'Tis the Season I've been overwhelmed by the generosity of this community this week. First up, while installing brake lines, I discovered one of the elbow fittings had some buggered threads. It probably would have worked okay, but there is no room for
probably when it comes to brakes. It's just a standard flare fitting elbow, but metric. Porsche somehow feels justified in charging $80 for the goddam things. Should be $5 tops. I started a thread here to see if anyone knew where to buy the correct substitute. The result is that this arrived compliments of Mark Heard yesterday. He wouldn't even let me pay postage. Thank you Mark!
Click to view attachmentAlso arriving yesterday was this little gem from
@tygaboy .
Click to view attachment A word of warning about doing business with Mr. Baker. The man does not honor an agreed upon fair price. He has refused payment! Seriously though Chris, thank you from the bottom of my heart!
There is yet one more act of kindness working its way through the mail. Hopefully it will arrive tomorrow but you will just have to wait to see.
The project this evening was to replace one of the missing connector tabs on the window defroster and resolder the one still on there.
Click to view attachmentNow, you can buy replacement tabs but it would be $15 shipped and I'm a CSOB and the replacement wouldn't exactly match the original. So I went all hillbilly again and made my own. Turns out, the thickness of these connectors is about 21g which is close to the thickness of Type M copper pipe. So, I pulled out the scrap I used as a welding backer way back when I welded in the frunk floor. Lopped off a chunk, cut it lengthwise, and hammered it out flat to make a sheet.
Click to view attachment Click to view attachment Next, I needed to make a pattern from the original. It is a 3D shape so I stuck a piece of good painter's tape on it and traced around the edges.
Click to view attachment I used an X-acto knife to cut around the edges, peel it off the original, transfer it to the copper sheet, and mark the outline with a sharpie.
Click to view attachment Full confession, a screwed the first one up by getting carried away with the snips. I did better the second time by just rough cutting with snips and then grinding with a dremel, fine tuning with a file, and finishing with a bit of grinding to fine tune the thickness and put a bevel on the leading edge of the connector. Then a little bending with needle nose pliers and a bit of 400 grit sandpaper finished it off.
Click to view attachment The only thing left was to solder it on. The original tab apparently took the metal under one of the solder pads with it when it departed, leaving a scarcity of metal to solder to. I filled in the void with solder as best I could and then cocked the tab just a tiny amount more inward than the original position to give that pad a touch more metal to bond to. Looks pretty good.
Click to view attachment Totally unrelated, but the other day I was doing a bit of cleaning and just had to snap a shot of the "display" that has been next to the TV for quite some time now. This wasn't sanctioned by the wife, but she is a VERY tolerant person. Even she couldn't resist picking up and testing out that leather wrapped wheel.
