  5. Porsche 914 (1970-1976) Interior Dome Cabin Light EMPI NEW (0 replies)
  6. Porsche 911 (65-76) 914-6 Exhaust Manifold Gasket (x1) REINZ output plenum seal (0 replies)
  7. Porsche 914-4 Crankshaft Seal Rear (Flywheel) ELRING KLINGER sealing ring (0 replies)
  8. Porsche : 914 Appearence Group 1975 Porsche 914 (0 replies)
  9. PORSCHE 914 INTERIOR DOOR HANDLE RIGHT SIDE PASSENGER & LATCH CUP (0 replies)
  10. 914 Porsche 96mm big bore kit (0 replies)
  11. Porsche 914 Instrument Cluster Gauges VDO (0 replies)
  12. Porsche Mirror Exterior Chrome Genuine Left or Right 914 70-76 / 914 731 039 10 (0 replies)
  13. PORSCHE 914 SEAT ADJUSTER STOPS (0 replies)
  14. BRAND NEW SET OF ORIGINAL OEM PORSCHE 912E 914 2.0 CONNECTING ROD BEARINGS (0 replies)
  15. NICE ORIGINAL GENUINE PORSCHE 911 914-6 SPORTOMATIC TORQUE CONV OIL PUMP COVER (0 replies)
  16. KAWASAKI NINJA LOWERING STRAP ZX1100D 1000R 750R Z1000 ZRX1100 ZZR 600 1100 750 (0 replies)
  17. Porsche- Exc. Condition Ring & Pinion w/ Differential Hsg & Gear Set 914 '70-'76 (0 replies)
  18. FUSE AND RELAY BOX UNDER THE DASH FOR PORSCHE 914 916 914/6 (0 replies)
  19. Porsche Engine Tune Up Kit, 914-4, 2.0 (73-76) (0 replies)
  20. MOTORCRAFT JK6-914-A Serpentine Belt/Fan Belt-Serpentine Belt (0 replies)
  21. Audi 100 Series Porsche 911 914 930 Ignition Coil Bosch 00025 (0 replies)
  22. Porsche 914 outer window fuzzy set of 2 metal (0 replies)
  23. 17" PANTHER 914 FLITE 5X115 IMPALA SS CHARGER ALERO MAGNUM CHROME WHEELS RIMS (0 replies)
  24. XRF DS914 XRF CHASSIS PARTS (0 replies)
  25. (FRONT KIT) (SILVER ZINC) Slotted & Drilled Rotors AND Metallic Brake Pads (0 replies)
  26. Porsche : 914 914 1972 Porsche 914, Original Owner, California Car, always garaged with cover (0 replies)
  27. CRYSTAL CLEAR HEAD LIGHTS LAMPS SIGNAL PARKING CORNER 91-96 CHEVY IMPALA/CAPRICE (0 replies)
  28. (FRONT KIT) (GOLD ZINC) Slotted & Drilled Rotors AND Metallic Brake Pads (0 replies)
  29. Porsche 914 -4 1.7 L Distributor, BOSCH , 0231174001 (0 replies)
  30. (FRONT KIT) (GOLD ZINC) Slotted & Drilled Rotors AND Metallic Brake Pads (0 replies)
  31. NEW MAHLE ENGINE OIL FILTER. PORSCHE (911, 914) 1965-1971 (#OC61/90110720309) (0 replies)
  32. PORSCHE 914 1.7 ENGINE COMPUTER AND HARNESS 0280000015 (0 replies)
  33. Porsche 356 /912 /911 /914 Fog Lights Original "Hella" (0 replies)
  34. ACDELCO OE SERVICE CV914C PCV Valve (0 replies)
  35. Complete Set of Original Porsche 914 Factory Service Manuals + Bonus Books (0 replies)
  36. WAGNER QC914 Brake Pad or Shoe, Front-ThermoQuiet Brake Pad (0 replies)
  37. VW Bus Van Porsche 914 Front Brake Hose 1971-79 (PAIR) (0 replies)
  38. 914 PORSCHE SPEEDOMETER (0 replies)
  39. Porsche 911 914/6 Brake Caliper M Type LH RH Front 911 911l 911e 911t 914-6 (0 replies)
  40. Multi Function 5 Pin Relay, Porsche 911/912/930/912E/914, 911.615.108.01 (69-89) (0 replies)
