Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Bosch Fuel Injector 0280150009 022906031A Porsche 914 Base 4 1.7L lot of 3 (0 replies)
  2. Porsche 911 (65-86) 914 Shift Rod Coupling Set SCREW (0 replies)
  3. Hidden Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  4. VDO Porsche 914 Tach 7K RPM Tachometer 1970-1973 91464130210 OEM (0 replies)
  5. New BWD Ignition Coil E914 (0 replies)
  6. BWD Ported Vacuum Switch EC914 (0 replies)
  7. Multi Function 5 Pin Relay, Porsche 911/912/930/912E/914, 911.615.108.01 (69-89) (0 replies)
  8. Porsche 914 turn signal wiper switch stalk (0 replies)
  9. Hella On/Off Dash Switch for Porsche 356/911/912/912E/930/914/C2/C4 (0 replies)
  10. ONESOURCE MKD914 Brake Pad or Shoe, Front (0 replies)
  11. Porsche 914 Defroster / Fresh Air Vent *Left Side* (0 replies)
  12. PORSCHE OEM 914 73-76 Side Shift Engine Motor Carrier with Mounts Complete!!!!!! (0 replies)
  13. Porsche 914 Outside Door Handle Leftt hand (0 replies)
  14. Porsche 914 Heater Air Distribution Flapper Box Vent *Left* (0 replies)
  15. 70 71 72 73 74 75 76 Porsche 914 Right Side Front Door Vent Glass (0 replies)
  16. 1969 Camaro 1969-1972 Nova 4SP BB Lockout Linkage Set (0 replies)
  17. AFE 30-10075 OER PRO 5R AIR FILTER AUDI 100/200/5000 PORSCHE 914/924 JAGUAR XJS (0 replies)
  18. Porsche 914 heater blower branch neat item for hot heat (0 replies)
  19. MOTORCRAFT WPT-914 Airbag/Module Connector (0 replies)
  20. Porsche 911 914-6 Wheel Studs Set - Long (0 replies)
  21. Brand New Power Steering Reservoir (Dorman 603-914) w/o Fluid Sensor (0 replies)
  22. PORSCHE 914 2 CLEAR FRONT TURN SIGNAL LENSES GENUINE NEW (0 replies)
  23. Porsche 911T 914-6 Spark Plugs BOSCH WR5DC+ 7992 ( 6 ) (0 replies)
  24. PORSCHE STEERING WHEEL RESTORATION 911 914 944 928 964 993 996 997 BOXSTER (0 replies)
  25. Porsche Wiper & Turn Signal Decals 911/912/914 (0 replies)
  26. Power Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  27. Porsche 914 TPS Position sensor board 1.7 72-73 1.7 L only fits late version (0 replies)
  28. Porsche Solid Wrist Pin Bushing 356/911/912/914/930 (0 replies)
  29. Clutch Disc Orginal PORSCHE 215mm SACHS GERMANY;1965-1969 911 E/T/S,914-6 to1972 (0 replies)
  30. Chrome C-pillar moulding / trim cover for 2011+ Kia Optima (0 replies)
  31. New MD914 brake Pads set front (0 replies)
  32. SMP/STANDARD ALS914 Rear ABS Wheel Sensor (0 replies)
  33. Monroe GX914 Front Ceramic Brake Pads (0 replies)
  34. MOOG DS914 Drag Link (0 replies)
  35. Porsche Early 911 912 914 356 930 **Early 911s engine grille badge** (0 replies)
  36. Electric Fuel Pump for 70-76 Porsche VW Beetle Transporter Vanagon 912 914 (0 replies)
  37. Porsche 914 Engine grill letters ful set PORSCHE metal GOLD new and shinny (0 replies)
  38. Harley-Davidson Motor Cycles Helmet XXL 63-64 cm Black Color B914 (0 replies)
