Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Porsche 914 Front and Rear Hubs...4 lugs (0 replies)
  2. Porsche 914 shifter assembly early version tail shift transmission (0 replies)
  3. 1976 Porsche 914 GT (0 replies)
  4. BMW E10 1600 2002 Porsche 911 912 914 Volvo 122 Voltage Regulator 90160320602 (0 replies)
  5. Weltmeister Chassis Stiffening Kit, For 914-4 Porsche, 1970-1976 (0 replies)
  6. Porsche 914 Drivers seat center pad black, from 1972 914, fair cond, has splits (0 replies)
  7. Porsche Original 914 Dash Metal Gauge Cluster Bezel look (0 replies)
  8. Porsche 914 front tire board. Look (0 replies)
  9. Porsche 914 1.7L Intake Manifold Genuine Original look (0 replies)
  10. PORSCHE 914 Interior Front A-Pillar panels (pair) and B pillar trim look (0 replies)
  11. 1973-74 Porsche 914 bumper (0 replies)
  12. Porsche 914 2.0 liter Stainless Steel Heat Exchangers / Pair - Mint! (0 replies)
  13. 1974 Porsche 914 /6 Tribute (0 replies)
  14. 1974 Porsche 914 -- (0 replies)
  15. Porsche 914/4 Cylinder Head Temperature Sensor Extension. (0 replies)
  16. Porsche 914 Original Style Rear Sway Bar Mounts (0 replies)
  17. OEM PORSCHE 914 914-6 LEFT & RIGHT FRONT HEADLIGHT ASSEMBLIES 1970-71 (0 replies)
  18. Porsche 901 911 912 914 needle cage bearing and race (0 replies)
  19. Porsche 911 / 914-6 Zenith 40TIN Pair of Carburators (0 replies)
  20. POrsche 914 transmission clutch cable support and roller (0 replies)
  21. Porsche 911 914 901 Locked Differential SCCA race. (0 replies)
  22. Porsche 914 Upper And Lower Dash (0 replies)
  23. 1970 1971 Porsche 914 Air Cleaner (0 replies)
  24. Porsche 914 Upper Rear Trunk Roof Holder (0 replies)
  25. Porsche 914 1.7 Crankshaft (0 replies)
  26. Porsche 914 5 Speed Tail Shift Transmission (0 replies)
  27. Porsche 914 2.0 liter cylinder head (0 replies)
  28. Pocket Manual Porsche 914 Technical Specifications c.1974 (0 replies)
  29. Porsche 914 center console bottom insert. Free Shipping (0 replies)
  30. Porsche 914 Targa Top Latch Set and Spare Parts (0 replies)
  31. Porsche 914 Tinted Early Drivers Door Glass. Very Nice! (0 replies)
  32. Porsche 914 Heater Blower Dual Pipe Splitter (0 replies)
  33. Porsche 914 Chrome Interior Door Handle Surrounds (0 replies)
  34. Porsche 914/4 8mm Rocker Arms for 911 Adjustment Screw Modification (0 replies)
  35. One Porsche 914 Front Turn Signal Assembly. Excellent! (0 replies)
  36. Porsche 914 Center Console with Gauges, Nice! (0 replies)
  37. Vintage Porsche 914 1.7 / 2.0 Owners Manual Model '73 1973 (0 replies)
  38. 1973 Porsche 914 2.5L 6CYL Twinplug 275HP (0 replies)
  39. 1970-1976 Porsche 914 Dark Red Right RH Rear Passenger Fender For Repair OEM (0 replies)
  40. Porsche 914 RH Passenger White Right Rear Trunk Hinge 914 512 060 10 OEM Used (0 replies)
  41. 1970-1976 Porsche 914 OEM Original Factory Brake Master Cylinder For Rebuild (0 replies)
  42. Porsche 914/4 Original Warm Air Elbows for Heat (0 replies)
  43. Porsche 914 heater control flap (0 replies)
  44. Porsche 914 heater box tubes (0 replies)
  45. VW Bus type 4 weber center intake manifold 72 - 79 yr porsche 914 (0 replies)
  46. Porsche 914 Fuse Box Cover Original 70-76 (0 replies)
  47. 1970 - 1973 Porsche 914 Headlight Switch 914.613.414.10 (0 replies)
  48. USED ORIGINAL GENUINE PORSCHE 914 1.7 VACUUM PRESSURE REGULATOR (0 replies)
  49. Porsche 914 Exhaust Muffler (#113) (0 replies)
