Full Version: eBay - 914 related Ads (RSS)
914World.com > The 914 Forums > Classified Forums > eBay - 914 related Ads (RSS)
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629
  1. PORSCHE 356 911 912 914 924 CLUTCH ALIGNMENT TOOL NEW also fits VW (0 replies)
  2. FFF01 Arlen Ness 19-914 Engraved Shifter Rod For Harley-Davidson Touring Models (0 replies)
  3. PORSCHE 914 LIGHTER OEM INTERIOR DASH VTG (0 replies)
  4. CRYSTAL CLEAR HEAD LIGHTS LAMPS SIGNAL PARKING CORNER 91-96 CHEVY IMPALA/CAPRICE (0 replies)
  5. Porsche 914 914/6 factory rear sway bar with drop links & shock bolts (0 replies)
  6. Porsche Crest Black Leather Key Ring Enamel 911 914 928 930 944 964 968 993 986 (0 replies)
  7. WAGNER MX914 Brake Pad or Shoe, Front-ThermoQuiet Brake Pad (0 replies)
  8. MOOG DS914 Drag Link-Steering Drag Link (0 replies)
  9. MOOG DS914 Steering Drag Link, Front (0 replies)
  10. MOTORCRAFT JK6-914-A Serpentine Belt/Fan Belt-Serpentine Belt (0 replies)
  11. Holley Performance 12-914 Electric Fuel Pump; In-Tank Electric Fuel Pump (0 replies)
  12. Competition Cams 914-16 Dual Valve Spring Assemblies; Valve Springs (0 replies)
  13. Quick Stop ZD914 Brake Pad or Shoe, Front (0 replies)
  14. Porsche 356 911 912 914 Brake Pad Set Rear TEXTAR OEM NEW + 1 year Warranty (0 replies)
  15. Porsche 914/4 70 71 8/72 F&R Brake Rotors Pads (0 replies)
  16. Porsche 914 Front Hood Hinge Early OEM RH Right side (0 replies)
  17. Auto Extra AXDS914 Drag Link Replacement Dodge Plymouth 4WD Each (0 replies)
  18. Porsche 914 factory stainless steel mirror like new. (0 replies)
  19. Porsche 914 Rear Deck Lid Hinge Left Side OEM Original (506) (0 replies)
  20. Porsche 914 Front trunk Hinge RH Right OEM (503) (0 replies)
  21. MOOG DS914 Drag Link-Steering Drag Link (0 replies)
  22. Douglas Wheel 14in. Sector Revolutionary Wheel Beadlock Ring Red 914-10R (0 replies)
  23. DORMAN 741-914 Window Regulator-Window Regulators (0 replies)
  24. Dorman 741-914 Power Window Motor and Regulator Assembly, Rear Left (0 replies)
  25. Lincoln : Town Car Executive Limousine 4-Door 2003 Lincoln Town Car Executive Limousine 4-Door 4.6L (914) 434-6985 (0 replies)
  26. DORMAN 902-914 Thermostat Housing/Water Outlet-Engine Coolant Water Outlet (0 replies)
  27. Sun Visor Clip, Left, Porsche 911/914/944/964, 911.731.323.41, (1969+) (0 replies)
  28. EXCELLENT RESTORED ORIGINAL GENUINE PORSCHE 914 STEERING RACK NLA (0 replies)
  29. Porsche 914 1970 Genuine Porsche Flywheel Bolt N0143361 (0 replies)
  30. Porsche 914 4 Vw 411 412 211 Muffler Gasket Set 70-74 (0 replies)
  31. PORSCHE 914 HELLA HORN ***OEM*** INCLUDES MOUNTING BRACKET 400 HZ (0 replies)
  32. PORSCHE STEERING WHEEL RESTORATION 911 914 944 928 964 993 996 997 BOXSTER (0 replies)
  33. Porsche 914 1969 1970 1971 1972 1973-1976 Car cover (0 replies)
  34. Rare Vintage Porsche 911 Magnesium Minilite Wheel's Two 10.5" x 15" ST, RSR, 914 (0 replies)
  35. Power Antenna Fix Kit - 1970 thru 1976 Porsche 914 (0 replies)