  39. Electric Fuel Pump for 70-76 Porsche VW Beetle Transporter Vanagon 912 914 (0 replies)
  40. SKI DOO SNOWMOBILE PARTS SPINDLE #914 (0 replies)
  41. Centric Parts 150.37303 Front Brake Hose Porsche 914 (0 replies)
  42. Porsche 914 Parts Grab Bag (0 replies)
  43. PORSCHE 914 CENTER CAPS MAHLE FUCHS PEDRINI Billet correct fit set of all 4 (0 replies)
  44. VW Porsche Type 4 104mm Piston & Cylinder Kit 914 Bus Big Bore (0 replies)
  45. Porsche 914 defrost light cover for center console beautiful condition LOOK (0 replies)
  46. DAYCO 71289 Upper Radiator Hose (0 replies)
  47. Porsche 356 speedster or 914 crown hubcap with badge (0 replies)
  48. (CL914) 00 01 02 KIA RIO SPEEDOMETER CLUSTER 101K 257-61635 (0 replies)
  49. PARTS MASTER DS914 Drag Link-Steering Drag Link (0 replies)
  50. Parts Master DS914 Steering Drag Link, Front (0 replies)
  51. Porsche 914 original owners manual 1974 (0 replies)
  52. DORMAN 603-914 Steering Pump (0 replies)
  53. MOOG DS914 Drag Link (0 replies)
  54. PORSCHE 914 5 SPEED ZF DOG LEG TRANSMISSION GD COND USED ORIG 901 (0 replies)
  55. New Moog Drag Link Front Ram Truck Dodge Ramcharger Plymouth Trailduster DS914 (0 replies)
  56. EBC Ultimax Brake Pad UD914 (0 replies)
  57. 1970-1972 Porsche 914/4 Original Toolkit. Complete with Tool Bag. (0 replies)
  58. Hidden Antenna Kit - 1970 thru 1976 Porsche 914 (0 replies)
  59. Porsche 914/6 Console Gauge Tachometer & Foot Rest rare (0 replies)
  60. PORSCHE 914 SPORT EXHAUST (0 replies)
  61. Porsche Brake Distribution Joint 356's/911/912/930/914/912E/C2/C4/911 (0 replies)
  62. Porsche 356 911 912 928 cayman boxster 914 944 embossed key pouch reproduction (0 replies)
  63. Bronze Pedal Bushing Kit Porsche 911/912/930/912E/914 (0 replies)
  64. SMOKE LENS HEAD LIGHTS LAMPS W/SIGNAL PARKING CORNER 91-96 CHEVY IMPALA/CAPRICE (0 replies)
  65. Porsche 911 Turn Signal Relay 1969-1984 Part# 914 618 303 11 (0 replies)
  66. 1973 1.7L Zambezi Green (0 replies)
  67. MOOG DS914 Drag Link-Steering Drag Link (0 replies)
  68. 1 left air cooled 2.0 cylinder head 071 101 371A VW Vanagon Porsche 914 (0 replies)
  69. Porsche 911 / 912 / 914 CV Joint Boot with Flange NEW (0 replies)
  70. 1975 Porsche 914 Deluxe Sales Brochure w/ FREE BONUS Technical Data Sheet. MINT! (0 replies)
  71. Porsche 914 upgrade Oil Cooler Kit (New) (0 replies)
  72. Porsche 914 TRANSMISSION DIFFERENTIAL from 1975 914 SIDE SHIFTER TRANS (0 replies)
  73. 443253115B Porsche 914 muffler to exhaust pipe gasket. (0 replies)
  74. 029105245 Porsche 912E 914 914/4 rear main seal (0 replies)
  75. 022115331 Porsche 1.8 914 912 VW oil cap O ring (0 replies)
  76. Porsche 914 944 951 968 Battery Hold Down Clamp GENUINE NEW + Warranty (0 replies)
  77. Porsche 914 speaker pods left and right fiberglass 6.5" speaker 2.75" depth NEW (0 replies)
  78. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS + PADS F/R (0 replies)