  50. Porsche 911 912 914 synchro sleeve (0 replies)
  51. PORSCHE 911 914 REPLACEMENT KEYS 1970-1984 HC72 (0 replies)
  52. Porsche 914 OE German cylinder heads (0 replies)
  53. 1970 PORSCHE 914/6 70 WIRING DIAGRAM (0 replies)
  54. New Starter Fit Melroe Spra Coupe Porsche VW Beetle 0-001-211-013 SBO0062 16450 (0 replies)
  55. Porsche 914 torpedo fuse glass fuse 25 amp to 5 amp mix original Germany (0 replies)
  56. Original Porsche 914 Useful Parts Lot (0 replies)
  57. Porsche Early 914, 914/6, 911 and 912 Steering Wheel. 380mm (0 replies)
  58. Porsche VW Vintage Jack 911 914 Bilstein restored with repro handle (0 replies)
  59. PORSCHE 914 / 914-6 Early Headlight Motor cover (gray) (0 replies)
  60. Porsche 914 2.0 "GA" Core Engine with Fuel Injection (0 replies)
  61. Porsche 911 and 914/6 Intake Manifolds for Weber (0 replies)
  62. 914 Porsche Dash Bezel (0 replies)
  63. Porsche 914 Tach Core (0 replies)
  64. Porsche 914 2.0L BISCHOFF Exhaust Muffler 039.251 (#112) (0 replies)
  65. Vintage Porsche wood shifter wooden knob part (0 replies)
  66. 1973 Porsche 914 1.7L Targa (0 replies)
  67. USED ORIGINAL GENUINE PORSCHE 914 DASHBOARD (0 replies)
  68. Porsche 914 Early Gas cap with new seal. (0 replies)
  69. Original Porsche 914 "Late" Rain Tray (0 replies)
  70. Porsche 914 Transmission side shifter (0 replies)
  71. Porsche 914 914-6 Appearance Package Heater genuine factory part (0 replies)
  72. Porsche 914 2.0 letters (0 replies)
  73. Porsche 914 Metal Gold Letters (0 replies)
  74. Vintage Porsche 914 VDO Fuel/Combo Gauge 914 641 102 20 late 1971-1972 (0 replies)
  75. porsche 914 AIR CLEANER (0 replies)
  76. 1973 Porsche 914 1.7L Targa (0 replies)
  77. Porsche 914 Auxiliary Air Valve (0 replies)
  78. Porsche 914/4 Fuel Injection Distributor, Excellent. (0 replies)
  79. Porsche 914 Early Front Calipers with Vented Rotor Spacers (0 replies)
  80. Porsche 914/4 Thermostatic Air Control Flaps (0 replies)
  81. Rebuilt & Improved Porsche 914/4 Relay Board (0 replies)
  82. Porsche 914/4 CV Drive Axle Joints (0 replies)
  83. Porsche 911, 914 Clutch Release Arm, NOS (0 replies)
  84. Porsche 914 Bursch Primary Muffler 1975-76 (0 replies)
  85. 1973 Porsche 914 (0 replies)
  86. Porsche 914 Washer Fluid Reservoir Excellent Condition from 1970 914 (0 replies)
  87. Porsche 914 Washer Fluid Reservoir Excellent Condition from 1972 914 (0 replies)
  88. Porsche 901 911 914 Transmission Transaxle Syncro Hub/Dog Ring (0 replies)
  89. PORSCHE 914 1969-1976 4 CYLINDER HAYNES Repair MANUAL 239 air cooled Germany (0 replies)
  90. Porsche 914 seat center pad in black, from pampered 1972 914, no splits, clean (0 replies)
  91. 1972 Porsche 914 front turn signal assemblies pair, nice Hella lenses, all OEM (0 replies)
  92. PORSCHE 911 912 914 STRUT TOPS (0 replies)
  93. set of (4) Porsche "Cookie Cutter" Wheels for 911, 944, 914-6 5x130 bolt pattern (0 replies)
  94. 1974 Porsche 914 (0 replies)
  95. 1972 Porsche 914 Black (0 replies)
  96. NOS 1974 PORSCHE 914 Brochure (0 replies)
  97. Porsche 914 Fog Light Switch (0 replies)
  98. 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976 PORSCHE 914 repair manual (0 replies)
  99. Pair of Very Nice Excellent Condition Porsche 914 Heat Control Boxes (0 replies)
  100. Porsche 914 Fuel Tank Tightening Strap & Bridge (0 replies)
  101. Porsche 911 & 914 NLA Carbon Filter Canister Support Strap (0 replies)
