Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. Wagner ZX914 Front Semi Metallic Pads (0 replies)
  2. Porsche 914 2.0 H6 Rear Brake Discs Rotors Genuine (0 replies)
  3. Porsche 911 S Turbo Steering Wheel With Horn Pad 911 912 914 74-78 Safety Wheel (0 replies)
  4. OneSource DS914 Drag Link (0 replies)
  5. Porsche 914 Wheel Adapters 4x130mm to 5x4.75 GM Bolt Pattern VW 4 Lug Rim 5 Lug (0 replies)
  6. TrackData RACING Checklists: PORSCHE 356, 911, 912, 914, 930, 935, 944, Boxster (0 replies)
  7. Porsche 911 930 914 License plate Light (set 2) OEM NEW (0 replies)
  8. Porsche 914 944 931 Ignition start Switch NEW OEM (0 replies)
  9. PORSCHE 911 356 914 912 SPEEDSTER TARGA SPYDER LOCKS (0 replies)
  10. porsche 914 rear brake rotors drilled and slotted (0 replies)
  11. Porsche 911 901 914 Transmission 5th Gear Set ZD 31:22 (0 replies)
  12. Porsche 914 Windshield Seal Front (Small Upper Section) OEM (0 replies)
  13. Porsche 356 911 912 914 _ Brake Pad Set _ REAR (0 replies)
  14. 5 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  15. Porsche 911 914 944 Windshield Washer Nozzles OEM X 2 (0 replies)
  16. Porsche Windshield Washer pressure CHECK VALVE (T) OEM VALEO (0 replies)
  17. Porsche 911 930 914 License plate Light X 2 OEM Brand NEW (0 replies)
  18. Porsche 914 Parking Brake Cable LEFT OEM NEW (0 replies)
  19. Porsche 911 (69-85 w/ Boge) 914 Strut Insert Front x2 (0 replies)
  20. Porsche 78-79 930/911 Turbo Distributor Vacuum Unit New NLA (0 replies)
  21. Porsche 914 clutch disc Porsche OEM nos new perfect 1970-1976 (0 replies)
  22. Brand New Power Steering Reservoir (Dorman 603-914) w/o Fluid Sensor (0 replies)
  23. Vintage 1970 Porsche club of America PCA grill badge 911 912 356 914 914/6 944 (0 replies)
  24. Vintage Porsche Bolt On 911 944 914 912 356 928 Chrome Mag Wheel Center Hub Cap (0 replies)
  25. Porsche 914/6 Wiper & Turn Signal Decals (70-72) (0 replies)
  26. shift knob for for porsche 911, 914, 928, 944 (0 replies)
  27. Porsche 914 set of bucket sets (0 replies)
  28. Porsche 914 911 912 VDO Guages Speedometer Tachometer Oil Temp Fuel (0 replies)
  29. Porsche 914Turbo Tie Rod Kit 70-76 (0 replies)
  30. PORSCHE 914 GEAR SETS 4TH-V,27:25 RATIO (0 replies)
  31. PORSCHE 914 GEAR SETS 4TH-V,27:25 RATIO box9 (0 replies)
  32. PORSCHE 914 GEAR SETS 5TH-ZD, 31:22 RATIO (0 replies)
  33. Porsche 914 Trunk Pivot Mount (0 replies)
  34. PORSCHE 914 GEAR SETS 3RD-N 23:29 RATIO (0 replies)
  35. Porsche Afternarket Flasher and Turn Signal Relay 914/4 1973 (0 replies)
  36. Porsche Solid Wrist Pin Bushing 914/4 70-76 (0 replies)
  37. 914 PORSCHE REAR TRUNK LID HYDRAULIC SHOCK (0 replies)
  38. Porsche 914 fuse panel (0 replies)
  39. Porsche 914/4 Interior Mirror 1970-1976 (0 replies)
  40. New Porsche 914 Clutch Cable 1970 - 1976 1.7 1.8 2.0 (0 replies)
  41. Porsche 914 chrome trim (0 replies)
  42. Porsche 914 jack and hold down (0 replies)
  43. Porsche 914 washer res (0 replies)
  44. Porsche 914 2 1/2" Black Gear Style Wheel Center Caps (0 replies)
  45. Porsche 356 Hubcap/Center Cap Remover Tool 911/912/944/914/930/VW UNIVERSAL TOOL (0 replies)
  46. 914 New Front Inner Bearing 311405625b (0 replies)
  47. Genuine Technical Specification Book, 914 (0 replies)
  48. SWF Windshield Washer Check Valve (0 replies)
  49. Porsche OEM 911 930 SC polished aluminum valve covers (upper) 914 912 (0 replies)
  50. Porsche 911 21mm front torsion bars 914 930 912 (0 replies)
  51. Porsche 914 Ignition Switch NO KEY 1972-1976 (0 replies)
  52. Porsche 911 / 914 Brake Fluid Reservoir With Cap (0 replies)
  53. porsche 911/914 engine case tie bolts (0 replies)
  54. Porsche 914 sail trim that is blacked out (0 replies)
