mb911
Jun 22 2017, 09:35 AM
QUOTE(tygaboy @ Jun 21 2017, 11:23 AM)
QUOTE(mepstein @ Jun 21 2017, 10:37 AM)
QUOTE(whitetwinturbo @ Jun 21 2017, 12:09 PM)
He's waiting on a piece from me
...and on a chunk of floor from me, too. It shipped yesterday!
The best part is we just got a really nice pressure fed sand blast cabinet at work that I can blast it and make it really nice before install.
mb911
Jun 22 2017, 02:33 PM
Pmb restored calipers came in the mail today.. So now just a few little brake parts to finish up.
Jun 22 2017, 03:57 PM
QUOTE(mb911 @ Jun 22 2017, 04:33 PM)
What size calipers?
mb911
Jun 22 2017, 08:34 PM
QUOTE(mepstein @ Jun 22 2017, 01:57 PM)
What size calipers?
Front are A's rear stock.. Was Eric's suggestions.
mb911
Jul 25 2017, 11:18 AM
Not much to report but finally have all of the engine parts back less cams. I may wait until winter to assemble that as still grinding amd welding amd don't want them to intertwine.
mb911
Jul 27 2017, 01:41 PM
Spent some time today and welded in the firewall patch areas and prepped amd painted and ready for rear firewall. Decided I am going to leave the top half installed and sister up to the new firewall and plug weld to each other this will give the chassis a bit more strength..
mb911
Jul 28 2017, 02:24 PM
And 1 half of the rear firewall on
mb911
Aug 5 2017, 06:12 AM
So no updates just been working on my dd as I am off a few weeks from work was able to change cam and lifters in that as it is dod or displacement on demand and the lifters are worn out..
Click to view attachment I did buy a new used set of cam towers from Henry @supertec so I can assemble the heads and get the engine back together as I need it for fixturing for some new exhaust..
Also testing the new -6 muffler is showing great promise.. Sound levels are perfect..
GeorgeRud
Aug 5 2017, 07:10 AM
Looks like you're not sitting around bored! It's always more fun to work on the Porsche than have to deal with a daily driver.
mb911
Aug 5 2017, 07:47 AM
Thats for sure.
mb911
Aug 5 2017, 07:24 PM
mb911
Aug 21 2017, 01:37 PM
So finally done with the flood damage repair, cam and lifter change out in my suburban, going on our honeymoon after being married for 18 years I am back at it it.. I fit the floor pan section in from chris.. I cut a bit too far in the wheel well but I can fix that easy enough..
tygaboy
Aug 21 2017, 01:43 PM
Ben - It's really coming along! The floor looks great...
But man, that's a big ol' chunk of the car you cut out to fit it. Glad to see the car I parted is going to such good use.
Chris
mb911
Aug 21 2017, 02:53 PM
QUOTE(tygaboy @ Aug 21 2017, 11:43 AM)
Chris
Thats for sure its good that I have it braced pretty well..
GeorgeRud
Aug 21 2017, 03:49 PM
Looks great! Please keep posting pics of your progress.
mb911
Aug 21 2017, 06:07 PM
QUOTE(GeorgeRud @ Aug 21 2017, 01:49 PM)
Will do as I make progress.. I think my next project is to make a copy of your mid rise lift..
mb911
Aug 27 2017, 12:22 PM
Well its tacked in.. Pretty happy with the fit. Going be really nice once welded and ground and blended. Thanks again Chris for the huge help.. Even if I would have bought a front floor pan from RD it would have not come with the metal I needed.. So i saved about 1/4 of the orginal floor pan..
Click to view attachment Click to view attachment
mb911
Aug 28 2017, 08:46 PM
And now its completly welded in.. Now to grind and blend
whitetwinturbo
Aug 29 2017, 10:22 PM
tygaboy
Aug 30 2017, 08:54 AM
mb911
Aug 30 2017, 01:55 PM
Thanks guys the grinding started last night..i might do that some more tonight but if I take my time the results are better so slow as I go..
mb911
Sep 3 2017, 01:58 PM
Taking the grinding really slow as if you rush it the seem will be noticable .. 1st step is to take the high spots off the weld with a 4.5 " grinder. Once thats done I use a die grinder with an abrasive wheel to further knock it down.. Next step is a blending disc and then check for any pinholes..
