Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923
  1. Mahle OC28 oil filter won't fit (10 replies)
  2. D Jet issues continue (10 replies)
  3. Turn Signal (6 replies)
  4. Birthday News for 6/10/25 (5 replies)
  5. How do I remove this nut? (10 replies)
  6. Which of two wires connects to MC brake switch (1 replies)
  7. 71dimmer switch question (0 replies)
  8. Why doesn't my horn base plate have a tab for the ground? (8 replies)
  9. Creamsicle 4742915025 Has Arrived (14 replies)
  10. Turn signal indicator lights come on with key (28 replies)
  11. JWest Customer Support (3 replies)
  12. Plastic Air Cleaner Distortion (2 replies)
  13. Stoddard Swap and BBQ Party 2025 (8 replies)
  14. Birthday News for 6/9/25 (4 replies)
  15. Filter wrench fo Mahle OC 28 (3 replies)
  16. Driving lights out (8 replies)
  17. Roll pins for CV joints (10 replies)
  18. Headlights possessed by demon?! (2 replies)
  19. Most Aggravating SIMPLE Job On A 914 (44 replies)
  20. Sorta on topic (6 replies)
  21. 914-6 oil tank and heat exchanger availability We are moving (3 replies)
  22. What year was the secondary oil relief valve eliminated? (2 replies)
  23. Birthday News for 6/7/25 (6 replies)
  24. Heating question with 911 motor (12 replies)
  25. oil pressure relief valve (11 replies)
  26. The light was right, (15 replies)
  27. What's the trick for installing targa seal (19 replies)
  28. trip cable bottom attachment help (9 replies)
  29. 914-6 Cold Start Enrichment System (6 replies)
  30. Rear trailing arm broken bolts (34 replies)
  31. Nice day (10 replies)
  32. Stock oil cooler (18 replies)
  33. Porsche sites are getting hammered today (8 replies)
  34. Detent sloppy on 901 side shift gearbox? (11 replies)
  35. Emergency Brake Switch light (22 replies)
  36. 1970 914-6 headlight surrounds (38 replies)
  37. Need help--Brake pedal goes all the way to floor after several new parts replaced (16 replies)
  38. High pitch whine (5 replies)
  39. Birthday News for 6/6/25 (7 replies)
  40. Steve McQueen Festival of Speed (91 replies)
  41. Suspension Spring Break (5 replies)
  42. Oil pressure with stock oil pump (4 replies)
  43. Tail shifter - Shift shaft seal replacement (7 replies)
  44. Idle adjustment question, take two (13 replies)
  45. 914 Headlight Washers Wiring (2 replies)
  46. Cool short video (4 replies)
  47. Birthday News for 6/4/25 (6 replies)
  48. Paypal (11 replies)
  49. Horn Base Plate (8 replies)
  50. 914 Subaru 2.5 engine and transmission conversion (21 replies)
  51. Priming engine before first start (29 replies)
  52. Reinstall Order Question (5 replies)
  53. It’s been mentioned before (6 replies)
  54. Float Guage Template? (5 replies)
  55. Brake Fluid overflow (5 replies)
  56. Half Fuel Injections work? (16 replies)
  57. Head light low/hi beam relay (3 replies)
  58. Shock absorber (3 replies)
  59. Header measurements (7 replies)
  60. Birthday News for 6/3/25 (7 replies)
  61. Can Someone Provide Me With The Wheel Bearing Dimensions? (6 replies)
  62. Idle adjustment question (72 replies)
  63. 4 into 1 header (13 replies)
  64. Anyone need fog reflectors? (9 replies)
  65. WCR Tee Shirt or Hoodie Order placement (4 replies)
  66. Birthday News for 6/2/25 (2 replies)
  67. 914 versus 914-6 front bearing grease cap (5 replies)
  68. Stuck in Reverse (5 replies)
  69. 914-6 hard oil line “attachments” (20 replies)
  70. 901 Limited Slip or Broken? (2 replies)
  71. Early Halloween (13 replies)
  72. 71 headlight relay wiring (1 replies)
  73. Weird Cultural Reunion 2015 (512 replies)
  74. Birthday News for 6/1/25 (6 replies)
  75. Spotted in the wild (22 replies)