  55. BING 64 CD Carburetors for Rotax 914 F/UL Engines (0 replies)
  56. Porsche 914 Fuel Injection Intake Manifolds fo 2 liter German Used Dirty Set (0 replies)
  57. Porsche 914 Fuel Injection Intake Manifolds fo 2 liter German Used (0 replies)
  58. Porsche 911 930 914 928 944 Tire Inflator Pump Air Compressor (0 replies)
  59. Porsche 914 & 914-6 complete fog light set lights,grills and switch LOOK (0 replies)
  60. Porsche 914 center console early style (0 replies)
  61. Original Porsche 914 Air Filter Assembly (0 replies)
  62. Kawasaki 1984 ZX900 Fork Air Line E-914 (0 replies)
  63. Porsche 914-4 clutch cable (0 replies)
  64. 911 930 912 928 914 After market Porsche whale tail (turbo) (0 replies)
  65. Porsche Carrera / 914-6 Racing - 1975 Out of Print Car Poster: ) (0 replies)
  66. Porsche 86 Stunden Nürburgring 1970 914/6 Car Poster Reprint (0 replies)
  67. 911 912 914 Porsche Shift Knob Brush/Polish 901 Pattern (0 replies)
  68. K&N E-2381 PORSCHE 914 Replacement Air Filter (0 replies)
  69. 1970 PORSCHE 914 ***ORIGINAL ARTICLE*** RARE!!! (0 replies)
  70. Porsche 914 2.0 L engine mounts 1975 w/ brackets (0 replies)
  71. D-Jetronic Fuel Injection Manual, Porsche 914, 1970-1973 (0 replies)
  72. Porsche 914 early door end caps new Rubber unlike OEM hard plastic ones (0 replies)
  73. Porsche 914 door stay strap roller rebuild kit 2 doors (0 replies)
  74. Porsche 914 door rollers for door strap (0 replies)
  75. Porsche 914 rear trunk spring rollers New set of 2 (0 replies)
  76. Porsche 914 Delrin clutch cable pulley + ss busing NLA (0 replies)
  77. Porsche 914 door stay aluminum strap (0 replies)
  78. 914 FUCHS 2.0L FACTORY OEM WHEEL SET 5.5 J X 15 PORSCHE VW BUS GHIA BUG (0 replies)
  79. Porsche 911 914 LED gage lights replacement white make your gauges bright BA7 (0 replies)
  80. Porsche 914 door scrapers, New rubber seals for your door to window gap set of 2 (0 replies)
  81. Porsche 914 outer window fuzzy set of 2 metal (0 replies)
  82. Holley Carburetor 3310 GM Chevy 396 Chevrolet 3878261-EH dated coded 914 (0 replies)
  83. Porsche 914 Late door window rollers new repair your windows (0 replies)
  84. Porsche 914 suspension articulated rear strut bushings (0 replies)
  85. wheel caps for Porsche 914 fuch mahle PEDRINI Much harder to dent than OEM (0 replies)
  86. Porsche 914 defrost vent seals set of 2 rubber (0 replies)
  87. Porsche 914 TPS Position sensor board 2.0L only (0 replies)
  88. Porsche 914 fender to cowl seal 914-559-155-10 set of 2 (0 replies)
  89. Porsche 914 WebCam camshaft and lifter set, 00-263 and 00-152, Type 4 IV, 86 (0 replies)
  90. Porsche 914 Outer door seal solid rubber will not absorb water no rust set of 2 (0 replies)
  91. Porsche 914 engine seal set of all 4 seals (0 replies)
  92. Porsche 914 engine rubber seal set of all 4 seals front sides and rear (0 replies)
  93. Porsche 914 Early gas cap seal New rubber easy to install (0 replies)
  94. Porsche 914 late style gas cap rubber seal NEW (0 replies)
  95. Porsche 914 engine deck lid bumper NEW NLA part (0 replies)
  96. porsche 914 Vertical targa and targa to window, scrapper seals new rubber 6 pcs (0 replies)
  97. Porsche 911 914 clutch brake Pedal Bushing KIT Bronze bushings (0 replies)
  98. 5- Porsche 911 901 914 Transmission Shafts Needle Bearings & Bushings 1965-76 (0 replies)
  99. 5 - Porsche 911 901 914 Transmission Syncronizer Rings 91130230106 1965-1986 (0 replies)
  100. Porsche 914 '70-'76 Fuel Tank Cap, German Qlty,New,914 (0 replies)
  101. Porsche 911 901 914 Transmission 5th Gear Set Z 29:23 (0 replies)
  102. GENUINE ORIGINAL PORSCHE 914 DASHBOARD ASHTRAY (0 replies)
  103. Porsche 911 914 901 Transmission "0" Third Gear Set 23: 28 1965-1976 (0 replies)