Once this is done only have half the firewall to weld on and the jack points and then done underneath the car..
mb911
Sep 4 2017, 05:45 AM
And now other firewall half in along with tge chassis reinforcement plates.. I think welding will be wrapped up by the start of winter..
mb911
Sep 4 2017, 06:57 PM
A little more progress.. The triangle jack plates are tacked on.. Once welded going to have a bunch of grinding to do..
GeorgeRud
Sep 4 2017, 07:39 PM
Are you going to install the GT stiffening panels in back as well? How about the inner longitudinal panel stiffening braces? With enough power, they might come in handy!
mb911
Sep 4 2017, 07:52 PM
QUOTE(GeorgeRud @ Sep 4 2017, 05:39 PM)
Yes actually both already installed. I have one other reinforcement to make that I see Eric shae does and I will do the same.
whitetwinturbo
Sep 4 2017, 08:19 PM
mb911
Sep 5 2017, 05:57 PM
Grinding will begin tomorrow..
mb911
Sep 10 2017, 06:34 PM
Took a little break from welding and grinding and put 1 head set together. I prefer to preassemble the whole assembly vs how waynes book suggests..
mb911
Sep 11 2017, 12:36 PM
I need to now source the "freeze" plugs for the cam towers..
Going to finish welding frunk floor in with the louvers this week then put back on jack stands so i can do the trunk floor.
mb911
Sep 11 2017, 06:02 PM
The other head set. 1st time I have used three bond but like it so far. Henry says it works great. Pictures of supertecs head refurb. These were done months ago and just finally getting them together.
Then attached is a picture of what I think I am going to go with..
Click to view attachmentClick to view attachmentClick to view attachment
Sep 11 2017, 06:22 PM
I was thinking of shipping merging similar for my suby build. But I have to do it on the cheap so it will probably be a vinyl wrap.
mb911
Sep 11 2017, 06:39 PM
Thats very nice as well. For me its either some variation of red or black. Leaning towards black and I know I will have a ton of body work but I painted this car in my garage.
tygaboy
Sep 12 2017, 10:19 AM
Ben - killer paint job you did! If you want to practice paint a 914, I'll volunteer my car.
And you can't go wrong with black. It was always one of my favorites on a flared car.
Sep 12 2017, 10:35 AM
First 914 I ever saw was a stock mid year car in black. Parked next door while my neighbors were having a party. Early 70's but I remember like yesterday. Ironic since I can barely remember yesterday.
mb911
Sep 12 2017, 10:38 AM
Spent a couple hours this morning and welded the rest of the front trunk floor and then ground. Now to find pin holes and hammer out a few spots. I will wait until car is upside right to finish that.. Next week.
mb911
Sep 13 2017, 06:09 PM
Rear trunk work has started..
mb911
Sep 14 2017, 05:46 AM
Sep 14 2017, 09:25 AM
Go Ben go!
mb911
Sep 14 2017, 04:19 PM
Thanks making headway.. Still thinking 90 of welding will be done in the next few weeks..
mb911
Sep 15 2017, 12:23 PM
Took some time to redo rotisserie a bit.. Make it a bit more stable..
mb911
Sep 15 2017, 12:24 PM
I should note this was a student fab project.
mb911
Sep 19 2017, 05:05 PM
Latest batch from platers.. I am sure I will have fun sorting.
mb911
Sep 20 2017, 07:23 AM
And a quick assembly of the pedal cluster freshly powdercoated and replated. It was really rough to start so looks pretty good now.
GeorgeRud
Sep 20 2017, 03:37 PM
QUOTE(mb911 @ Sep 19 2017, 03:05 PM)
Click to view attachment Those do look nice! The level of restorations are amazing these days!
mb911
Sep 20 2017, 07:32 PM
George the funny thing is this car doesn't deserve that level of restoration but its getting it because its fun.
Lucky9146
Sep 20 2017, 08:00 PM
QUOTE(mb911 @ Sep 20 2017, 06:23 AM)
Click to view attachmentFollowing your thread and you are doing great work! The pedal cluster looks fantastic! and your metal work skills are impressive
Dave_Darling
Sep 21 2017, 11:35 AM
No hand throttle, then?
--DD
mb911
Sep 21 2017, 12:07 PM
QUOTE(Dave_Darling @ Sep 21 2017, 09:35 AM)
--DD
Need to do that yet.. Gotta find the parts..
GeorgeRud
Sep 21 2017, 04:00 PM
I think Mikey914 has them available.
