Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. RALLYE SIGN PORSCHE 356 RACE MEETING NEDERLAND 550 911 912 914 917 VW BEETLE BUG (0 replies)
  2. A SOMEWHAT FUCHED UP PORSCHE 914 FUCHS ALLOY WHEEL. LQQK! (0 replies)
  3. Porsche 911 914/6 Aluminum Washer 8.4X15X1.5 mm Valve Covers Set of 34 Brand New (0 replies)
  4. Porsche 911 914/6 Aluminum Washer 8.4X15X1.5 mm Valve Covers Set of 22 Brand New (0 replies)
  5. Porsche 914 complete carpet set with front& rear trunks (0 replies)
  6. Porsche 911 912 914 924 factory Blaupunkt am fm radio (0 replies)
  7. Porsche 914 Motor Mount NEW 914-4 '73-76 (0 replies)
  8. Wheel Lug studs Porsche 914 steel wheels with plastic covers caps - full set (0 replies)
  9. Wells JA914 Distributor Cap New in Box (0 replies)
  10. 04 05 06 07 NISSAN TITAN FRONT GRILL GRILLE 62310-7S000 ORIGINAL OEM #914 (0 replies)
  11. 1970-72 Porsche 914 Original Passenger Footrest w/Strap (0 replies)
  12. 1965-1979 FORD, MERC, LTD II, T-BIRD, COUG, FA-914 HERSHEY LOWER BALL JOINT (0 replies)
  13. VW Type4 Porsche 914 .STD/.STD Steel Back Main Bearings (0 replies)
  14. Hirschmann Automatic Electric Power Antenna Porsche 911 912 914 944 Chrome Mast (0 replies)
  15. Porsche 914 complete headlight assembly (0 replies)
  16. Porsche 914 front hood. (0 replies)
  17. PORSCHE 914 FRONT BRAKE DUST SHIELD (0 replies)
  18. PORSCHE 914 OEM STEEL LUG NUTS BOLTS *** SET OF 4 *** (0 replies)
  19. Porsche 914 Chrome Window Crank Handle, all 914 (0 replies)
  20. Porsche Hood Crest Emblem kit 911 914 944 928 964 968 Carrera Turbo 65-94 (0 replies)
  21. SportsCarGraphic PORSCHE 914 ROVER 3500S DODGE CHALLENGER 440 MAGNUM BRM FORMLA1 (0 replies)
  22. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 911 911SC 912 930 turbo 69-86 (0 replies)
  23. VW Porsche 914 Bug Beetle Bus NOS Bosch Vacuum Advance (0 replies)
  24. Tyre Tire Valve Stem Caps Air Dust Covers+Tool Wrench Modified Porsche Auto 5pcs (0 replies)
  25. Cool Black Porsche Emblem Tyre Tire Stem Valve Air Caps Cover Anti-Theft Locking (0 replies)
  26. Porsche Tyre Tire Stem Valve Air Cap Anti-Theft Locking (0 replies)
  27. Porsche 911 901 914 Transmission Pinion Shaft Front Bearing 99911000700 1965-76 (0 replies)
  28. Porsche 911 901 914 Transmission Shifting Guide Sleeve 90130240202 1965-71 (0 replies)
  29. Porsche 911 901 914 Transmission 1st / Reverse Slider / Shift Sleeve 91130222600 (0 replies)
  30. 2 - Porsche 911 901 914 Transmission Synchronizer Lock Rings 91130231101 1965-86 (0 replies)
  31. 1 - Porsche 911 901 914 Transmission Synchro & Hardware Kit (2nd-5th) 1965-76 (0 replies)
  32. Porsche 914-6 Cartoon Airbrushed T-Shirt Sports Car (0 replies)
  33. Eaton Detroit TruTrac for GM 12 bolt 4 series 33 spline (0 replies)
  34. Early Porsche 911/ 901 / 914 Transmission Clutch Fork 901.116.712.00 (0 replies)
  35. Porsche 911 901 914 Transmission 5th Gear Set ZD 31:22 (0 replies)
