Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Mainshaft Bearing PORSCHE 911 1.6 H4 1.7 H4 2.0 H6 2.2 H6 912 914 (0 replies)
  2. MANUAL TRANSMISSION GEAR TEETH PORSCHE 911 914 (0 replies)
  3. porsche 914 used fiberglass rear bumper (0 replies)
  4. porsche 914 used taillights (0 replies)
  5. porsche 914 motor mounts hardware (0 replies)
  6. porsche 914 misc nut bolts (0 replies)
  7. used porsche 914 headlamp buckets (0 replies)
  8. used 914 porsche manual trans (0 replies)
  9. Porsche Differential Carrier Bearing & seal set 911 912 914 924 928 69-86 (0 replies)
  10. New Porsche 914 Clutch Cable 1970 - 1976 1.7 1.8 2.0 (0 replies)
  11. 2 Brand New Porsche 914 Front Turn Signal Lenses (0 replies)
  12. Cylinder heads and jugs for Porsche 914 2.0 motor (0 replies)
  13. Porsche Hood Crest Emblem kit 911 914 944 928 964 968 Carrera Turbo 65-94 (0 replies)
  14. LED Tail Light Conversion - Lucas 679 and 915 Tail Lights (0 replies)
  15. Brand New Complete OE German Porsche 914 Axle With CV Joints (0 replies)
  16. OE Porsche USA NEW 914 2.0 Throttle Switch #0-280-120-032 (0 replies)
  17. Used Porsche 914 2.0 1973-1974 Cylinder Head Complete With Valves & Springs (0 replies)
  18. Brand New OE German Porsche 914-4 CV Joint With Boot, Grease, and roll pins. (0 replies)
  19. Porsche Cylinder Head Temperature Sensor 914/4 914/6 70-76 (0 replies)
  20. Dorman 955-914 Door Mirror (0 replies)
  21. Carlson P914 Front Disc Hardware Kit (0 replies)
  22. Standard Motor Products DS914 Power Window Switch (0 replies)
  23. Wagner MX914 Front Premium Semi Metallic Pads (0 replies)
  24. FDP 914 Parking Brake Shoe (0 replies)
  25. PORSCHE 914 WINDOW CRANK HANDLE ALSO DOOR PULL INSERT (0 replies)
  26. PORSCHE 914 DASH GAUGE CLUSTER 1971-1976 (0 replies)
  27. One porsche 914 or vw 4 lug riviera rim (0 replies)
  28. porsche 914 parts lot (0 replies)
  29. 1972 porsche 914 wiper motor (0 replies)
  30. porsche 914 oil temp " taco plate" with cover. (0 replies)
  31. porsche 914 left and right chrome door handles (0 replies)
  32. VW type 4 Porsche 914 1.7L rocker arms, shafts, spacers and blocks 8mm threads (0 replies)
  33. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  34. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  35. PORSCHE Genuine Key Set Leather Fob 911 912 914 924 930 964 Carrera Turbo (0 replies)
  36. Porsche Flasher Turn Signal Relay 912 914 911 (70-89) (0 replies)
  37. Porsche Brake & Clutch Pedal Pads 356 911 930 912 914 Carrera Turbo (50-98) (0 replies)
  38. 1965-to-1995__911_912_914_924_928_930_944_968__OEm__Front Hood Emblem__Porsche__ (0 replies)
  39. PORSCHE Belt Alternator Conti 911 914 930 (69-89) (0 replies)
  40. Porsche 914/4 8/72 73 74 75 76 F&R Brake Rotors Pads (0 replies)
  41. Porsche 914/4 70 71 8/72 F&R Brake Rotors Pads (0 replies)
  42. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  43. HLY-12-903 Holley In Tank Fuel Pump / HLY-12-914 (0 replies)
  44. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  45. Porsche 914 horn contact (0 replies)
  46. Porsche 914 NOS wiper switch PORSCHE (0 replies)
  47. LOWER FUEL INJECTOR REPAIR KIT PORSCHE 912 914 928 (0 replies)
  48. 914 NEW NOS OEM DASH 91455202211 NEW INSTRUMENT BRACKET NEW OEM NOS 914 DASH (0 replies)
  49. VW PORSCHE 914 & 914/6 Repair Guide 1.7 and 2.0 NOS (0 replies)
  50. Porsche 914 Metal Trunk Roller, Rollers - Made in USA (0 replies)
  51. Porsche 914 Chassis Stiffening &Tr-Arm Boxing Kit Plans (0 replies)
  52. Porsche 914-4 clutch cable (0 replies)
  53. porsche 914 ash tray ex condition (0 replies)
  54. 914 porsche OEM Hella front L&R Marker light lenses. (0 replies)
