Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922
  1. Question about building up the 2.0 ? (19 replies)
  2. AFR 10:1 at idle. Exhaust temp through the roof. Timing or fuel? (15 replies)
  3. Master Cylinder Install Video (13 replies)
  4. SOT: Powerless (13 replies)
  5. 914/6 split oil cooler in fog lamp openings? (20 replies)
  6. Pilot Bearing Orientation (3 replies)
  7. 916 Pics (2 replies)
  8. Fake Fuchs Center Cap? (5 replies)
  9. source for Schnorr washers (13 replies)
  10. Birthday News for 8/7/20 (6 replies)
  11. Birthday News for 8/6/20 (8 replies)
  12. Is This An Endplay Spacer ? (5 replies)
  13. Wiring diagrams (27 replies)
  14. GT Flares (13 replies)
  15. 991 Turbo S Exclusive Series Special Edition Factory Video (0 replies)
  16. bleeder valve screw Front brakes (10 replies)
  17. Turn signals, flashers, new to me (9 replies)
  18. Trip odometer knob and cable (9 replies)
  19. Replacement A/C Compressor (9 replies)
  20. Best method to check your clutch cable tube (15 replies)
  21. What is the best/cheapest place to buy parts for a 75 914 motor (16 replies)
  22. Spark plug gap with flamethrower coil (5 replies)
  23. Birthday News for 8/5/20 (10 replies)
  24. Birthday News for 8/4/20 (9 replies)
  25. S caliper corrosion (3 replies)
  26. Subaru trans half shaft question (4 replies)
  27. Which ECU unit for 1.7 ltr - 1972 (European) (7 replies)
  28. Gauge MPH to KPH conversion (9 replies)
  29. New video Sunday.... (10 replies)
  30. How does master cylinder warning work (12 replies)
  31. Does the fuel tank really need to come out to install through the body swaybar? (29 replies)
  32. Question on Torsion Bars (12 replies)
  33. Transmission Synchro Internals (5 replies)
  34. Piston Orientation (4 replies)
  35. seat cover grippers (3 replies)
  36. Cary's 73 1.7 Rustoration Thread (1118 replies)
  37. If you have a 3.2 L Build would you still drive a 2 L or 1.7 L car in the garage? (64 replies)
  38. Starter won't turn (4 replies)
  39. Fuel pressure leakdown? (5 replies)
  40. Light switch question 1975 1.8 (4 replies)
  41. Fuel line/hose grommet for engine tin question (5 replies)
  42. parking lights on (8 replies)
  43. Blower motor (9 replies)
  44. Cheap 2.0 Stainless Heat exchangers (9 replies)
  45. First and Reverse crunch when hot (5 replies)
  46. lights in engine bay (10 replies)
  47. Rubber welting for flares (9 replies)
  48. Decoding my Eng #*64E02805* (0 replies)
  49. Birthday News for 8/3/20 (7 replies)
  50. Anyone own either of these 1.7 models ? (15 replies)
  51. Gauge wire to fuel pump (8 replies)
  52. 914-6 Conversion throttle/cooler/shifter shaft (9 replies)
  53. Another new part under developement 914.424.241.02 (13 replies)
  54. Wiper intermittent relay (3 replies)
  55. How much torque is too much? (37 replies)
  56. L-Jet 1.8 Running Super Rich (19 replies)
  57. 944 opinions (30 replies)
  58. Karrousel Racing Air Cleaner Removal (4 replies)
  59. Need help with weird noise. (1 replies)
  60. Wiring Harness Restoration (16 replies)
  61. Firewall shifter bushing (4 replies)
  62. Does this belong to anyone here? (2 replies)
  63. We salute our sponsors! (18 replies)
  64. 914 and 356 Compared (20 replies)
  65. Need a aux oil cooler setup for my type 4 Westy (1 replies)
  66. Hagerty insurance (21 replies)
  67. Flywheel minimum thickness? (11 replies)
  68. Birthday News for 8/2/20 (3 replies)
  69. Thinking out loud - 1911 (15 replies)
  70. Ravena green L65K (9 replies)
  71. Shifter rod seal (2 replies)
  72. AA's Rebuilt 914-6/911 flywheel (8 replies)
  73. New guy with a Field find 74 914 1.8 (23 replies)
  74. Where does this go? (0 replies)
  75. Birthday News for 8/1/20 (6 replies)
  76. Any mechanics around the Des Moines, IA area (0 replies)