  36. SIA 1940 LINCOLN ZEPHYR 1958 BONNEVILLE 1976 PORCHE 914 (0 replies)
  37. SCGraphic PORSCHE 914 AMC & HUDSON HORNET DE TOMASO MANGUSTA ASTON MARTIN (0 replies)
  38. SportsCarGraphic 1970 PORSCHE 914 FORD CAPRI1600 & 3000GT GREMLIN ROOTES AVENGER (0 replies)
  39. SportCarGraphic FIAT 850 RACER PORSCHE 914 TRIUMPH STAG LOTUS 72 FERRARI 365GT (0 replies)
  40. Porsche 911 914 901 Transmission "X" 28:24 "Short Ratio" 5th Gear Set (0 replies)
  41. "RARE" Porsche 911 901 914 Transmission "M" "Short Ratio" 29:22 3rd Gear Set (0 replies)
  42. Porsche 911 914 901 Transmission "A" 1st Gear 11:34 (0 replies)
  43. Powder Coated Porsche 914 2.0 L, VW Type 4 Beetle Bus Intake Manifolds (0 replies)
  44. Porsche : 914 1973 Porsche 914 (0 replies)
  45. 1974 PORSCHE 914 ORIGINAL DEALERSHIP SALES BROCHURE (0 replies)
  46. PORSCHE 911 912 914 STEERING RACK (0 replies)
  47. Original Porsche 914 Front Body Panel Right Connector Plate -New. (0 replies)
  48. ORIGINAL PORSCHE 914 DRIVER SIDE HEATER HOSE for 1973-76 (0 replies)
  49. Original Porsche 914 Double Heater Blower Outlet Used (0 replies)
  50. Cooling Tin Porsche 914 Type 4 Painted POR 15 Cooling No Reserve (0 replies)
  51. porsche 914 rear bumper (0 replies)
  52. Porsche 914 Tachometer Gauge...Refurbished! (0 replies)
  53. Porsche : 914 1700 1973 PORSCHE 914 EXCELLENT CONDITION READY TO DRIVE OR SHOW (0 replies)
  54. Martini PORSCHE 917 LH 1970 #21 Vinyl Banner Poster 911 914 944 Garage Racing (0 replies)
  55. Porsche 914-4 74-76 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  56. Porsche 914-4 Tachometer VDO Good for any 4 Cylinder engine (0 replies)
  57. Vintage VW, Formula, Porsche 914 Campagnolo Race Wheels (0 replies)
  58. Martini Porsche 911 RSR Turbo 1974 Banner 956 914 935 (0 replies)
  59. PORSCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  60. Porsche 914 Plush Carpet set 70-76 NEW (0 replies)
  61. Porsche 914 GERMAN MATCH Perlon Carpet set 70-76 (0 replies)
  62. Porsche 356 914 & VW Beetle Ghia Interior Door Handles (0 replies)
  63. 1970-1976 Porsche 914 Cluster Instrument Cluster White Face Gauges 70-76 (0 replies)
  64. Porsche 914 center console box (0 replies)
  65. NOS Porsche 914 Haneline Engine Turned Stainless Steel Throttle Plate (0 replies)
  66. Porsche : 914 914 1974 Porsche 914 Garaged for 17 Years (0 replies)
  67. Porsche 914 & VW Campmobile Super Beetle New Front Brake Hose 113.611.701E * (0 replies)
  68. VW DIP STICK WITH TEMP. GAGE (0 replies)
  69. Custom California Plates 914/6 (0 replies)
  70. Porsche 914 tail light (0 replies)
  71. Porsche 914 fog/driving light bulbs 1 Pair EXTRA BRIGHT 60 Watt (0 replies)
  72. Porsche 914 glove box lock (0 replies)
  73. PORSCHE Genuine Key Set Leather Fob 911 912 914 924 930 964 Carrera Turbo 70-97 (0 replies)
  74. PORSCHE 914 HEAD LIGHT BEAUTY RINGS SB34 HELLA (0 replies)