  55. Porsche 4 CV Axle boots 911 912 914/4 914/6 65-76 (0 replies)
  56. Porsche 914 SCAT Crank Shaft 2.0L VW Type 4 (0 replies)
  57. Porsche 914 carpet strip sill set of 2 Black Execellent new no more wavy trim (0 replies)
  58. Porsche 914/6 GT Laguna Seca 1976 Poster (0 replies)
  59. Porsche 914/6 GT Laguna Seca 1976 Poster (0 replies)
  60. Porsche/ VW Piston Ring Set STD 914/4 1.7 (0 replies)
  61. 1970- 1972 Porsche 914 Front Calipers Single Bleeder Valve (0 replies)
  62. porsche 914 washer container tank (0 replies)
  63. 1970- 1972 Porsche 914 rear Calipers Single Bleeder Valve (0 replies)
  64. Type 4 VW Bus Porsche 914 Cylinder Piston Rings Kit 2000 Volkswagon Vanagon 2.0 (0 replies)
  65. Type 4 VW Bus Porsche 914 Cylinder Piston Rings Kit 2000 Volkswagon Vanagon 2.0 (0 replies)
  66. Porsche 914 front hood. (0 replies)
  67. OEM IGNITION LOCK AND MASTER VALET KEY FOR PORSCHE 914 . (0 replies)
  68. Porsche 914 Front spoiler (0 replies)
  69. Porsche 914 Rocker Panel Covers with Raised Lettering. (0 replies)
  70. 17" PANTHER 914 FLITE 5X115 IMPALA SS CHARGER ALERO MAGNUM CHROME WHEELS RIMS (0 replies)
  71. Moog Front Steering Drag Link DS914 (0 replies)
  72. Porsche 911,912,914, Nardi 'Guilloche' Steering Wheel, Made In Italy, On Sale~!! (0 replies)
  73. Porsche 914/4 8/72 73 74 75 76 Rotors Ceramic Pads (0 replies)
  74. Porsche 914/4 70 71 8/72 Rotors Ceramic Pads (0 replies)
  75. 4 Porsche 911 901 914 Transmission Synchroniser & Hardware Kits (2-5th) 1965-76 (0 replies)
  76. Porsche : 914 porsche 914 (0 replies)
  77. Porsche 911 Carrera RSR Sebring 73 Vinyl Banner Poster 914 917 944 Garage Slot (0 replies)
  78. Porsche 914 Driver Door Storage / Arm Rest (0 replies)
  79. NOS PORSCHE 912 911 CAR IDENTIFICATION ID PLATE GENUINE 914 904 906 RS ST RSR (0 replies)
  80. Porsche 911 Accelerator Pedal Modified for a Porsche 914. (0 replies)
  81. Porsche 914 Relay Board. (0 replies)
  82. LOUD Fiamm Dual Blaster Trumpet Hi/Lo Horn Set fits Classic Porsche 911 912 914 (0 replies)
  83. VW Porsche 914 Throttle Body 2 Liter 039 133 067 #4744 (0 replies)
  84. Porsche 914/4 5 Bolt Conversion Parts. (0 replies)
  85. VW DIP STICK WITH TEMP. GAGE (0 replies)
  86. 1974 PORSCHE 914 ORIGINAL DEALERSHIP SALES BROCHURE (0 replies)
  87. White Emblem Tyre Tire Valve Stem Cap Air Dust Covers+Tool Wrench Modify Porsche (0 replies)
  88. Weber IDF 44 IDF44 Webber Dual Carbs Carburetors w/ 914 Manifolds and Linkage (0 replies)
  89. Tyre Tire Valve Stem Caps Air Dust Covers+Tool Wrench Modified Porsche Auto 5pcs (0 replies)
  90. OE Genuine Porsche USA NEW Taillight Lens-One side only- Your choice (0 replies)
  91. Porsche Tyre Tire Stem Valve Air Cap Anti-Theft Locking (0 replies)
  92. New Rear Centric 2-wheel set Brake Pad VW 356 5 Series Porsche 914 72 71 70 Car (0 replies)
  93. IMC 405 43016 398 Rear Brake Rotor/Disc (0 replies)
  94. How To Rebuild Your Volkswagen / Porsche Air Cooled Engine & Porsche 914 Engine (0 replies)
  95. 80's Porsche 911 914 Radio VW Scirocco GOLF (0 replies)
  96. Haynes Porsche 914 All 4 cylinder 1969 - 1976 Repair Manual (0 replies)
  97. Porsche 914 Speedometer Gauge (74-76 Late Model) (Refurbished) W/Glass Lens (0 replies)
  98. PORSCHE NOS STEEL WHEEL CENTER CAPS FOR PORSCHE 914 (0 replies)
  99. OE Genuine Porsche USA NEW Taillight Lens Pair (0 replies)
  100. Porsche 914 Passenger Side Rear Taillight Housing Brand New NOS (0 replies)
  101. OE Genuine Porsche Euro Passenger Side Taillight Lens (0 replies)
  102. Kawaski ZX6 1990-93 Targa Tinted Fluorescent Red Windscreen/ Windshield (0 replies)
  103. Porsche 914 Center Console Gauge Wiring Harness (NEW! Reproduction) (0 replies)