  76. Birthday News for 5/31/25 (9 replies)
  77. Whatever happened to the 2015 WCR, or WCC San Simeon Event Thread (4 replies)
  78. My new ride 3.0 subi, 5 lug, safari height (28 replies)
  79. Maddogs Motorsports (3 replies)
  80. Interference with shift rod (13 replies)
  81. Clutch & throttle cable access at pedal box (7 replies)
  82. How to sell off a large 914 parts collection? (16 replies)
  83. In need of a 914 tow in Louisville KY tomorrow if possible (14 replies)
  84. Turn signal indicator not working (7 replies)
  85. Fresh air blower update (23 replies)
  86. Correct M.C. for "A" and "M" caliper car? (12 replies)
  87. EZ30R Subaru questions (36 replies)
  88. Shifting issues (13 replies)
  89. Subie misfire PS bank (4 replies)
  90. Birthday News for 5/30/25 (6 replies)
  91. Bent flapper door on Air Flow Meter? (2 replies)
  92. Ignore this post (6 replies)
  93. Rehoboth Beach Cars & Coffee (11 replies)
  94. Shift Coupler not there? (7 replies)
  95. Horn power (3 replies)
  96. Wiring question (4 replies)
  97. *Project 2.4* • Dion’s endeavor • Six conversion (1146 replies)
  98. Allowable CV/Axle Play (4 replies)
  99. Wiring diagram for turn signal (2 replies)
  100. PCA LA Autocross - 5/24/2025 (7 replies)
  101. Fog Light Bulbs (2 replies)
  102. Birthday News for 5/28/25 (5 replies)
  103. Memorial Day (10 replies)
  104. Heater Control Valve (1 replies)
  105. Red Rocks Classic 2024 - 20th Annual Event! (271 replies)
  106. Brake Fluid Supply Lines (5 replies)
  107. Cloth covered hoses for Charcoal Canister (6 replies)
  108. Running light question (10 replies)
  109. Was looking for parasitic loss… (25 replies)
  110. New Meyers Manx…… 914 seats? (8 replies)
  111. PCA 41st Annual Memorial Day Car Show (8 replies)
  112. O.t car show (12 replies)
  113. Birthday News for 5/27/25 (4 replies)
  114. 123 distributor curve questions (5 replies)
  115. MSD W/ Pertronix Ignitor 2 Question (0 replies)
  116. First ride of the season = oil leak! (24 replies)
  117. Birthday News for 5/26/25 (10 replies)
  118. Is this enough twist under the tank? (8 replies)
  119. More fresh air blower (9 replies)
  120. 914-6 struts/shocks (4 replies)
  121. Speedo angle gear - Are they suppose to last more then 1 season? (8 replies)
  122. Retrofit GPS Speedometer-Odometer in Stock Gauge? (9 replies)
  123. Engine run stand pics (5 replies)
  124. Thread lock or anti-sieze? (15 replies)
  125. Exhaust Headers (6 replies)
  126. Birthday News for 5/25/25 (5 replies)
  127. Raspberry 914 finally getting some updates (31 replies)
  128. /6 conversion questions (21 replies)
  129. * * Route 66 Classic. * * May 14 - 18, 2025 (225 replies)
  130. VDO Oil gage and temp sender question (27 replies)
  131. Water Spray Cooling System (9 replies)
  132. Holiday weekend sale (2 replies)
  133. OT: just some FI pics from my other car (2 replies)
  134. Birthday News for 5/24/25 (8 replies)
  135. door sill rivet color for a 1974 black or white (5 replies)
  136. Only 13 days left for hotel reservations for 2025 WCR June 26-28 So Cal (0 replies)
  137. Birthday News for 5/19/25 (11 replies)
  138. Nor Cal 914 Fest (43 replies)
  139. Birthday News for 5/23/25 (12 replies)
  140. German 70s movie with 914 content (13 replies)
  141. Car Trailer Needed in June - Sarasota area (9 replies)
  142. Testing Distro - SUN? (3 replies)
  143. 914 Bare Shell in Phoenix (3 replies)
  144. Road Trip Time (13 replies)
  145. Fresh Air Box Seals (4 replies)
  146. Oil Bath Filter (3 replies)
  147. Rainy day inspection (6 replies)
  148. Sale Venue Advice (6 replies)
  149. Birthday News for 5/22/25 (6 replies)
  150. Porsche Sidescript Question (7 replies)