  41. Porsche 911 Rod Bearing Set (Standard)1972-1977 NEW #NS (0 replies)
  42. PORSCHE 914 EARLY ENGINE MOUNTING BRACKET (0 replies)
  43. Porsche 914 Carbon Canister / Filter (0 replies)
  44. porsche 914 bra front sold to the highest bidder (0 replies)
  45. Porsche 911 / 912 / 914 Clutch Release Bearing KIT, '65-'76 ,NEW, #NS (0 replies)
  46. FRONT SEMI METALLIC DISC BRAKE PAD KIT FULL SET WITH LIFETIME WARRANTY (0 replies)
  47. Porsche 914 72-76 Disc Brake Rotor Front Set of 2 SEBRO COATED 411407075B (0 replies)
  48. Porsche 914 70-72 Disc Brake Rotor Front Left or Right SEBRO COATED 411407075 (0 replies)
  49. VEL. MARTINI MAT SET FOR Porsche 914 (0 replies)
  50. Porsche Marelli Distributor 1970-71 911T and 914-6 (0 replies)
  51. PORSCHE 901 911 912 914 5 LUG REAR WHEEL HUB T E S LWB 911T 911E 911S (0 replies)
  52. Porsche Muffler Gasket Set, 021.298.001.A 914-4 (70-74) (0 replies)
  53. Porsche 914 4/6 Battery Tray (Upper part) DANSK new holder shelf bracket 914/4 (0 replies)
  54. Porsche 914 4-cylinder 1969-76 service/repair/maintenance manual (0 replies)
  55. Stator 2112-0516 (0 replies)
  56. VDO Speedometer Cable Angle Drive (0 replies)
  57. 914 PORSCHE PEDAL SYSTEM, CLUTCH AND BRAKE PEDALS (0 replies)
  58. 2000-2004 BMW K1200 RS/GT Power Commander 3 / PCIII USB - 914-611 (0 replies)
  59. Porsche 911 / 912 914 / Decklid Lock upper part NEW #NS (0 replies)
  60. Porsche 911 / 912 / 914 / 930 Pedal Bushing Set (Bronze) , NEW #NS (0 replies)
  61. Porsche 911 / 912 / 914 Front(Left or Right) Tie Rod Assembly, NEW #NS (0 replies)
  62. New Porsche 914 Clutch Cable 1970 - 1976 1.7 1.8 2.0 (0 replies)
  63. Porsche 911 912 914 Brake Pedal Bushing Set of 2 CANYON 911 423 542 00 (0 replies)
  64. Porsche 911 912 914 65-89 Clutch Pedal Bushing Set of 2 CANYON 91142334101 (0 replies)
  65. Porsche 911 Turbo 912E 914 4/6 Clutch Cable Clevis at Release Fork URO (0 replies)
  66. Porsche 911 (65-71) 914-6 engine Oil Filter (x2) OEM Mahle (0 replies)
  67. Porsche 911 (65-71) 914-6 engine Oil Filter (x4) OEM Mahle (0 replies)
  68. Porsche 914 1970-1974 Original Fog Lights Package. (0 replies)
  69. Porsche 914 Four Original Used Center Caps. (0 replies)
  70. Porsche 914 Seat Rails (0 replies)
  71. Porsche 911 / 912 / 914 / 930 License Plate Light 1974 - 89 NEW #NS (0 replies)
  72. Porsche 911 / 912 / 914 / Shift Rod Bushing (in Tunnel) 930 NEW #NS (0 replies)
  73. Hygrade 914 Carburetor Repair Kit (0 replies)
  74. 1973 PORSCHE 914 "TRUNK HOOD / COVER / LID" LIGHT, BABY BLUE (0 replies)
  75. Electric Fuel Pump, Porsche 912E/914, (75-76) (0 replies)
  76. 1970 - 1976 Porsche 914 Right Side Passenger Door with Vent Window and Glass (0 replies)
  77. VW Porsche 914 2.0L 32/36 Weber Carburetor Carburator Conversion (0 replies)
  78. 92 Porsche 911 964 C2 complete front rear suspension struts brakes 914 912 SC (0 replies)
  79. Porsche 911 / 912 / 914 Steering Rack Boots (2) NEW #NS (0 replies)
