Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924
  1. Oops! (14 replies)
  2. OT: Birthday Fairy Report for 3 July 2012 (9 replies)
  3. Washed my hands of Jake Raby (36 replies)
  4. Bill Brewster Automotive (2 replies)
  5. Hello from the Nurburgring Again (4 replies)
  6. Another way of dumping all your motor oil (9 replies)
  7. 914 Leather - is it Finished or Unfinished? (14 replies)
  8. P201 (2 replies)
  9. Oh here we go ! (53 replies)
  10. Best way to refinish a targa top? (21 replies)
  11. SFBA: Red Rocks Crew? (12 replies)
  12. Starter about to fall off.... (11 replies)
  13. cfm? (13 replies)
  14. SOT: 914-6 diagram in Haynes 914 4 cyl manual (0 replies)
  15. My 13" wheel conversion project (14 replies)
  16. OT: A "short bus" I'd like to ride in (14 replies)
  17. what cam I do? (5 replies)
  18. Late Model Window Regulator Coil Spring (7 replies)
  19. Trailing Arm Bushings (13 replies)
  20. power to fuel pump (16 replies)
  21. 914 1.8 FI Throttle set up-Urgent (1 replies)
  22. Throttle cable end cap (3 replies)
  23. Charcoal Canister Mounting (5 replies)
  24. Vacuum Lines (2 replies)
  25. ahhh finally figured it out! (8 replies)
  26. 914's sightings in Richmond today (3) (1 replies)
  27. OT: Birthday Fairy Report for 2 July 2012 (6 replies)
  28. Vacuum Lines (2 replies)
  29. Need wiring help! (15 replies)
  30. rear caliper conundrum (10 replies)
  31. length of weltmeister oil relief pistons & springs (1 replies)
  32. Fuel Lines and Fuel Pump location (1 replies)
  33. BMW & Toyota Team Up (0 replies)
  34. How I waste my time (8 replies)
  35. 914-6 for $10K....no affiliation (17 replies)
  36. Engine fuel hose/Vacuum line kit? (5 replies)
  37. Corvair content (6 replies)
  38. Registered Again (13 replies)
  39. any shops in Billings, MT? (1 replies)
  40. OT: Birthday Fairy Report for 1 July 2012 (7 replies)
  41. Dash pad question (7 replies)
  42. Any tricks to installing the Master Cylinder Feed lines (9 replies)
  43. rocker arms (1 replies)
  44. Finally Finished (21 replies)
  45. 2.0 distributor questions... (21 replies)
  46. What's involved in a 5 lug conversion? (2 replies)
  47. 914-6 Heat Exchanger Availability (42 replies)
  48. First high altitude drive (13 replies)
  49. Happy Father's Day to me (2 replies)
  50. Original coating of the headlight pivots & headlight bracket plates (16 replies)
  51. What would you like for your next hardware kit? (8 replies)
  52. Big 4. What can I get? What can I build? (1 replies)
  53. How many weeks for a refund? (18 replies)
  54. MPS Adjustment Tool Kit (3 replies)
  55. Does the air duct/fan shroud split apart? (3 replies)
  56. DJet Problems (11 replies)
  57. Another 1.7/1.8 head question (0 replies)
  58. Gear Shift Knob For Porsche 914 for Sale (16 replies)
  59. Learning to weld (4 replies)
  60. OT: Birthday Fairy Report for 30 June 2012 (4 replies)
  61. Fun article and video in Forbes (0 replies)
  62. What will my car look like with LE type treatment? or Leave Alone (26 replies)
  63. Got my 915/916 Gearbox (6 replies)
  64. Door handle rebuild (8 replies)
  65. Ansa muffler suitability on a 76 2.0 (1 replies)
  66. KOSTAL 12Pol. Plug for Regulator Plate (1 replies)
  67. The start of a beautiful build (22 replies)
  68. Beige Dash (9 replies)
  69. twisted engine? (28 replies)
  70. I never want to remove these again (5 replies)
  71. A Rescued 70 - 914 (0 replies)
  72. Steering Wheel Poll! (73 replies)
  73. OT: Birthday Fairy Report for 29 June 2012 (6 replies)
  74. Clean slate firewall shiftrod bushing solution (4 replies)
  75. O.T. best wishes to Andyrew & Jerica (11 replies)
  76. oil tem psender gaskets (4 replies)