  77. New steering rack eyebolt - and rebuild kit available soon (how to shown) (3 replies)
  78. Rear wheel bearings (4 replies)
  79. Tin question (4 replies)
  80. Need Some Help In San Antonio (1 replies)
  81. Help; 1970 1.7l swap to a 74 1.8L (6 replies)
  82. Speaking of battery trays... (3 replies)
  83. Long shot (5 replies)
  84. battery tray question (12 replies)
  85. Value? (3 replies)
  86. 914-6 Conversion Q's (21 replies)
  87. 914ish question for the brain trust (7 replies)
  88. Any danger in using this probe down the dipstick tube? (15 replies)
  89. Birthday News for 7/31/20 (6 replies)
  90. seats done (33 replies)
  91. Sources for Wire, Grommets, and Boots? (4 replies)
  92. Value of 16x7 Fuchs (14 replies)
  93. Combo/Temp Gauge Lighting Configuration (9 replies)
  94. CAD updates (5 replies)
  95. Ignition timing (5 replies)
  96. Somewhat off topic: Audi S5 Prestige (19 replies)
  97. Difference between early and late rear brakes (12 replies)
  98. What Carbs should I get..... (13 replies)
  99. gearbox. open it up or not? (8 replies)
  100. Birthday News for 7/30/20 (7 replies)
  101. I ran across someone selling a -6 for $500 (53 replies)
  102. Air Cleaners For Dellorto DRLA 40 (3 replies)
  103. PANEL BEATER NEEDED! (No Porsche Content) (2 replies)
  104. Birthday News for 7/29/20 (6 replies)
  105. New URO Part: Upper Rear Trunk Post (6 replies)
  106. Removing speedo ? (2 replies)
  107. This Would Be Nice To Have (9 replies)
  108. Oil Pressure Sensor Gauge Fitting - NPT or M10x1? (9 replies)
  109. Found the major source of Oil Leakage (13 replies)
  110. Difference Between 1.7 and 1.8 TB Gaskets? (1 replies)
  111. Under Trunk Temp. (26 replies)
  112. Awaking my 914 thats been off the road longer than I’ve been alive... (44 replies)
  113. Rear trunk lid torsion bars (0 replies)
  114. Testing a tach (2 replies)
  115. Replacing the lug bolts with studs and nuts (8 replies)
  116. Has anyone heard from? (12 replies)
  117. Bad Starter? (7 replies)
  118. should I junk my fuel injection for my 1.7 for dual 44idf Webers (30 replies)
  119. date first registered - how to establish? (22 replies)
  120. Anyone have VTO wheels? (25 replies)
  121. Bumble mostly finished (14 replies)
  122. '73 2.0 master cylinder (8 replies)
  123. Bumble mostly finished (5 replies)
  124. Restoring a 914 (26 replies)
  125. a couple of 14s available in N. Michigan (0 replies)
  126. Birthday News for 7/28/20 (5 replies)
  127. Electrical connector tool (7 replies)
  128. 2.7L W/ CIS to Weber 40s (12 replies)
  129. Help! First unknown broken part! (3 replies)
  130. Clutch cable tightness (1 replies)
  131. Interior door pull hardware info request (1 replies)
  132. Birthday News for 7/27/20 (11 replies)
  133. WTB Front fender left overs (2 replies)
  134. Sail lower chrome molding (3 replies)
  135. AAR Picture needed (13 replies)
  136. 71 1.7 won’t start... (16 replies)
  137. Tachometer (1 replies)
  138. WTB 914-6 sweatshirts/Hoodies/T-shirts (8 replies)
  139. Great price or crack pipe ...def my favorite game ...chime in (21 replies)
  140. Got some neat parts today (13 replies)
  141. A little help (2 replies)
  142. OT: Jason feature on the Carrera GT (2 replies)
  143. Needing some old-timer's advice on adjusting valves the proper way (3 replies)
  144. 1971 Ignition Switch (13 replies)
  145. Official Northeast Anniversary Gathering Info Thread (295 replies)
  146. Minimum Lift Height Needed To Pull Engine Out (17 replies)
  147. Converting Oil Temp gauge to Oil Pressure Gauge? (19 replies)
  148. San Diego Mountains/Desert drive tomorrow 7/25 (1 replies)
  149. Reputable 914Shop in SoCal (1 replies)
  150. Birthday News for 7/26/20 (7 replies)