  104. DAYCO 71289 Upper Radiator Hose (0 replies)
  105. Porsche 914 factory Italian pedrini wheels, 5.5 x 15, nice used set of four. (0 replies)
  106. PORSCHE "Do you speak 914?" in german retro t shirt (0 replies)
  107. CARLSON P914 Front Brake Disc Hardware Kit (0 replies)
  108. RAYBESTOS PGD914C Brake Pad or Shoe, Front (0 replies)
  109. PORSCHE 914S (0 replies)
  110. PORSCHE 914 VOLKSWAGEN BEETLE THERMO TIME SWITCH VDO (0 replies)
  111. USED ORIGINAL PORSCHE 914 914-6 DEALER INSTALLED AIR CONDITIONER EVAPORATOR (0 replies)
  112. 826072Y914 NI1520107 AutoBodyParts New Door Handle Smooth black Maxima 2003 (0 replies)
  113. Porsche Pedal Bushing Set Bronze 911 914 912 911SC Carrera 930 Turbo 65-86 (0 replies)
  114. Porsche Targa Top Trunk Mount Support Kit 914/4 914/6 70-76 (0 replies)
  115. Porsche 911 914 clutch brake Pedal Bushing KIT Bronze bushings (0 replies)
  116. Porsche 914 4/6 Speedometer Angle Drive on Transmission speedo gear (0 replies)
  117. Porsche 914-4 Fuel Pump, Electrical,Porsche 914 '74-'76 (0 replies)
  118. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 1.8 2.0 73-76 (0 replies)
  119. 1970-1976 Porsche 914 Cluster Instrument Cluster White Face Gauges 70-76 (0 replies)
  120. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  121. Early Porsche 911/ 901 / 914 Transmission Clutch Fork 901.116.712.00 (0 replies)
  122. PORSCHE Front Wheel Bearing & Seal Set 911 914 924 944 (64-89) (0 replies)
  123. Porsche 911 901 914 Transmission 5th Gear Set ZD 31:22 (0 replies)
  124. Mustang Falcon Comet Front and Rear Sway Bar Kit 536/914 ADDCO solid bars (0 replies)
  125. PORSCHE 914 butterfly horn button (0 replies)
  126. Porsche (2) Front Turn Signal Lenes 914/4 914/6 70-76 (0 replies)
  127. Porsche : 914 2.0-Liter 1974 Porsche 914 2.0 EFI Daily Driver & Autocrosser! w/Original Sales Documents! (0 replies)
  128. Porsche 914 driving light fog lamp (0 replies)
  129. Porsche 914 1.7L & 1.8L 1970 71 72 73 74 NOS Super Sprint Freeflow Exhaust O19G* (0 replies)
  130. PORSCHE STEERING WHEEL RESTORATION 911 914 944 928 964 993 996 997 BOXSTER (0 replies)
  131. Porsche 356 911 912 914 944 928 "Porsche Parking Only" Sign (0 replies)
  132. Porsche 914 Instrument Cluster Holder Plastic (0 replies)
  133. Porsche 914 912 911 Shift Knob Reproduction with Crush Sleeve (0 replies)
  134. Porsche 914 Silver Button Fuel Gauge - Used - 91464110240 (0 replies)
  135. Porsche 914 Fuel Gauge - Used - 91464110240 (0 replies)
  136. Porsche 914 356 911 Brake Line Big T Fitting 91435566700 (0 replies)
  137. Porsche 914 Fender to Cowl Seal 2 Sets of Two (4) (0 replies)
  138. Porsche 914 Nylon Door Latch Cam Set of Two - One For Each Side 914531905C (0 replies)
  139. Porsche 914 Large Door Handle Seal Set of Two PCG53160100 (0 replies)
  140. Porsche Genuine Black Master Key 911 912 914 930 964 993 (0 replies)
  141. Porsche 911 and 914 Trunk and lid bump stop NEW OEM (0 replies)
  142. Porsche Stuttgart Emblem 911 914 (0 replies)
  143. Porsche oval charcoal canister fits 914, 912, 911, 356 and VW models (0 replies)
  144. PORSCHE NOS WINDSHIELD WIPER SHAFT HEX NUTS FOR 65-89 911 AND 70-76 914 (0 replies)
  145. PORSCHE 356 911 912 914 924 FLYWHEEL LOCK 6 VOLT & 12 VOLT PORSCHE & VW (0 replies)
  146. PORSCHE NOS OIL TEMPERATURE SENDING UNIT FOR 911 AND 914-6 (0 replies)
  147. 91-95 Legend 4DR Euro Clear Corner Signal Lights Lamps (0 replies)
  148. PORSCHE USED OIL LINE ADAPTER FITTING FOR 914-6 (0 replies)
  149. porsche 914 fuel tank feed and return lines (0 replies)
  150. TrackData RACING Checklists: PORSCHE 356, 911, 912, 914, 930, 935, 944, Boxster (0 replies)
