Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924
  1. OT: Birthday Fairy Report for 8 Oct 2011 (7 replies)
  2. Rear trailing arm inner mount hole... what diameter? (3 replies)
  3. mystery motor (13 replies)
  4. any good 914 mechanics near Placerville (Folsom) Ca. ? (6 replies)
  5. 4742903579 (0 replies)
  6. 4722916160 (0 replies)
  7. 4752909903 (0 replies)
  8. Type IV Engine design (8 replies)
  9. Kansas City (5 replies)
  10. NPC: Looking for an anodizing place, any recommendations? (7 replies)
  11. External oil cooler adapter plates- stock location (6 replies)
  12. Cooling Flap Spring (2 replies)
  13. Holy Crap it runs! (3 replies)
  14. Paint Code L98P (5 replies)
  15. do you need a set of rear sway bar drop links ? (10 replies)
  16. SOT/SPC "Ran When Parked," "Duel Carbs & Exhaust" (18 replies)
  17. OT: Birthday Fairy Report for 7 Oct 2011 (9 replies)
  18. Thread size for fuel tank petcock? (8 replies)
  19. Seized engine sheet metal screws (20 replies)
  20. Stuck pushrod tubes (7 replies)
  21. Calling Eric Shea Brake Help Please (5 replies)
  22. Mfg. Decals (18 replies)
  23. Wiring A Fuel Pump - Valy please take a look at this (13 replies)
  24. Transmission side cover nuts - (3 replies)
  25. Cleanest engine you will ever see (3 replies)
  26. Brake pedal to master cylinder push rod -Source? (8 replies)
  27. where is camelback porsche ? (6 replies)
  28. Fuel Pump (13 replies)
  29. To Buy or Not to Buy? (25 replies)
  30. Petit Le Mans 2011 (26 replies)
  31. Towing question,...need help! (6 replies)
  32. 1.8 Drive train (5 replies)
  33. NON 914 but will intrest ya (18 replies)
  34. Windshields (6 replies)
  35. Feeler Gauage handles for Valve Adjustments (1 replies)
  36. 914 similarities with the TUCKER ? any ? (7 replies)
  37. POLL-ish: running SSHE with steel or stainless elbows ? (9 replies)
  38. Looking for a Tan Interior Swatch (6 replies)
  39. OT: Birthday Fairy Report for 6 Oct 2011 (6 replies)
  40. Suggestions for Karmann Ghia forums ? (11 replies)
  41. Injector trigger points (13 replies)
  42. Passenger Side foam footrest (6 replies)
  43. Honest opinion on my car (18 replies)
  44. Goodyear 30R9 Fuel Hose (1 replies)
  45. Go for a drive..... it will change your whole day. (11 replies)
  46. Adriatic Blue 914-6 (13 replies)
  47. Three new funny 914 videos ... (1 replies)
  48. Thread display changed! What happened? Did I do something? (10 replies)
  49. SBC V8 Water Pump Failure (50 replies)
  50. How structural is the fire wall (0 replies)
  51. backdating 75/76 exhaust to 2.0 or 1.7/1.8 style (6 replies)
  52. I Got Hacked (5 replies)
  53. Alternator options: Bosch reman, aftermarket, custom rebuild (14 replies)
  54. OT: Birthday Fairy Report for 5 Oct 2011 (6 replies)
  55. CAT & EGR Wiring Diagram (1 replies)
  56. 914/4 Engine Shroud Colors (5 replies)
  57. Oil Pressure Light Stays On Too Long (1 replies)
  58. Body work question (0 replies)
  59. Morph Carpet Kit - Perhaps I got a short cut piece? (16 replies)
  60. 914 LE Side Stripes (22 replies)
  61. 914 sighting at VW Harvest in Leander, TX. (15 replies)
  62. Anyone have experience with DRD Racing? (8 replies)
  63. stereo gear you can hear but not see. (28 replies)
  64. New vacuum lines-no vacuum leaks-what a difference! (7 replies)
  65. What the Heck Are These? Shock Extensions? (43 replies)
  66. Porsche Phoniks (20 replies)
  67. electrical gremlin (6 replies)
  68. Group buy GT manual release (163 replies)
  69. PNW: Need a storage place for the winter (6 replies)
  70. Phenolic Block Intake Gaskets for 4 Bolt Heads (5 replies)
  71. 914-6 experts whats up with this six? (55 replies)
