Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 outer window fuzzy set of 2 metal (0 replies)
  2. Porsche 914 inner door fuzzey seals for windows (0 replies)
  3. Porsche 914 Main targa seal rubber with aluminum clips will not rust (0 replies)
  4. 914 Porsche 2.0L Fuel Injectors - Newly Rebuilt (0 replies)
  5. Porsche 914 1969 1970 1971 1972 1973-1976 Car cover (0 replies)
  6. 73-76 Porsche 914/4 (Front Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  7. 73-76 Porsche 914/4 (F&R SET) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  8. 70-71 Porsche 914/4 (F&R SET) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  9. 70-71 Porsche 914/4 (Front Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  10. 70-76 Porsche 356 914/4 (Rear Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  11. 70-72 Porsche 914/6 (Rear Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  12. 70-76 Porsche 914/4 (Rear Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  13. 70-72 Porsche 914/6 (F&R SET) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  14. 70-72 Porsche 914/6 (Front Set) POSI QUIET CERAMIC BRAKE PADS (0 replies)
  15. "RARE" Porsche 911 901 914 Transmission "M" "Short Ratio" 29:22 3rd Gear Set (0 replies)
  16. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  17. Porsche 911 914 901Transmission "V" 4th Gear Set 27:25 (0 replies)
  18. Early Porsche 911/ 901 / 914 Transmission Clutch Fork 901.116.712.00 (0 replies)
  19. Porsche 911 914 901 Transmission "0" Third Gear Set 23: 28 1965-1976 (0 replies)
  20. Porsche 914 OEM Right side Head lamp Cover (0 replies)
  21. PORSCHE 914 HEADLIGHT BEZEL USED, LEFT SIDE ONLY (0 replies)
  22. PORSCHE 911 944 928 912 914 OEM ALUMINUM LUG NUTS SET OF 5 (0 replies)
  23. 1 - Porsche 911 901 914 Transmission Synchro & Hardware Kit (2nd-5th) 1965-76 (0 replies)
  24. Porsche 911 901 914 Transmission 1st / Reverse Slider / Shift Sleeve 91130222600 (0 replies)
  25. Porsche 911 901 914 Transmission Pinion Shaft Front Bearing 99911000700 1965-76 (0 replies)
  26. Porsche 911 901 914 Transmission Pinion Shaft Thrust washer 90130229401 1965-76 (0 replies)
  27. 4 - Porsche 911 901 914 Transmission Synchronizer Lock Rings 91130231101 1965-86 (0 replies)
  28. Porsche 911 901 914 Transmission 1st / Reverse Slider / Shift Sleeve 91130222600 (0 replies)
  29. 5 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  30. Porsche 911 901 914 Transmission Shifting Guide Sleeve 90130240202 1965-71 (0 replies)
  31. Porsche 911 901 914 Transmission 1st Gear Synchro & Hardware Kit 1965-76 (0 replies)
  32. Porsche 914/4 Workshop Maintenance & Repair Manual by Drake Publishers (1972,... (0 replies)
  33. Mann Filter Porsche 914 P/N 039129620 A (0 replies)
  34. Aluminum finned valve covers VW Volkswagon Type IV 4 914 (0 replies)
  35. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  36. Porsche 911 Carrera RSR Sebring 73 Banner 914 917 944 (0 replies)
  37. Hella Side Marker Lamps for Porsche 914 all years. (0 replies)
  38. Hella front Turn Indicator lens for PORSCHE 914 (4 Total Lenses) (0 replies)
  39. PORSCHE 914 2.0 LITER CASE 1973 (0 replies)
  40. Porsche 914 Type IV 2.0 Manifold Pressure Sensor (0 replies)
  41. PORSCHE 914 SHIFT LEVER WITH LEATHER BOOT AND NICE BALL (0 replies)
  42. 1967 PORSCHE 911-AD/PICTURE/PRINT 65 66 68 928 914 924 TARGA (0 replies)
  43. Martini Porsche 911 RSR Turbo 1974 Banner 956 914 935 (0 replies)
  44. Porsche 914 Miscellaneous Interior Parts (0 replies)
  45. Porsche 914 Hella Factory Fog Lights (0 replies)
  46. Porsche : 914 1974 Porshe 914 Slant Nose Wide Body, NO RESERVE!! (0 replies)
  47. Porsche Section 69 70 71-79 Hollander Interchange Manual 5th 356 911 912 914 924 (0 replies)