  80. Mini Cooper S Convertible JCW R56 R57 Passenger Right Taillight 63 21 7 255 914 (0 replies)
  81. 914 Porsche steering column (0 replies)
  82. 911/914 Inline Fuel Pressure Gauge Kit (0 replies)
  83. One Can Liquid Wrench Silicone Spray LM914 11oz Spray (0 replies)
  84. EXCELLENT! WINDOW CRANK HANDLE FOR PORSCHE 914 914/6 916 914-6 912 911 (0 replies)
  85. Porsche 356 B / C / 911 / 912 / 914 / 930 Ball Cup Bushing for Shift Lever NEW (0 replies)
  86. Porsche 911 / 912 / 914 Sway Bar Bushing - Sway Bar Link to Ball Pin (4) NEW #NS (0 replies)
  87. Porsche 911 / 912 / 914 / 930 Steering Shaft Bearing (in Lower Shaft Housing)#NS (0 replies)
  88. Porsche 912 / 914 Flywheel Bolts (5) NEW #NS (0 replies)
  89. Porsche 356 / 911 / 912 / 914 Windshield Washer Nozzle NEW #NS (0 replies)
  90. Porsche 914 center console original! (0 replies)
  91. Cast Iron Exhaust Manifold (Dorman# 674-914) (0 replies)
  92. *PROJECT MU* B-Force- PBF914 BRAKE PADS- FRONT (0 replies)
  93. Porsche 914 horn contact (0 replies)
  94. Porsche Oil Pressure Sender Unit URO 911 914/6 / 901 741 551 01 (0 replies)
  95. Porsche Ignition Switch Meyle 914/4 72-74 / 111 905 865 (0 replies)
  96. NEW PORSCHE 914 VACUUM TUBE ELBOW (0 replies)
  97. Stage 8 CV Joint Locking Bolt Kit for 914 (0 replies)
  98. USED ORIGINAL GENUINE PORSCHE 911 356 912 914 944 968 BRAKE IN LINE CONNECTOR (0 replies)
  99. Porsche 912 914 Hose 14 X 19 mm - Outside Cloth Braided CONTITECH N 020 371 1 (0 replies)
  100. Rear transmission rubber mounts for PORSCHE 914 914/6 914-6 916 (0 replies)
  101. Porsche 914 4/6 Speedometer Angle Drive on Transmission speedo gear (0 replies)
  102. Porsche 911 (72-77) Rod Bearing + 0.25 mm (set 12) GENUINE bearings (0 replies)
  103. Porsche mainshaft bearing 999 053 025 00 911 912 914 (0 replies)
  104. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  105. Blaupunkt Radio Faceplate Porsche 911 356 914 VW Bug Bus Mercedes BMW Alfa (0 replies)
  106. porsche 914 fuse block sold to the highest bidder (0 replies)
  107. porsche 914 blower fan motor and assembly sold to the highest bidder (0 replies)
  108. VW SHORT block AP ENGINE 004-101.102A S112 3 1975 1800CC/PORSCHE 914 (0 replies)
  109. Porsche 914 chrome fog light grills. (0 replies)
  110. PCV VALVE Genuine OEM NEW AC CV914C Buick Pontiac Oldsmobile Chevrolet GMC D9 (0 replies)
  111. Porsche 914 clear front turn signal lens Set of 2 with seals (0 replies)
  112. Porsche 914 interior rear view mirror BMW conversion (0 replies)
  113. Porsche 914 72-76 Rear Brake Hose 113611775 211611775B (0 replies)
  114. USED 914 PORSCHE ASHTRAY PULL-OUT CIGARETTE CIGAR 914-6 2.0 DASH PART (0 replies)
  115. Porsche Turn Signal Front Lens Euro-Spec Clear/Amber set Hella 914/4 914/6 (0 replies)
  116. Porsche 356 911 914 JACK PAD RECEIVER STEEL NEW (0 replies)
  117. Porsche 911 / 914 Wrist Pin Bushings (6) NEW #NS (0 replies)