  72. paint shops around Atlanta (1 replies)
  73. Dash Brake light puzzle (11 replies)
  74. Tic, tic, tic, tic (29 replies)
  75. RPM drops at Idle (4 replies)
  76. Brake Caliper (6 replies)
  77. Oil pressure switch boot (5 replies)
  78. '76 914 engine troubles (9 replies)
  79. Porsche Rennsport IV Parking & Transportation Update (0 replies)
  80. 914 GT sound ... Just for fun (4 replies)
  81. Saratoga Springs Auto Museum Exhibit (6 replies)
  82. Grr... Someone backed into my car! (11 replies)
  83. World certified? (14 replies)
  84. OT: Birthday Fairy Report for 4 Oct 2011 (4 replies)
  85. Turn Signal Housing (9 replies)
  86. New 914 driver.. (14 replies)
  87. My track car came home today (22 replies)
  88. Looking for 12 stunning examples of 914's for calendar and LE prin (118 replies)
  89. V8 Heater options... (9 replies)
  90. Spark Plugs for a 75 (1 replies)
  91. Nice weather... (23 replies)
  92. Reading Posts (2 replies)
  93. 914 Skateboard (55 replies)
  94. Paul's phoenix red restoration Thread (181 replies)
  95. Best $32 spent- Valve spring installation tol (5 replies)
  96. 914 alignment for track day (1 replies)
  97. What size is the bolt (16 replies)
  98. Red 74 Sighting, Tumwater WA (2 replies)
  99. Marks on push rods (13 replies)
  100. Elephant Racing (22 replies)
  101. OT: Birthday Fairy Report for 3 Oct 2011 (6 replies)
  102. Dash replacement advice (10 replies)
  103. OT: Detomaso Pantera -Possible swap for my v8 (41 replies)
  104. ATTN Mid easters. (140 replies)
  105. 914 siting in tv show (9 replies)
  106. Coronado Speed festival, Fleet week 2011... (42 replies)
  107. RTV and Laziness = Mature Audiences Only (3 replies)
  108. Clutch Job / Flywheel / end-play / expensive (2 replies)
  109. strange noise (4 replies)
  110. Pilot Light Install (7 replies)
  111. PCV missing (3 replies)
  112. GB 10 sets engine seals (rubber aroud body) (0 replies)
  113. Bursch leak (6 replies)
  114. Simple, Low and On Wheels (1 replies)
  115. Electric wiring 101... (5 replies)
  116. Gauge grounding question (2 replies)
  117. Is the heater tube welded to the firewall? (2 replies)
  118. 76 2.0 cylinder shims (2 replies)
  119. Joe at Series 9 (5 replies)
  120. OT: Birthday Fairy Report for 2 Oct 2011 (6 replies)
  121. Battery tray (6 replies)
  122. Petit le Mans 9/28- 10/1 Road Atlanta (77 replies)
  123. spacer for 2.0 intake (1 replies)
  124. My new car! (49 replies)
  125. Dry oil filter? (9 replies)
  126. Injection computer question...need replacement (1 replies)
  127. Tires (6 replies)
  128. Need to find Template (5 replies)
  129. RAT 9530 or 9550? (12 replies)
  130. 1.8 questions (1 replies)
  131. What is the minimum valve/piston clearance? (3 replies)
  132. Someone please go and save this one. Factory /6 (13 replies)
  133. Best spark plugs for a 914-6 (3 replies)
  134. Cylinder Head Exhaust Gasket Size? (3 replies)
  135. 2nd Gear? (1 replies)
  136. Best Engine Rebuild Book (9 replies)
  137. Piston Rings (6 replies)
  138. 914 vs 911T - no, not a performance question (37 replies)
  139. Help 1.8 injectors not working (12 replies)
  140. OT: Birthday Fairy Report for 1 Oct 2011 (5 replies)
  141. Turn Signals (1 replies)
  142. Engine test (21 replies)
  143. Clutch Cable Adjustment (6 replies)
  144. 70' 914 + 3M Di-Noc vinyl = Wicked look.... (14 replies)
  145. Front trunk (10 replies)
  146. Case and crank saga continues (21 replies)
  147. Making my side shift conversion fresh/new again... (2 replies)
  148. Sunk valve seats? (6 replies)
  149. hello friday! (23 replies)
  150. OT (w/ PC): Awesome Test Mule (2 replies)