  79. Porsche 914 911 944 928 Blaupunkt San Antonio original owners manual (0 replies)
  80. Porsche 914 Sun Visor excellent condition driver's side (0 replies)
  81. Porsche 914 Headlamp Assembly & Motors (0 replies)
  82. Porsche : 914 2.0 1976 Porsche 914 (0 replies)
  83. ***Porsche 914/914-6 Complete Workshop/Service/Repair Manuals for 1969-1976*** (0 replies)
  84. Porsche 914-6 GT Koni Dual Adjustable Racing Rear Shock New NLA Rare ONLY ONE! (0 replies)
  85. Porsche 914 Bosch Fog/Driving Light Lens 1975-1976 Rare!! (0 replies)
  86. Porsche 914 '69-'76 Outdoor Custom Fit Car Cover SALE! (0 replies)
  87. Proform 2-Piece Die-Cast Aluminum Valve Covers 141-914 Chevy SBC 283 305 350 400 (0 replies)
  88. Porsche 914 Throttle body gasket 1.7 motor only NEW (0 replies)
  89. Porsche 914 5 SPEED TRANSAXLE - SIDE SHIFT - CORE (0 replies)
  90. Porsche Fuel Filter Mahle KL11 914 70-76 356 A B C SC 56-65 (0 replies)
  91. Porsche Shifter Boot Black Rubber OEM 911 912 914 / 914 424 901 00 (0 replies)
  92. Porsche VW 914 914/6 1969-1976 9 Volume Workshop Repair Manual +Parts on CD! (0 replies)
  93. BLAUPUNKT CAR RADIO PORSCHE 911 912 914 BLAUPUNKT RADIO MERCEDES RADIO-Vintage (0 replies)
  94. Porsche steering rack pan seal set of 2 with steel clip like OEM 911 914 356 (0 replies)
  95. Porsche 914 Air Cleaner Box (0 replies)
  96. Full Set Front Rear Disc Rotor for Kawasaki ZZR 1100 90 91 92 1990 1991 1992 New (0 replies)
  97. Full Set Brake Disc Rotor for Kawasaki ZXR NINJA 750 89 91 93 95 ZXR R 750 90 92 (0 replies)
  98. Porsche 914 Late carpet kit Tan loop Nice 10 piece kit NEW WITHTAN CONSOL (0 replies)
  99. Full Set Front Rear Brake Disc Rotor for Kawasaki ZEPHYR 1100 92 94 97 99 02 05 (0 replies)
  100. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  101. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  102. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  103. PORSCHE 914 CAR COVER 1971 1972 1973 1974 1975 1976 NEW (0 replies)
  104. EBC Ultimax Slotted Rotors - USR914 (0 replies)
  105. Porsche 914 215mm Forged Flywheel (0 replies)
  106. SMOKE LENS HEAD LIGHTS LAMPS W/SIGNAL PARKING CORNER 91-96 CHEVY IMPALA/CAPRICE (0 replies)
  107. 1973 Porsche 914 head light motor covers (0 replies)
  108. PORSCHE 901 CLUTCH FORK 70-71 911 ALL 914 (0 replies)
  109. Dual Electric Trumpet Hi/Lo Horns Set Porsche 911 912 914 LOUDEST We Can Find!!! (0 replies)
  110. PORSCHE 914 OIL COOLER (0 replies)
  111. Porsche 914 Volkswagen 411 412 Transporter Engine Connecting Rod Bearing Set (0 replies)
  112. Original OEM Porsche Factory 914 914-6 Headlight & Hazard Light Switch Combo (0 replies)
  113. Porsche 914 dash switch bezel nut tool wrench wiper & headlight Targa Carerra (0 replies)
  114. VW & Porsche 1980 - 08 Bug in 24 Chalon 914 Carbureted 914 GTI Pickup Jetta Test (0 replies)