  118. Porsche 356 / 911 / 912 / 914 Wrist Pin Bushing NEW #NS (0 replies)
  119. RENNLINE 1974 1994 911/912/914/930/964 INTERIOR DOOR HANDLE SET PLAIN BLACK (0 replies)
  120. Porsche 356 A / B / C / 911 / 912 Fuel Level Sensor Gasket NEW #NS (0 replies)
  121. 914 PORSCHE HOOD HINGES 70-76 PORSCHE (0 replies)
  122. Porsche 912 914 Vacuum Hose 3.5 X 7 mm Outside Cloth Braided CONTITECH N0203535 (0 replies)
  123. Porsche 912 914 Hose 12 X 19 mm Outside Cloth Braided CONTITECH N 020 290 1 (0 replies)
  124. Porsche 914 engine stickers decals (peel & stick) (0 replies)
  125. Porsche 356 911 930 914-6 Camshaft Gear 3 Lock Plates + 1 year Warranty (0 replies)
  126. Belltech Lowering Kit New Truck Hardbody Pickup ML Class G MB Nissan 914SP (0 replies)
  127. Belltech Sport Trucks Lowering Kits with Street Performance Shock Absorber 914SP (0 replies)
  128. Porsche 914 Left Right pair Inside Roll Bar Trim, black vinyl upholstery panels (0 replies)
  129. Porsche 911 / 912 / 914 / Locking Plate for Differential Housing Bolts NEW #NS (0 replies)
  130. Porsche 911 / 912 / 914 / CV Joint Axle Boot Rear Inner or Outer NEW #NS (0 replies)
  131. 97-04 CHEVY CORVETTE C5 BLACK CLEAR BUMPER CORNER SIGNAL LIGHTS LAMPS PAIR (0 replies)
  132. Porsche 356 / C 356 / SC 911 / 912 / 914 Set Of 4 Bleed Valve covers NEW #NS (0 replies)
  133. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS + PADS F/R (0 replies)
  134. 98-02 ACCORD PRELUDE JDM ADJUSTABLE COILOVER LOWERING SPRINGS w/ SILVER SLEEVE (0 replies)
  135. EXCELLENT ORIGINAL PORSCHE 911 356B 356C 912 914 930 ATE BRAKE BANJO FITTING (0 replies)
  136. Porsche 356A 911 914 1956 1957 1958 1959 - 1973 Elring Klinger Main Shaft Seal (0 replies)
  137. RAYBESTOS ATD914C Brake Pad or Shoe, Front-Advanced Technology Brake Pad (0 replies)
  138. Porsche 914 1974 Meistersatz Ignition Switch 111905865K (0 replies)
  139. Porsche 914 Victor Reinz Felt Washer - Flywheel to Pilot Bearing (0 replies)
  140. Porsche 914 356A 356B 356C 356SC 1956 1957 1958 - 1976 Beru Spark Plug Wire Set (0 replies)
  141. Porsche 914 1971 O.E.M. Windshield Moulding Set 106353914 (0 replies)
  142. Porsche 914 engine seal set of all 4 seals (0 replies)
  143. NEW ARLEN NESS CHROME ENGRAVED SHIFT LINKAGE HARLEY DAVIDSON TOURING FLHT FLHX (0 replies)
  144. Spec Stage 4 Clutch SP914 for 65-69 Porsche 911 2.0L 911 T 911E (0 replies)
  145. Porsche 914 clutch pressure plate and disk new in box remanufactured (0 replies)
  146. Porsche 356 B / C / 914 Transmission Shift Rod Seal NEW #NS (0 replies)
  147. Pair NOS Cibie Tango driving beam Headlamps for porsche 356 911 912 914 (0 replies)
  148. Porsche 356 / 914 / 928 Brake Fluid Reservoir Cap NEW #NS (0 replies)
  149. Porsche : 914 GT Steel flare car 914/6 With GT Steel Flares (0 replies)
  150. Porsche 356 / 911 / 912 / 914 / 928 / 930 Back-Up Light Switch, URO ,NEW #NS (0 replies)