  48. Porsche 914 side shift transmission complete (0 replies)
  49. Porsche 24hrs DuMans 1970 - Porsche 914-6 Car Poster Licensed Reprint. (0 replies)
  50. Porsche 914 Winshield/ Targa Trim Chrome (0 replies)
  51. Porsche 914 Side Shift Transmission Case - Magnesium (0 replies)
  52. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  53. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  54. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  55. Vintage Hapewe Pliers For Porsche 911 & 914/6 Factory Tool Kits (0 replies)
  56. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  57. Porsche 914 & 914/6- Brian Long definitive history- mint + free shipping (0 replies)
  58. Elring M/T Gasket Set (0 replies)
  59. VDO GUAGES COMPLETE INSTRUMENT KIT 5 GAUGES HERITAGE GOLD (0 replies)
  60. Porsche 914 Plush Carpet set 70-76 NEW (0 replies)
  61. Porsche 914 GERMAN MATCH Perlon Carpet set 70-76 (0 replies)
  62. porsche 914 engine cover with rain drip pan (0 replies)
  63. GENUINE AND ORIGINAL REAR SWAY BAR CLAMPS/SUPPORTING BOW FOR 73-74 PORSCHE 914 (0 replies)
  64. AFTER MARKET DRIVERS SIDE EXTERIOR MIRROR 1973 Porsche 914 2.0. MANUALLY ADJUST (0 replies)
  65. GENUINE AND ORIGINAL HELLA FOG LIGHT SWITCH (W/O PULL KNOB) PORSCHE 914 2.0 (0 replies)
  66. GENUINE AND ORIGINAL REAR SWAY BAR CLAMPS/SUPPORTING BOW FOR 73-74 PORSCHE 914 (0 replies)
  67. PORSCHE 914/4 1970 All Ceramic Front Brake Pads With Shims (0 replies)
  68. Porsche : 914 924 Turbo 1981 Porsche 924 Turbo!! (0 replies)
  69. Porsche 914 VDO combi gauge -fuel oil brake (0 replies)
  70. VW Porsche 914 Bug Beetle Bus NOS Bosch Vacuum Advance (0 replies)
  71. Ball Joints 1974 volkswagen 412 or Porche 914 NOS Quinton Hazell (0 replies)
  72. porsche 914 hood (0 replies)
  73. porsche 914 left rear fender (0 replies)
  74. porsche 914 right rear fender (0 replies)
  75. porsche 914 right front fender (0 replies)
  76. porsche 914 left front fender (0 replies)
  77. Porsche 914 Fuel tank (0 replies)
  78. Porsche 914 Fuse Box Block, 12 Pole Ceramic Fuse Style, OEM , 914 '70-'76, New (0 replies)
  79. Porsche 356 911 912 914 924 928 944 964 Steering Wheel (0 replies)
  80. Volkswagen Bus, 412, Porche 914 Air Flow Meter 1974 Bosch, Air Cooled (0 replies)
  81. Porsche Back-Up Light Switch 914/4 (70-76) (0 replies)
  82. PAIR OF USED ORIGINAL PORSCHE 914 FRONT WHEEL GREASE CUP CAPS (0 replies)
  83. 356 & 912 & 914 Weber 40 IDF Rebuild Kit for Porsche (0 replies)
  84. 1 Porsche 356 911T 911S 912 914 Original German License Plate, VW AUDI BMW #5 (0 replies)
  85. Porsche 356 911T 911S 912 914 Original German License Plate VW AUDI BMW LOT #4 (0 replies)
  86. Porsche 356 911T 911S 912 914 Original German License Plate VW AUDI BMW LOT #3 (0 replies)
  87. Porsche 356 911T 911S 912 914 Original German License Plate VW AUDI BMW LOT #2 (0 replies)
  88. Porsche 356 911T 911S 912 914 Original German License Plate VW AUDI BMW Mercedes (0 replies)
  89. Bosch 0237022025 Distributor for VW - porsche 914, 924, 928? (0 replies)
  90. New PORSCHE Positive Lower Side Stripe Kit 914 911 930 924 944 S1 S2 GTS Turbo (0 replies)
  91. 65-73 Porsche 911T 911E 911S 912 914 Dual Electirc Horns, NEW VW AUDI 66 67 68 (0 replies)
  92. Porsche 914 Motor Mount (0 replies)
  93. Porsche 911 914 Audi TT A3 A4 Volvo BMW E36 E34 46 Turbo Blow Off Valve Type RS (0 replies)
  94. Porsche 914 Air Cleaner Box (0 replies)
  95. Porsche 914 Air Cleaner Box (0 replies)
  96. PORCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  97. PORSCHE 914 HEAT CONTROL LEVERS (0 replies)
  98. NEW YORK PORSCHE 911 914 COMPRESSOR 1978-1979-1980-1981-1982-1983 ROTOLOCK RIGHT (0 replies)