  75. Porsche 914 door sill strip (0 replies)
  76. Ferrari 328 308 GTS rear sheetmetal clip repair section kit car 1987 914 metal (0 replies)
  77. Porsche 914 rear shock cover (0 replies)
  78. Porsche 914 emergency brake lever (0 replies)
  79. Blaupunkt Frankfurt Radio Escutcheon Porsche 356 911 912 914 VW BMW Mercedes (0 replies)
  80. VW Logo Radio Knobs Blaupunkt Becker 914 VW Bus Bug Beetle Thing (0 replies)
  81. Blaupunkt Faceplate Radio Porsche 911 356 VW 914 Bug Bus BMW Mercedes (0 replies)
  82. Blaupunkt AM/FM Radio Porsche 911 356 VW 914 Bug Bus Jaguar Mercedes (0 replies)
  83. Porsche 914 horn button (0 replies)
  84. Porsche 914 six 914-6 genuine accelerator bell crank pull rod All bell crank rod (0 replies)
  85. Porsche 914 six 914-6 genuine factory engine ignition wiring harness incredible (0 replies)
  86. Porsche 914 six 914-6 genuine used oil tank filler neck and dipstick tube Genuin (0 replies)
  87. Porsche 914 type four VW bus allison napa 009 high output ignition distributor s (0 replies)
  88. Porsche 356, 912, 914 and early 911 Windshield Washer Nozzle (0 replies)
  89. Porsche 914 six 914-6 working used wiper rack and motor extremely rare! (0 replies)
  90. Porsche 914 very nice original snow plow spoiler Very nice used original Mitcom (0 replies)
  91. Porsche : 914 914-6 rims 1975 914 Porsche All original Silver Runs great! (0 replies)
  92. 1970 Porsche 914 & 914/6 sales brochure Original Clean (0 replies)
  93. Porsche Shifter Bushing Kit - Cup Shaft & Coupler 914/4 1.7 70-72 (0 replies)
  94. Porsche 914 Short Shift Kit (0 replies)
  95. Bosch Distributor 050 , Porsche356,Porsche 914, VW (0 replies)
  96. Porsche 901, 911, 914 23/28 O 3rd Gear Set (0 replies)
  97. Porsche 914 914-6 factory wool aftermarket carpet kit (0 replies)
  98. Porsche 914 Tech Tips 700 with beautiful burgundy vinyl cover (0 replies)
  99. Porsche 944 911 912 914 356C & Nissan 240Z 260Z Outer Wheel Bearings 38-99920 * (0 replies)
  100. Porsche 911 914 924 912 factory blaupunkt frankfurt rebuilt warranty Perfect fo (0 replies)
  101. Stainless Threshold Sill and carpet strips for 1970-76 Porsche 914's. (0 replies)
  102. Porsche 914 911 912 factory used jack nice!!! (0 replies)
  103. PORSCHE 911-912-914 OEM ORIGINAL UNIVERSAL BLK ROUND RELAY ( 911.615.109.01 ) (0 replies)
  104. PORSCHE 914 OEM ORIGINAL HELLA TURN SIGNAL BLINKER RELAY ( 914.618.303.10 ) (0 replies)
  105. PORSCHE 914 OEM ORIGINAL HELLA LICENSE PLATE / TRUNK COMPARTMENT LIGHT (0 replies)
  106. Porsche 914 1969-1972 1973 1974 1975 1976 Car Cover (0 replies)
  107. Porsche 914 lid lock upper front trunk latch 70 - 76 yr. 914 511 051 10 (0 replies)
  108. Porsche Flasher Turn Signal Relay 912 914 911 (70-89) (0 replies)
  109. Weber 48 IDA empi VW Velocity stack Filters VW 914 RX-7 Cobra GT-40 (0 replies)
  110. Weber 48 IDA empi VW Velocity stack Filters VW 914 RX-7 Cobra GT-40 (0 replies)