  36. Hirschmann Automatic Electric Power Antenna Porsche 911 912 914 944 Chrome Mast (0 replies)
  37. WELLS JD914 Distributor Cap (0 replies)
  38. Raybestos Brake Pads (0 replies)
  39. Engine Intake Valve-AE WD EXPRESS 072 43041 232 fits 73-76 Porsche 914 2.0L-H4 (0 replies)
  40. nos BOSCH STARTER in Box ~ PORSCHE 914 ~ 001 211 012 ~ VW Volkswagen 1967-1974 (0 replies)
  41. Porsche 914 Speedometer Drive 91431802901 (0 replies)
  42. Porsche 911 914 928 944 VW Fuchs OEM Wheel Lug Nuts (20) Fully Mirror Polished (0 replies)
  43. Porsche Trunk Lid Rubber Stop, 914.512.195.10, 914 (70-73) (0 replies)
  44. Trunk Lid Rubber Stop, Set of Three, Porsche 914 (70-73), 914.512.195.10 (0 replies)
  45. Standard Motor Products DS914 Power Window Switch (0 replies)
  46. PORSCHE 914 INTERIOR DOOR HANDLE LEFT SIDE DRIVER SIDE & LATCH CUP (0 replies)
  47. Porsche 911 912 914 Brake pressure warning Switch for braking light master unit (0 replies)
  48. Porsche 914 Oil Strainer Gasket Set 1970 to 1976 (0 replies)
  49. 70 71 72 73 74 75 76 PORSCHE 914 R. FRT SPINDLE/KNUCKLE 4 CYL 85783 (0 replies)
  50. Front Brake Hose VW Volkswagen Super Beetle & Bus Van 71-79 & Porsche 914 72-76 (0 replies)
  51. New FEL-PRO BS 25034 Seal, Crankshaft Fits Porsche 914 912 911 (0 replies)
  52. Shifter Coupler Bushing Repair Kit for Porsche 356 911 912 914 930 Manual Trans (0 replies)
  53. Shifter Coupler Bushing Repair Kit for Porsche 356 911 912 914 930 Manual Trans (0 replies)
  54. Triumph Pre Unit Preunit Mainshaft & Low Gear T914 16T Transmission 650cc 1960 (0 replies)
  55. OEM Porsche 914 Emblem Insignia Logo Script Black 1970-1976 (0 replies)
  56. NEW Porsche 911 65-98 914 930 Engine Oil Pump Return Tube LASO 930 107 040 (0 replies)
  57. Porsche 914 Windshield Wiper Assembly (0 replies)
  58. 1965 - 1977 Porsche Alternator 911 914 2.0 2.4 2.7L Generator (0 replies)
  59. DNJ Engine Components PR914 Piston Ring Set (0 replies)
  60. Porsche 911 914 912 924 1966 1969 1970 1971 1975 1976 - 1988 O.E.M. Stop Block (0 replies)
  61. Porsche 911 1970 1975 Genuine Porsche Key Blank (Red) 91453190311 (0 replies)
  62. Porsche 914 1973 Elring Klinger Axle Joint Gasket 91433223701 (0 replies)
  63. Porsche 911 914 1970 1973 1975 1977 1980 - 1988 Genuine Clutch Pedal Bushing (0 replies)
  64. Porsche 911 914 O.E.M. Bell Crank Bushing for Accelerator Pedal/ Throttle (0 replies)
  65. Q/H#CC30,Saab#7194137 Carbon Clutch Release Brng.1960-74 Saab 93,95,96,97,Sonett (0 replies)
  66. Disc Brake Caliper NuGeon Reman 54043017783 (0 replies)
  67. Porsche 356 911 912 914 924 928 944 964 Steering Wheel (0 replies)
  68. Porsche 914 Rivierra Wheel Black With Polished Lip & Spokes or All Chrome 914 (0 replies)
  69. Dorman Window Regulator 741-914 (0 replies)
  70. Porsche 914 defrost vent seals set of 2 rubber (0 replies)
  71. MM DN800 Porsche 356 911T 911S 912 914 Original German License Plate,VW AUDI BMW (0 replies)
  72. Ignition Coil PORSCHE 911 914 930 (0 replies)
  73. Porsche 911 912 914 930 Brake Fluid Reservoir,GENUINE,NEW #NS 55 (0 replies)