  102. Porsche 914 Adjustable Passenger Side Seat Frame/Track (0 replies)
  103. Porsche 914/924 Steering Column Support, Ign. Switch Housing and Steering Lock (0 replies)
  104. Porsche 914 Fuel Level Tank Sender (0 replies)
  105. Porsche 914 914-6 Rebuilt Pedal Assembly Cluster (0 replies)
  106. Porsche 914 914-6 Front Sway Bar Assembly (Restored) (0 replies)
  107. Porsche 912, 914 VW Type IV Bus Taco Plate Temperature Sender (0 replies)
  108. Porsche 911 912 914 914-6 Speedometer Angle Drive (0 replies)
  109. Porsche 914 914-6 Exterior Mirror (0 replies)
  110. Porsche 912, 914 VW Fuel Injection Relay Pack (0 replies)
  111. Porsche 911 912 914 901 Original Orange Crest Hood Emblem (0 replies)
  112. Porsche 914 ECU Computer 1.7L 2.0L Battery Tray Bracket (0 replies)
  113. Porsche 912, 914 1.7 2.0 D-Tronic Antibackfire Deceleration Valve (0 replies)
  114. Porsche 911 ZENITH 40TIN Carburetor Bodies 914 Corvair Weber 40ida (0 replies)
  115. Porsche 914 1.7 2.0 D-Tronic Auxiliary Air Regulator Valve Type IV VW (AAR) (0 replies)
  116. Porsche 914 Headlight Switch (late style) (0 replies)
  117. Porsche 914, 914-6 Interior Plastic Screw Hole Plugs (0 replies)
  118. Porsche 914, 914-6 Parking Brake Tee Cable (0 replies)
  119. Porsche 914 1.8 1.8L Throttle Body (TBI) and Sensor (TPS) (0 replies)
  120. Porsche 914 1.7 2.0 D-Tronic Fuel Pressure Regulator (0 replies)
  121. Porsche 914 1.7 2.0 D-Tronic Positive Crankcase Valve Type IV VW (PCV) (0 replies)
  122. Porsche 914 Rear Targa Latches (late) (0 replies)
  123. Porsche 914, 914-6 Rear Targa Latches (early) (0 replies)
  124. Porsche 914, 914-6 Front Targa Latches (0 replies)
  125. Porsche 914 914-6 Targa Pad Latch Covers (0 replies)
  126. Porsche 914 914-6 Parking Brake Cover (0 replies)
  127. Car Cover for Porsche 914 (0 replies)
  128. 1973 Porsche 914 (0 replies)
  129. VINTAGE PORSCHE 914 TECHNICIANS MANUAL (0 replies)
  130. Porsche 914 Throttle Stop (0 replies)
  131. 1974 Porsche 914 914 (0 replies)
  132. Porsche 914 Alloy Wheel (0 replies)
  133. 1970-1976 PORSCHE 914 SERIES CLYMER SERVICE MANUAL REPAIR HANDBOOK 71 72 73 74 (0 replies)
  134. Porsche 914 Roll Bar Vinyl Covering. (0 replies)
  135. Porsche 914 Interior Trim for A and B Pillars (0 replies)
  136. Porsche 914 Front Sway Bar Mount Bracket. (0 replies)
  137. Porsche 914 Defrost Light With Screws. (0 replies)
  138. PORSCHE 914 right FRONT HOOD BONNET HINGE & SPRING Original factory Germany (0 replies)
  139. 1970-1976 genuine Porsche 914 Headlight Assembly -Right Passenger Side Germany (0 replies)
  140. 1970-1976 genuine Porsche 914 Headlight Assembly -Left Drivers Side Germany used (0 replies)
  141. ORIGINAL FACTORY PORSCHE 914 LOWER UNDER DASH KNEE PAD GERMANY RESTORATION (0 replies)
  142. PORSCHE 914 Windshield Wiper Arms original factory Germany oe restoration nice (0 replies)
  143. Porsche 914 Hood Latch Receiver lock original factory Germany oem restoration (0 replies)
  144. headlight actuator seal porsche 914 cover rubber genuine factory Germany (0 replies)
  145. porsche 914 headlight motor seal genuine Germany factory part restoration (0 replies)
  146. Porsche 914 Distributor 1.7L. (0 replies)
  147. Porsche 914 Pressure Sensor (0 replies)
  148. Porsche 914 Intake Distribution Housing 1.7L (0 replies)
  149. Porsche 914 Intake Manifolds (0 replies)
  150. Porsche 914 Heads 1.7L (0 replies)