  99. BOSCH BC914 Brake Pad or Shoe, Front (0 replies)
  100. Porsche 914 Used Bosch Starter 003911023A 911 912 (0 replies)
  101. LEATHER 911 RS CARRERA 914/6 VDM 380 mm STEERING WHEEL PORSCHE 911 S E T (0 replies)
  102. PORSCHE KEY CHAIN 356 550 911 914 DEALER VW SPLIT BUG BEETLE RARE GOLDEN COOL T1 (0 replies)
  103. keyChain, leather, metal, fashion and honorable, key rings, HONEST-914 (0 replies)
  104. Pierburg 12V fuel pump P/N: 7.21440.28 (Rotax 914) (0 replies)
  105. Porsche 911 914 Brake Pedal Bushing set Bronze (0 replies)
  106. BING 64 CD Carburetors for Rotax 914 F/UL Engines (0 replies)
  107. VW Porsche 914 type 4 2.0 Forged flywheel resurfaced lightened 12lbs. (0 replies)
  108. Porsche 914/6 GT Mid Engine Racing Montage CarPoster: ) (0 replies)
  109. porsche 914 rear brake rotors drilled and slotted (0 replies)
  110. PORSCHE 914/4-914/6's 70-76 HEADLIGHT MOTORS (0 replies)
  111. PORSCHE 914/4 70-76 complete FUSE BOX ASSEMBLY (0 replies)
  112. Porsche : 914 Porsche 914 ravenna green VIDEO (0 replies)
  113. VINTAGE PORSCHE 914 SIDE BODY "PORSCHE " DECALS O.E.M. STILL STICKY CLEAN BACK!! (0 replies)
  114. Porsche 914 Rebuilt 2.0L cylinder heads (0 replies)
  115. Pertronix Ignitor Ignition & Coil Porsche 912E 914 924 (0 replies)
  116. Porsche 914 targa white plastic roof holders forward clips left and right (0 replies)
  117. Porsche 914 fuse panel with relays (0 replies)
  118. Porsche 914 locking glove box with lid wood trim - includes key & mounting screw (0 replies)
  119. Dual Electric Trumpet Hi/Lo Horns Set Porsche 911 912 914 LOUDEST We Can Find!!! (0 replies)
  120. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER (0 replies)
  121. Porsche 914 Rear View Mirror Used (0 replies)
  122. PORSCHE 914 DOOR HANDLES IGNITION TRUNKS ALL LOCKS ONE KEY FITS ALL (0 replies)
  123. Porsche 914 1.7 distributor cap/rotor (0 replies)
  124. Porsche 914 Clock 91464111910 (0 replies)
  125. BRAND NEW HASTINGS AIR FILTER / CLEANER AF914 OBSOLETE PART NUMBER HARD TO FIND (0 replies)
  126. porsche 914 dash pad (0 replies)
  127. porsche 914 rear deck emblem (0 replies)
  128. porsche 914 leather steering wheel with horn pad (0 replies)
  129. Porsche 914 Top of Targa Bar Trim Chrome (0 replies)
  130. PORSCHE 914 HEAT LEVER LIGHT OEM (0 replies)
  131. 91-95 Legend 4DR Clear Signal Corner/Bumper Lights Lamp (0 replies)
  132. Porsche 914 Sail Panel Trim Chrome (0 replies)
  133. 1975 FIAT X 1/9 vs. PORSCHE 914 in a RARE, ORIG AD! (0 replies)
  134. Porsche 911 Bump Steer Kit New 1974-1989 S SC Carrera Turbo 914 (0 replies)
  135. porsche 914 fuel injection trigger points (0 replies)
  136. Porsche 914 Winshield Trim Chrome (0 replies)
  137. CONSOLE for 914 with Airconditioning ( sold ) (1 replies)
  138. Porsche 914 86 Stunden NüRburgring 1970 Factory Poster RARE (0 replies)
  139. Porsche 914 Charcoal Gray Loop Carpet Set 1970 -1975 (0 replies)
  140. Porsche 914 Black Loop Carpet Set 1970 -1975 (0 replies)
  141. porsche 914 fuchs alloy wheels (0 replies)
  142. PORSCHE 911 912 914 HORN CENTER STEERING WHEEL 901.613.805.0 (0 replies)
  143. Porsche 914 Brake Pads NEW (0 replies)
  144. Porsche 914 Headlight Covers (0 replies)
  145. LOUD Fiamm Dual Blaster Trumpet Hi/Lo Horn Set fits Classic Porsche 911 912 914 (0 replies)
  146. Element Front & Rear Brake Pads 2008 2009 (0 replies)
  147. Element Front & Rear Brake Pads 2004 2005 (0 replies)
  148. Element Front & Rear Brake Pads 2006 2007 (0 replies)
  149. SportsCarGraphic PORSCHE 914 ROVER 3500S DODGE CHALLENGER 440 MAGNUM BRM FORMLA1 (0 replies)
  150. #24 914 Type IV header with glass pack, solid, no rust BEFORE hi temp paint nice (0 replies)