  115. Vintage Brass Enamel PORSCHE Crest Hub Cap Emblem Logo ~ Very Nice ~ 914 (0 replies)
  116. 1968-1986 1987 1988 1989 Porsche 911 912 914 BMW 1600 2002 Front Brake Pads OEM (0 replies)
  117. Porsche 914-6 Winner 24 Hrs of LeMans Factory Racing Poster (0 replies)
  118. Porsche 911 / 914 Differential Hexagon Head Bolts (12) (0 replies)
  119. GOODMARK Park Brake Pedal Pad 4330-914-651 (0 replies)
  120. VW Porsche 2.0 94mm x 71mm Flat Top Piston & Cylinder Kit 914 Type 4 (0 replies)
  121. 06-08 CHEVY UPLANDER 3.9L V6 AT 1-ROW (Standard) Radiator 2881 (0 replies)
  122. VW PORSCHE ~ IGNITION LOCK TUMBLER W/ KEYS ~ BEETLE KARMAN GUIA FASTBACK 914 + (0 replies)
  123. Porsche 911 914 Audi TT A3 A4 Volvo BMW E36 E34 46 Turbo Blow Off Valve Type RS (0 replies)
  124. SMP/STANDARD DS-914 Switch, Power Window (0 replies)
  125. Throttle Position Sensor ACDelco GM Original Equipment 213-914 (0 replies)
  126. PORSCHE 914 BUMPER GUARD 914 505 064 10 Right, 914 1.7/1.8/2.0 1973-74 (0 replies)
  127. Porsche 914 Chrome Window Crank Handle OEM Qlty W/Screw, all 914 (0 replies)
  128. 90135563101 Porsche rear brake hose 911 912, 914 1969-1983. Pex brand (0 replies)
  129. CAYENNE Seat Belt Pads 911 356 914 944 928 (0 replies)
  130. Porsche 914 Ashtray (0 replies)
  131. Lloyd Mats Porsche Targa Custom Embroidered Targa Front Floor Mats (0 replies)
  132. PORSCHE 914 CROME BODY TRIM (0 replies)
  133. Porsche two syllable word t shirt 356 911 914 928 944 (0 replies)
  134. Lloyd Mats Porsche 914 Custom Embroidered Porsche Front Floor Mats (1970-1976) (0 replies)
  135. Lloyd Mats Porsche 914 Custom Embroidered Porsche Front Floor Mats (1970-1976) (0 replies)
  136. Lloyd Mats Porsche 914 Custom Embroidered Porsche Front Floor Mats (1970-1976) (0 replies)
  137. Lloyd Mats Porsche 914 Custom Embroidered Porsche Front Floor Mats (1970-1976) (0 replies)
  138. Lloyd Mats Porsche 914 & 914-6 Front Floor Mats (1970-1976) (0 replies)
  139. Lloyd Mats Porsche 914 & 914-6 Front Floor Mats (1970-1976) (0 replies)
  140. TECH TIPS 700 FOR PORSCHE 914 BY DR. 914 book latest edition (0 replies)
  141. Lloyd Mats Porsche 914-6 Custom Embroidered 914-6 Floor Mats (1970-1971) (0 replies)
  142. Lloyd Mats Porsche 914-6 Custom Embroidered 914-6 Floor Mats (1970-1971) (0 replies)
  143. Porsche 914 defrost vent seals set of 2 rubber (0 replies)
  144. 4ea UG914/U Coax Adapter Bnc to Bnc (0 replies)
  145. Porsche 914 2 1/2" Black Gear Style Wheel Center Caps (0 replies)
  146. Porsche 911 912 914 924 928 930 944 968 Check Valve for Windshield Washer New (0 replies)
  147. Porsche 911 912 914 924 928 930 944 968 Check Valve for Windshield Washer New (0 replies)
  148. Porsche 914 (72-76) Brake Caliper Repair Seal Kit Front FTE NEW + 1 YR WARRANTY (0 replies)
  149. Porsche 914 engine lid pull cable and latch. (0 replies)
  150. Porsche 914 - Genuine OEM Hella Rear Tail Light Lenses (0 replies)
