Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923
  1. High Idle when warmed up (14 replies)
  2. Snorkels...914-6 vs 911 (17 replies)
  3. Head lamp dust cover (4 replies)
  4. Starter bolt size and/or part number (2 replies)
  5. 914 newbie (18 replies)
  6. Green 74 (2 replies)
  7. Benefit of 5 lug conversion (27 replies)
  8. Over-rev of 2.0 Liter Four (9 replies)
  9. Props to PMB (2 replies)
  10. Birthday News for 3/18/22 (2 replies)
  11. Some new design/render work (37 replies)
  12. When does the oil filter fill up ? (7 replies)
  13. Spark Plugs Talking (16 replies)
  14. fuel pump fail (26 replies)
  15. Spark Plug Gap with CD ignition? (1 replies)
  16. Just another home build 2056 upgrade...but this one is mine! (264 replies)
  17. Fuel injector plug boots (5 replies)
  18. How test/inspect 2.0L DJet throttle body before swapping it in? (10 replies)
  19. Front trunk inner seal causing trunk to "bow" (4 replies)
  20. VDO Cylinder Head Temp gauge CHT wiring (14 replies)
  21. Very sad day (14 replies)
  22. 1969 invitation to discover the new 914 (10 replies)
  23. A big thank you! (3 replies)
  24. Birthday News for 3/17/22 (4 replies)
  25. Painting my targa top (18 replies)
  26. Rubber Replacents (11 replies)
  27. Degreasing a wire harness? (18 replies)
  28. Route 66 tour help (1 replies)
  29. Simple Anti-Theft Switch (40 replies)
  30. Cylinder leak down test (6 replies)
  31. !@#$ (18 replies)
  32. Oil pressure gauge benefits (14 replies)
  33. OT: 917 (4 replies)
  34. Birthday News for 3/16/22 (5 replies)
  35. Back pad insulation (6 replies)
  36. Hello from Mexico (35 replies)
  37. Repainting Targa Top (2 replies)
  38. 2.0 exhaust pipes (12 replies)
  39. 2.0L headers and exhaust set up question (15 replies)
  40. 14 mm countersink. (3 replies)
  41. New TIG welder thoughts (42 replies)
  42. Climate Control Unit...bulb sockets? (0 replies)
  43. Door cage nuts - OEM or other options? (4 replies)
  44. Dealing with Dealer Installed A/C (2 replies)
  45. Access Panel Thru Firewall to Engine Comp (20 replies)
  46. Birthday News for 3/15/22 (5 replies)
  47. LJet Dark Magic tune up kit (13 replies)
  48. targa top skin (5 replies)
  49. Ugly Rain Hats Out (21 replies)
  50. sandblasting rear brake calipers (13 replies)
  51. engine build 1911 (11 replies)
  52. If you see a good deal pass it on (0 replies)
  53. engine sheet metal (0 replies)
  54. Birthday News for 3/14/22 (5 replies)
  55. Treating the inside of suspension parts? (4 replies)
  56. Sun Visor issues (10 replies)
  57. Driving a 914-6 through the surf (6 replies)
  58. Perlon backpad question (5 replies)
  59. POR 15 (26 replies)
  60. Members with 74 1.8 (153 replies)
  61. OT: Gulf - Porsche 917 (8 replies)
  62. New /6 oil tanks coming from Poland? (4 replies)
  63. Birthday News for 3/13/22 (4 replies)
  64. Appbiz GT door panels (5 replies)
  65. Relay board part number (5 replies)
  66. OT: Cry Macho (15 replies)
  67. Fuel Leak- Injectors 1975 2.0 (1 replies)
  68. 914 Cutaway Poster (9 replies)
  69. VIN Sticker (18 replies)
  70. Another Hard To Find Item (3 replies)
  71. NLA part request - 421 839 455 (13 replies)
  72. Oil light flickering on the ‘75 FI car (10 replies)
  73. wouldn't you like to have this 914 in your garage? (31 replies)
  74. Birthday News for 3/12/22 (6 replies)
  75. Stumped? Transmission ring gear question? (0 replies)
  76. Wheel Bore Size? (5 replies)
  77. How do you know it’s a NOS roof? (18 replies)
