So it looks like more bad news coming my way regarding the previous work. The passenger front fender has to come off because it was welded on over a bent wheel well that is high and the hood strikes that when being closed. The passenger side fender is also out of alignment a little, but the driver's side is off a bunch. These were both replaced in VA.
Also, as if that was not enough, the passenger's quarter panel is off, welded on the wrong way, and the taillight housing will not even fit in the opening. This was done in VA. The driver's side fits OK but needs some work too.
Looks like Kent is going to have to remove a lot of sheetmetal and then redo a lot of work I already paid to have fixed once. That really hurts.
I am not bad-mouthing Scott. His work is history as it relates to my Six (see Part 1 of my build thread) and I am not going backwards. However, I can't post pictures showing the work Kent is having to correct to make my car straight, true and right and take the chance someone might associate that previously done work with Kent's shop or the work Kent is now doing to correct all of this stuff. So I am trying to be clear about what was done in the past and what Kent is now doing.
I am going to post some pictures at some point - but I am technically challenged in reducing the picture size to add a bunch into one post. I wish we had an auto-resizer for pictures like Pelican. Maybe we could all donate to that software program for Sir Andy so we could make life easier for us old folks????