  104. GENUINE AND ORIGINAL OIL DIP STICK AND OIL CAP FOR PORSCHE 914 2.0 1970-1976 (0 replies)
  105. Used Porsche 914 2.0 1973-1974 Cylinder Head Complete With Valves & Springs (0 replies)
  106. OE Genuine Porsche USA NEW 914 2.0 Throttle Switch (0 replies)
  107. PORSCHE 914 OEM GOLD EMBLEM 914 REAR METAL EMBLEM (0 replies)
  108. Early Porsche 911/ 901 / 914 Transmission Clutch Fork 901.116.712.00 (0 replies)
  109. SET OF GENUINE ORIGINAL PORSCHE 914 PULL KNOBS FOR HEAD/HAZARD/FLOOD LIGHTS (0 replies)
  110. Porsche 914 Fuel Injected 1.8 sys Air Intake (0 replies)
  111. VW Type 4 Cooling Tins Porsche 914 Volkswagen Painted POR 15 Cooling No Reserve (0 replies)
  112. Porsche 914 Timing Access Plug 1.7 1.8 2.0 VW Bus Type 4 411 Volkswagen (0 replies)
  113. Porsche 911 914 901 Transmission "X" 28:24 "Short Ratio" 5th Gear Set (0 replies)
  114. "RARE" Porsche 901 911 914 Transmission "N" 23:29 "Close Ratio" 3rd Gear Set (0 replies)
  115. Hirschmann Retractable/Telescopic AM FM Radio Antenna Aerial Porsche 911 356 914 (0 replies)
  116. 1970-1976 PORSCHE 914 / 914-6 STEERING WHEEL WITH BUTTERFLY HORN PAD (0 replies)
  117. 1965 - 1969 Porsche 911, 912, & 1970 - 1976 Porsche 914 Clutch Release Fork (0 replies)
  118. 70 71 72 73 74 75 76 Porsche 914 SACHS New Clutch Kit (0 replies)
  119. 1971 - 1976 Porsche 914 Pair of Saddle/Brown Bucket Seats (0 replies)
  120. MUSTANG 3/4" REAR SWAY BAR KIT BY ADDCO MFG. 65-66 (0 replies)
  121. Porsche Oil Pressure Sender 911 914 E L S T 6 65-73 65 (0 replies)
  122. Porsche Calendar Poster Full Color 914 2.0 1973 1974 Outstanding 13.5"X17" MINT (0 replies)
  123. 2 Brand New Porsche 914 Front Turn Signal Lenses (0 replies)
  124. Hirschmann Telescopic AM FM Radio Antenna/Aerial BLACK MAST Porsche 356 914 911 (0 replies)
  125. Porsche 911 912 914 new throw out bearing or release bearing (0 replies)
  126. Porsche 914 NOS wiper switch swf (0 replies)
  127. VW TYPE4 PORSCHE 914 .STD/.STD STEEL BACK MAIN BEARINGS (0 replies)
  128. Porsche 914 NOS turn signal switch SWF (0 replies)
  129. Porsche 914 vintage wood gear shift knob LOOK (0 replies)
  130. CU11X ECU NOS Rebuilt by BOSCH 1970-72 Porsche 914 & 71 VW 411 Free Shipping (0 replies)
  131. porsche 914 metal emblem (0 replies)
  132. Suzuki : RM-Z Brand New 2012 Suzuki RMZ450 RM Z450 Dirtbike Sale Call Today 732.914.9104 (0 replies)
  133. porsche 914 window regulator driver side (0 replies)
  134. PORSCHE 914 BRONZE SHIFTER BUSHING 901 TRANSAXLE 73-76 (0 replies)
  135. PORSCHE WHEELs RIMS EMBLEMS DECALS 356 911 928 914 924 944 912 speedster 17 18 (0 replies)
  136. Porsche 914 Battery Tray 91450158710 Quality rust repair part. (0 replies)
  137. New Thule Thule 914 4 Bike Receiver Hitch Rack | Super Deal | FedEx Fast Ship (0 replies)
  138. Porsche 914 Passenger Side Window Regulator (0 replies)
  139. Porsche 914 Drivers Side Window Regulator (0 replies)
  140. Brand New Complete OE German Porsche 914 Axle With CV Joints (0 replies)
  141. AM FM Car Radio Hidden Antenna Porsche 911 912 914 356 (0 replies)
  142. PORSCHE WHEELs RIMS EMBLEMS DECALS 356 911 928 914 924 944 912 speedster 17 18 (0 replies)
  143. NewTek Automotive SMD914 Front Semi Metallic Pads (0 replies)
  144. NewTek Automotive Distribution SMD914 Front Semi Metallic Pads (0 replies)
  145. Porsche 914 1.7 F.I. Computer remanufactured (0 replies)
  146. PORSCHE 911-912-914 ORIGINAL OEM RUBBER SHIFTER BOOT (0 replies)
  147. porsche 914 steering wheel (0 replies)
  148. Original 1971 Porsche Full Line Mailer Brochure 911 T,E,S,Targa;914;914/6 (0 replies)
  149. Porsche 914 main targa rubber repair seal new top section (0 replies)
  150. Porsche 914 Rear deck lid seal glass to engine lid rubber with aluminum clip (0 replies)