  78. Sharing my new metal fab small business! (26 replies)
  79. Celette Bench In Tenn 12K (1 replies)
  80. Stamped numbers right rear trunk floor corner (4 replies)
  81. Do I need to make these? Potential GB for "early " cars (7 replies)
  82. Firing order (70 replies)
  83. Birthday News for 3/11/22 (6 replies)
  84. Birthday News for 3/10/22 (4 replies)
  85. Aluminum Windshield Trim (18 replies)
  86. numbers on back (9 replies)
  87. Visited a warehouse of used 914 parts (16 replies)
  88. Seta belt help (16 replies)
  89. Front trunk (1 replies)
  90. an exact 914 factory reproduction dash at last (14 replies)
  91. Mystery connection (34 replies)
  92. DPD condenser replacement (6 replies)
  93. Bumper Tops (13 replies)
  94. 914 Hardware Sets? (10 replies)
  95. Amelia Werks Reunion 2022 (11 replies)
  96. Windshield trim removal? (6 replies)
  97. Birthday News for 3/9/22 (5 replies)
  98. Replacing climate control unit (heater/fresh air/defrost/fan control) (7 replies)
  99. 914-6 Engine numbers? (7 replies)
  100. Piston ring end gap (19 replies)
  101. Birthday News for 3/8/22 (12 replies)
  102. Fuel tank bay holes (6 replies)
  103. Ultrasonic cleaning/vapor honing questions (27 replies)
  104. 1974 914 flashing circle g (1 replies)
  105. Chrome woes (18 replies)
  106. white-green wire mystery (9 replies)
  107. Looking for a rental for the Route 66 tour (2 replies)
  108. L Jet vacuum leak pursuit '74 1.8 (37 replies)
  109. Birthday News for 3/7/22 (6 replies)
  110. 914 siting in Fort Mill SC (6 replies)
  111. VW/Audi/ Porsche Cargo ship blaze (80 replies)
  112. Fuel Injector Question (13 replies)
  113. Spaced Out! (8 replies)
  114. Decel valve vacuum levels (2 replies)
  115. Door panel fit (13 replies)
  116. Can't figure out white wire (13 replies)
  117. Rebuilding 2.0 heads (7 replies)
  118. Glass How To Question (2 replies)
  119. Trunk Light (12 replies)
  120. explanation of the Ferrari 308 vs 914-6 caliper (12 replies)
  121. Fog lights side markers and clock (4 replies)
  122. Brass shift coupler bushings are totally worth it (9 replies)
  123. Birthday News for 3/6/22 (6 replies)
  124. Is there a specific aftermarket VDO fuel gauge to use? (9 replies)
  125. Grrrrr - bent flywheel dowl pin (7 replies)
  126. Nuts (8 replies)
  127. Think this cracked wheel can be fixed? (26 replies)
  128. Fuel Regulator Mystery Question (6 replies)
  129. Lot 176 914-6 white (5 replies)
  130. Carpet glue remover. (0 replies)
  131. Starting down the road (9 replies)
  132. 2022 Northeast 914 Gathering Sneak Peek Video (32 replies)
  133. Steering Rack Rebuild Parts (6 replies)
  134. Birthday News for 3/5/22 (4 replies)
  135. ginther windscreen (2 replies)
  136. help wanted: 914 build Sacramento/San Fransisco (5 replies)
  137. Werks Reunion - Who’s going? (2 replies)
  138. Moved: FS rear view mirror (-- replies)
  139. 914-6 sheet metal group buy (48 replies)
  140. Suspension parts for a daily driver (21 replies)
  141. Rebel Racing not responding (16 replies)
  142. Paypal and Ship Station - NO UPS (10 replies)
  143. 986 shifter cables (20 replies)
  144. Birthday News for 3/4/22 (6 replies)
  145. Thinking about joining your cult, but I want to do it right. (62 replies)
  146. Blast from the Past. (16 replies)
  147. Heat Exchangers for a 914-6 GT with a 3.0L (17 replies)
  148. Birthday News for 3/3/22 (8 replies)
  149. not a 914 but its in the library of congress (2 replies)
  150. Birthday News for 2/25/22 (7 replies)