  74. Porsche 911 / 912 / 914 / 930 Brake Fluid Reservoir,GENUINE,NEW #NS (0 replies)
  75. Porsche 911 / 912 / 914 / 930 Brake Fluid Reservoir,GENUINE,NEW #NS (0 replies)
  76. Porsche 914 Rear Bumper Bar (0 replies)
  77. NOS ORIGINAL GENUINE BOSCH PORSCHE 911 912 914 914-6 STARTER DRIVE UNIT (0 replies)
  78. Oil Line Wrench Set, Porsche 911/930/914-6/944/968 (65-95) (0 replies)
  79. Front Brake Pad Set, Porsche 914/914/6 (70-76) (0 replies)
  80. DNJ RB914.10 Engine Connecting Rod Bearing Set (0 replies)
  81. Front Brake Hose, Porsche 911/912/914/912E/930, 901.355.632.01, (65-89) (0 replies)
  82. POWER STOP JBR914XPR Front Brake Rotor/Disc (0 replies)
  83. Porsche 911 914 Sachs Performance Clutch Pressure Plate - 215 mm "Sport" (0 replies)
  84. Porsche 911 912 930 Support Rod for Throttle Bellcrank Genuine 914 301 307 00 (0 replies)
  85. Porsche 914 Volkswagen 412 Campmobile Transporter Fuel Injec Cold Start Valve (0 replies)
  86. Porsche 914 Left Right pair Inside Roll Bar Trim, black vinyl upholstery panels (0 replies)
  87. Power Window Regulator w/ Motor (Dorman 741-914) Rear Left (0 replies)
  88. 1974 Porsche 914 original Steering wheel leather wrapped (0 replies)
  89. Porsche 911 912 & 914 ball joint. NOS NLA (0 replies)
  90. NEW DP STANDARD SINTERED METAL BRAKE PADS # DP914 (0 replies)
  91. PORSCHE 911 912 914 924 928 944 968 OEM WHEEL LUGS NUTS LOCKS (0 replies)
  92. ABT Ceramic Brake Pads [Front Set] C914-1 (0 replies)
  93. Porsche Gear Shifter Bushing Kit Cup Shaft Coupler 911 911SC 912 930 Turbo 69-86 (0 replies)
  94. Porsche 930 Turbo Rocker Arms set of 12 NOS 911 914/6 (0 replies)
  95. 914 PORSCHE RACK AND PINION, OFF ROAD. STEERING RACK, SAND TRAIL STEERING (0 replies)
  96. Porsche Wheel Center Cap Set, 914.361.303.03SET, 914-4 (70-76) (0 replies)
  97. Porsche 914 and 914-6 used rear shock caps (0 replies)
  98. PORSCHE 914 Door Handle (0 replies)
  99. HJC / Motorcycle Helmet / FG-17 Ace / Adult Large / Red -White-Black / 628-914 (0 replies)
  100. Porsche 924/944 wing screw and washer for emergency wheel # 914 722 104 10 (0 replies)
  101. Complete 1971 Porsche 914 1.7L 1.7 Flat Four Engine (0 replies)
  102. e 70 71 72 73 74 75 76 Porsche 914 Buyers Guide Info (0 replies)
  103. 91462820311 Porsche Windshield Washer Nozzle 911 912 914 924 944 NEW SWF (0 replies)
  104. Porsche 914 914/6 factory rear sway bar with drop links & shock bolts (0 replies)
  105. STARTER SOLENOID 37MT John Deere RE501166, SE501444 Massey Ferguson 294-165-M91 (0 replies)
  106. STARTER SOLENOID 37MT 1115609, 1115613, 1115650, D904A, E7HZ-11390-B, SW2157 New (0 replies)
  107. Porsche 914 clear front turn signal lens Set of 2 with seals (0 replies)
  108. Porsche 914 front turn signal lens's with buckets/houseings. (0 replies)
  109. DRIVER SIDE DOOR LATCH FOR PORSCHE 914 914/6 914-6 916 (0 replies)
  110. Porsche 914 2.0 fuel injection system nice used (0 replies)
  111. PORSCHE 914 ENGINE LID GRILLE WITH "PORSCHE" LETTERING (0 replies)