  77. 28,000 original miles (21 replies)
  78. 914-6 Garage find "Out of Hibernation" (42 replies)
  79. OT: Birthday Fairy Report for 28 June 2012 (7 replies)
  80. Stolen and Recovered (7 replies)
  81. Help needed with air conditioner charging (9 replies)
  82. Car died. (9 replies)
  83. Do you know this Ebay guy? (18 replies)
  84. H4 Headlight Question (7 replies)
  85. Joe O'Brien, Do you have a Brother (1 replies)
  86. rear caliper adjustments (4 replies)
  87. SOT lookin for a cyclops brake lite for (2 replies)
  88. Are these Con Rod Bearing Junk (NEW but Lose) (5 replies)
  89. Victor Reinz engine gasket set (1 replies)
  90. The Bursch Sound (3 replies)
  91. 914 Spare Parts Catalog, Found them in the junk (5 replies)
  92. driver side suspension console (5 replies)
  93. Cut-off tool recommendations (7 replies)
  94. Champher piston skirts (3 replies)
  95. rear end shimmy... (18 replies)
  96. 5.5Jx15 Steel Wheel and Tire combos (3 replies)
  97. OT: Birthday Fairy Report for 27 June 2012 (8 replies)
  98. Gurney style alloy wheel caps (12 replies)
  99. To Spot Weld or not to Spot Weld (4 replies)
  100. Console Completed (23 replies)
  101. Flywheel Question (2 replies)
  102. Interesting Front Flares (21 replies)
  103. Need help with ashtray measurement (5 replies)
  104. sandwich oil cooler adapter and oil cooler questions (16 replies)
  105. Dash Caps (22 replies)
  106. OT: Can you help me identify this fastener? (7 replies)
  107. This car went from $3k to $13.5k in a month (8 replies)
  108. The Carb Revolution (24 replies)
  109. Anyone in Lincon have time this Saturday? (1 replies)
  110. Anyone know of a good 14" tire (6 replies)
  111. Recognize this Steering Wheel? (5 replies)
  112. '72 2.4 911e into 914-4 (19 replies)
  113. OT: Birthday Fairy Report for 26 June 2012 (7 replies)
  114. Dual Weber 44 IDF Jetting for 2270/2258 (4 replies)
  115. Roll cage in Tampa Bay or other Florida area (12 replies)
  116. Great tool for creating air flow (22 replies)
  117. No good deed goes unpunished (91 replies)
  118. CHT Gauge (9 replies)
  119. 914 Body Work (12 replies)
  120. /4 Flywheel Wear Limits. (8 replies)
  121. pm problems (4 replies)
  122. Floor tar (23 replies)
  123. Help please....no start! (13 replies)
  124. Now ready Early and late - Aluminum door trim (47 replies)
  125. Jack point round-up and question (3 replies)
  126. rattly door windows (19 replies)
  127. noise from front end (15 replies)
  128. Removing Heat from the Car (8 replies)
  129. 914/6 signal switch issues/headlight issues (2 replies)
  130. Dash face metal (2 replies)
  131. Larz Anderson Museum German Car Day 2012 (7 replies)
  132. Rear trunk Repair (9 replies)
  133. New Guy doing a rebuild and restore (8 replies)
  134. nice cv bolts and an excellent documented engine rebuild (8 replies)
  135. Newbie rocker cover/fire extinguisher inquiry (4 replies)
  136. Scotty B (6 replies)
  137. Craigslist score (16 replies)
  138. Updated: I Propose a 914 World Fund Raiser (193 replies)
  139. Attaching fiberglass bumpers (7 replies)
  140. rear sway bars? (5 replies)
  141. Chrome bumper repairs in the SF Bay Area? (9 replies)
  142. OT: Birthday Fairy Report for 25 June 2012 (5 replies)
  143. OT: Birthday Fairy Report for 24 June 2012 (4 replies)
  144. PNW Annual Parts Obsolete Campout Finished! (38 replies)
  145. Crappy El Cheapo Rebuilt Calipers (22 replies)
  146. Malware on this site? (12 replies)
  147. If Only... (10 replies)
  148. Window adjustment (2 replies)
  149. The World’s Worst Car Is For Sale On Craigslist (28 replies)
  150. Test the Fuel Level Sender with Water? (4 replies)