  111. PORSCHE 914/4 914/6 HANDBOOK (0 replies)
  112. Porsche 911 914 Audi TT A3 A4 Volvo BMW E36 E34 46 Turbo Blow Off Valve Type RS (0 replies)
  113. Genuine Porsche Key Blank Black Master 70-98 911, 914, 912E (0 replies)
  114. Bosch 0237022025 Distributor for VW - porsche 914, 924, 928? (0 replies)
  115. Porsche 2 Window Crank Handles Black 914/4 914/6 70-76 (0 replies)
  116. seat belt relay #133 919 431 Porsche 914 ghia bug (0 replies)
  117. Porsche Ignition Switch Meyle 914/4 73-76 (0 replies)
  118. Porsche : 914 V8 1970 PORSCHE 914 V8 CONVERSION CHEVY 350 (0 replies)
  119. PORSCHE - 914- black vinyl decal - 3 in x 76 in logo pinstripe *PAIR* (0 replies)
  120. Porsche 914 Electric Fuel Pump, New, Never Installed, Porsche 914 1970-1974 (0 replies)
  121. Porsche 914 Door Box Left Side (0 replies)
  122. Porsche 914 Window Regulator Driver Side (0 replies)
  123. Porsche 914 Blower (0 replies)
  124. Porsche 914 Window Regulator Passenger Side (0 replies)
  125. Porsche 914 Door Handle Arm Rest Right Side (0 replies)
  126. Porsche 914 Flywheel Spacer Washer (0 replies)
  127. Porsche 914 Windshield Water Container (0 replies)
  128. Porsche 914 Window Regulator Passenger Side (0 replies)
  129. Porsche 914 Flywheel Spacer Washer (0 replies)
  130. FUEL PUMP ELECTRIC CHEVY CAMARO PONTIAC FIREBIRD NEW AC DELCO 43-914 (0 replies)
  131. Porsche 914 used chrome rear bumper with bumper top LOOK (0 replies)
  132. ?? GERMAN AUTOMOBILE CAR BADGE # 100.000 VW PORSCHE 914 JUBILEE MODELL ?? (0 replies)
  133. Boge Front Strut Insert (0 replies)
  134. Porsche Key Blanks Black & Red Genuine Set 911 912 914 964 930 Carrera Turbo (0 replies)
  135. PORSCHE 914 CUSTOM REAR DECK LID FOR WATER COOLED 914's (0 replies)
  136. Mr. Gasket Flywheel Bolt Kit 914 (0 replies)
  137. PORSCHE WHEELs RIMS EMBLEMS DECALS 356 911 928 914 924 944 912 speedster 17 18 (0 replies)
  138. Porsche 10 Emblem Speed Nuts with seals 356 911 912 914 924 930 944 (65-98) (0 replies)
  139. PORSCHE 914/6 70 71 72 ROTORS PADS FRONT (0 replies)
  140. PORSCHE 914/4 70 71 08/72 BRAKE ROTORS PADS F&R (0 replies)
  141. Tyre Tire Valve Stem Caps Air Dust Covers+Tool Wrench Modified Porsche Auto 5pcs (0 replies)
  142. Porsche Tyre Tire Stem Valve Air Cap Anti-Theft Locking (0 replies)
  143. Cool Black Porsche Emblem Tyre Tire Stem Valve Air Caps Cover Anti-Theft Locking (0 replies)
  144. Cool Black Porsche Emblem Tyre Tire Stem Valve Air Caps Cover Anti-Theft Locking (0 replies)
  145. porsche 914 guage cluster (0 replies)
  146. porsche 914 guage cluster (0 replies)
  147. Porsche 914 Wiper/Washer Switch/Column 914 '74-'75,New (0 replies)
  148. Porsche 356 911 930 914-6 Camshaft Gear Lock Plate (x3) (0 replies)
  149. porsche 914 front headlamp surrounds n.o.s. (0 replies)
  150. Porsche 914 944 951 968 OEM Battery Hold Down Clamp NEW (0 replies)