  112. NOS Amco Wood Shift Knob 4-Speed Pattern 67 1/2-71 Porsche 911 912 914 8241-42 (0 replies)
  113. PORSCHE 914 SEAT BELT COVERS OEM (0 replies)
  114. Porsche 911 914 930 Bosch Ignition Coil 00025 (0 replies)
  115. Porsche 914 Engine cover and grill (0 replies)
  116. Pair NOS Cibie Tango driving beam Headlamps for porsche 356 911 912 914 (0 replies)
  117. 4X Bright White 8 SMD LED Car Side Wedge Tail Light T10 194 168 158 259 914 #SB7 (0 replies)
  118. VW BEETLE TYPE1 TYPE2 PORSCHE 914 **NOS** CONDENSER (BOSCH) (311 905 295 C) (0 replies)
  119. FTE Brake Master Cylinder (0 replies)
  120. 1966 PORSCHE 911,914,1967 PLYMOUTH,ROAD RUNNER,FURY,426 AC # R42XLS SPARK PLUGS (0 replies)
  121. Porsche 914 Front Hood Hinges (0 replies)
  122. Porsche 911 912 914 928 924 968 Boxster Cayenne Cayman Porsche Hood Emblem Seal (0 replies)
  123. OneSource DS914 Drag Link (0 replies)
  124. Carquest 41151 EGR Valve (0 replies)
  125. Porsche 911 912 Bosch Distributor 0231174007 914 1.7L OEM (316) (0 replies)
  126. alternator regulator Deutz, Hyundai Pony / CASE Ag & Industrial Porsche 911, 914 (0 replies)
  127. Porsche Bosch Distributor 914 0231174001 Used (314) (0 replies)
  128. Haynes Repair Manual, Porsche 914 (69-76) (0 replies)
  129. Porsche Santech R134a A/C Conversion Kit 911 914 924 928 930 944 964 968 986 993 (0 replies)
  130. Engine Bay Shroud Seal, Left, Porsche 914, (70-76), 914.504.157.10 (0 replies)
  131. Porsche 911 912 914 924 944 Windshield Washer Nozzle - NEW (0 replies)
  132. Porsche 914 Window Regulator Passenger Side (0 replies)
  133. Porsche Fuse Box Clear Plastic Cover, 12 Fuse, 914.612.316.10, 914 (70-76) (0 replies)
  134. Porsche Turn Signal Switch, 914.613.913.14, 914 (72-76) (0 replies)
  135. Steering Coupler, Porsche 901.347.201.02 911/912/914-6/930/912E (65-89) (0 replies)
  136. Turn Signal Switch Knob, Porsche Switch Knob,911/912/914-6 901.552.853.00(65-73) (0 replies)
  137. Porsche Door Pocket Set with Vinyl, 914 (70-76) (0 replies)
  138. Wagner QC914 Front Ceramic Brake Pads (0 replies)
  139. Porsche Dash Trim Vinyl Cover, Basket, 914.552.113.11, 914 (72-76) (0 replies)
  140. Bosal 251-914 Hanger (0 replies)
  141. Chevrolet Corvette Racing Adidas Polo in Black XL $80 MP914 (0 replies)
  142. Chevrolet Corvette Racing Team, Adidas Polo in Black XL $80 MP914 (0 replies)
  143. Steering Drag Link Front MOOG DS914 (0 replies)
  144. steering wheel installation kit black Kenworth fixed or tilt telescopic 914/7914 (0 replies)
  145. NICE USED ORIGINAL GENUINE PORSCHE 911 912 914-6 SPORTOMATIC CONTROL VALVE (0 replies)
  146. e 70 71 72 73 74 75 76 Porsche 914 Buyers Guide Info (0 replies)
  147. PORSCHE 914 INTERIOR DOOR HANDLE PASSENGER SIDE (RIGHT) (0 replies)
  148. PORSCHE 356 911 912 914 924 FLYWHEEL LOCK 6 VOLT & 12 VOLT PORSCHE & VW (0 replies)
  149. Chrome C-Pillar Post Protector Cover Molding Trim B914 for Kia Optima 2011-2013 (0 replies)
  150. D31 FRONT CERAMIC BRAKE PADS AUTOZEK PREMIUM PORSCHE 914 70 71 72 73 74 75 (0 replies)
